#1 2020-03-07 13:18:01
noname
installing Devuan on Samsung Chromebook Pro
I'd like to replace ChromeOS with Devuan.  However, Gallium seems to be based on xubuntu, and as far as i can tell xubuntu is still using the dreaded system-d.
From what i've read, it's possible to get ChromeOS to drop into Legacy-Boot mode, but using the actual device i haven't been able to get into that mode.
I'm not sure if i've been looking at obsolete web-pages, or if i've been misunderstanding something.
Any clues might help, tia.
#2 2020-03-07 15:09:18
Re: installing Devuan on Samsung Chromebook Pro
I put AntiX (systemd free) onto my Toshiba chromebook, (2GB ram/16GB eMMC), I used mrchromebox's boot replacement software.
https://mrchromebox.tech/
#3 2020-03-08 14:28:19
noname
Thanks for the link, will check it out, atm i don't know what AntiX is etc, but i can read lol, and i appreciate the pointer.
#4 2020-03-08 19:29:59
AntiX - https://antixlinux.com/
Once you have upgraded the boot loader, you should be able to load any distro that you choose. smile
