#1 2020-05-10 22:54:29
Kiwi Rider
Updating X
Good morning, hope you and yours are well.
Attempting to install the appropriate AMD driver for my video card, I get the following error :
error: Detected X Server version 'XServer 1.19.2_64a' is not supported. Supported versions are X.Org 6.9 or later, up to XServer 1.10 (default:v2:x86_64:lib32:XServer 1.19.2_64a:none:4.9.0-12-amd64:)
Installation will not proceed.
While better than many systems, I find the graphics performance lacking at times and would love to see an improvement.
As per the thread at https://dev1galaxy.org/viewtopic.php?id=3296 I have installed the firmware and standard radeon driver. The card is a Radeon HD 6950  - sure it's older by today's standards but it's the best I can afford by my budget standards smile
Thanks in advance for any suggestions on how to improve performance.
#2 2020-05-11 07:35:11
ToxicExMachina
Re: Updating X
The only appropriate driver for your videocard is xserver-xorg-video-radeon from Devuan repository.
#3 2020-05-12 16:10:38
Re: Updating X
Catalyst ("fglrx") doesn't work any more.
"Il semble que la perfection soit atteinte non quand il n'y a plus rien à ajouter, mais quand il n'y a plus rien à retrancher." — Antoine de Saint-Exupéry
#4 2020-05-13 09:23:37
Magnus
Re: Updating X
That forced me to buy a new graphic card.  - Then it affected Ceres. - A NVIDIA card...
#5 2020-05-13 16:33:10
Re: Updating X
Well the situation is markedly better for new AMD cards because AMD themselves are effectively writing the open source drivers and they now out-perform the proprietary version for most tasks.
#6 2020-05-13 22:30:08
Magnus
Re: Updating X
As long as the AMD card is new... But my experience say that NVIDIA upgrade theire drivers to support new X versions for a longer lasting period than AMD does.
#7 2020-05-15 08:42:16
ToxicExMachina
Re: Updating X
Instead of supporting proprietary fglrx driver AMD preferred to support fully featured free driver. It's xserver-xorg-video-radeon and Mesa in Devuan repository. It works even with very old AMD GPUs.
Nvidia don't support GNU/Linux. Proprietary blob is total garbage. It doesn't even support OpenGL (there is NvGL, which is NOT OpenGL). So downgrading to nvidia is very big mistake. Nvidia hate everything related to freedom and choice.
#8 2020-05-15 10:41:22
Magnus
Re: Updating X
In any case, there was no driver with OpenGL support - I need OpenGL for Dark Table - for my AMD HD7970 a year ago, because AMD did not upgrade its drivers to the version of X that Ceres used. However, NVIDIA's drivers work well. OpenGL also works well with NVIDIA's drivers and NVIDA usually has the habit of upgrading its drivers considerably longer than AMD does.
And about freedom and choise. The only wish I have is a working graphic card that last more than a few years.
Must tell: My mom has my old computer from 2003 with ASCII installed. The graphic card is a NVIDIA GEFORCE 4 TI 4200 and there are still working proprietary drivers for it.
#9 2020-05-15 20:55:33
ToxicExMachina
Re: Updating X
I think you're spreading misinformation. Ceres has one of newest drivers for AMD videocards including Radeon HD 7970. It has the best OpenGL support ever.
#10 2020-05-18 07:38:45
Magnus
Re: Updating X
And the name of the driver is?
