#1 2020-05-10 07:42:40
PengouinPdt
neofetch on ceres
Hi, just a litte "bug" with neofetch when dectect os for Ceres :
:~$ neofetch
           `':ddd;:,.              --------
                 `'dPPd:,.         OS: Devuan GNU/Linux 1.0.0 (jessie) x86_64
                     `:b$$b`.      Kernel: 5.6.0-1-amd64
                        'P$$$d`    Uptime: 27 mins
                         .$$$$$`   Packages: 2124 (dpkg), 6 (flatpak)
                         ;$$$$$P   Shell: bash 4.4.12
                      .:P$$$$$$`   Resolution: 1920x1080
                  .,:b$$$$$$$;'    DE: Xfce
             .,:dP$$$$$$$$b:'      WM: Xfwm4
      .,:;db$$$$$$$$$$Pd'`         WM Theme: Clearlooks-Phenix-Cinnabar
 ,db$$$$$$$$$$$$$$b:'`             Theme: Flat-Remix-GTK-Red-Darkest-Solid [GTK2], Adwaita [GTK3]
:$$$$$$$$$$$$b:'`                  Icons: Material-Black-Mango-Numix [GTK2], Adwaita [GTK3]
 `$$$$$bd:''`                      Terminal: xfce4-terminal
   `'''`                           Terminal Font: Monospace 12
                                   CPU: Intel Celeron J1800 (2) @ 2.582GHz
                                   GPU: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
                                   Memory: 1560MiB / 3646MiB
:~$ uname -a
Linux *** 5.6.0-1-amd64 #1 SMP Debian 5.6.7-1 (2020-04-29) x86_64 GNU/Linux
 :~$ grep -v '^#' /etc/apt/sources.list
deb http://deb.devuan.org/merged ceres main non-free contrib
$ cat /etc/os-release
PRETTY_NAME="Devuan GNU/Linux 4 (chimaera/ceres)"
NAME="Devuan GNU/Linux"
ID=devuan
ID_LIKE=debian
HOME_URL="https://www.devuan.org/"
SUPPORT_URL="https://devuan.org/os/community"
BUG_REPORT_URL="https://bugs.devuan.org/"
#2 2020-05-10 08:35:08
Re: neofetch on ceres
The neofetch script grabs that information from the output of lsb_release -a so you should check that output and if it's wrong then file a bug against the lsb-release package in ceres.
#3 2020-05-10 12:16:40
Ogis1975
This stems from lsb_release switching to reading the cross-distro standard file, /usr/lib/os-release. More info here:
https://bugs.debian.org/cgi-bin/bugrepo … bug=939733
            ----+- Peter Kropotkin -+----
#4 2020-05-10 13:55:42
I'm not seeing it in my ceres installation. Everything says Devuan 4 ceres except /etc/issue, which still says 3.
Was this originally a jessie installation that got upgraded?
#5 2020-05-10 16:36:28
PengouinPdt
No!
From ascii to Ceres!
#6 2020-05-12 16:04:22
So what is the output of lsb-release -a on your system?
If it's not a Devuan problem then I can submit a PR to neofetch with a correction if needed, Dylan is a very receptive developer.
#7 2020-05-17 15:51:12
PengouinPdt
Excuse-me @Head_on_a_Stick; I've not seen your reply!
$ lsb_release -a
No LSB modules are available.
Distributor ID:	Devuan
Description:	Devuan GNU/Linux 1.0.0 (jessie)
Release:	1.0.0
Codename:	jessie
Terrible!
I'm on really on Ceres:
#8 2020-05-17 17:55:44
Mon Dieu!
Quelle est la sortie de
apt policy base-files
#9 2020-05-17 19:07:47
PengouinPdt
$ apt policy base-files
base-files:
  Installé : 11+devuan2
  Candidat : 11+devuan2
 Table de version :
 *** 11+devuan2 500
        500 http://deb.devuan.org/merged ceres/main amd64 Packages
        100 /var/lib/dpkg/status
#10 2020-05-17 20:18:38
Hmm, looks like ceres doesn't have an lsb-release package: http://deb.devuan.org/devuan/pool/main/l/lsb/
I presume you still have the ASCII version?
@fsmithred: did you try running neofetch or lsb_release -a in your ceres system?
#11 2020-05-18 06:24:43
xinomilo
Unknown
runs fine here too ( ceres amd64 )
# apt policy lsb-release
lsb-release:
  Installed: 11.1.0
  Candidate: 11.1.0
  Version table:
*** 11.1.0 500
        500 https://some_mirror/merged ceres/main amd64 Packages
neofetch also :
# neofetch
   ..,,;;;::;,..                   user@host
           `':ddd;:,.              ---------
                 `'dPPd:,.         OS: Devuan GNU/Linux 4 (chimaera/ceres) x86_64
                     `:b$$b`.      Host: blahblahblah
                        'P$$$d`    Kernel: 5.6.0-1-amd64
#12 2020-05-18 11:56:59
@HoaS: both. This is on an upgraded Refracta. (Not sure if I started with ascii or beowulf.)
Description:	Devuan GNU/Linux 4 (chimaera/ceres)
Release:	testing/unstable
Codename:	n/a
/n/n
   ..,,;;;::;,..                   user@r10lvm
           `':ddd;:,.              -----------
                     `:b$$b`.      Host: KVM/QEMU (Standard PC (i440FX + PIIX, 1996) pc-i440fx-2.8)
                         .$$$$$`   Uptime: 6 mins
                         ;$$$$$P   Packages: 1079 (dpkg)
                      .:P$$$$$$`   Shell: bash 5.0.16
                  .,:b$$$$$$$;'    Resolution: 1280x720
             .,:dP$$$$$$$$b:'      DE: Xfce
      .,:;db$$$$$$$$$$Pd'`         WM: Xfwm4
 ,db$$$$$$$$$$$$$$b:'`             WM Theme: Clearlooks-Phenix-DarkPurpy
:$$$$$$$$$$$$b:'`                  Theme: Clearlooks-Phenix-DarkPurpy [GTK2]
 `$$$$$bd:''`                      Icons: nuoveXT2 [GTK2]
   `'''`                           Terminal: xfce4-terminal
                                   CPU: QEMU Virtual version 2.5+ (4) @ 2.394GHz
                                   GPU: 00:02.0 Vendor 1234 Device 1111
                                   Memory: 294MiB / 984MiB
#13 2020-05-18 14:37:26
PengouinPdt
$ apt policy lsb-release
lsb-release:
  Installé : 4.1+devuan2
  Candidat : 4.1+devuan2
 Table de version :
     11.1.0 500
 *** 4.1+devuan2 30000
ahhh !?
#14 2020-05-18 16:05:49
This is jessie:
$ apt-cache policy lsb-release
lsb-release:
  Installed: 4.1+devuan2
  Candidate: 4.1+devuan2
  Version table:
 *** 4.1+devuan2 0
        500 http://auto.mirror.devuan.org/merged/ jessie/main amd64 Packages
$ lsb_release -a
Description:	Devuan GNU/Linux 1.0 (jessie)
Release:	1.0
Codename:	jessie
Oh! My ascii has the same version, but shows ascii in the output of 'lsb_release -a'
lsb-release:
  Installed: 11.1.0
  Candidate: 11.1.0
  Version table:
 *** 11.1.0 500
This is ceres:
lsb-release:
  Installed: 11.1.0
  Candidate: 11.1.0
  Version table:
 *** 11.1.0 500
Codename:	n/a
#15 2020-05-18 18:56:49
Looks like it was installed from a .deb package but it has been pinned to 30000, thus preventing an upgrade to the ceres package. How strange. Might be worth checking /etc/apt/preferences and also any files under /etc/apt/preferences.d/ to see how that happened.
Upgrade to the current version with
# apt install lsb-release=11.1.0
¯\_(ツ)_/¯
#16 2020-05-18 20:04:06
PengouinPdt
cat /etc/apt/preferences.d/apt-listbugs
Explanation: Pinned by apt-listbugs at 2020-04-01 20:46:09 +0200
Explanation:   #901952: xdelta: expected from file (/tmp/pristine-tar.SljdkfANnj/recreatetarball) of length 7557120 bytes
Package: tar
Pin: version 1.29b-1.1
Pin-Priority: 30000
Explanation:   #924151: grub2-common: wrong grub.cfg for efi boot and fully encrypted disk
Explanation:   #926689: cryptsetup-initramfs: config lines in grub.cfg for cryptodisk/luks and other modules missing
Package: grub2-common
Pin: version 2.02~beta3-5+deb9u2
Pin-Priority: 30000
Explanation:   #925134: grub-efi-amd64-signed: doesn't mount cryptodisk
Explanation:   #945001: grub-efi-amd64: GRUB-EFI messes up boot variables
Package: grub-efi-amd64
Pin-Priority: 30000
Explanation:   #929685: ca-certificates-java,default-jre-headless,openjdk-11-jre-headless: get rid of the circular dependency
Package: openjdk-11-jre-headless
Pin: version *
Pin-Priority: -30000
Explanation:   #932085: grub-common: Grub can't load initrd for Xen after upgrade to Buster
Package: grub-common
Pin-Priority: 30000
Explanation:   #935115: bash: [regression] passing variable assignments to functions broken in POSIX mode, violating POSIX
Package: bash
Pin: version 4.4-5
Pin-Priority: 30000
Explanation:   #939733: lsb-release: lsb_release does not show point release on Debian 10.1
Package: lsb-release
Pin: version 4.1+devuan2
Pin-Priority: 30000
Explanation:   #939813: tasksel: selected packages marked for removal on apt full-upgrade
Package: tasksel
Pin: version 3.39+devuan1.9
Pin-Priority: 30000
Explanation:   #950174: missing schema files makes udisks monitor crash
Package: gvfs-daemons
Pin: version 1.30.4-1
Pin-Priority: 30000
Explanation:   #952399: OpenSSL linking without license exception
Package: kmod
Pin: version 23-2
Pin-Priority: 30000
Explanation:   #953098: xscreensaver: Crashes with XIO:  fatal IO error
Package: xscreensaver
Pin: version 5.36-1
Pin-Priority: 30000
Explanation: Pinned by apt-listbugs at 2020-04-01 21:49:38 +0200
Explanation:   #919348: xfce4-screensaver: Accidental upload to unstable while fixing bug #919151
Package: xfce4-screensaver
Pin: version *
Explanation: Pinned by apt-listbugs at 2020-04-08 18:50:03 +0200
Explanation:   #558422: grub-pc: upgrade hangs
Package: grub-pc
Pin: version *
Explanation: Pinned by apt-listbugs at 2020-04-10 01:16:02 +0200
Explanation:   #948739: gparted should not mask .mount units
Explanation:   #955858: gparted: does not start, 'unable to init server', tmp.mount does not exist
Package: gparted
Pin: version *
Explanation: Pinned by apt-listbugs at 2020-04-13 00:29:46 +0200
Explanation:   #956427: python3-httplib2 >= 1.13.0 breaks python3-wsgi-intercept << 1.9.0
Package: python3-httplib2
Pin: version 0.9.2+dfsg-1
Pin-Priority: 30000
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
Les paquets supplémentaires suivants seront installés :
  distro-info-data
Les NOUVEAUX paquets suivants seront installés :
  distro-info-data
Les paquets suivants seront mis à jour :
  lsb-release
1 mis à jour, 1 nouvellement installés, 0 à enlever et 3 non mis à jour.
Il est nécessaire de prendre 34,6 ko dans les archives.
Après cette opération, 17,4 ko d'espace disque seront libérés.
Souhaitez-vous continuer ? [O/n] o
Réception de :1 http://deb.devuan.org/merged ceres/main amd64 distro-info-data all 0.41+devuan1 [6712 B]
Réception de :2 http://deb.devuan.org/merged ceres/main amd64 lsb-release all 11.1.0 [27,9 kB]
34,6 ko réceptionnés en 2s (18,0 ko/s)
Récupération des rapports de bogue… Fait
Analyse des informations Trouvé/Corrigé… Fait
bogues de gravité serious sur lsb-release (4.1+devuan2 → 11.1.0) <En attente de traitement>
 b1 - #939733 - lsb-release: lsb_release does not show point release on Debian 10.1
Résumé :
 lsb-release(1 bogue)
Êtes-vous certain(e) de vouloir installer/mettre à niveau les paquets ci-dessus ? [Y/n/?/...]
ohohh
#17 2020-06-15 23:49:19
PengouinPdt
After lsb-release-11.1 installed:
$ neofetch
   ..,,;;;::;,..                   xyz@pc-abc
           `':ddd;:,.              --------
                     `:b$$b`.      Kernel: 5.6.0-2-amd64
                        'P$$$d`    Uptime: 13 hours, 42 mins
                         .$$$$$`   Packages: 2255 (dpkg), 12 (flatpak)
                                   Memory: 1384MiB / 3646MiB
$ lsb_release -a
Codename:	n/a
