#1 2020-06-01 20:42:36
Marjorie
Updating Sources to Beowulf stable
Can someone tell me how I go about updating my sources information, which are already set to Beowulf, now that Beowulf's Suite has moved from testing to stable?
If I try and update my package indices in Synaptic I get the message:
"Repository 'https://mirror.ungleich.ch/mirror/packages/devuan/merged beowulf InRelease' changed its 'Suite' value from 'testing' to 'stable' This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details."
This is repeated for the other sources.
I've read man apt-secure and it tells me how to update my repository if I'm a repository owner but not what I need to do as a simple user.
#2 2020-06-01 20:47:31
Re: Updating Sources to Beowulf stable
Don't care if you have explicitely stated Beowulf and not stable in your sources.list. The message comes once, and then its fine.
#3 2020-06-01 20:47:53
larsH
Hi
There are currently problems with the repos. it seems someone might have stable before evryone involved was ready. Please be patient a couple of days. I am sure things are going to be sorted out. But it takes some time.
Have a nice day
Lars H
#4 2020-06-01 21:03:59
Marjorie
I can't see any way of doing this in synaptic, however
from an answer on the DNG list you can do it using apt:
$ sudo apt update
and, when asked, answer 'yes' for each source.
$ sudo apt update
[sudo] password for marjorie:
Hit:1 https://updates.signal.org/desktop/apt xenial InRelease
Get:2 https://mirror.ungleich.ch/mirror/packages/devuan/merged beowulf InRelease [25.6 kB]
Get:3 https://mirror.ungleich.ch/mirror/packages/devuan/merged beowulf-security InRelease [25.6 kB]
Get:4 https://mirror.ungleich.ch/mirror/packages/devuan/merged beowulf-updates InRelease [25.6 kB]
Get:5 https://mirror.ungleich.ch/mirror/packages/devuan/merged beowulf-backports InRelease [25.6 kB]
E: Repository 'https://mirror.ungleich.ch/mirror/packages/devuan/merged beowulf InRelease' changed its 'Suite' value from 'testing' to 'stable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
Do you want to accept these changes and continue updating from this repository? [y/N] y
E: Repository 'https://mirror.ungleich.ch/mirror/packages/devuan/merged beowulf-security InRelease' changed its 'Suite' value from 'testing-security' to 'stable-security'
E: Repository 'https://mirror.ungleich.ch/mirror/packages/devuan/merged beowulf-updates InRelease' changed its 'Suite' value from 'testing-updates' to 'stable-updates'
E: Repository 'https://mirror.ungleich.ch/mirror/packages/devuan/merged beowulf-backports InRelease' changed its 'Suite' value from 'testing-backports' to 'stable-backports'
Get:6 https://mirror.ungleich.ch/mirror/packages/devuan/merged beowulf-backports/main Sources [243 kB]
Get:7 https://mirror.ungleich.ch/mirror/packages/devuan/merged beowulf-backports/main amd64 Packages [297 kB]
Fetched 591 kB in 26s (22.8 kB/s)
Building dependency tree
42 packages can be upgraded. Run 'apt list --upgradable' to see them.
#5 2020-06-01 21:16:29
Yes, on apt update that works fine. I rarely use Synaptic. cli is fine for me.
#6 2020-06-01 22:56:57
It's not a bug. It's just that events are happening slightly out of sequence. Official announcement is coming soon. Say yes. If you were already up to date, you won't see any new packages.
#7 2020-06-02 09:52:31
wingcommander1999
Hi, for using https mirrors you need to install the https transport package like:
sudo apt install apt-transport-https
Just update the sources to take effect.
Sources
AMD Ryzen 7 5700X - Gigabyte B550 AORUS ELITE V2 - 32Gb Vengeance Pro RGB White - NVME/SSD 2,5To - RTX4060TI 6Gb White - PSU Corsair 750w White - Case Corsair 5000D AirFlox Case fan x7 White - AIO 240 Corssair RGB White
Daedalus / W11
#8 2020-06-02 10:05:31
larsH
Thank you
I was as well unaware of this step. Now my problems with updating apt sources is gone as well (for installing I am using aptitude, for upgrading apt)
Have a nice day
Lars H
