#1 2020-03-09 01:18:54
Copper36
Anoise or anything similar?
In the past, using Xubuntu, I often enjoyed the sounds of nature via pretty brilliant program called Anoise (https://anoise.tuxfamily.org). One distinct feature of which is that you had download (quite big though) sound files but did not need continuous Internet connection. Of course I tried to use in under Devuan, and, not surprisingly, it did not work.
So may I ask the community if anyone knows if it's possible to run it on ASCII or has heard about any reasonable alternative?
Thank you.
#2 2020-03-09 06:25:51
czeekaj
Re: Anoise or anything similar?
looks like you could probably just download the .wav files and use audacious to play them. If you don't mind a Daemon that looks like winamp.
