#1 2020-04-15 17:17:49
yeupou
deb.devuan.org geoloc mirror issue?
These days, depending on the deb.devuan.org automatically selected, I get a range of speed from  24.4 kB/s to 50 MB/s
Just a test earlier today:
Get:4 http://deb.devuan.org/merged unstable/main amd64 libprotobuf22 amd64 3.11.4-4 [899 kB]
47% [4 libprotobuf22 625 kB/899 kB 70%]                                                         24.4 kB/s 1h 1min 40
CTRL-C + same command :
Get:28 http://deb.devuan.org/merged stable/main amd64 menu amd64 2.1.47+b1 [380 kB]
Get:29 http://deb.devuan.org/merged unstable/main amd64 pluma-common all 1.24.0-1 [1895 kB]
Get:30 http://deb.devuan.org/merged unstable/main amd64 pluma amd64 1.24.0-1 [429 kB]
Fetched 56.1 MB in 5s (11.6 MB/s)
Is there a convenient way to choose among mirrors, to skip the one that seems overloaded?
#2 2020-04-15 18:10:39
Re: deb.devuan.org geoloc mirror issue?
Choose one from the mirror list. https://devuan.org/get-devuan
Good luck avoiding network congestion.
Edit: It's safer to use codenames (ascii instead of stable). Also, mixing stable with unstable generally does not work.
#3 2020-04-22 15:45:26
yeupou
Ok, maybe I was not clear enough: the deb.devuan.org automatical mirror selection is these days broken from my location.
Network congestion is not an issue while some mirrors are providing 11.6 MB/s.
deb.devuan.org automatically picks mirrors that are clearly not relevant from here. Did something change recently in this regard?
#4 2020-04-22 16:19:13
xinomilo
Unknown
there is no 'geoloc' for deb.devuan.org. just use a mirror that suits your location best.
(had the same question couple of months ago, mirrors@d.o kindly replied)
