#1 2020-03-27 18:20:28
kapqa
Devuan Ascii - Opensource Drivers Amd / AMD RX560
Hello ,
i just installed ths program here on Devuan Ascii
https://www.svp-team.com/wiki/SVP:Linux
and it seems that my graphics card AMD RX560 is very poorly performing with Devuan 2.0 Asciii.
i changed the options for svptube2 to playback only in mp4 format (the RX560 has no hardware encoding/decoding for VP9 codec?) but the playback is still very laggy.
My question is:
is there a way to improve the Graphics Driver on Devuan for the AMD cards?
All i did was to install
firmware-linux-nonfree
Thank you very much!
#2 2020-03-27 19:03:34
Re: Devuan Ascii - Opensource Drivers Amd / AMD RX560
Install 4.19 backports kernel and the non-free firmware from backports.
#3 2020-03-27 21:29:20
kapqa
Hello Rolfie, hallo!
I upgraded to Beowulf, but the graphics seems still a bit lacking.
Followed this advice here
https://linuxconfig.org/how-to-install- … -10-buster
and installed all those packages (on Beowufl)
Should i still install newer Kernel - but i suppose there is no Backports yet for Beowulf.
The problem is, with the program above, the framerate conversion functions, but whenever i move the window to another monitor, the frame-dropping occurs. it couuld well also just be a problem with the svp4linux setup;
thank you!
#4 2020-03-27 22:08:07
Check with
vainfo
vdpauinfo
Make sure the vainfo, vdpauinfo, va-driver-all & vdpau-driver-all packages are installed before trying that.
And I think newer AMD cards need this line in /etc/environment (or in a fragment file under /etc/environment.d/) for VDPAU acceleration to work:
VDPAU_DRIVER=radeonsi
#5 2020-03-28 15:15:18
kapqa
Check with
vainfo
vdpauinfo
Thanks!
This is the output
vainfo
error: XDG_RUNTIME_DIR not set in the environment.
libva info: VA-API version 1.4.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so
libva info: Found init function __vaDriverInit_1_4
libva info: va_openDriver() returns 0
vainfo: VA-API version: 1.4 (libva 2.4.0)
vainfo: Driver version: Mesa Gallium driver 18.3.6 for Radeon RX 560 Series (POLARIS11, DRM 3.27.0, 4.19.0-8-amd64, LLVM 7.0.1)
vainfo: Supported profile and entrypoints
      VAProfileMPEG2Simple            :	VAEntrypointVLD
      VAProfileMPEG2Main              :	VAEntrypointVLD
      VAProfileVC1Simple              :	VAEntrypointVLD
      VAProfileVC1Main                :	VAEntrypointVLD
      VAProfileVC1Advanced            :	VAEntrypointVLD
      VAProfileH264ConstrainedBaseline:	VAEntrypointVLD
      VAProfileH264ConstrainedBaseline:	VAEntrypointEncSlice
      VAProfileH264Main               :	VAEntrypointVLD
      VAProfileH264Main               :	VAEntrypointEncSlice
      VAProfileH264High               :	VAEntrypointVLD
      VAProfileH264High               :	VAEntrypointEncSlice
      VAProfileHEVCMain               :	VAEntrypointVLD
      VAProfileHEVCMain               :	VAEntrypointEncSlice
      VAProfileHEVCMain10             :	VAEntrypointVLD
      VAProfileJPEGBaseline           :	VAEntrypointVLD
      VAProfileNone                   :	VAEntrypointVideoProc
vdpauinfo
vdpauinfo
display: :0.0   screen: 0
API version: 1
Information string: G3DVL VDPAU Driver Shared Library version 1.0
Video surface:
name   width height types
420    16384 16384  NV12 YV12
422    16384 16384  UYVY YUYV
444    16384 16384  Y8U8V8A8 V8U8Y8A8
Decoder capabilities:
name                        level macbs width height
MPEG1                          --- not supported ---
MPEG2_SIMPLE                    3 65536  4096  4096
MPEG2_MAIN                      3 65536  4096  4096
H264_BASELINE                  52 65536  4096  4096
H264_MAIN                      52 65536  4096  4096
H264_HIGH                      52 65536  4096  4096
VC1_SIMPLE                      1 65536  4096  4096
VC1_MAIN                        2 65536  4096  4096
VC1_ADVANCED                    4 65536  4096  4096
MPEG4_PART2_SP                  3 65536  4096  4096
MPEG4_PART2_ASP                 5 65536  4096  4096
DIVX4_QMOBILE                  --- not supported ---
DIVX4_MOBILE                   --- not supported ---
DIVX4_HOME_THEATER             --- not supported ---
DIVX4_HD_1080P                 --- not supported ---
DIVX5_QMOBILE                  --- not supported ---
DIVX5_MOBILE                   --- not supported ---
DIVX5_HOME_THEATER             --- not supported ---
DIVX5_HD_1080P                 --- not supported ---
H264_CONSTRAINED_BASELINE       0 65536  4096  4096
H264_EXTENDED                  --- not supported ---
H264_PROGRESSIVE_HIGH          --- not supported ---
H264_CONSTRAINED_HIGH          --- not supported ---
H264_HIGH_444_PREDICTIVE       --- not supported ---
HEVC_MAIN                      186 65536  4096  4096
HEVC_MAIN_10                   186 65536  4096  4096
HEVC_MAIN_STILL                --- not supported ---
HEVC_MAIN_12                   --- not supported ---
HEVC_MAIN_444                  --- not supported ---
Output surface:
name              width height nat types
B8G8R8A8         16384 16384    y  NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 A8I8 I8A8
R8G8B8A8         16384 16384    y  NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 A8I8 I8A8
R10G10B10A2      16384 16384    y  NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 A8I8 I8A8
B10G10R10A2      16384 16384    y  NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 A8I8 I8A8
Bitmap surface:
name              width height
A8               16384 16384
Video mixer:
feature name                    sup
DEINTERLACE_TEMPORAL             y
DEINTERLACE_TEMPORAL_SPATIAL     -
INVERSE_TELECINE                 -
NOISE_REDUCTION                  y
SHARPNESS                        y
LUMA_KEY                         y
HIGH QUALITY SCALING - L1        y
HIGH QUALITY SCALING - L2        -
HIGH QUALITY SCALING - L3        -
HIGH QUALITY SCALING - L4        -
HIGH QUALITY SCALING - L5        -
HIGH QUALITY SCALING - L6        -
HIGH QUALITY SCALING - L7        -
HIGH QUALITY SCALING - L8        -
HIGH QUALITY SCALING - L9        -
parameter name                  sup      min      max
VIDEO_SURFACE_WIDTH              y        48     4096
VIDEO_SURFACE_HEIGHT             y        48     4096
CHROMA_TYPE                      y
LAYERS                           y         0        4
attribute name                  sup      min      max
BACKGROUND_COLOR                 y
CSC_MATRIX                       y
NOISE_REDUCTION_LEVEL            y      0.00     1.00
SHARPNESS_LEVEL                  y     -1.00     1.00
LUMA_KEY_MIN_LUMA                y
LUMA_KEY_MAX_LUMA                y
#6 2020-03-28 18:30:47
kapqa
I am a bit confused about this statement because on the Debian Wiki on ATI there is nowhere to be seen such a requirement
https://wiki.debian.org/it/AtiHowTo
