#1 2020-03-16 08:20:59
rmottola
New kernel not stable (4.9.0-12)
I am using Devuan on an HP laptop with intel 64bit cpu. Everything
worked very well, I did a lot of compilation and it is very stable,
never had a freeze in months!
[    0.100000] smpboot: CPU0: Intel(R) Core(TM)2 CPU T7200  @ 2.00GHz
(family: 0x6, model: 0xf, stepping: 0x6)
[    0.100000] Performance Events: PEBS fmt0-, Core2 events, Intel PMU
driver.
[    0.100000] core: PEBS disabled due to CPU errata
Yesterday I installed a kernel upgrade, bad things happened
1) after the first reboot with the new kernel, I get up to my desktop,
check out sources ad start building Arctic Fox browser, come back after
a time and find the machine completely frozen - no disk activity, no
mouse possible, no errors. No response to power button pressed (had to
press 5 seconds)
2) at reboot, machine freezes quite early in the boot process
3) I retry and it still freezes
I tried selecting in GRUB the older kernel and it boots. It goes past
the last error, starts file system check/journal replay and the machine
seems stable again.
This is the last good kernel version:
4.9.0-11-amd64 #1 SMP Debian 4.9.189-3+deb9u2 (2019-11-11) x86_64 GNU/Linux
the unstable version must be the version 4.9.210-1 installed
What could the issue be? I read about backports of spectre mitigations
being possible issues.
#2 2020-03-19 07:05:08
Re: New kernel not stable (4.9.0-12)
Have you got the intel-microcode installed? Take the one from backports, thats newer. If that does not help try kernel 4.19 from backports.
#3 2020-03-19 18:23:08
+1 for intel-microcode.
rmottola wrote:
I read about backports of spectre mitigations being possible issues.
The mitigations can be disabled with various kernel parameters: https://github.com/torvalds/linux/blob/ … .txt#L2702
