#1 2020-03-31 21:41:50
Monti
LibreOffice 6.1.5 or 6.4.2 to ASCII from Beowulf or Ceres repos?
Hi!
I am running ASCII 2.1 and are wondering if it is possible to install LibreOffice 6.1.5 or 6.4.2 from the Beowulf or Ceres repositories?
Thanks,
Monti
#2 2020-04-01 05:55:47
Re: LibreOffice 6.1.5 or 6.4.2 to ASCII from Beowulf or Ceres repos?
LibreOffice 6.1.5-3 from the Beowulf repos
and
LibreOffice 6.4.2-2 from Beowulf bpo (back ports)
#3 2020-04-01 08:28:15
ruenoak
Hi Monti I could be wrong but I don't think backports are ready for Beowulf.
I was able to run LibreOffice 6.4.2.2 using an Appimage from here: https://www.libreoffice.org/download/appimage/
seems to work fine for me.
hope this helps.
"Has cat, eats cheese, drinks coffee, Chaotic Neutral " smile
#4 2020-04-01 17:40:42
Monti
Thank you very much to both of you, GlennW and ruenoak.
I tried adding
to sources.list
Then got this when trying to do a install:
$ sudo apt-get -t beowulf-backports install libreoffice
Building dependency tree
 libreoffice : Depends: libreoffice-base but it is not going to be installed
               Depends: libreoffice-calc but it is not going to be installed
               Depends: libreoffice-core (= 1:6.4.2-2~bpo10+1) but it is not going to be installed
               Depends: libreoffice-draw but it is not going to be installed
               Depends: libreoffice-impress but it is not going to be installed
               Depends: libreoffice-math but it is not going to be installed
               Depends: libreoffice-report-builder-bin but it is not going to be installed
               Depends: libreoffice-writer but it is not going to be installed
               Depends: python3-uno (>= 4.4.0~beta2) but it is not going to be installed
               Recommends: fonts-noto-core but it is not installable
               Recommends: fonts-noto-extra but it is not installable
               Recommends: fonts-noto-ui-core but it is not installable
               Recommends: libreoffice-nlpsolver but it is not going to be installed
               Recommends: libreoffice-report-builder but it is not going to be installed
               Recommends: libreoffice-script-provider-bsh but it is not going to be installed
               Recommends: libreoffice-script-provider-js but it is not going to be installed
               Recommends: libreoffice-script-provider-python but it is not going to be installed
               Recommends: libreoffice-sdbc-mysql but it is not going to be installed
               Recommends: libreoffice-sdbc-postgresql but it is not going to be installed
               Recommends: libreoffice-wiki-publisher but it is not going to be installed
               Recommends: libreoffice-java-common (>= 1:6.4.2~) but it is not going to be installed
Ruenoak, it seems like you were right regarding Beowulf backports not being ready yet.
#5 2020-04-01 17:56:52
Sorry, you are running ASCII and want to install a big package from Beowulf backports, that is bound to cause trouble. Anyhow, in backports you won't find the libreoffice meta package.
Use https://pkginfo.devuan.org/ to search which package is where to find.
PS: And it really looks like Beowulf-backports have vanished again. I have used it before, no more present.
#6 2020-04-01 18:32:50
bbatten
FWIW I find I can download tarballs of the LibreOffice program and help pack deb files (currently at 6.2.2) from here. It works fine on Devuan ascii 2.1.
#7 2020-04-02 21:18:08
Monti
Thanks for the info Rolfie! Appreciate it. Good to know.
And thank you bbatten for the link and sharing. I have tried to find a way to install the package(s) (LibreOffice_6.4.2_Linux_x86-64_deb.tar.gz), but I am not sure which is the best way. Could you please show me?
Thanks.
#8 2020-04-03 08:28:28
You can use a tarball from the Libreoffice website to install. Make sure you have a deb and the right architecture. Optionally also load the offline help and the language pack. Then do:
- Extract the contents of the tarball(s) to /tmp. With Mate desktop I use Engrampa.
- As root go into /tmp, cd into LibreOffice_6.4.2_Linux_x86-64/DEBs.
- Install with dpkg -i *.deb
- Optionally repeat with offline help and the language pack.
- Reboot and use LO
#9 2020-04-03 18:41:33
Monti
Thanks a lot rolfie! That worked and everything seems to be working just fine.
Regarding removing the packages at a later point I am wondering how this is done when *.deb is used for multiple packages as in the DEBS archive. I know that removing a simple .deb package is done by just using -r with the package name. Would it be sufficient to just use -r twice with the two common prefixes libobasis6.4*.deb and libreoffice6.4*.deb in the archive?
Thanks
#10 2020-04-04 07:58:37
/tmp is cleaned out on every reboot, so if you have extracted the tarball to there as suggested, you don't need to worry about the debs.
Anyhow, when extracting a LO tarball, the files will always end up in a subdirectory with the version in the name (when you specify to create directories as int he comrpessed image).
#11 2020-04-04 08:47:47
Monti
Sorry for not being clear rolfie. I meant how to uninstall LibreOffice all together from the system when installing multiple .deb-files in one go as with "-i *.deb" smile
Like; Could I for example use -r twice for the two different prefixes used in the archive, libobasis6.4*.deb and libreoffice6.4*.deb, to uninstall LibreOffice?
#12 2020-04-04 11:43:04
apt remove libreoffice_6.4 will do. The beauty of this approach is that dpkg is part of the Debian/Devuan package administration. The installation will be listed as local in the package database. You may use all tools/commands you usually use, like synaptic, apt/apt-get, ....
As root enter apt list libreoffice in a terminal and see what you get.
#13 2020-04-04 19:51:17
bbatten
Hi Monti,
caveat: The .deb files for Libreoofice provided by Devuan differ somewhat from those supplied by Librefoffice. So if you currently have the Devuan packages installed, it would be a good idea to purge them before installing the native Libreoffice packages for the first time.
[edit] Also, this will prevent an inadvertent Devuan install attempt when their Libreoffice packages are updated.
The two tarballs that you get from the Libreooffice download site currently are:
LibreOffice_6.4.2_Linux_x86-64_deb_helppack_en-US.tar.gz
They untar into the ./LibreOffice_6.4.2.2_Linux_x86-64_deb/ and ./LibreOffice_6.4.2.2_Linux_x86-64_deb_helppack_en-US subdirectories in the current directory.
gview ./LibreOffice_6.4.2.2_Linux_x86-64_deb/readmes/README_en-US and follow the directions.
cd into the help pack DEBS directory and repeat.
FWIW, here's the script I use to do the download:
[8] bryan: cat ~/bin/getlo
#!/bin/bash
# getlo - get libreoffice and builtin help pack
[ $# -eq 1 ] && rev=$1 || rev=5.3.1
wget http://download.documentfoundation.org/libreoffice/stable/${rev}/deb/x86_64/LibreOffice_${rev}_Linux_x86-64_deb.tar.gz
wget http://download.documentfoundation.org/libreoffice/stable/${rev}/deb/x86_64/LibreOffice_${rev}_Linux_x86-64_deb_helppack_en-US.tar.gz
wait
# End getlo
Let me know how it goes.
#14 2020-04-04 21:05:31
Monti
Thanks a lot rolfie! Really appreciate it.
Regarding apt list libreoffice I strangely got this one:
:~$ apt list libreoffice
Listing... Done
libreoffice/stable,stable-security,now 1:5.2.7-1+deb9u11 amd64 [residual-config]
Before installing LO 6.4.2 I did a regular uninstall of version 5 plus autoremove. So I am not sure what this is.
[Edit] Posted this post right after yours bbatten. Thanks a lot for your followup. I'll dig into what you wrote.
#15 2020-04-17 12:20:41
Monti
Ok bbatten. Have tried things out and it works just fine.
Thanks a lot for the lesson smile
#16 2020-04-18 18:32:18
bbatten
You're welcome! FYI Libreoffice went to 6.4.3.2 as of 4/7/20.
#17 2020-04-21 11:12:39
Monti
Thanks again bbatten! Appreciate it smile
