#1 2020-03-24 20:01:03
deepforest
[SOLVED] Nvidia warning at boot #2
Hello! Here is similar topic https://dev1galaxy.org/viewtopic.php?pid=10918
I have an up-to-date Devuan ASCII with Nvidia non-free drivers 340.108
But i want to know how remove this message from booting log?
root@home:/etc/modprobe.d# dmesg | grep -i nvidia
[    1.094049] udevd[93]: Error running install command for nvidia
[    8.801126] udevd[427]: could not find module by name='nvidia'
root@home:/etc/default# grep "install nvidia" /etc/modprobe.d/*
/etc/modprobe.d/nvidia.conf:install nvidia modprobe -i nvidia-legacy-340xx $CMDLINE_OPTS
/etc/modprobe.d/nvidia.conf:install nvidia-uvm modprobe nvidia ; modprobe -i nvidia-legacy-340xx-uvm $CMDLINE_OPTS
ps sorry for my English
pps i have no this file "/etc/modprobe.d/lrm-video"
smile
pyzNi 3.14zDa! smile
#2 2020-03-25 03:59:37
ToxicExMachina
Re: [SOLVED] Nvidia warning at boot #2
How did you install the driver?
What about nouveau?
#3 2020-03-25 13:33:14
deepforest
Hi!) Thanks for quick reply)
Non-free nvidia driver i am installing from Devuan repo.
# apt install linux-headers-$(uname -r|sed 's/[^-]*-[^-]*-//') nvidia-legacy-340xx-driver
I have bit problem with blacklisting nouveau on Devuan. Blacklisting method through /etc/modprobe.d/* not help. I am blacklisted nouveau only through GRUB. Why usual(/etc/modprobe.d/*) method blacklisting not work?
GRUB_CMDLINE_LINUX_DEFAULT="modprobe.blacklist=nouveau nouveau.blacklist=1 nomodset quiet splash"
smile
#4 2020-03-25 17:49:18
You probably need to run update-initramfs (or live-update-initramfs) to make the blacklist take effect. Without that the initial ramdisk will still tell the OS to load nouveau. Check the man page first though.
Chris
#5 2020-03-25 23:48:32
Hi, I blacklist the nouveau driver, for the proprietary driver install with this in the grub line...
nokmsboot nouveau.modeset=0
I leave it there after install, but i still see the module has loaded with lsmod, but it doesn't seem to create any problems.
anyhow, it may help ...
#6 2020-03-26 04:09:13
ToxicExMachina
Try the following command as root:
dpkg-reconfigure nvidia-kernel-dkms
#7 2022-04-09 22:27:07
deepforest
smile
