#1 2020-05-22 20:50:55
kapqa
(beowulf) mac samba share no longer accessible
Hello ,
i have noticed that on Devuan Beowulf i can no longer access the Smb share from my MacMini Server (running Mac OSX 10.6 hence Samba V.1)
on a separate partition running Ubuntu 20.04 Focal Fossa i noticed the same issue, but got cleared with the help of this trick here
https://askubuntu.com/questions/1232691 … access-nas
however, on Devuan Beowulf, the same trick fails.
it seems also, that the
gvfs-smb
package is not included?
Thank you very much for the help.
#2 2020-05-24 19:14:54
bgstack15
Re: (beowulf) mac samba share no longer accessible
For Ceres, I found gvfs-backends:
$ apt-file list gvfs-backends | grep -iE 'smb|samba'
gvfs-backends: /usr/lib/gvfs/gvfsd-smb
gvfs-backends: /usr/lib/gvfs/gvfsd-smb-browse
gvfs-backends: /usr/libexec/gvfsd-smb
gvfs-backends: /usr/libexec/gvfsd-smb-browse
gvfs-backends: /usr/share/GConf/gsettings/gvfs-smb.convert
gvfs-backends: /usr/share/glib-2.0/schemas/org.gnome.system.smb.gschema.xml
gvfs-backends: /usr/share/gvfs/mounts/smb-browse.mount
gvfs-backends: /usr/share/gvfs/mounts/smb.mount
Based on my quick searching, it appears that gvfs-backends is not required by any of the other gvfs packages, which doesn't make too much sense.
$ apt-cache show gvfs\* | grep -iE 'Package|-backends'
Package: gvfs
Suggests: gvfs-backends
Package: gvfs-backends
Filename: pool/DEBIAN/main/g/gvfs/gvfs-backends_1.44.1-1_amd64.deb
Package: gvfs-fuse
Package: gvfs-bin
Package: gvfs-common
Package: gvfs-daemons
Package: gvfs-libs
So maybe that's the package in question for Beowulf.
#3 2020-05-26 23:04:01
kapqa
hmm, i don't know,
i already had installed
like
sudo apt install gvfs*
#4 2020-06-08 19:02:28
devujan
Dear kapqa - this topic seems to me less distribution specific but SAMBA version specific. @work I run several SAMBA installations with several Windows fileshares - and every 2-4 years SAMBA or Microsoft or both break the working configurations. So a smb.conf on a linux running SAMBA 4.6 with for an M$-file server running on Windows 2003 fails with SAMBA 4.7. Fixed that -a  few month later the concept is broken with Windoz2012 replacing Windows 2003....
I don't want to blame SAMBA - they do a horrific job for me and M$- but they have to shot on a moving target - and backward configuration compatibility - as well as a configuration beauty contest isn't top one on their list.
As I don't have your environment here I cannot diagnose your problem - but maybe I can give you some hints.
1) You really don't care for security and need a quick and dirty fix - here you are:
Get the source of the last version which worked - spend an weekend in getting the necessary environment to get it compiled - install and enjoy.
2) If you like hacking - and like to learn more from your system setup SAMBA is a good starting point. (Good character building stuff!)
- Try to get your MAC Server to go to debug mode (RTFM)
- Read and try several documented and less documented modes and parameters in the samba client.
- Google for the error messages.
- Reconfigure smb.conf on both sides (and restart services)
- Succeed or fail. - Even if you fail you have learned a lot.
#5 2020-06-09 19:28:07
Why use SAMBA between Linux and Mac? They are both UNIX variants so NFS or something similar is more likely to work.
The only situation I would want to use SAMBA is if I needed to share files between Windows and Linux systems.
Chris
#6 2020-06-10 19:43:33
kapqa
Thanks chris2be8,
i have also a NFS share activated on the macmini,
but this also does not show up on Devuan Beowulf when i click on "Browse Network"
#7 2020-06-10 21:15:14
nfs-common is installed?
#8 2020-06-14 12:55:29
kapqa
thank you,
yes, the error was probably on (my) mac-side.
resetted the whole network settings on the mac by deleting the respective *.plist and now the network sharing is functioning correctly and the mac is also shown in the devuan network.
please mark as solved.
