#1 2020-04-15 10:10:17
aus9
[SOLVED] setting up sakura terminal with a new conf
Hi
If you install sakura from the repos....you may not get a home config
or the home config you get may not be quite what you were expecting.
First I installed this conf file to $HOME./config/sakura/
https://raw.githubusercontent.com/arcan … akura.conf
Then I changed the font line to
font= Dejavu Sans Mono 16
and if interested the reason for the font change is the default font "merged" characters together.
but not with my font change. YMMV
if interested a screenshot
https://imgur.com/TqZM1lW
In case its not clear from the config file....the keyboard combinations use Ctrl + Shift not a meta key etc
so add a tab converts to C+S+t
toggle off/on scrollbar with C+S + s
good luck
