#1 2020-03-30 03:21:43
aus9
[SOLVED]How do I unpack our intrd.img
Hi
I want to do some exploring of our initrd.img
I found a simple command that appeared to work but it only unpacks microcode
eg  all commands done as root
cp /boot/initrd.img-4.19.0-8-amd64 /tmp
cd /tmp
cpio -i -F initrd.img*
ls -al (culling older timestamps)
kernel
and the kernel has sub dirs to lead to your amd or intel or both microcodes.
I am aware that we have a file as follows
file initrd.img-4.19.0-8-amd64
initrd.img-4.19.0-8-amd64: ASCII cpio archive (SVR4 with no CRC)
I found a hit after changing my search to ask why I could only see a kernel  got this
https://unix.stackexchange.com/question … ely-kernel
new root commands
mkdir /tmp/unpack
cp /boot/initrd.img-4.19.0-8-amd64 /tmp/unpack
cd /tmp/unpack
(cpio -id; zcat | cpio -id) < initrd.img-4.19.0-8-amd64
ls
bin  conf  cryptroot  etc  init  initrd.img-4.19.0-8-amd64  kernel  lib  lib64	run  sbin  scripts  usr
#2 2020-04-21 17:59:49
dgrif
Re: [SOLVED]How do I unpack our intrd.img
Almost easier is to use the programs found in the package "initramfs-tools-core". In particular lsinitramfs and unmkinitramfs work really well for me. I build a custom kernel and initramfs to have a router system that runs completely within memory once booted, no disk or usb stick
access.
#3 2020-04-22 01:41:34
aus9
Thanks will check out later
