#1 2020-05-01 15:39:39
nixer
Install Devuan Beowulf in Windows 10 WSL (Windows Subsystem for Linux)
FlibberTGibbet mentioned that the Buster to Beowulf migration did work in WSL.  I had read about WSL but never tried it, so I gave it a spin.  It works.
This process is divided into three main parts:
Activate WSL in Windows 10 > Install Debian from MS Store > Migrate to Beowulf
Why do this?  > Why not?  It is there, give it a try and see if it helps with your productivity in some way.  My purpose was to run a native linux app "Virtual-Manager" (virt-manager) within windows for a friend of mine who wants to access KVM and its vhosts.  Your purpose may be different.
Install/Activate WSL in Windows
You will need to install an xserver in windows if you wish to display native linux apps.  After all, this is my reason for testing this WSL.  Xming seems to be the most popular, but this page mentioned that vcxsrv was the most pure opensource xserver for windows available.  It seems to work fine.
Install Debian in WSL
Boot up the "program" Debian in Windows 10.  You should have sudo rights by default, but if you want a root user, set the root password with:
sudo passwd root
Migrate Debian Buster to Devuan Beowulf:
My migration steps, mostly taken from the link above.
This step may be optional, but I have done it on all Beowulf upgrades and migrations that I have done.
export the PATH in /root/.bashrc with:
export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Change apt sources:
nano /etc/apt/sources.list
Make your sources.list look like the one provided. Comment out all other lines.
deb http://deb.devuan.org/merged beowulf main
deb http://deb.devuan.org/merged beowulf-updates main
deb http://deb.devuan.org/merged beowulf-security main
#deb http://deb.devuan.org/merged beowulf-backports main
Now you have to update the package lists from the Beowulf repositories.
Recent changes in APT mean this is not allowed but we can override this behaviour.
apt update --allow-insecure-repositories
The Devuan keyring should now be installed so that packages can be authenticated.
apt install devuan-keyring --allow-unauthenticated
Update the package lists again so that packages are authenticated from here on in.
apt update
Upgrade your packages so that you have the latest versions. Note that this does not complete the migration.
apt upgrade
Once this is done eudev needs to be installed.
apt install eudev
The last command is known to cause package breaks but we will fix this as part of the migration process.
apt -f install
The command to install eudev pulled in sysvinit-core, but not sysvinit, so:
apt install sysvinit
Just to make sure all is updated:
apt dist-upgrade
Systemd* packages were removed during this process, but just to make sure:
apt purge systemd libnss-systemd
apt autoremove --purge
apt autoclean
Before you start installing any packages in WSL, I recommend that you make apt to not install recommended packages.
I suspect this will help keep the WSL smaller and leaner.  Add the following to /etc/apt/apt.conf.d/00norecommends:
APT::Install-Recommends "no";
Reboot  >  But the shutdown/reboot commands do not work in WSL.  The WSL process has to be stopped/started like any other service in Windows.
If you install openssh-server, you will notice that it does not start automatically with WSL, nor will most, or all, other linux services that you think should start.  Installing sysv-rc-conf and rcconf programs do not help, unless I did something wrong.  This may be a bug but I see no error message anywhere, yet.  However, this little script seems to control the start/stop of both WSL and its system services at the windows boot.  Beware, this script will start WSL with Windows, and it will start the (linux services) that you add to the command.txt file list.  I don't know about the security of this, but it seems to work.
Like FlibberTGibbet said, there is a niche group of people who would want or need this.  I feel this is true, but I am only tinkering.
I did not take exact notes during this testing, so if I made a mistake or overlooked something, please add your input.  After finding some good links, this was pretty easy.  And FlibberT was right, it is nice to have a (Devuan) linux terminal available in windows.  If I am going to use windows, I do want some Devuan on it.
The option to use virtualization in windows still stands, but the ability to use a native linux program in windows without using a virtualization program is pretty neat too.  It removes a layer of complexity for the end user.  Instead of learning an entire program like virtualbox, the user only has to learn a couple of terminal commands to keep the WSL updated.  I hope my friend appreciates this new capability, and others may as well.
The only problem that I have seen thus far, is that the virt-manager program does not read the keys from the preferred $HOME area of the WSL user.  It reads the keys from the global /etc/pki/libvirt location within WSL.  The program "virt-manager" does work.  Will need to look into this more, later on.
#2 2020-05-02 03:30:01
MiyoLinux
Re: Install Devuan Beowulf in Windows 10 WSL (Windows Subsystem for Linux)
Thanks nixer! I had someone asking me for help with this a couple of weeks ago, but I didn't have a clue where to even start. Thanks for posting this and giving me something to point him to!
#3 2024-02-17 13:06:17
mmaglis
For anyone looking for Devuan on Windows Subsystem for Linux (WSL), there is now a much easier way with DevuanWSL https://github.com/VPraharsha03/DevuanWSL
Image is Beowulf based.
dist-upgrade to Daedalus brakes.
#4 2024-02-17 18:01:24
Did you skip Chimaera?
dist-upgrade works fine form one version to the next release.
#5 2024-02-18 12:46:16
nixer
I was wondering the same thing, but delgado posted before I did.
This WSL is good for a some people, but I only need windows to run my tax program once or twice a year, and a couple other programs during the year.  I prefer to use a windows virtual machine in a devuan host system than to use WSL in a windows machine.  But this was fun to play with.
#6 2024-03-01 20:27:11
mmaglis
Yes, I probably did a direct dist-upgrade to Daedalus and skipped Chimaera (facepalm).
For my work, I am given a Windows11 laptop, but have to access often and administer Linux servers. Having a Linux environment always handy is useful. I have not yet decided if I prefer WSL to a Linux installation on a virtual machine. I am still experimenting and evaluating.
It surely feels like an assimilation attempt from Microsoft to get Linux users "Borged"! :-)
