Pages: 1
My configuration is poorly supported in Debian 10, no graphical interface works.
I found the source of the incident and I share the tip with you.
For full support I have chosen a minimal installation.
Once the installation is done, just add the missing dependencies as root:
apt install firmware-amd-graphics amd64-microcodeAfter installing the missing dependencies, we can choose a desktop environment:
taskselAt the end just reboot to take effect.
After reboot in some cases, you can have graphical glitches, to fix them just need to reinstall cinnamon like:
apt install --reinstall cinnamon -yLast edited by wingcommander1999 (2020-04-14 03:17:26)
AMD Ryzen 7 5700X - Gigabyte B550 AORUS ELITE V2 - 32Gb Vengeance Pro RGB White - NVME/SSD 2,5To - RTX4060TI 6Gb White - PSU Corsair 750w White - Case Corsair 5000D AirFlox Case fan x7 White - AIO 240 Corssair RGB White
Daedalus / W11
Notwithstanding that this is the Devuan forums, your problem is already covered in the Debian wiki: https://wiki.debian.org/AtiHowTo#Firmware
wingcommander1999 wrote:My configuration is poorly supported in Debian 10, no graphical interface works
In my case and my hardware configuration, I need to add some dependencies to make my graphical interface work.
After that applies only to my hardware configuration, I only share my feedback and if it can help my next I would be delighted.
Daedalus / W11
Pages: 1
