#1 2020-06-13 12:47:37
HevyDevy
system info practice script
Just thought i would share this here and ask a question or two..be mindful im only learning and hope to improve.
This is just a practice script to show system info but in a very basic way, has nothing on programs like neofetch or screenfetch etc.
So below is my effort so far and just want to know if this would work on your devuan system ok. Also id like to figure out a better method of displaying the window manager instead of using wmctrl, like something in coreutils.
Anyhow, needs bash and wmctrl as a dependency and is only work for devuan, i hope wink
#!/usr/bin/env bash
titles=('\e[1;34m%-6s\e[m\t') # blue titles
line=('\e[1;31m%-37s\e[m\n') # red line
printf "\n"
printf "\t" ; echo "$(whoami)@$(hostname)"
printf  $line | tr ' ' -
printf  $titles "os:" ; cat /etc/os-release | awk 'NR==1' | sed 's/............//;s/.//;s/.$//g'
printf  $titles "kernel:" ; uname --kernel-release
printf  $titles "uptime:" ; uptime -p | sed 's/^...//g'
printf  $titles "pkgs:" ; dpkg -l | wc -l
printf  $titles "memory:" ; free -mh | awk 'NR==2 {print $3" / "$2}'
printf  $titles "wm:" ; wmctrl -m | awk 'NR==1 {print $2}'
printf  $titles "shell:" ;  echo $SHELL
printf  $titles "editor:" ; echo $EDITOR
echo $'\e7\e[2;800H\e[16D\e[7m' $(date +"%Y/%m/%d %H:%M")$'\e8'
printf "\n"
prints out this with some colors and stuff like so.
          user@hostname
os:     Devuan GNU/Linux 3 (beowulf)
kernel: 4.19.0-9-amd64
uptime: 1 hour, 59 minutes
pkgs:   813
memory: 721Mi / 7.7Gi
wm:     dwm
shell:  /bin/bash
editor: vim
#2 2020-06-13 13:06:01
HevyDevy
Re: system info practice script
also trying to work on incorporating the devuan logo in ascii somehow and also display manager and de for those who use them.
#3 2020-06-13 13:37:40
nixer
It works pretty good here.  I noticed the editor line at the bottom was empty though.  Is that because I do not have a default editor configured?
os:       Devuan GNU/Linux 4 (chimaera/ceres)
kernel:    5.6.0-2-amd64
uptime:    4 hours, 15 minutes
pkgs:     2028
memory:    4.0Gi / 15Gi
wm:       Xfwm4
shell:    /bin/bash
editor:
I did have to install wmctl as it was not installed.
#4 2020-06-13 14:09:10
HevyDevy
Thanks nixer,
yeah if you havent got $EDITOR configured in .bashrc i dont think the script will display editor.
just put this in your bashrc
export EDITOR='vim'
replace vim for whatever editor you like.
cheers
#5 2020-06-13 14:09:36
Marjorie
Works for me, but I had to install the wmctrl package as it's not there by default.
user@hostname
uptime:	22 hours, 44 minutes
pkgs: 	2102
memory:	3.1Gi / 7.8Gi
wm:   	Mutter
shell:	/bin/bash
editor:	/usr/bin/gedit
#6 2020-06-13 14:14:21
HevyDevy
Thanks Marjorie, ill see if i can get rid of that dependency on wmctrl.
#7 2020-06-13 14:22:43
Works here on my beowulf. I didn't feel like installing wmctrl, so I changed that line to
printf  $titles "wm:" ; basename $(cat /etc/X11/default-display-manager)
#8 2020-06-13 14:45:41
HevyDevy
Thanks fsmithred, that would work nicely for display managers i will add that in. cheers
#9 2020-06-13 15:44:08
You don't need cat:
printf  $titles "os:" ; awk 'NR==1' /etc/os-release | sed 's/............//;s/.//;s/.$//g'
Or with awk alone:
printf  $titles "os:" ; awk -F'"' '/PRETTY/{print $2}' /etc/os-release
That will return a slightly larger number because the dpkg output prints an information section and also lists some non-installed packages, try this instead:
printf  $titles "pkgs:" ; dpkg -l | grep -c '^ii'
#10 2020-06-13 16:39:55
HevyDevy
Nice, thanks Hoas. I was thinking that cat was not needed.
#11 2020-06-13 17:24:56
fanderal
Works here. Installed wmctrl to show fluxbox, then saw fsmithred's edit and tried it. The difference: wmctrl capitalizes the 'F' in fluxbox, default-display-manager doesn't. wink
kernel: 5.4.0-0.bpo.2-rt-amd64
uptime: 10 days, 2 hours, 22 minutes
pkgs:   865
memory: 93Mi / 3.7Gi
wm:     fluxbox
shell:  /bin/bash
editor: nano
#12 2020-06-14 09:57:53
HevyDevy
Thanks fanderal, ive installed xdm display manager and tried that command of fsmithred but only get xdm (i have dwm as wm), must only work for lxdm, lightdm, gdm etc, what display manager are you using?
