#1 2020-03-09 00:33:49
take_a_number
Can't execute program. System doesn't recognize it's location.
I had just installed devuan in the LXQt environment. Tried to extract Palemoon for Linux, but the system was unresponsive several times when I tried to right-click and extract the tarball. When I double clicked the tarball and extraced the program it worked fine, but if I try to run palemoon via the executable I get the following message:
"Failed to execute child process "home/[username]/Desktop/palemoon/palemoon" (No such file or directory)"
Which makes no sense because the file is right there along that exact filepath. I went through these steps on a virtual machine once before and never had this issue occur. What happened? Was there some kind of desyncing issue? How would I go about fixing this error?
Lord Wily did nothing wrong.
#2 2020-03-09 14:22:55
Re: Can't execute program. System doesn't recognize it's location.
Extract Palemoon to /tmp.
As root do a cd /tmp and then mv palemoon /opt/palemoon
As user create starter on the desktop that calls up /opt/palemoon/palemoon
That should work fine.
#3 2020-03-09 15:21:44
Have you downloaded the correct architecture?
file ~/Desktop/palemoon/palemoon
dpkg --print-architecture
#4 2020-03-10 21:08:58
take_a_number
Not too sure what this was meant to accomplish but I don't think it worked.
[username]@[hostname]:~$ file ~/Desktop/palemoon/palemoon
/home/[username]/Desktop/palemoon/palemoon: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux.so.2, for GNU/Linux 2.6.18, BuildID[sha1]=85a9932d8111ba3bb1c58f85331435adab6e79e8, stripped
[username]@[hostname]:~$ dpkg --print-architexture
dpkg: error: unknown option --print-architexture
Type dpkg --help for help about installing and deinstalling packages [*];
Use 'apt' or 'aptitude' for user-friendly package management;
Type dpkg -Dhelp for a list of dpkg debug flag values;
Type dpkg --force-help for a list of forcing options;
Type dpkg-deb --help for help about manipulating *.deb files;
Options marked [*] produce a lot of output - pipe it through 'less' or 'more' !
Did you mistype the second instruction set perhaps?
Well I'd love to try that but unfortunately I'd need to reinstall everything since I already forgot what I set my root password as. Which wouldn't be an issue, were it not for the fact that the machine I'm doing this on is a TOSHIBA and for some odd reason I can no longer access the BIOS after installing.
This is actually the second time in a row now I've had this issue. The first time I was able to hold down Fn + F12 and reach the boot options, but after my first install I could no longer do this. I was later able to get back in by taking out the battery, running on AC power and then holding Fn and repeatedly pressing F12. Now neither of these options work any longer and I have no idea what the hell is going on. I'm probably going to have to try and flash the BIOS on this damn thing the next chance I get just because this thing is so damn finnicky.
If it helps diagnosis, the power options on the top right of the login screen are all greyed out. Also, this is a non-UEFI model, which is crazy, because my two Lenovos are UEFI capable and they didn't put up anywhere near as much of a fight as this bratty heap of circuits is.
#5 2020-03-10 21:57:24
You have to run dpkg as root.
#6 2020-03-11 03:30:39
More importantly you'll need to spell the argument the way it was given,
i.e. --print-architecture rather than --print-architexture
#7 2020-03-11 07:26:47
boycottsystemd
Root password can be reset AFAIK so no need for reinstall Devuan.
Palemoon has some troubles in LXDE but I'm not sure whether it apply to LXQT too. Can you try another DE ? Icewm or Xfce for example.
#8 2020-03-11 10:05:23
That should read /home/[username]/Desktop/palemoon/palemoon.
However, try moving it to /home/[username]/palemoon/palemoon & running by typing ./palemoon/palemoon in a terminal.
(If that doesn't work, check the permissions.)
#9 2020-03-11 17:11:14
That's probably the wrong architecture. Unless your system is very old you want a 64-bit executable.
Post output from uname -a which will tell us what sort of system you are running on, and what OS it runs.
Also post output from ls -ld ~/Desktop/palemoon/palemoon so we can see what permissions it has.
Chris
