#1 2020-05-25 05:35:33
Job
(Solved) No sound out of headphones
I can hear sound from speakers.  When I insert headphones sound to speakers stops however, no sound to headphones.  When I load pavucontrol, I get "Establishing connection to pulseaudio. Please wait..."
This laptop has a Realtek ALC292 sound card.  Hopefully someone can assist me.  I wonder if there is some kind of sound driver I need.
Regards,
#2 2020-05-25 06:48:01
PedroReina
Re: (Solved) No sound out of headphones
I dont know about pavucontrol because I dont use pulseaudio, but I could try to use alsamixer to see the level of headphones.
#3 2020-05-25 06:59:31
larsH
Hi
Try with alsamixer on a terminal. Pulseaudio is not enabled by default on Devuan and is not really needed. You can use either alsamixer or in your gui add an alsamixer (for instance volumeicon-alsa), or enable pulseaudio by doing the following: Pulseaudio
- If you have no sound, make sure the following line in
   /etc/pulse/client.conf.d/00-disable-autospawn.conf is commented as
   shown here:
   #autospawn=no
Have a nice day
Lars H
#4 2020-05-25 10:26:52
Are these USB headphones or do they use a conventional (mini) jack connection?
Can we see the output of this command with the headphones plugged in:
amixer
#5 2020-05-25 16:50:20
Job
Head_on_Stick,
Not USB regular 3.5mm.
#6 2020-05-25 16:51:24
Job
I will try alsamixer.
#7 2020-05-25 16:53:51
Job
larsH wrote:
Hi
   shown here:
   #autospawn=no
Have a nice day
Lars H
I have sound on speakers only, no sound on headphones.
#8 2020-05-25 17:03:26
Job
Alsamixer did it. Alsamixer showed headphones sliders white out, I turned them gray and pushed sliders up.
Thank you all for your replies.
