#1 2020-04-04 11:47:18
LU344928
[Solved] Incomplete install of Tor
Hello again good people and pundits. Since my last activity here I've installed ascii 2.1 on my Asus laptop. Things went well except it failed to install grub but a quick search fixed that. I'm impressed at the lightning speed with which it boots and now it's up and running I naturally want to install my favorite programs. Had no luck installing Tor thru the package manager so switched to a terminal. It seemed to install ok but went I went to the menu > internet the shortcut is not there. Nor is it in accessories. When I searched in run program nothing came up.
Here's what happened:
root@devuan:~# apt install tor
Building dependency tree
  libseccomp2 tor-geoipdb torsocks
Suggested packages:
  mixmaster torbrowser-launcher socat tor-arm apparmor-utils obfsproxy
  obfs4proxy
  libseccomp2 tor tor-geoipdb torsocks
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 2,797 kB of archives.
After this operation, 11.8 MB of additional disk space will be used.
Get:1 http://deb.devuan.org/merged ascii/main amd64 libseccomp2 amd64 2.3.1-2.1+deb9u1 [40.7 kB]
Get:2 http://deb.devuan.org/merged ascii/main amd64 tor amd64 0.2.9.16-1 [1,480 kB]
Get:3 http://deb.devuan.org/merged ascii/main amd64 torsocks amd64 2.2.0-1+deb9u1 [72.7 kB]
Get:4 http://deb.devuan.org/merged ascii/main amd64 tor-geoipdb all 0.2.9.16-1 [1,204 kB]
Fetched 2,797 kB in 17s (164 kB/s)
Selecting previously unselected package libseccomp2:amd64.
(Reading database ... 129544 files and directories currently installed.)
Preparing to unpack .../libseccomp2_2.3.1-2.1+deb9u1_amd64.deb ...
Unpacking libseccomp2:amd64 (2.3.1-2.1+deb9u1) ...
Selecting previously unselected package tor.
Preparing to unpack .../tor_0.2.9.16-1_amd64.deb ...
Unpacking tor (0.2.9.16-1) ...
Selecting previously unselected package torsocks.
Preparing to unpack .../torsocks_2.2.0-1+deb9u1_amd64.deb ...
Unpacking torsocks (2.2.0-1+deb9u1) ...
Selecting previously unselected package tor-geoipdb.
Preparing to unpack .../tor-geoipdb_0.2.9.16-1_all.deb ...
Unpacking tor-geoipdb (0.2.9.16-1) ...
Processing triggers for libc-bin (2.24-11+deb9u4) ...
Setting up libseccomp2:amd64 (2.3.1-2.1+deb9u1) ...
Processing triggers for man-db (2.7.6.1-2) ...
Setting up torsocks (2.2.0-1+deb9u1) ...
Setting up tor (0.2.9.16-1) ...
Something or somebody made /var/lib/tor disappear.
Creating one for you again.
Something or somebody made /var/log/tor disappear.
[ ok ] Starting tor daemon...done.
Setting up tor-geoipdb (0.2.9.16-1) ...
root@devuan:~#
Your advice would be appreciated, thanks.
You can't be a real country unless you have your own beer. It helps to have an airline too but at the very least you need a beer.
Frank Zappa
#2 2020-04-04 15:59:19
Re: [Solved] Incomplete install of Tor
You might need to install torbrowser-launcher (or one of the other suggested packages)?
I've never used tor so that's just a guess based on it's name.
Chris
#3 2020-04-04 16:19:15
xinomilo
Unknown
you probably need tor browser.
apt install torbrowser-launcher
or download from official website. https://www.torproject.org/download/
tor package is the tor daemon only. it doesn't include torbrowser, nor do you want it to run torbrowser. torbrowser includes its own tor daemon.
#4 2020-04-05 09:45:32
LU344928
Chris
Thanks Chris.
Frank Zappa
#5 2020-04-05 09:51:51
LU344928
That didn't work:
root@devuan:~# apt install torbrowser-launcher
Package torbrowser-launcher is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'torbrowser-launcher' has no installation candidate
root@devuan:~#
So I went back to the package manager but a search didn't find it either.
Got it that time. I was surprised to see that I didn't have to install it. I just extracted the archive and it worked straight away. Thanks for that.
Frank Zappa
