#1 2020-06-04 23:07:24
F_Sauce
AmaroK
Hei!
For some time now AmaroK and MariaDB have been incompatible, some solutions to this?
The amarok database reported the following errors:
GREPME MySQLe query failed! (2000) Error message file '/usr/share/kde4/apps/amarok/mysqle/errmsg.sys' had only 982 error messages, but it should contain at least 983 error messages.
Check that the above file is the right version for this program! on init
In most cases you will need to resolve these errors before Amarok will run properly.
This is from a fresh install, and it is similar on several other computers.
Thanks,
Olav
I'm on Devuan with KDE
#2 2020-06-05 10:15:52
Re: AmaroK
There's no amarok in buster, therefore there is no amarok in beowulf. Try stevepusser's build. I recommend downloading the packages to install manually rather than adding a foreign repo.
http://forums.debian.net/viewtopic.php? … dd5b92d7be
#3 2020-06-05 11:24:52
F_Sauce
Re: AmaroK
Sorry, should have mentioned, I'm on ASCII.
#4 2020-06-05 13:40:08
F_Sauce
Re: AmaroK
Thanks for the link!
