#1 2020-05-10 22:41:21
ve1drg
emacs on ASCII
I installed emacs on ascii,  which was a new installation  and I see the following error when I use it.  I am still able to use it. But wondering how to fix this error?
(emacs:15478): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
#2 2020-05-11 07:45:13
ToxicExMachina
Re: emacs on ASCII
I suggest to install emacs-lucid instead of emacs-gtk. It won't solve entire problem because you have to install some of additional packages but it will solve the problem in case of GNU Emacs because GTK based GUI is trash.
#3 2020-05-11 14:41:23
ve1drg
Re: emacs on ASCII
Thanks for the tip on Emacs.
I dont have the lucid version on the apt-get update system.  So I removed what I had and installed everything over.  This time I chose emacs in the search list and nothing more and it went on fine and now I have no errors.
Thanks for the tip.  As things are good now.
#4 2020-05-15 08:50:48
ToxicExMachina
Re: emacs on ASCII
Looks like it was a problem with repos because according to apt-get there is emacs-lucid in the Ceres repo:
$ apt-cache search emacs-lucid
emacs-lucid - GNU Emacs editor (with Lucid GUI support)
I suspect you just couldn't get necessary packages, especially the ones related to d-bus and GTK. I think that was the reason why you had a problem with GTK UI for Emacs.
