#1 2020-04-11 12:08:45
mmaglis
Raspberry Pi 2 Model B does not boot
A RPi 2 Model B does not boot using image file devuan_ascii_2.0.0_armhf_raspi2.img.xz
It shows the initial color screen and then goes blank and stops.
There is no green led activity after this.
Can anyone point me to the right direction?
#2 2020-04-11 13:43:44
tuxd3v
Re: Raspberry Pi 2 Model B does not boot
hello mmaglis,
Does you have a usb-serial cable to do some debug on that Image?
Does you experimented the image here: http://arm-files.devuan.org/
Best Regards,
tux
#3 2020-04-12 10:24:55
mmaglis
I probably have a usb-serial cable somewhere, but I do not know how to debug. Is there any guide somewhere?
I checked these new beowulf images, but there is none for RPi 2 yet. Nevertheless, I expected an older/tested image on an older RPi version to work smoothly.
#4 2020-04-12 17:37:34
tuxd3v
the usb-serial adapter is conected to usb port, and then to the GPIO uart pins:
for instance take a look at the rpi GPIO:
https://www.raspberrypi.org/documentation/usage/gpio/
Ground - GPIO 6
Tx         - GPIO 8
RX        - GPTI 10
then use for example picocom to connect to the uart:
apt-get install picocom
#picocom /dev/your_tty_device -b 115200
And only then apply power to the board.. and see wat is comming in the uart, its the best tool for debug smile
remember:
Tx means board TX( which means it needs to be conected to usb-serial RX )
Rx means board RX( which means it needs to be conected to usb-serial TX )
in the meantime you can try the image I proposed smile
and say something about it smile
Best Regards,
tux
Best Regards,
tux
#5 2020-05-21 17:01:54
tuxd3v
hello mmaglis,
this image is known to work with your Raspberry Pi version( RPI 2B )
http://arm-files.devuan.org/devuan_beow … 0.3.img.xz
user     :password
devuan:devuan
root      :toor
You just need to add a udev rule, so that the ethernet interface don't get named to a strange name..
cat - <<EOF >> /etc/udev/rules.d/70-persistent-net.rules
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="yours_maccaddress", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
EOF
Substitute 'yours_maccaddress' with your macaddress..
You cave 3 forms to get it..
boot with that image, attache a display, and a keyboard, and do a ifconfig
or
boot with another image and do a 'ifconfig', and its there,
Or
Use a usb-serial cable attached to the ttyAMA0 uart, and power up the pi and see what comes in the uart smile
Best Regards,
tux
