#1 2016-12-05 17:42:32
catprints
your irc client
Actually, I,m looking for suggestions (from experienced people) as to a choice for a reasonably simple and secure irc client.
Searching the web shows a lot of choices. Thanks in advance.
"The obstacle is the path."
#2 2016-12-05 18:10:49
xunilog
Re: your irc client
You're sticking with IRC? Not interested in tox?
Both the qtox and utox clients are multiplatform https://tox.chat/clients.html
I'm intrigued by tox, have tested both the client apps I mentioned above, but I'm not actively using 'em (nor IRC).
#3 2016-12-05 19:32:48
mlsmith
Re: your irc client
I've been using Hexchat for quite a while. Works good for my needs.
#4 2016-12-06 13:40:33
catprints
Re: your irc client
Thanks people,
xunilog: tox looks more like a private? communications client to me.
Think I'll go with hexchat for a start, irssi, I'll look at too. Appreciate the feedback.
edit: irssi-the clean appearance and lack of distractions ,I find, are appealing to me.
#5 2017-05-25 22:41:56
pekman
Re: your irc client
Weechat is the best... Whowww.
  • * Cli
  • * Pluguins
  • * Scriptable
Coolll...
#6 2017-05-26 18:27:13
Re: your irc client
Hexchat here, works great, easy interface.
#7 2017-05-28 17:05:27
malinas
Re: your irc client
For a CLI, I'd definitely recommend weechat for the reasons given by pekman, plus sensible defaults (e.g. creates a separate window for each server).
For a GUI, if you only have one computer, Hexchat is definitely the way to go.
If you have several computers on your local network, however, Quassel is worth a try. You can install quassel-core on one machine (for instance a raspberry pi) and use quassel-client from any other machine to access your session. I find it a very interesting alternative to running Hexchat in VNC (or a similar way of keeping a GUI in a remote session).
#8 2019-11-18 01:02:54
seeker
Re: your irc client
Are either of these available through the available packages? I have looked for "qtox" but it is not found in Synaptic. Just using the "tox" keyword does not bring back any names I recognize.
#9 2019-11-18 12:09:19
ToxicExMachina
Re: your irc client
Tox is dead. I wouldn't recommend to waste time on it. It's insecure and half-working solution. Tox also can't replace IRC.
#10 2019-11-18 20:27:31
seeker
Re: your irc client
What does everyone recommend as a replacement?
#11 2019-11-18 20:44:42
sgage
Re: your irc client
Hexchat is good - relatively full-featured, but easy to use right away.
#12 2019-11-19 08:07:33
ToxicExMachina
Re: your irc client
There is no need to replace Tox. It was defective project from the beginning of development.
