#1 2020-03-26 19:03:37
kapqa
upgrade python3 on devuan ascii / howto install
Hello ,
i would like to install a package on Devuan Ascii from Debian Buster in order to install a program that requires a newer cython
Preparing to unpack cython3_0.29.2-2_amd64.deb ...
Unpacking cython3 (0.29.2-2) ...
dpkg: dependency problems prevent configuration of cython3:
cython3 depends on python3 (>= 3.7~); however:
  Version of python3 on system is 3.5.3-1.
now i installed python3.7
python3.7 --version
Python 3.7.3
however, when i try to install the above .deb, the system still complains that the python3 is on 3.5.3.
How can i tell the system to use for the installation of this .deb the newly installed Python3.7.3?
Thank you very much
#2 2020-03-27 11:44:46
kapqa
Re: upgrade python3 on devuan ascii / howto install
i seemed to have found a solution here
https://linuxconfig.org/how-to-change-d … etch-linux
under
Local User Python Version
which resulted in my case in
echo 'alias python3="/home/rich/python/v3.7.2/bin/python3"' >> ~/.bashrc
now python3 is upgraded to
python3 --version
Python 3.7.2
however, upon trying to install the cython3.deb , the result is still the same:
s/
rich@rich-PC:~/Downloads$ sudo dpkg -i cython3_0.29.2-2_amd64.deb
[sudo] password for rich:
(Reading database ... 127671 files and directories currently installed.)
Unpacking cython3 (0.29.2-2) over (0.29.2-2) ...
#3 2020-03-27 11:45:18
You probably need to change a symlink or two - the one for /usr/bin/python and /usr/bin/python3 would be my best guess.
Here's what I have in ascii:
$ ls -l /usr/bin/python*
lrwxrwxrwx 1 root root       9 Jan 24  2017 /usr/bin/python -> python2.7
lrwxrwxrwx 1 root root       9 Jan 24  2017 /usr/bin/python2 -> python2.7
-rwxr-xr-x 1 root root 3779512 Sep 26  2018 /usr/bin/python2.7
lrwxrwxrwx 1 root root       9 Jan 20  2017 /usr/bin/python3 -> python3.5
-rwxr-xr-x 1 root root 4751184 Sep 27  2018 /usr/bin/python3.5
-rwxr-xr-x 1 root root 4751184 Sep 27  2018 /usr/bin/python3.5m
lrwxrwxrwx 1 root root      10 Jan 20  2017 /usr/bin/python3m -> python3.5m
It is safer to download the packages and then install them. Do not add debian repos to sources.list or you might break your system.
#4 2020-03-27 12:11:13
kapqa
well, probably this locally installed python3 version is incomplete?
sudo update-alternatives --config python3
There are 2 choices for the alternative python3 (providing /usr/bin/python3).
  Selection    Path                      Priority   Status
* 0            /usr/local/bin/python3.7   50        auto mode
  1            /usr/bin/python3.5         40        manual mode
  2            /usr/local/bin/python3.7   50        manual mode
python3 --version
Python 3.7.3
however,
(Reading database ... 128889 files and directories currently installed.)
dpkg: error processing package cython3 (--install):
 cython3
#5 2020-03-27 12:16:22
kapqa
i used this guide here to install python3 on my system locally
https://linuxize.com/post/how-to-instal … -debian-9/
maybe i could choose to install python3.7 on top of system-level python3?
the author above does not recommend it (see point n.6).
Do not use the standard make install as it will overwrite the default system python3 binary.
most the packages on ascii seem hold on python3.5.3
https://ibb.co/Cmq7HyB
#6 2020-03-27 12:32:09
kapqa
well, i resorted to a trick *changed ascii to beowulf* for a moment
and did let upgrade python3, now the package would finally install.
#7 2021-11-18 14:18:12
kapqa
hello, i found a solution here, on how to install python3.8 for usage with program:
https://www.linuxcapable.com/how-to-ins … -bullseye/
