#1 2020-02-25 20:23:41
Illegalum
Devuan on Odroid HC1
Tried installing the embedded image for odroid XU4 on my oidroid HC1 as hardkernel says in general it is the same board. first didn't get it to boot.
then found i can get it to boot by copying the exynos5422-odroidxu4.dtb to exynos5422-odroidhc1.dtb in the boot folder.
then the system boots , but after booting unfortunately there is no eth0
running the debian image on the hc1 works and can afterwords move over to the devuan repository's but it would be nice if i can get some help on making the image work for odroid HC1 and HC2
Lum
#2 2020-02-27 02:33:39
tuxd3v
Re: Devuan on Odroid HC1
You came to the right place smile
At least in kernel 5.5.6, exists a device tree source file for it smile
/arch/arm/boot/dts/exynos5422-odroidhc1.dts
you can build it if you want to smile
For hc2, I don't find it sad
Can you do a dmesg, in the system were everything works?
also a zcat /proc/config.gz ?
Thanks,
could be that I make a build for it, but not yet, some day.. smile
To build it, you first need a crosscompiler if you are in another arch..:
you will need a 'arm-linux-gnueabihf' compiler..
if you are in amd64 arch..
apt-get install flex bison make libssl-dev bc quilt rsync fakeroot libncurses-dev
download the crosscompiler,
arm-linux-gnueabihf compiler,
Extract it to the correct place you want, then update your path:
export PATH=$PATH:$PWD/path_to_ToolChain/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin
then :
make -C kernel_path ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf-  clean
So now you have your kernel tree clean smile
So, for hc1...
You have a distro from devuan for Odroid xu4,
https://mirror.leaseweb.com/devuan/devu … xu4.img.xz
In the distro were it is working,
copy that file content to:
'your_kernel_path/.config',
    you can also copy same file to:
        'your_kernel_path/arch/arm/configs/exynos5422-odroidhc1_defconfig'
this will parse and generate your .config file..
make -C kernel_path ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf-  exynos5422-odroidhc1_defconfig
Create deb packages to install:
make -C kernel_path ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- deb-pkg -j$(nproc)
several deb packages will be created(deb packages have several things that need to be adjusted, but it will work I believe without that adjustments..)..
You just need to install them on the new system, and adapt names.. smile
or
Generate several directories with Image,dtbs,modules:
make -C kernel_path ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- Image dtbs modules -j$(nproc)
pass everything to new system, update names, don't forget the content of 'boot.scr'.. or boot.cmd , and that's it smile
This brief explanation for the kernel..
try it, and check if you are able to boot...
Best Regards,
tux
Best Regards,
tux
#3 2020-02-27 14:02:23
Illegalum
Hi , Thank you for your great reply
Lots of info, currently only running a pair of odroid HC1 on linux so guess I will have to try and compile on there.
in general the Hc1 is a striped version of the XU4 , the HC2 is an HC1 on a 3.5 inch bay for a 3.5 inch disk so I don't know if it shows different when loading the kernel
think it will just load as an HC1
I'm now running a devuan version that I converted from a debian emmbeded image Debian-Stretch-1.0~RC2-20180403-XU3-XU4.img.xz
The main problem is when I start of with the
tuxd3v wrote:
So, for hc1...
it seems to load the whole USB bus wrong and so I also cannot copy any data to it like the new kernel
so how could I inject this kernel in the  devuan xu4 image ?
and how it is easiest to share the  config.gz and dmesg ?
Lum
#4 2020-02-27 18:55:09
tuxd3v
jwheins
Hello,
In that version you are running of Devuan, that you adapted( from debian )...
1) A dmesg, is a command, you just need to type as root:
    dmesg
2) To get the kernel config, you just need to type as root:
3) To get a cpuinformation
     cat /proc/cpuinfo
This commands return a result a lot of information..
if you could post it here for each individually, it would be nice, or use a "paste" service like this smile
I assume that, in this image you have, you got network running right?
Anyway, to pass the deb packages or the new kernel,
You can just insert your sdcard in your computer, and copy the deb packages to it( if you don't have ethernet running or ssh on the device ).
Then insert the sdcard into the sbc board, and:
dpkg -i *.deb  smile
Best Regards,
tux
Best Regards,
tux
#5 2020-02-27 23:17:58
Illegalum
Dmesg
[    0.000000] Booting Linux on physical CPU 0x100
[    0.000000] Linux version 4.14.165+ (root@loki) (gcc version 4.9.2 (Debian 4.9.2-10+deb8u2)) #1 SMP PREEMPT Mon Jan 20 10:57:56 UTC 2020
[    0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Hardkernel Odroid XU4
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 128 MiB at 0xb6800000
[    0.000000] Samsung CPU ID: 0xe5422001
[    0.000000] On node 0 totalpages: 518656
[    0.000000] free_area_init_node: node 0, pgdat c0d8efc0, node_mem_map eee25000
[    0.000000]   Normal zone: 1728 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 196608 pages, LIFO batch:31
[    0.000000]   HighMem zone: 322048 pages, LIFO batch:31
[    0.000000] Running under secure firmware.
[    0.000000] random: get_random_bytes called from start_kernel+0x90/0x428 with crng_init=0
[    0.000000] percpu: Embedded 17 pages/cpu s37568 r8192 d23872 u69632
[    0.000000] pcpu-alloc: s37568 r8192 d23872 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516928
[    0.000000] Kernel command line: console=tty1 console=ttySAC2,115200n8 root=UUID=e139ce78-9841-40fe-8823-96a304a09859 rootwait ro fsck.repair=yes net.ifnames=0  smsc95xx.macaddr=00:1e:06:61:7a:87  governor=performance hdmi_tx_amp_lvl=31 hdmi_tx_lvl_ch0=3 hdmi_tx_lvl_ch1=3 hdmi_tx_lvl_ch2=3 hdmi_tx_emp_lvl=6 hdmi_clk_amp_lvl=31 hdmi_tx_res=0 HPD=true vout=hdmi  s5p_mfc.mem=16M
[    0.000000] hdmi: using HDMI mode
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1904756K/2074624K available (8192K kernel code, 657K rwdata, 2356K rodata, 1024K init, 321K bss, 38796K reserved, 131072K cma-reserved, 1157120K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                   modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                     .text : 0xc0008000 - 0xc0900000   (9184 kB)
                     .init : 0xc0c00000 - 0xc0d00000   (1024 kB)
                     .data : 0xc0d00000 - 0xc0da45a0   ( 658 kB)
                      .bss : 0xc0dac090 - 0xc0dfc6a8   ( 322 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] hperf_hmp: fast CPUs mask: 000000F0
[    0.000000] hperf_hmp: slow CPUs mask: 0000000F
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Tasks RCU enabled.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] Switching to timer-based delay loop, resolution 41ns
[    0.000000] clocksource: mct-frc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000007] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000032] genirq: irq_chip COMBINER did not update eff. affinity mask of irq 49
[    0.001581] Console: colour dummy device 80x30
[    0.002287] console [tty1] enabled
[    0.002328] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002370] pid_max: default: 32768 minimum: 301
[    0.002587] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002628] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003515] CPU: Testing write buffer coherency: ok
[    0.004435] CPU0: thread -1, cpu 0, socket 1, mpidr 80000100
[    0.020049] Setting up static identity map for 0x40100000 - 0x40100060
[    0.020673] ARM CCI driver probed
[    0.020910] Exynos MCPM support installed
[    0.027986] Hierarchical SRCU implementation.
[    0.043987] smp: Bringing up secondary CPUs ...
[    0.072398] CPU1: thread -1, cpu 1, socket 1, mpidr 80000101
[    0.100364] CPU2: thread -1, cpu 2, socket 1, mpidr 80000102
[    0.128359] CPU3: thread -1, cpu 3, socket 1, mpidr 80000103
[    0.156372] CPU4: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.156381] CPU4: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[    0.176352] CPU5: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.176359] CPU5: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[    0.184689] CPU6: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.184696] CPU6: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[    0.192660] CPU7: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.192667] CPU7: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[    0.192922] smp: Brought up 1 node, 8 CPUs
[    0.192970] SMP: Total of 8 processors activated (384.00 BogoMIPS).
[    0.192993] CPU: All CPU(s) started in HYP mode.
[    0.193013] CPU: Virtualization extensions available.
[    0.194839] devtmpfs: initialized
[    0.212464] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.212631] hperf_hmp: registered cpufreq transition notifier
[    0.212823] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.212861] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.215281] pinctrl core: initialized pinctrl subsystem
[    0.217428] NET: Registered protocol family 16
[    0.222461] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.224299] cpuidle: using governor menu
[    0.225272] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.225303] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.233880] exynos-audss-clk 3810000.audss-clock-controller: epll 180633609
[    0.257115] EXYNOS5420 PMU initialized
[    0.302615] usbcore: registered new interface driver usbfs
[    0.302688] usbcore: registered new interface driver hub
[    0.302859] usbcore: registered new device driver usb
[    0.303308] i2c-gpio soc:i2c-hdmi: using pins 177 (SDA) and 178 (SCL)
[    0.303877] s3c-i2c 12c70000.i2c: slave address 0x00
[    0.303905] s3c-i2c 12c70000.i2c: bus frequency set to 378 KHz
[    0.304154] s3c-i2c 12c70000.i2c: i2c-1: S3C I2C adapter
[    0.304714] media: Linux media interface: v0.10
[    0.304767] Linux video capture interface: v2.00
[    0.304885] pps_core: LinuxPPS API ver. 1 registered
[    0.304906] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.305180] s3c2410-wdt 101d0000.watchdog: watchdog inactive, reset disabled, irq disabled
[    0.306056] Advanced Linux Sound Architecture Driver Initialized.
[    0.307411] clocksource: Switched to clocksource mct-frc
[    0.366056] VFS: Disk quotas dquot_6.6.0
[    0.366146] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.380186] NET: Registered protocol family 2
[    0.380783] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.380877] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.381046] TCP: Hash tables configured (established 8192 bind 8192)
[    0.381164] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.381219] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.381430] NET: Registered protocol family 1
[    0.382113] RPC: Registered named UNIX socket transport module.
[    0.382136] RPC: Registered udp transport module.
[    0.382156] RPC: Registered tcp transport module.
[    0.382174] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.382380] Trying to unpack rootfs image as initramfs...
[    0.675433] random: fast init done
[    0.721153] Freeing initrd memory: 5580K
[    0.722691] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.723912] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.727374] audit: initializing netlink subsys (disabled)
[    0.727623] audit: type=2000 audit(0.724:1): state=initialized audit_enabled=0 res=1
[    0.728211] Initialise system trusted keyrings
[    0.728423] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    0.735852] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.736723] NFS: Registering the id_resolver key type
[    0.736761] Key type id_resolver registered
[    0.736781] Key type id_legacy registered
[    0.736811] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.736863] romfs: ROMFS MTD (C) 2007 Red Hat, Inc.
[    0.741481] Key type asymmetric registered
[    0.741505] Asymmetric key parser 'x509' registered
[    0.741579] bounce: pool size: 64 pages
[    0.741642] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.741868] io scheduler noop registered
[    0.741892] io scheduler deadline registered
[    0.742058] io scheduler cfq registered (default)
[    0.742080] io scheduler mq-deadline registered
[    0.742099] io scheduler kyber registered
[    0.742342] io scheduler bfq registered
[    0.744826] samsung-usb2-phy 12130000.phy: 12130000.phy supply vbus not found, using dummy regulator
[    0.745837] exynos5_usb3drd_phy 12100000.phy: 12100000.phy supply vbus not found, using dummy regulator
[    0.745923] exynos5_usb3drd_phy 12100000.phy: 12100000.phy supply vbus-boost not found, using dummy regulator
[    0.746294] exynos5_usb3drd_phy 12500000.phy: 12500000.phy supply vbus not found, using dummy regulator
[    0.746379] exynos5_usb3drd_phy 12500000.phy: 12500000.phy supply vbus-boost not found, using dummy regulator
[    0.751470] dma-pl330 3880000.adma: Loaded driver for PL330 DMAC-241330
[    0.751500] dma-pl330 3880000.adma: 	DBUFF-4x8bytes Num_Chans-6 Num_Peri-16 Num_Events-6
[    0.754163] dma-pl330 121a0000.pdma: Loaded driver for PL330 DMAC-241330
[    0.754191] dma-pl330 121a0000.pdma: 	DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[    0.756920] dma-pl330 121b0000.pdma: Loaded driver for PL330 DMAC-241330
[    0.756948] dma-pl330 121b0000.pdma: 	DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[    0.757815] dma-pl330 10800000.mdma: Loaded driver for PL330 DMAC-241330
[    0.757843] dma-pl330 10800000.mdma: 	DBUFF-64x8bytes Num_Chans-8 Num_Peri-1 Num_Events-32
[    0.825576] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.827979] 12c00000.serial: ttySAC0 at MMIO 0x12c00000 (irq = 58, base_baud = 0) is a S3C6400/10
[    0.828395] 12c10000.serial: ttySAC1 at MMIO 0x12c10000 (irq = 59, base_baud = 0) is a S3C6400/10
[    0.828799] 12c20000.serial: ttySAC2 at MMIO 0x12c20000 (irq = 60, base_baud = 0) is a S3C6400/10
[    1.772517] console [ttySAC2] enabled
[    1.776523] 12c30000.serial: ttySAC3 at MMIO 0x12c30000 (irq = 61, base_baud = 0) is a S3C6400/10
[    1.787186] exynos-mixer 14450000.mixer: Linked as a consumer to 14650000.sysmmu
[    1.793200] iommu: Adding device 14450000.mixer to group 0
[    1.800303] exynos-hdmi 14530000.hdmi: Failed to get supply 'vdd': -517
[    1.806187] exynos-drm-g2d 10850000.g2d: Linked as a consumer to 10a60000.sysmmu
[    1.812970] exynos-drm-g2d 10850000.g2d: Linked as a consumer to 10a70000.sysmmu
[    1.820269] iommu: Adding device 10850000.g2d to group 1
[    1.825891] exynos-drm-g2d 10850000.g2d: The Exynos G2D (ver 4.1) successfully probed.
[    1.834516] exynos-rot 11c00000.rotator: Linked as a consumer to 11d40000.sysmmu
[    1.840805] iommu: Adding device 11c00000.rotator to group 2
[    1.846762] exynos-rot 11c00000.rotator: The exynos rotator is probed successfully
[    1.854750] exynos-drm-ipp exynos-drm-ipp: drm ipp registered successfully.
[    1.865280] mali 11800000.mali: Continuing without Mali regulator control
[    1.871392] mali 11800000.mali: GPU identified as 0x0620 r0p1 status 0
[    1.877630] mali 11800000.mali: Protected mode not available
[    1.883196] devfreq devfreq0: Couldn't update frequency transition information.
[    1.890735] mali 11800000.mali: Probed as mali0
[    1.904472] brd: module loaded
[    1.906693] libphy: Fixed MDIO Bus: probed
[    1.910524] usbcore: registered new interface driver r8152
[    1.915675] usbcore: registered new interface driver cdc_ether
[    1.921478] usbcore: registered new interface driver cdc_subset
[    1.929492] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.934592] ehci-exynos: EHCI EXYNOS driver
[    1.939076] exynos-ehci 12110000.usb: EHCI Host Controller
[    1.944218] exynos-ehci 12110000.usb: new USB bus registered, assigned bus number 1
[    1.952096] exynos-ehci 12110000.usb: irq 80, io mem 0x12110000
[    1.971465] exynos-ehci 12110000.usb: USB 2.0 started, EHCI 1.00
[    1.976298] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.982799] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.989986] usb usb1: Product: EHCI Host Controller
[    1.994864] usb usb1: Manufacturer: Linux 4.14.165+ ehci_hcd
[    2.000468] usb usb1: SerialNumber: 12110000.usb
[    2.005629] hub 1-0:1.0: USB hub found
[    2.008826] hub 1-0:1.0: 3 ports detected
[    2.013726] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.018948] ohci-exynos: OHCI EXYNOS driver
[    2.023282] exynos-ohci 12120000.usb: USB Host Controller
[    2.028479] exynos-ohci 12120000.usb: new USB bus registered, assigned bus number 2
[    2.036189] exynos-ohci 12120000.usb: irq 80, io mem 0x12120000
[    2.103696] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    2.109054] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.116747] usb usb2: Product: USB Host Controller
[    2.121005] usb usb2: Manufacturer: Linux 4.14.165+ ohci_hcd
[    2.126635] usb usb2: SerialNumber: 12120000.usb
[    2.131792] hub 2-0:1.0: USB hub found
[    2.134956] hub 2-0:1.0: 3 ports detected
[    2.141214] mousedev: PS/2 mouse device common for all mice
[    2.146614] i2c /dev entries driver
[    2.164584] vdd_ldo9: Bringing 3300000uV into 3000000-3000000uV
[    2.186890] vdd_sd: Bringing 3300000uV into 2800000-2800000uV
[    3.273228] s5m-rtc s2mps14-rtc: rtc core: registered s5m-rtc as rtc0
[    3.282227] s5p-jpeg 11f50000.jpeg: Linked as a consumer to 11f10000.sysmmu
[    3.287809] iommu: Adding device 11f50000.jpeg to group 3
[    3.293506] s5p-jpeg 11f50000.jpeg: encoder device registered as /dev/video30
[    3.300407] s5p-jpeg 11f50000.jpeg: decoder device registered as /dev/video31
[    3.307339] s5p-jpeg 11f50000.jpeg: Samsung S5P JPEG codec
[    3.313011] s5p-jpeg 11f60000.jpeg: Linked as a consumer to 11f20000.sysmmu
[    3.319772] iommu: Adding device 11f60000.jpeg to group 4
[    3.325469] s5p-jpeg 11f60000.jpeg: encoder device registered as /dev/video32
[    3.332379] s5p-jpeg 11f60000.jpeg: decoder device registered as /dev/video33
[    3.339313] s5p-jpeg 11f60000.jpeg: Samsung S5P JPEG codec
[    3.345899] s5p-mfc 11000000.codec: Linked as a consumer to 11200000.sysmmu
[    3.351838] s5p-mfc 11000000.codec: Linked as a consumer to 11210000.sysmmu
[    3.358695] iommu: Adding device 11000000.codec to group 5
[    3.382088] s5p-mfc 11000000.codec: preallocated 16 MiB buffer for the firmware and context buffers
[    3.389798] (NULL device *): Direct firmware load for s5p-mfc-v8.fw failed with error -2
[    3.397772] s5p_mfc_load_firmware:73: Firmware is not present in the /lib/firmware directory nor compiled in kernel
[    3.408360] s5p-mfc 11000000.codec: decoder registered as /dev/video10
[    3.414827] s5p-mfc 11000000.codec: encoder registered as /dev/video11
[    3.423702] exynos-gsc 13e00000.video-scaler: Linked as a consumer to 13e80000.sysmmu
[    3.430143] iommu: Adding device 13e00000.video-scaler to group 6
[    3.437440] exynos-gsc 13e10000.video-scaler: Linked as a consumer to 13e90000.sysmmu
[    3.444017] iommu: Adding device 13e10000.video-scaler to group 7
[   15.102157] thermal thermal_zone0: failed to read out thermal zone (-22)
[   15.108315] thermal thermal_zone1: failed to read out thermal zone (-22)
[   15.115023] thermal thermal_zone2: failed to read out thermal zone (-22)
[   15.121720] thermal thermal_zone3: failed to read out thermal zone (-22)
[   15.128389] thermal thermal_zone4: failed to read out thermal zone (-22)
[   15.134887] device-mapper: uevent: version 1.0.3
[   15.139041] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
[   15.161507] sdhci: Secure Digital Host Controller Interface driver
[   15.166237] sdhci: Copyright(c) Pierre Ossman
[   15.170769] Synopsys Designware Multimedia Card Interface Driver
[   15.177158] dwmmc_exynos 12200000.mmc: IDMAC supports 32-bit address mode.
[   15.183483] dwmmc_exynos 12200000.mmc: Using internal DMA controller.
[   15.189804] dwmmc_exynos 12200000.mmc: Version ID is 250a
[   15.195195] dwmmc_exynos 12200000.mmc: DW MMC controller at irq 83,64 bit host data width,64 deep fifo
[   15.204587] dwmmc_exynos 12200000.mmc: allocated mmc-pwrseq
[   15.232656] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[   15.259795] dwmmc_exynos 12220000.mmc: IDMAC supports 32-bit address mode.
[   15.265253] dwmmc_exynos 12220000.mmc: Using internal DMA controller.
[   15.271650] dwmmc_exynos 12220000.mmc: Version ID is 250a
[   15.277030] dwmmc_exynos 12220000.mmc: DW MMC controller at irq 84,64 bit host data width,64 deep fifo
[   15.307891] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
[   15.336488] ledtrig-cpu: registered to indicate activity on CPUs
[   15.343711] s5p-secss 10830000.sss: s5p-sss driver registered
[   15.348220] hidraw: raw HID events driver (C) Jiri Kosina
[   15.360960] exynos-nocp: new NoC Probe device registered: 10ca1000.nocp
[   15.366225] exynos-nocp: new NoC Probe device registered: 10ca1400.nocp
[   15.372887] exynos-nocp: new NoC Probe device registered: 10ca1800.nocp
[   15.379755] exynos-nocp: new NoC Probe device registered: 10ca1c00.nocp
[   15.390080] NET: Registered protocol family 17
[   15.393076] NET: Registered protocol family 15
[   15.397510] Key type dns_resolver registered
[   15.402178] Registering SWP/SWPB emulation handler
[   15.406885] registered taskstats version 1
[   15.410566] Loading compiled-in X.509 certificates
[   15.419730] Key type encrypted registered
[   15.440736] OF: graph: no port node found in /soc/hdmi@14530000
[   15.446070] [drm] Exynos DRM: using 14450000.mixer device for DMA mapping operations
[   15.453050] exynos-drm exynos-drm: bound 14450000.mixer (ops 0xc0965d0c)
[   15.459588] exynos-drm exynos-drm: bound 14530000.hdmi (ops 0xc09663ac)
[   15.466166] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   15.472749] [drm] No driver support for vblank timestamp query.
[   15.478752] [drm] Cannot find any crtc or sizes
[   15.483628] [drm] Initialized exynos 1.0.0 20110530 for exynos-drm on minor 0
[   15.490510] [drm] Cannot find any crtc or sizes
[   15.496272] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   15.500310] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3
[   15.508145] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
[   15.517315] xhci-hcd xhci-hcd.3.auto: irq 150, io mem 0x12000000
[   15.523419] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[   15.530020] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   15.537212] usb usb3: Product: xHCI Host Controller
[   15.542062] usb usb3: Manufacturer: Linux 4.14.165+ xhci-hcd
[   15.547695] usb usb3: SerialNumber: xhci-hcd.3.auto
[   15.552860] hub 3-0:1.0: USB hub found
[   15.556295] hub 3-0:1.0: 1 port detected
[   15.560369] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   15.565641] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4
[   15.573269] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0  SuperSpeed
[   15.579900] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[   15.588007] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[   15.594661] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   15.601857] usb usb4: Product: xHCI Host Controller
[   15.606704] usb usb4: Manufacturer: Linux 4.14.165+ xhci-hcd
[   15.612337] usb usb4: SerialNumber: xhci-hcd.3.auto
[   15.617493] hub 4-0:1.0: USB hub found
[   15.620612] mmc_host mmc1: Bus speed (slot 0) = 200000000Hz (slot req 200000000Hz, actual 200000000HZ div = 0)
[   15.620986] hub 4-0:1.0: 1 port detected
[   15.632500] mmc1: new ultra high speed SDR104 SDXC card at address e624
[   15.639350] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[   15.642175] mmcblk1: mmc1:e624 SR64G 59.5 GiB
[   15.646841] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 5
[   15.653064]  mmcblk1: p1 p2
[   15.662158] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
[   15.671042] xhci-hcd xhci-hcd.6.auto: irq 151, io mem 0x12400000
[   15.677121] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[   15.683743] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   15.690942] usb usb5: Product: xHCI Host Controller
[   15.695788] usb usb5: Manufacturer: Linux 4.14.165+ xhci-hcd
[   15.701419] usb usb5: SerialNumber: xhci-hcd.6.auto
[   15.706564] hub 5-0:1.0: USB hub found
[   15.710020] hub 5-0:1.0: 1 port detected
[   15.714090] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[   15.719365] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 6
[   15.726989] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0  SuperSpeed
[   15.733621] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[   15.741723] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[   15.748388] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   15.755580] usb usb6: Product: xHCI Host Controller
[   15.760430] usb usb6: Manufacturer: Linux 4.14.165+ xhci-hcd
[   15.766063] usb usb6: SerialNumber: xhci-hcd.6.auto
[   15.771243] hub 6-0:1.0: USB hub found
[   15.774663] hub 6-0:1.0: 1 port detected
[   15.779540] rtc rtc1: invalid alarm value: 1900-1-1 0:0:0
[   15.784035] s3c-rtc 101e0000.rtc: rtc core: registered s3c as rtc1
[   15.791228] exynos-bus: new bus device registered: soc:bus_wcore ( 84000 KHz ~ 400000 KHz)
[   15.798715] exynos-bus: new bus device registered: soc:bus_noc ( 67000 KHz ~ 100000 KHz)
[   15.806654] exynos-bus: new bus device registered: soc:bus_fsys_apb (200000 KHz ~ 200000 KHz)
[   15.815104] exynos-bus: new bus device registered: soc:bus_fsys (200000 KHz ~ 200000 KHz)
[   15.823365] exynos-bus: new bus device registered: soc:bus_fsys2 ( 75000 KHz ~ 150000 KHz)
[   15.831690] exynos-bus: new bus device registered: soc:bus_mfc ( 96000 KHz ~ 333000 KHz)
[   15.839721] exynos-bus: new bus device registered: soc:bus_gen ( 89000 KHz ~ 267000 KHz)
[   15.847708] exynos-bus: new bus device registered: soc:bus_peri ( 67000 KHz ~  67000 KHz)
[   15.855937] exynos-bus: new bus device registered: soc:bus_g2d ( 84000 KHz ~ 333000 KHz)
[   15.863951] exynos-bus: new bus device registered: soc:bus_g2d_acp ( 67000 KHz ~ 267000 KHz)
[   15.872370] exynos-bus: new bus device registered: soc:bus_jpeg ( 75000 KHz ~ 300000 KHz)
[   15.880510] exynos-bus: new bus device registered: soc:bus_jpeg_apb ( 84000 KHz ~ 167000 KHz)
[   15.888931] exynos-bus: new bus device registered: soc:bus_disp1_fimd (120000 KHz ~ 200000 KHz)
[   15.897628] exynos-bus: new bus device registered: soc:bus_disp1 (120000 KHz ~ 300000 KHz)
[   15.905865] exynos-bus: new bus device registered: soc:bus_gscl_scaler (150000 KHz ~ 300000 KHz)
[   15.914687] exynos-bus: new bus device registered: soc:bus_mscl ( 84000 KHz ~ 400000 KHz)
[   15.922736] samsung-i2s 3830000.i2s: ASoC: Failed to create component debugfs directory
[   15.930391] samsung-i2s 3830000.i2s: ASoC: Failed to create component debugfs directory
[   15.938894] odroid-audio sound: multicodec <-> 3830000.i2s mapping ok
[   15.947788] s5m-rtc s2mps14-rtc: setting system clock to 2020-02-27 14:03:40 UTC (1582812220)
[   15.959272] ALSA device list:
[   15.960792]   #0: Odroid-XU4
[   15.964738] Freeing unused kernel memory: 1024K
[   15.994254] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[   16.000293] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[   16.005984] random: udevadm: uninitialized urandom read (16 bytes read)
[   16.831551] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd
[   16.856747] usb 4-1: New USB device found, idVendor=152d, idProduct=0578
[   16.862001] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   16.869103] usb 4-1: Product: USB to ATA/ATAPI Bridge
[   16.874125] usb 4-1: Manufacturer: JMicron
[   16.878353] usb 4-1: SerialNumber: 0123456789ABCDEF
[   16.935552] usb 6-1: new SuperSpeed USB device number 2 using xhci-hcd
[   16.960342] usb 6-1: New USB device found, idVendor=0bda, idProduct=8153
[   16.965600] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[   16.972699] usb 6-1: Product: USB 10/100/1000 LAN
[   16.977382] usb 6-1: Manufacturer: Realtek
[   16.981448] usb 6-1: SerialNumber: 000001000000
[   17.157728] usb 6-1: reset SuperSpeed USB device number 2 using xhci-hcd
[   17.224461] r8152 6-1:1.0 eth0: v1.09.9
[   17.779869] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[   18.364561] udevd[347]: starting version 3.2.2
[   18.411271] udevd[348]: starting eudev-3.2.2
[   18.533571] gpiomem-exynos 13400000.gpiomem: Initialised: GPIO register area is 2
[   18.539858] gpiomem-exynos 13400000.gpiomem: Initialised: Registers at 0x13400000
[   18.547133] gpiomem-exynos 13400000.gpiomem: Initialised: Registers at 0x14010000
[   18.561852] input: gpio_keys as /devices/platform/gpio_keys/input/input0
[   18.568975] Driver for 1-wire Dallas network protocol.
[   18.617264] s5p-mfc 11000000.codec: Direct firmware load for s5p-mfc-v8.fw failed with error -2
[   18.624625] s5p_mfc_load_firmware:73: Firmware is not present in the /lib/firmware directory nor compiled in kernel
[   18.635618] s5p-mfc 11000000.codec: Direct firmware load for s5p-mfc-v8.fw failed with error -2
[   18.643820] s5p_mfc_load_firmware:73: Firmware is not present in the /lib/firmware directory nor compiled in kernel
[   18.787089] SCSI subsystem initialized
[   18.796404] usbcore: registered new interface driver usb-storage
[   18.827766] scsi host0: uas
[   18.829816] usbcore: registered new interface driver uas
[   18.830139] scsi 0:0:0:0: Direct-Access     JMicron  Generic          3102 PQ: 0 ANSI: 6
[   18.883910] ------------[ cut here ]------------
[   18.887153] WARNING: CPU: 0 PID: 379 at drivers/spi/spidev.c:733 spidev_probe+0x104/0x1c0 [spidev]
[   18.896053] /soc/spi@12d30000/spidev@0: buggy DT: spidev listed directly in DT
[   18.903514] Modules linked in: sd_mod spidev(+) evdev uas usb_storage scsi_mod spi_s3c64xx w1_gpio wire gpio_keys uio_pdrv_genirq uio extcon_usb_gpio exynos_gpiomem
[   18.917914] CPU: 0 PID: 379 Comm: udevd Not tainted 4.14.165+ #1
[   18.923800] Hardware name: ODROID-XU4
[   18.927459] [<c011053c>] (unwind_backtrace) from [<c010c6e0>] (show_stack+0x10/0x14)
[   18.935164] [<c010c6e0>] (show_stack) from [<c08acfa0>] (dump_stack+0xa0/0xb4)
[   18.942352] [<c08acfa0>] (dump_stack) from [<c012404c>] (__warn+0xec/0x104)
[   18.949281] [<c012404c>] (__warn) from [<c012409c>] (warn_slowpath_fmt+0x38/0x48)
[   18.956741] [<c012409c>] (warn_slowpath_fmt) from [<bf13825c>] (spidev_probe+0x104/0x1c0 [spidev])
[   18.965681] [<bf13825c>] (spidev_probe [spidev]) from [<c05d0494>] (spi_drv_probe+0x7c/0xa8)
[   18.974070] [<c05d0494>] (spi_drv_probe) from [<c059eb14>] (driver_probe_device+0x27c/0x474)
[   18.982473] [<c059eb14>] (driver_probe_device) from [<c059ee0c>] (__driver_attach+0x100/0x11c)
[   18.991057] [<c059ee0c>] (__driver_attach) from [<c059cb50>] (bus_for_each_dev+0x6c/0xa0)
[   18.999197] [<c059cb50>] (bus_for_each_dev) from [<c059de6c>] (bus_add_driver+0x1d0/0x268)
[   19.007430] [<c059de6c>] (bus_add_driver) from [<c059fa70>] (driver_register+0x78/0xf8)
[   19.015404] [<c059fa70>] (driver_register) from [<bf13e094>] (spidev_init+0x94/0x1000 [spidev])
[   19.024072] [<bf13e094>] (spidev_init [spidev]) from [<c0101b68>] (do_one_initcall+0x50/0x18c)
[   19.032648] [<c0101b68>] (do_one_initcall) from [<c01a8d00>] (do_init_module+0x64/0x1f4)
[   19.040703] [<c01a8d00>] (do_init_module) from [<c01a7a18>] (load_module+0x1ee8/0x260c)
[   19.048675] [<c01a7a18>] (load_module) from [<c01a835c>] (SyS_finit_module+0xa4/0xd4)
[   19.056477] [<c01a835c>] (SyS_finit_module) from [<c0108680>] (ret_fast_syscall+0x0/0x54)
[   19.064800] ---[ end trace f33bf58b3c6d4b82 ]---
[   21.798783] sd 0:0:0:0: [sda] 1875385008 512-byte logical blocks: (960 GB/894 GiB)
[   21.804904] sd 0:0:0:0: [sda] 4096-byte physical blocks
[   21.810272] sd 0:0:0:0: [sda] Write Protect is off
[   21.814859] sd 0:0:0:0: [sda] Mode Sense: 53 00 00 08
[   21.815216] sd 0:0:0:0: [sda] Disabling FUA
[   21.819018] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   21.828408] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
[   21.842726]  sda: sda1
[   21.845616] sd 0:0:0:0: [sda] Attached SCSI disk
[   21.850695] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   22.186697] EXT4-fs (mmcblk1p2): re-mounted. Opts: errors=remount-ro,discard
[   22.194705] random: crng init done
[   22.196639] random: 7 urandom warning(s) missed due to ratelimiting
[   22.811137] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   22.887767] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: discard
[   23.382749] r8152 6-1:1.0 eth0: carrier on
[   23.721831] NET: Registered protocol family 10
[   23.725889] Segment Routing with IPv6
[   23.902266] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   24.457587] NFSD: starting 90-second grace period (net c0d84240)
#6 2020-02-27 23:19:06
Illegalum
config.gz
# Automatically generated file; DO NOT EDIT.
# Linux/arm 4.14.165 Kernel Configuration
CONFIG_ARM=y
CONFIG_ARM_HAS_SG_CHAIN=y
CONFIG_NEED_SG_DMA_LENGTH=y
CONFIG_ARM_DMA_USE_IOMMU=y
CONFIG_ARM_DMA_IOMMU_ALIGNMENT=8
CONFIG_MIGHT_HAVE_PCI=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_HAVE_PROC_CPU=y
CONFIG_NO_IOPORT_MAP=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_ARCH_HAS_BANDGAP=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_VECTORS_BASE=0xffff0000
CONFIG_ARM_PATCH_PHYS_VIRT=y
CONFIG_GENERIC_BUG=y
CONFIG_PGTABLE_LEVELS=2
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_EXTABLE_SORT=y
# General setup
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_CROSS_COMPILE=""
# CONFIG_COMPILE_TEST is not set
CONFIG_LOCALVERSION=""
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_HAVE_KERNEL_XZ=y
CONFIG_HAVE_KERNEL_LZO=y
CONFIG_HAVE_KERNEL_LZ4=y
CONFIG_KERNEL_GZIP=y
# CONFIG_KERNEL_LZMA is not set
# CONFIG_KERNEL_XZ is not set
# CONFIG_KERNEL_LZO is not set
# CONFIG_KERNEL_LZ4 is not set
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE=y
CONFIG_POSIX_MQUEUE_SYSCTL=y
CONFIG_CROSS_MEMORY_ATTACH=y
CONFIG_FHANDLE=y
# CONFIG_USELIB is not set
CONFIG_AUDIT=y
CONFIG_HAVE_ARCH_AUDITSYSCALL=y
CONFIG_AUDITSYSCALL=y
CONFIG_AUDIT_WATCH=y
CONFIG_AUDIT_TREE=y
# IRQ subsystem
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
CONFIG_GENERIC_IRQ_MIGRATION=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_CHIP=y
CONFIG_IRQ_DOMAIN=y
CONFIG_IRQ_DOMAIN_HIERARCHY=y
CONFIG_HANDLE_DOMAIN_IRQ=y
CONFIG_IRQ_DOMAIN_DEBUG=y
CONFIG_IRQ_FORCED_THREADING=y
CONFIG_SPARSE_IRQ=y
CONFIG_GENERIC_IRQ_DEBUGFS=y
CONFIG_ARCH_CLOCKSOURCE_DATA=y
CONFIG_GENERIC_TIME_VSYSCALL=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_ARCH_HAS_TICK_BROADCAST=y
CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
# CONFIG_NO_HZ_FULL is not set
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
# CPU/Task time and stats accounting
CONFIG_TICK_CPU_ACCOUNTING=y
# CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
CONFIG_IRQ_TIME_ACCOUNTING=y
CONFIG_BSD_PROCESS_ACCT=y
# CONFIG_BSD_PROCESS_ACCT_V3 is not set
CONFIG_TASKSTATS=y
CONFIG_TASK_DELAY_ACCT=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
# RCU Subsystem
CONFIG_PREEMPT_RCU=y
# CONFIG_RCU_EXPERT is not set
CONFIG_SRCU=y
CONFIG_TREE_SRCU=y
CONFIG_TASKS_RCU=y
CONFIG_RCU_STALL_COMMON=y
CONFIG_RCU_NEED_SEGCBLIST=y
CONFIG_BUILD_BIN2C=y
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=17
CONFIG_LOG_CPU_MAX_BUF_SHIFT=12
CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
CONFIG_GENERIC_SCHED_CLOCK=y
CONFIG_CGROUPS=y
CONFIG_PAGE_COUNTER=y
CONFIG_MEMCG=y
CONFIG_MEMCG_SWAP=y
CONFIG_MEMCG_SWAP_ENABLED=y
CONFIG_BLK_CGROUP=y
# CONFIG_DEBUG_BLK_CGROUP is not set
CONFIG_CGROUP_WRITEBACK=y
CONFIG_CGROUP_SCHED=y
CONFIG_FAIR_GROUP_SCHED=y
CONFIG_CFS_BANDWIDTH=y
CONFIG_RT_GROUP_SCHED=y
# CONFIG_CGROUP_PIDS is not set
CONFIG_CGROUP_RDMA=y
CONFIG_CGROUP_FREEZER=y
CONFIG_CPUSETS=y
CONFIG_PROC_PID_CPUSET=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_CGROUP_PERF=y
CONFIG_CGROUP_BPF=y
CONFIG_SOCK_CGROUP_DATA=y
# CONFIG_CHECKPOINT_RESTORE is not set
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
CONFIG_IPC_NS=y
CONFIG_USER_NS=y
CONFIG_PID_NS=y
CONFIG_NET_NS=y
# CONFIG_SCHED_AUTOGROUP is not set
# CONFIG_SYSFS_DEPRECATED is not set
CONFIG_RELAY=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
# CONFIG_INITRAMFS_FORCE is not set
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
CONFIG_RD_LZ4=y
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
CONFIG_HAVE_UID16=y
CONFIG_BPF=y
# CONFIG_EXPERT is not set
CONFIG_UID16=y
CONFIG_MULTIUSER=y
# CONFIG_SGETMASK_SYSCALL is not set
CONFIG_SYSFS_SYSCALL=y
# CONFIG_SYSCTL_SYSCALL is not set
CONFIG_POSIX_TIMERS=y
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_ABSOLUTE_PERCPU is not set
CONFIG_KALLSYMS_BASE_RELATIVE=y
CONFIG_PRINTK=y
CONFIG_PRINTK_NMI=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_FUTEX_PI=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_BPF_SYSCALL=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_ADVISE_SYSCALLS=y
# CONFIG_USERFAULTFD is not set
CONFIG_MEMBARRIER=y
# CONFIG_EMBEDDED is not set
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# CONFIG_PC104 is not set
# Kernel Performance Events And Counters
CONFIG_PERF_EVENTS=y
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_SLUB_DEBUG=y
# CONFIG_SLUB_MEMCG_SYSFS_ON is not set
CONFIG_COMPAT_BRK=y
# CONFIG_SLAB is not set
CONFIG_SLUB=y
CONFIG_SLAB_MERGE_DEFAULT=y
# CONFIG_SLAB_FREELIST_RANDOM is not set
# CONFIG_SLAB_FREELIST_HARDENED is not set
CONFIG_SLUB_CPU_PARTIAL=y
# CONFIG_SYSTEM_DATA_VERIFICATION is not set
CONFIG_PROFILING=y
CONFIG_TRACEPOINTS=y
# CONFIG_OPROFILE is not set
CONFIG_HAVE_OPROFILE=y
# CONFIG_KPROBES is not set
# CONFIG_JUMP_LABEL is not set
CONFIG_UPROBES=y
# CONFIG_HAVE_64BIT_ALIGNED_ACCESS is not set
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_ARCH_USE_BUILTIN_BSWAP=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_OPTPROBES=y
CONFIG_HAVE_NMI=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_GENERIC_IDLE_POLL_SETUP=y
CONFIG_ARCH_HAS_SET_MEMORY=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_CLK=y
CONFIG_HAVE_DMA_API_DEBUG=y
CONFIG_HAVE_HW_BREAKPOINT=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_HAVE_ARCH_JUMP_LABEL=y
CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
CONFIG_SECCOMP_FILTER=y
CONFIG_HAVE_GCC_PLUGINS=y
# CONFIG_GCC_PLUGINS is not set
CONFIG_HAVE_CC_STACKPROTECTOR=y
CONFIG_CC_STACKPROTECTOR=y
# CONFIG_CC_STACKPROTECTOR_NONE is not set
CONFIG_CC_STACKPROTECTOR_REGULAR=y
# CONFIG_CC_STACKPROTECTOR_STRONG is not set
CONFIG_THIN_ARCHIVES=y
CONFIG_HAVE_CONTEXT_TRACKING=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
CONFIG_MODULES_USE_ELF_REL=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
CONFIG_HAVE_EXIT_THREAD=y
CONFIG_ARCH_MMAP_RND_BITS_MIN=8
CONFIG_ARCH_MMAP_RND_BITS_MAX=16
CONFIG_ARCH_MMAP_RND_BITS=8
# CONFIG_HAVE_ARCH_HASH is not set
# CONFIG_ISA_BUS_API is not set
CONFIG_CLONE_BACKWARDS=y
CONFIG_OLD_SIGSUSPEND3=y
CONFIG_OLD_SIGACTION=y
# CONFIG_CPU_NO_EFFICIENT_FFS is not set
# CONFIG_HAVE_ARCH_VMAP_STACK is not set
CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y
CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
CONFIG_STRICT_KERNEL_RWX=y
CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
CONFIG_STRICT_MODULE_RWX=y
# CONFIG_REFCOUNT_FULL is not set
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
CONFIG_HAVE_GENERIC_DMA_COHERENT=y
CONFIG_SLABINFO=y
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
# CONFIG_MODULE_SIG is not set
# CONFIG_MODULE_COMPRESS is not set
# CONFIG_TRIM_UNUSED_KSYMS is not set
CONFIG_MODULES_TREE_LOOKUP=y
CONFIG_BLOCK=y
CONFIG_LBDAF=y
CONFIG_BLK_SCSI_REQUEST=y
CONFIG_BLK_DEV_BSG=y
CONFIG_BLK_DEV_BSGLIB=y
CONFIG_BLK_DEV_INTEGRITY=y
CONFIG_BLK_DEV_ZONED=y
CONFIG_BLK_DEV_THROTTLING=y
CONFIG_BLK_DEV_THROTTLING_LOW=y
# CONFIG_BLK_CMDLINE_PARSER is not set
CONFIG_BLK_WBT=y
CONFIG_BLK_WBT_SQ=y
CONFIG_BLK_WBT_MQ=y
CONFIG_BLK_DEBUG_FS=y
# CONFIG_BLK_SED_OPAL is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_AIX_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
# CONFIG_MAC_PARTITION is not set
CONFIG_MSDOS_PARTITION=y
# CONFIG_BSD_DISKLABEL is not set
# CONFIG_MINIX_SUBPARTITION is not set
# CONFIG_SOLARIS_X86_PARTITION is not set
# CONFIG_UNIXWARE_DISKLABEL is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_KARMA_PARTITION is not set
CONFIG_EFI_PARTITION=y
# CONFIG_SYSV68_PARTITION is not set
# CONFIG_CMDLINE_PARTITION is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
CONFIG_CFQ_GROUP_IOSCHED=y
# CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
# CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED="cfq"
CONFIG_MQ_IOSCHED_DEADLINE=y
CONFIG_MQ_IOSCHED_KYBER=y
CONFIG_IOSCHED_BFQ=y
CONFIG_BFQ_GROUP_IOSCHED=y
CONFIG_PADATA=y
CONFIG_ASN1=y
CONFIG_UNINLINE_SPIN_UNLOCK=y
CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
CONFIG_MUTEX_SPIN_ON_OWNER=y
CONFIG_RWSEM_SPIN_ON_OWNER=y
CONFIG_LOCK_SPIN_ON_OWNER=y
CONFIG_FREEZER=y
# System Type
CONFIG_MMU=y
CONFIG_ARCH_MULTIPLATFORM=y
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_NETX is not set
# CONFIG_ARCH_IOP13XX is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IOP33X is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_KS8695 is not set
# CONFIG_ARCH_W90X900 is not set
# CONFIG_ARCH_LPC32XX is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C24XX is not set
# CONFIG_ARCH_DAVINCI is not set
# CONFIG_ARCH_OMAP1 is not set
# Multiple platform selection
# CPU Core family selection
# CONFIG_ARCH_MULTI_V6 is not set
CONFIG_ARCH_MULTI_V7=y
CONFIG_ARCH_MULTI_V6_V7=y
# CONFIG_ARCH_MULTI_CPU_AUTO is not set
# CONFIG_ARCH_VIRT is not set
# CONFIG_ARCH_MVEBU is not set
# CONFIG_ARCH_ACTIONS is not set
# CONFIG_ARCH_ALPINE is not set
# CONFIG_ARCH_ARTPEC is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_BCM is not set
# CONFIG_ARCH_BERLIN is not set
# CONFIG_ARCH_DIGICOLOR is not set
# CONFIG_ARCH_HIGHBANK is not set
# CONFIG_ARCH_HISI is not set
# CONFIG_ARCH_KEYSTONE is not set
# CONFIG_ARCH_MESON is not set
# CONFIG_ARCH_MXC is not set
# CONFIG_ARCH_MEDIATEK is not set
# TI OMAP/AM/DM/DRA Family
# CONFIG_ARCH_OMAP3 is not set
# CONFIG_ARCH_OMAP4 is not set
# CONFIG_SOC_OMAP5 is not set
# CONFIG_SOC_AM33XX is not set
# CONFIG_SOC_AM43XX is not set
# CONFIG_SOC_DRA7XX is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_QCOM is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_ARCH_ROCKCHIP is not set
# CONFIG_ARCH_SOCFPGA is not set
# CONFIG_PLAT_SPEAR is not set
# CONFIG_ARCH_STI is not set
# CONFIG_ARCH_S5PV210 is not set
CONFIG_ARCH_EXYNOS=y
CONFIG_S5P_DEV_MFC=y
CONFIG_ARCH_EXYNOS3=y
CONFIG_ARCH_EXYNOS4=y
CONFIG_ARCH_EXYNOS5=y
# EXYNOS SoCs
CONFIG_SOC_EXYNOS3250=y
CONFIG_CPU_EXYNOS4210=y
CONFIG_SOC_EXYNOS4212=y
CONFIG_SOC_EXYNOS4412=y
CONFIG_SOC_EXYNOS5250=y
CONFIG_SOC_EXYNOS5260=y
CONFIG_SOC_EXYNOS5410=y
CONFIG_SOC_EXYNOS5420=y
CONFIG_SOC_EXYNOS5440=y
CONFIG_SOC_EXYNOS5800=y
CONFIG_EXYNOS5420_MCPM=y
CONFIG_EXYNOS_CPU_SUSPEND=y
CONFIG_PLAT_SAMSUNG=y
# Samsung Common options
# Boot options
# CONFIG_SAMSUNG_ATAGS is not set
# Power management
# CONFIG_ARCH_RENESAS is not set
# CONFIG_ARCH_SUNXI is not set
# CONFIG_ARCH_SIRF is not set
# CONFIG_ARCH_TANGO is not set
# CONFIG_ARCH_TEGRA is not set
# CONFIG_ARCH_UNIPHIER is not set
# CONFIG_ARCH_U8500 is not set
# CONFIG_ARCH_VEXPRESS is not set
# CONFIG_ARCH_WM8850 is not set
# CONFIG_ARCH_ZX is not set
# CONFIG_ARCH_ZYNQ is not set
# Processor Type
CONFIG_CPU_V7=y
CONFIG_CPU_THUMB_CAPABLE=y
CONFIG_CPU_32v6K=y
CONFIG_CPU_32v7=y
CONFIG_CPU_ABRT_EV7=y
CONFIG_CPU_PABRT_V7=y
CONFIG_CPU_CACHE_V7=y
CONFIG_CPU_CACHE_VIPT=y
CONFIG_CPU_COPY_V6=y
CONFIG_CPU_TLB_V7=y
CONFIG_CPU_HAS_ASID=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
# Processor Features
# CONFIG_ARM_LPAE is not set
# CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set
CONFIG_ARM_THUMB=y
# CONFIG_ARM_THUMBEE is not set
CONFIG_ARM_VIRT_EXT=y
CONFIG_SWP_EMULATE=y
# CONFIG_CPU_BIG_ENDIAN is not set
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_BPREDICT_DISABLE is not set
CONFIG_CPU_SPECTRE=y
CONFIG_HARDEN_BRANCH_PREDICTOR=y
CONFIG_KUSER_HELPERS=y
CONFIG_VDSO=y
CONFIG_OUTER_CACHE=y
CONFIG_OUTER_CACHE_SYNC=y
CONFIG_MIGHT_HAVE_CACHE_L2X0=y
CONFIG_CACHE_L2X0=y
# CONFIG_CACHE_L2X0_PMU is not set
# CONFIG_PL310_ERRATA_588369 is not set
# CONFIG_PL310_ERRATA_727915 is not set
# CONFIG_PL310_ERRATA_753970 is not set
# CONFIG_PL310_ERRATA_769419 is not set
CONFIG_ARM_L1_CACHE_SHIFT_6=y
CONFIG_ARM_L1_CACHE_SHIFT=6
CONFIG_ARM_DMA_MEM_BUFFERABLE=y
CONFIG_ARM_HEAVY_MB=y
CONFIG_ARCH_SUPPORTS_BIG_ENDIAN=y
CONFIG_DEBUG_ALIGN_RODATA=y
CONFIG_MULTI_IRQ_HANDLER=y
# CONFIG_ARM_ERRATA_430973 is not set
CONFIG_ARM_ERRATA_643719=y
# CONFIG_ARM_ERRATA_720789 is not set
# CONFIG_ARM_ERRATA_754322 is not set
# CONFIG_ARM_ERRATA_754327 is not set
# CONFIG_ARM_ERRATA_764369 is not set
# CONFIG_ARM_ERRATA_775420 is not set
# CONFIG_ARM_ERRATA_798181 is not set
# CONFIG_ARM_ERRATA_773022 is not set
# CONFIG_ARM_ERRATA_818325_852422 is not set
# CONFIG_ARM_ERRATA_821420 is not set
# CONFIG_ARM_ERRATA_825619 is not set
# CONFIG_ARM_ERRATA_852421 is not set
# CONFIG_ARM_ERRATA_852423 is not set
# Bus support
# CONFIG_PCI is not set
# CONFIG_PCI_DOMAINS_GENERIC is not set
# CONFIG_PCI_SYSCALL is not set
# DesignWare PCI Core Support
# PCI Endpoint
# CONFIG_PCI_ENDPOINT is not set
# CONFIG_PCCARD is not set
# Kernel Features
CONFIG_HAVE_SMP=y
CONFIG_SMP=y
CONFIG_SMP_ON_UP=y
CONFIG_ARM_CPU_TOPOLOGY=y
CONFIG_SCHED_MC=y
CONFIG_HPERF_HMP=y
# CONFIG_HPERF_HMP_DEBUG is not set
CONFIG_HMP_FAST_CPU_MASK="F0"
CONFIG_HMP_SLOW_CPU_MASK="0F"
# CONFIG_SCHED_SMT is not set
CONFIG_HAVE_ARM_SCU=y
CONFIG_HAVE_ARM_ARCH_TIMER=y
CONFIG_MCPM=y
CONFIG_BIG_LITTLE=y
# CONFIG_BL_SWITCHER is not set
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_3G_OPT is not set
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_NR_CPUS=8
CONFIG_HOTPLUG_CPU=y
# CONFIG_ARM_PSCI is not set
CONFIG_ARCH_NR_GPIO=512
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT=y
CONFIG_PREEMPT_COUNT=y
CONFIG_HZ_FIXED=0
# CONFIG_HZ_100 is not set
# CONFIG_HZ_200 is not set
CONFIG_HZ_250=y
# CONFIG_HZ_300 is not set
# CONFIG_HZ_500 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=250
CONFIG_SCHED_HRTICK=y
# CONFIG_THUMB2_KERNEL is not set
CONFIG_ARM_PATCH_IDIV=y
CONFIG_AEABI=y
# CONFIG_OABI_COMPAT is not set
CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
# CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
# CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
CONFIG_HAVE_ARCH_PFN_VALID=y
CONFIG_HIGHMEM=y
CONFIG_HIGHPTE=y
CONFIG_CPU_SW_DOMAIN_PAN=y
CONFIG_HW_PERF_EVENTS=y
CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
# CONFIG_ARM_MODULE_PLTS is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_HAVE_MEMBLOCK=y
CONFIG_NO_BOOTMEM=y
CONFIG_MEMORY_ISOLATION=y
# CONFIG_HAVE_BOOTMEM_INFO_NODE is not set
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_COMPACTION=y
CONFIG_MIGRATION=y
# CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_BOUNCE=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
# CONFIG_ARCH_WANTS_THP_SWAP is not set
# CONFIG_CLEANCACHE is not set
# CONFIG_FRONTSWAP is not set
CONFIG_CMA=y
# CONFIG_CMA_DEBUGFS is not set
CONFIG_CMA_AREAS=7
# CONFIG_ZPOOL is not set
# CONFIG_ZBUD is not set
CONFIG_ZSMALLOC=y
CONFIG_PGTABLE_MAPPING=y
CONFIG_ZSMALLOC_STAT=y
CONFIG_GENERIC_EARLY_IOREMAP=y
# CONFIG_IDLE_PAGE_TRACKING is not set
CONFIG_FRAME_VECTOR=y
# CONFIG_PERCPU_STATS is not set
CONFIG_FORCE_MAX_ZONEORDER=11
CONFIG_ALIGNMENT_TRAP=y
# CONFIG_UACCESS_WITH_MEMCPY is not set
CONFIG_SECCOMP=y
CONFIG_SWIOTLB=y
CONFIG_IOMMU_HELPER=y
# CONFIG_PARAVIRT is not set
# CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
# CONFIG_XEN is not set
# Boot options
CONFIG_USE_OF=y
CONFIG_ATAGS=y
# CONFIG_DEPRECATED_PARAM_STRUCT is not set
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
CONFIG_ARM_APPENDED_DTB=y
CONFIG_ARM_ATAG_DTB_COMPAT=y
# CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER is not set
CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND=y
CONFIG_CMDLINE="s5p_mfc.mem=16M"
# CONFIG_CMDLINE_FROM_BOOTLOADER is not set
CONFIG_CMDLINE_EXTEND=y
# CONFIG_CMDLINE_FORCE is not set
# CONFIG_KEXEC is not set
# CONFIG_CRASH_DUMP is not set
CONFIG_AUTO_ZRELADDR=y
# CONFIG_EFI is not set
# CPU Power Management
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_GOV_ATTR_SET=y
CONFIG_CPU_FREQ_GOV_COMMON=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=m
CONFIG_CPU_FREQ_GOV_USERSPACE=m
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=m
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
# CPU frequency scaling drivers
CONFIG_CPUFREQ_DT=y
CONFIG_CPUFREQ_DT_PLATDEV=y
# CONFIG_ARM_BIG_LITTLE_CPUFREQ is not set
# CONFIG_ARM_EXYNOS5440_CPUFREQ is not set
# CONFIG_ARM_KIRKWOOD_CPUFREQ is not set
# CONFIG_QORIQ_CPUFREQ is not set
# CPU Idle
CONFIG_CPU_IDLE=y
# CONFIG_CPU_IDLE_GOV_LADDER is not set
CONFIG_CPU_IDLE_GOV_MENU=y
# ARM CPU Idle Drivers
# CONFIG_ARM_CPUIDLE is not set
# CONFIG_ARM_BIG_LITTLE_CPUIDLE is not set
CONFIG_ARM_EXYNOS_CPUIDLE=y
CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED=y
# Floating point emulation
# At least one emulation must be selected
CONFIG_VFP=y
CONFIG_VFPv3=y
CONFIG_NEON=y
CONFIG_KERNEL_MODE_NEON=y
# Userspace binary formats
CONFIG_BINFMT_ELF=y
CONFIG_ELFCORE=y
CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
CONFIG_BINFMT_SCRIPT=y
# CONFIG_BINFMT_FLAT is not set
# CONFIG_HAVE_AOUT is not set
CONFIG_BINFMT_MISC=m
CONFIG_COREDUMP=y
# Power management options
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
# CONFIG_HIBERNATION is not set
CONFIG_PM_SLEEP=y
CONFIG_PM_SLEEP_SMP=y
# CONFIG_PM_AUTOSLEEP is not set
# CONFIG_PM_WAKELOCKS is not set
CONFIG_PM=y
CONFIG_PM_DEBUG=y
CONFIG_PM_ADVANCED_DEBUG=y
# CONFIG_PM_TEST_SUSPEND is not set
CONFIG_PM_SLEEP_DEBUG=y
# CONFIG_APM_EMULATION is not set
CONFIG_PM_OPP=y
CONFIG_PM_CLK=y
CONFIG_PM_GENERIC_DOMAINS=y
# CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
CONFIG_PM_GENERIC_DOMAINS_SLEEP=y
CONFIG_PM_GENERIC_DOMAINS_OF=y
CONFIG_CPU_PM=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ARM_CPU_SUSPEND=y
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
CONFIG_NET=y
CONFIG_NET_INGRESS=y
CONFIG_NET_EGRESS=y
# Networking options
CONFIG_PACKET=y
CONFIG_PACKET_DIAG=m
CONFIG_UNIX=y
CONFIG_UNIX_DIAG=m
# CONFIG_TLS is not set
CONFIG_XFRM=y
CONFIG_XFRM_ALGO=y
CONFIG_XFRM_USER=m
CONFIG_XFRM_SUB_POLICY=y
CONFIG_XFRM_MIGRATE=y
CONFIG_XFRM_STATISTICS=y
CONFIG_XFRM_IPCOMP=m
CONFIG_NET_KEY=y
CONFIG_NET_KEY_MIGRATE=y
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_IP_FIB_TRIE_STATS=y
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_MULTIPATH=y
CONFIG_IP_ROUTE_VERBOSE=y
CONFIG_IP_ROUTE_CLASSID=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_IP_PNP_RARP=y
CONFIG_NET_IPIP=m
CONFIG_NET_IPGRE_DEMUX=m
CONFIG_NET_IP_TUNNEL=m
CONFIG_NET_IPGRE=m
CONFIG_NET_IPGRE_BROADCAST=y
CONFIG_IP_MROUTE=y
CONFIG_IP_MROUTE_MULTIPLE_TABLES=y
CONFIG_IP_PIMSM_V1=y
CONFIG_IP_PIMSM_V2=y
CONFIG_SYN_COOKIES=y
CONFIG_NET_IPVTI=m
CONFIG_NET_UDP_TUNNEL=m
CONFIG_NET_FOU=m
CONFIG_NET_FOU_IP_TUNNELS=y
CONFIG_INET_AH=m
CONFIG_INET_ESP=m
# CONFIG_INET_ESP_OFFLOAD is not set
CONFIG_INET_IPCOMP=m
CONFIG_INET_XFRM_TUNNEL=m
CONFIG_INET_TUNNEL=m
CONFIG_INET_XFRM_MODE_TRANSPORT=m
CONFIG_INET_XFRM_MODE_TUNNEL=m
CONFIG_INET_XFRM_MODE_BEET=m
CONFIG_INET_DIAG=m
CONFIG_INET_TCP_DIAG=m
CONFIG_INET_UDP_DIAG=m
# CONFIG_INET_RAW_DIAG is not set
CONFIG_INET_DIAG_DESTROY=y
CONFIG_TCP_CONG_ADVANCED=y
CONFIG_TCP_CONG_BIC=m
CONFIG_TCP_CONG_CUBIC=y
CONFIG_TCP_CONG_WESTWOOD=m
CONFIG_TCP_CONG_HTCP=m
CONFIG_TCP_CONG_HSTCP=m
CONFIG_TCP_CONG_HYBLA=m
CONFIG_TCP_CONG_VEGAS=m
CONFIG_TCP_CONG_NV=m
CONFIG_TCP_CONG_SCALABLE=m
CONFIG_TCP_CONG_LP=m
CONFIG_TCP_CONG_VENO=m
CONFIG_TCP_CONG_YEAH=m
CONFIG_TCP_CONG_ILLINOIS=m
CONFIG_TCP_CONG_DCTCP=m
CONFIG_TCP_CONG_CDG=m
CONFIG_TCP_CONG_BBR=m
CONFIG_DEFAULT_CUBIC=y
# CONFIG_DEFAULT_RENO is not set
CONFIG_DEFAULT_TCP_CONG="cubic"
CONFIG_TCP_MD5SIG=y
CONFIG_IPV6=m
CONFIG_IPV6_ROUTER_PREF=y
CONFIG_IPV6_ROUTE_INFO=y
CONFIG_IPV6_OPTIMISTIC_DAD=y
CONFIG_INET6_AH=m
CONFIG_INET6_ESP=m
# CONFIG_INET6_ESP_OFFLOAD is not set
CONFIG_INET6_IPCOMP=m
CONFIG_IPV6_MIP6=m
CONFIG_IPV6_ILA=m
CONFIG_INET6_XFRM_TUNNEL=m
CONFIG_INET6_TUNNEL=m
CONFIG_INET6_XFRM_MODE_TRANSPORT=m
CONFIG_INET6_XFRM_MODE_TUNNEL=m
CONFIG_INET6_XFRM_MODE_BEET=m
CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION=m
CONFIG_IPV6_VTI=m
CONFIG_IPV6_SIT=m
CONFIG_IPV6_SIT_6RD=y
CONFIG_IPV6_NDISC_NODETYPE=y
CONFIG_IPV6_TUNNEL=m
CONFIG_IPV6_GRE=m
CONFIG_IPV6_FOU=m
CONFIG_IPV6_FOU_TUNNEL=m
CONFIG_IPV6_MULTIPLE_TABLES=y
CONFIG_IPV6_SUBTREES=y
CONFIG_IPV6_MROUTE=y
CONFIG_IPV6_MROUTE_MULTIPLE_TABLES=y
CONFIG_IPV6_PIMSM_V2=y
# CONFIG_IPV6_SEG6_LWTUNNEL is not set
# CONFIG_IPV6_SEG6_HMAC is not set
# CONFIG_NETWORK_SECMARK is not set
CONFIG_NET_PTP_CLASSIFY=y
CONFIG_NETWORK_PHY_TIMESTAMPING=y
CONFIG_NETFILTER=y
CONFIG_NETFILTER_ADVANCED=y
CONFIG_BRIDGE_NETFILTER=m
# Core Netfilter Configuration
CONFIG_NETFILTER_INGRESS=y
CONFIG_NETFILTER_NETLINK=m
CONFIG_NETFILTER_NETLINK_ACCT=m
CONFIG_NETFILTER_NETLINK_QUEUE=m
CONFIG_NETFILTER_NETLINK_LOG=m
CONFIG_NF_CONNTRACK=m
CONFIG_NF_LOG_COMMON=m
# CONFIG_NF_LOG_NETDEV is not set
CONFIG_NF_CONNTRACK_MARK=y
CONFIG_NF_CONNTRACK_ZONES=y
CONFIG_NF_CONNTRACK_PROCFS=y
CONFIG_NF_CONNTRACK_EVENTS=y
CONFIG_NF_CONNTRACK_TIMEOUT=y
CONFIG_NF_CONNTRACK_TIMESTAMP=y
CONFIG_NF_CONNTRACK_LABELS=y
CONFIG_NF_CT_PROTO_DCCP=y
CONFIG_NF_CT_PROTO_GRE=m
CONFIG_NF_CT_PROTO_SCTP=y
CONFIG_NF_CT_PROTO_UDPLITE=y
CONFIG_NF_CONNTRACK_AMANDA=m
CONFIG_NF_CONNTRACK_FTP=m
CONFIG_NF_CONNTRACK_H323=m
CONFIG_NF_CONNTRACK_IRC=m
CONFIG_NF_CONNTRACK_BROADCAST=m
CONFIG_NF_CONNTRACK_NETBIOS_NS=m
CONFIG_NF_CONNTRACK_SNMP=m
CONFIG_NF_CONNTRACK_PPTP=m
CONFIG_NF_CONNTRACK_SANE=m
CONFIG_NF_CONNTRACK_SIP=m
CONFIG_NF_CONNTRACK_TFTP=m
CONFIG_NF_CT_NETLINK=m
CONFIG_NF_CT_NETLINK_TIMEOUT=m
CONFIG_NF_CT_NETLINK_HELPER=m
CONFIG_NETFILTER_NETLINK_GLUE_CT=y
CONFIG_NF_NAT=m
CONFIG_NF_NAT_NEEDED=y
CONFIG_NF_NAT_PROTO_DCCP=y
CONFIG_NF_NAT_PROTO_UDPLITE=y
CONFIG_NF_NAT_PROTO_SCTP=y
CONFIG_NF_NAT_AMANDA=m
CONFIG_NF_NAT_FTP=m
CONFIG_NF_NAT_IRC=m
CONFIG_NF_NAT_SIP=m
CONFIG_NF_NAT_TFTP=m
CONFIG_NF_NAT_REDIRECT=m
CONFIG_NETFILTER_SYNPROXY=m
CONFIG_NF_TABLES=m
CONFIG_NF_TABLES_INET=m
CONFIG_NF_TABLES_NETDEV=m
CONFIG_NFT_EXTHDR=m
CONFIG_NFT_META=m
# CONFIG_NFT_RT is not set
CONFIG_NFT_NUMGEN=m
CONFIG_NFT_CT=m
CONFIG_NFT_SET_RBTREE=m
CONFIG_NFT_SET_HASH=m
# CONFIG_NFT_SET_BITMAP is not set
CONFIG_NFT_COUNTER=m
CONFIG_NFT_LOG=m
CONFIG_NFT_LIMIT=m
CONFIG_NFT_MASQ=m
CONFIG_NFT_REDIR=m
CONFIG_NFT_NAT=m
# CONFIG_NFT_OBJREF is not set
CONFIG_NFT_QUEUE=m
CONFIG_NFT_QUOTA=m
CONFIG_NFT_REJECT=m
CONFIG_NFT_REJECT_INET=m
CONFIG_NFT_COMPAT=m
CONFIG_NFT_HASH=m
CONFIG_NF_DUP_NETDEV=m
CONFIG_NFT_DUP_NETDEV=m
CONFIG_NFT_FWD_NETDEV=m
CONFIG_NETFILTER_XTABLES=y
# Xtables combined modules
CONFIG_NETFILTER_XT_MARK=m
CONFIG_NETFILTER_XT_CONNMARK=m
CONFIG_NETFILTER_XT_SET=m
# Xtables targets
# CONFIG_NETFILTER_XT_TARGET_AUDIT is not set
CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
CONFIG_NETFILTER_XT_TARGET_CONNMARK=m
CONFIG_NETFILTER_XT_TARGET_CT=m
CONFIG_NETFILTER_XT_TARGET_DSCP=m
CONFIG_NETFILTER_XT_TARGET_HL=m
CONFIG_NETFILTER_XT_TARGET_HMARK=m
CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m
CONFIG_NETFILTER_XT_TARGET_LED=m
CONFIG_NETFILTER_XT_TARGET_LOG=m
CONFIG_NETFILTER_XT_TARGET_MARK=m
CONFIG_NETFILTER_XT_NAT=m
CONFIG_NETFILTER_XT_TARGET_NETMAP=m
CONFIG_NETFILTER_XT_TARGET_NFLOG=m
CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
CONFIG_NETFILTER_XT_TARGET_NOTRACK=m
CONFIG_NETFILTER_XT_TARGET_RATEEST=m
CONFIG_NETFILTER_XT_TARGET_REDIRECT=m
CONFIG_NETFILTER_XT_TARGET_TEE=m
CONFIG_NETFILTER_XT_TARGET_TPROXY=m
CONFIG_NETFILTER_XT_TARGET_TRACE=m
CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP=m
# Xtables matches
CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
CONFIG_NETFILTER_XT_MATCH_BPF=m
CONFIG_NETFILTER_XT_MATCH_CGROUP=m
CONFIG_NETFILTER_XT_MATCH_CLUSTER=m
CONFIG_NETFILTER_XT_MATCH_COMMENT=m
CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m
CONFIG_NETFILTER_XT_MATCH_CONNLABEL=m
CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=m
CONFIG_NETFILTER_XT_MATCH_CONNMARK=m
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
CONFIG_NETFILTER_XT_MATCH_CPU=m
CONFIG_NETFILTER_XT_MATCH_DCCP=m
CONFIG_NETFILTER_XT_MATCH_DEVGROUP=m
CONFIG_NETFILTER_XT_MATCH_DSCP=m
CONFIG_NETFILTER_XT_MATCH_ECN=m
CONFIG_NETFILTER_XT_MATCH_ESP=m
CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
CONFIG_NETFILTER_XT_MATCH_HELPER=m
CONFIG_NETFILTER_XT_MATCH_HL=m
CONFIG_NETFILTER_XT_MATCH_IPCOMP=m
CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
CONFIG_NETFILTER_XT_MATCH_IPVS=m
CONFIG_NETFILTER_XT_MATCH_L2TP=m
CONFIG_NETFILTER_XT_MATCH_LENGTH=m
CONFIG_NETFILTER_XT_MATCH_LIMIT=m
CONFIG_NETFILTER_XT_MATCH_MAC=m
CONFIG_NETFILTER_XT_MATCH_MARK=m
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
CONFIG_NETFILTER_XT_MATCH_NFACCT=m
CONFIG_NETFILTER_XT_MATCH_OSF=m
CONFIG_NETFILTER_XT_MATCH_OWNER=m
CONFIG_NETFILTER_XT_MATCH_POLICY=m
CONFIG_NETFILTER_XT_MATCH_PHYSDEV=m
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
CONFIG_NETFILTER_XT_MATCH_QUOTA=m
CONFIG_NETFILTER_XT_MATCH_RATEEST=m
CONFIG_NETFILTER_XT_MATCH_REALM=m
CONFIG_NETFILTER_XT_MATCH_RECENT=m
CONFIG_NETFILTER_XT_MATCH_SCTP=m
CONFIG_NETFILTER_XT_MATCH_STATE=m
CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
CONFIG_NETFILTER_XT_MATCH_STRING=m
CONFIG_NETFILTER_XT_MATCH_TCPMSS=m
CONFIG_NETFILTER_XT_MATCH_TIME=m
CONFIG_NETFILTER_XT_MATCH_U32=m
CONFIG_IP_SET=m
CONFIG_IP_SET_MAX=256
CONFIG_IP_SET_BITMAP_IP=m
CONFIG_IP_SET_BITMAP_IPMAC=m
CONFIG_IP_SET_BITMAP_PORT=m
CONFIG_IP_SET_HASH_IP=m
CONFIG_IP_SET_HASH_IPMARK=m
CONFIG_IP_SET_HASH_IPPORT=m
CONFIG_IP_SET_HASH_IPPORTIP=m
CONFIG_IP_SET_HASH_IPPORTNET=m
# CONFIG_IP_SET_HASH_IPMAC is not set
CONFIG_IP_SET_HASH_MAC=m
CONFIG_IP_SET_HASH_NETPORTNET=m
CONFIG_IP_SET_HASH_NET=m
CONFIG_IP_SET_HASH_NETNET=m
CONFIG_IP_SET_HASH_NETPORT=m
CONFIG_IP_SET_HASH_NETIFACE=m
CONFIG_IP_SET_LIST_SET=m
CONFIG_IP_VS=m
CONFIG_IP_VS_IPV6=y
CONFIG_IP_VS_DEBUG=y
CONFIG_IP_VS_TAB_BITS=12
# IPVS transport protocol load balancing support
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
CONFIG_IP_VS_PROTO_AH_ESP=y
CONFIG_IP_VS_PROTO_ESP=y
CONFIG_IP_VS_PROTO_AH=y
CONFIG_IP_VS_PROTO_SCTP=y
# IPVS scheduler
CONFIG_IP_VS_RR=m
CONFIG_IP_VS_WRR=m
CONFIG_IP_VS_LC=m
CONFIG_IP_VS_WLC=m
CONFIG_IP_VS_FO=m
CONFIG_IP_VS_OVF=m
CONFIG_IP_VS_LBLC=m
CONFIG_IP_VS_LBLCR=m
CONFIG_IP_VS_DH=m
CONFIG_IP_VS_SH=m
CONFIG_IP_VS_SED=m
CONFIG_IP_VS_NQ=m
# IPVS SH scheduler
CONFIG_IP_VS_SH_TAB_BITS=8
# IPVS application helper
CONFIG_IP_VS_FTP=m
CONFIG_IP_VS_NFCT=y
CONFIG_IP_VS_PE_SIP=m
# IP: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV4=m
CONFIG_NF_CONNTRACK_IPV4=m
# CONFIG_NF_SOCKET_IPV4 is not set
CONFIG_NF_TABLES_IPV4=m
CONFIG_NFT_CHAIN_ROUTE_IPV4=m
CONFIG_NFT_REJECT_IPV4=m
CONFIG_NFT_DUP_IPV4=m
# CONFIG_NFT_FIB_IPV4 is not set
CONFIG_NF_TABLES_ARP=m
CONFIG_NF_DUP_IPV4=m
CONFIG_NF_LOG_ARP=m
CONFIG_NF_LOG_IPV4=m
CONFIG_NF_REJECT_IPV4=m
CONFIG_NF_NAT_IPV4=m
CONFIG_NFT_CHAIN_NAT_IPV4=m
CONFIG_NF_NAT_MASQUERADE_IPV4=m
CONFIG_NFT_MASQ_IPV4=m
CONFIG_NFT_REDIR_IPV4=m
CONFIG_NF_NAT_SNMP_BASIC=m
CONFIG_NF_NAT_PROTO_GRE=m
CONFIG_NF_NAT_PPTP=m
CONFIG_NF_NAT_H323=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_MATCH_AH=m
CONFIG_IP_NF_MATCH_ECN=m
CONFIG_IP_NF_MATCH_RPFILTER=m
CONFIG_IP_NF_MATCH_TTL=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_TARGET_SYNPROXY=m
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_TARGET_NETMAP=m
CONFIG_IP_NF_TARGET_REDIRECT=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP_NF_TARGET_CLUSTERIP=m
CONFIG_IP_NF_TARGET_ECN=m
CONFIG_IP_NF_TARGET_TTL=m
CONFIG_IP_NF_RAW=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
# IPv6: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV6=m
CONFIG_NF_CONNTRACK_IPV6=m
# CONFIG_NF_SOCKET_IPV6 is not set
CONFIG_NF_TABLES_IPV6=m
CONFIG_NFT_CHAIN_ROUTE_IPV6=m
CONFIG_NFT_CHAIN_NAT_IPV6=m
CONFIG_NFT_MASQ_IPV6=m
CONFIG_NFT_REDIR_IPV6=m
CONFIG_NFT_REJECT_IPV6=m
CONFIG_NFT_DUP_IPV6=m
# CONFIG_NFT_FIB_IPV6 is not set
CONFIG_NF_DUP_IPV6=m
CONFIG_NF_REJECT_IPV6=m
CONFIG_NF_LOG_IPV6=m
CONFIG_NF_NAT_IPV6=m
CONFIG_NF_NAT_MASQUERADE_IPV6=m
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_MATCH_AH=m
CONFIG_IP6_NF_MATCH_EUI64=m
CONFIG_IP6_NF_MATCH_FRAG=m
CONFIG_IP6_NF_MATCH_OPTS=m
CONFIG_IP6_NF_MATCH_HL=m
CONFIG_IP6_NF_MATCH_IPV6HEADER=m
CONFIG_IP6_NF_MATCH_MH=m
CONFIG_IP6_NF_MATCH_RPFILTER=m
CONFIG_IP6_NF_MATCH_RT=m
CONFIG_IP6_NF_TARGET_HL=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_REJECT=m
CONFIG_IP6_NF_TARGET_SYNPROXY=m
CONFIG_IP6_NF_MANGLE=m
CONFIG_IP6_NF_RAW=m
CONFIG_IP6_NF_NAT=m
CONFIG_IP6_NF_TARGET_MASQUERADE=m
CONFIG_IP6_NF_TARGET_NPT=m
# DECnet: Netfilter Configuration
# CONFIG_DECNET_NF_GRABULATOR is not set
CONFIG_NF_TABLES_BRIDGE=m
CONFIG_NFT_BRIDGE_META=m
CONFIG_NFT_BRIDGE_REJECT=m
CONFIG_NF_LOG_BRIDGE=m
CONFIG_BRIDGE_NF_EBTABLES=m
CONFIG_BRIDGE_EBT_BROUTE=m
CONFIG_BRIDGE_EBT_T_FILTER=m
CONFIG_BRIDGE_EBT_T_NAT=m
CONFIG_BRIDGE_EBT_802_3=m
CONFIG_BRIDGE_EBT_AMONG=m
CONFIG_BRIDGE_EBT_ARP=m
CONFIG_BRIDGE_EBT_IP=m
CONFIG_BRIDGE_EBT_IP6=m
CONFIG_BRIDGE_EBT_LIMIT=m
CONFIG_BRIDGE_EBT_MARK=m
CONFIG_BRIDGE_EBT_PKTTYPE=m
CONFIG_BRIDGE_EBT_STP=m
CONFIG_BRIDGE_EBT_VLAN=m
CONFIG_BRIDGE_EBT_ARPREPLY=m
CONFIG_BRIDGE_EBT_DNAT=m
CONFIG_BRIDGE_EBT_MARK_T=m
CONFIG_BRIDGE_EBT_REDIRECT=m
CONFIG_BRIDGE_EBT_SNAT=m
CONFIG_BRIDGE_EBT_LOG=m
CONFIG_BRIDGE_EBT_NFLOG=m
# CONFIG_IP_DCCP is not set
CONFIG_IP_SCTP=m
# CONFIG_SCTP_DBG_OBJCNT is not set
CONFIG_SCTP_DEFAULT_COOKIE_HMAC_MD5=y
# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_SHA1 is not set
# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_NONE is not set
CONFIG_SCTP_COOKIE_HMAC_MD5=y
# CONFIG_SCTP_COOKIE_HMAC_SHA1 is not set
CONFIG_INET_SCTP_DIAG=m
CONFIG_RDS=m
CONFIG_RDS_TCP=m
# CONFIG_RDS_DEBUG is not set
# CONFIG_TIPC is not set
CONFIG_ATM=m
CONFIG_ATM_CLIP=m
CONFIG_ATM_CLIP_NO_ICMP=y
CONFIG_ATM_LANE=m
CONFIG_ATM_MPOA=m
CONFIG_ATM_BR2684=m
CONFIG_ATM_BR2684_IPFILTER=y
CONFIG_L2TP=m
CONFIG_L2TP_DEBUGFS=m
CONFIG_L2TP_V3=y
CONFIG_L2TP_IP=m
CONFIG_L2TP_ETH=m
CONFIG_STP=m
CONFIG_GARP=m
CONFIG_MRP=m
CONFIG_BRIDGE=m
CONFIG_BRIDGE_IGMP_SNOOPING=y
CONFIG_BRIDGE_VLAN_FILTERING=y
CONFIG_HAVE_NET_DSA=y
# CONFIG_NET_DSA is not set
CONFIG_VLAN_8021Q=m
CONFIG_VLAN_8021Q_GVRP=y
CONFIG_VLAN_8021Q_MVRP=y
CONFIG_DECNET=m
CONFIG_DECNET_ROUTER=y
CONFIG_LLC=m
CONFIG_LLC2=m
CONFIG_IPX=m
CONFIG_IPX_INTERN=y
CONFIG_ATALK=m
CONFIG_DEV_APPLETALK=m
CONFIG_IPDDP=m
CONFIG_IPDDP_ENCAP=y
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_PHONET is not set
CONFIG_6LOWPAN=m
# CONFIG_6LOWPAN_DEBUGFS is not set
CONFIG_6LOWPAN_NHC=m
CONFIG_6LOWPAN_NHC_DEST=m
CONFIG_6LOWPAN_NHC_FRAGMENT=m
CONFIG_6LOWPAN_NHC_HOP=m
CONFIG_6LOWPAN_NHC_IPV6=m
CONFIG_6LOWPAN_NHC_MOBILITY=m
CONFIG_6LOWPAN_NHC_ROUTING=m
CONFIG_6LOWPAN_NHC_UDP=m
CONFIG_6LOWPAN_GHC_EXT_HDR_HOP=m
CONFIG_6LOWPAN_GHC_UDP=m
CONFIG_6LOWPAN_GHC_ICMPV6=m
CONFIG_6LOWPAN_GHC_EXT_HDR_DEST=m
CONFIG_6LOWPAN_GHC_EXT_HDR_FRAG=m
CONFIG_6LOWPAN_GHC_EXT_HDR_ROUTE=m
CONFIG_IEEE802154=m
CONFIG_IEEE802154_NL802154_EXPERIMENTAL=y
CONFIG_IEEE802154_SOCKET=m
CONFIG_IEEE802154_6LOWPAN=m
CONFIG_MAC802154=m
CONFIG_NET_SCHED=y
# Queueing/Scheduling
CONFIG_NET_SCH_CBQ=m
CONFIG_NET_SCH_HTB=m
CONFIG_NET_SCH_HFSC=m
CONFIG_NET_SCH_ATM=m
CONFIG_NET_SCH_PRIO=m
CONFIG_NET_SCH_MULTIQ=m
CONFIG_NET_SCH_RED=m
CONFIG_NET_SCH_SFB=m
CONFIG_NET_SCH_SFQ=m
CONFIG_NET_SCH_TEQL=m
CONFIG_NET_SCH_TBF=m
CONFIG_NET_SCH_GRED=m
CONFIG_NET_SCH_DSMARK=m
CONFIG_NET_SCH_NETEM=m
CONFIG_NET_SCH_DRR=m
CONFIG_NET_SCH_MQPRIO=m
CONFIG_NET_SCH_CHOKE=m
CONFIG_NET_SCH_QFQ=m
CONFIG_NET_SCH_CODEL=m
CONFIG_NET_SCH_FQ_CODEL=m
CONFIG_NET_SCH_FQ=m
CONFIG_NET_SCH_HHF=m
CONFIG_NET_SCH_PIE=m
CONFIG_NET_SCH_INGRESS=m
CONFIG_NET_SCH_PLUG=m
CONFIG_NET_SCH_DEFAULT=y
CONFIG_DEFAULT_FQ=y
# CONFIG_DEFAULT_CODEL is not set
# CONFIG_DEFAULT_FQ_CODEL is not set
# CONFIG_DEFAULT_SFQ is not set
# CONFIG_DEFAULT_PFIFO_FAST is not set
CONFIG_DEFAULT_NET_SCH="fq"
# Classification
CONFIG_NET_CLS=y
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_TCINDEX=m
CONFIG_NET_CLS_ROUTE4=m
CONFIG_NET_CLS_FW=m
CONFIG_NET_CLS_U32=m
CONFIG_CLS_U32_PERF=y
CONFIG_CLS_U32_MARK=y
CONFIG_NET_CLS_RSVP=m
CONFIG_NET_CLS_RSVP6=m
CONFIG_NET_CLS_FLOW=m
CONFIG_NET_CLS_CGROUP=m
CONFIG_NET_CLS_BPF=m
CONFIG_NET_CLS_FLOWER=m
CONFIG_NET_CLS_MATCHALL=m
CONFIG_NET_EMATCH=y
CONFIG_NET_EMATCH_STACK=32
CONFIG_NET_EMATCH_CMP=m
CONFIG_NET_EMATCH_NBYTE=m
CONFIG_NET_EMATCH_U32=m
CONFIG_NET_EMATCH_META=m
CONFIG_NET_EMATCH_TEXT=m
# CONFIG_NET_EMATCH_CANID is not set
CONFIG_NET_EMATCH_IPSET=m
CONFIG_NET_CLS_ACT=y
CONFIG_NET_ACT_POLICE=m
CONFIG_NET_ACT_GACT=m
CONFIG_GACT_PROB=y
CONFIG_NET_ACT_MIRRED=m
# CONFIG_NET_ACT_SAMPLE is not set
CONFIG_NET_ACT_IPT=m
CONFIG_NET_ACT_NAT=m
CONFIG_NET_ACT_PEDIT=m
CONFIG_NET_ACT_SIMP=m
CONFIG_NET_ACT_SKBEDIT=m
CONFIG_NET_ACT_CSUM=m
CONFIG_NET_ACT_VLAN=m
CONFIG_NET_ACT_BPF=m
CONFIG_NET_ACT_CONNMARK=m
CONFIG_NET_ACT_SKBMOD=m
CONFIG_NET_ACT_IFE=m
CONFIG_NET_ACT_TUNNEL_KEY=m
CONFIG_NET_IFE_SKBMARK=m
CONFIG_NET_IFE_SKBPRIO=m
CONFIG_NET_IFE_SKBTCINDEX=m
CONFIG_NET_CLS_IND=y
CONFIG_NET_SCH_FIFO=y
# CONFIG_DCB is not set
CONFIG_DNS_RESOLVER=y
CONFIG_BATMAN_ADV=m
CONFIG_BATMAN_ADV_BATMAN_V=y
CONFIG_BATMAN_ADV_BLA=y
CONFIG_BATMAN_ADV_DAT=y
CONFIG_BATMAN_ADV_NC=y
CONFIG_BATMAN_ADV_MCAST=y
CONFIG_BATMAN_ADV_DEBUGFS=y
# CONFIG_BATMAN_ADV_DEBUG is not set
CONFIG_OPENVSWITCH=m
CONFIG_OPENVSWITCH_GRE=m
CONFIG_OPENVSWITCH_VXLAN=m
CONFIG_VSOCKETS=m
CONFIG_NETLINK_DIAG=m
CONFIG_MPLS=y
CONFIG_NET_MPLS_GSO=m
# CONFIG_MPLS_ROUTING is not set
# CONFIG_NET_NSH is not set
# CONFIG_HSR is not set
# CONFIG_NET_SWITCHDEV is not set
CONFIG_NET_L3_MASTER_DEV=y
# CONFIG_NET_NCSI is not set
CONFIG_RPS=y
CONFIG_RFS_ACCEL=y
CONFIG_XPS=y
CONFIG_CGROUP_NET_PRIO=y
CONFIG_CGROUP_NET_CLASSID=y
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
# CONFIG_BPF_JIT is not set
# CONFIG_BPF_STREAM_PARSER is not set
CONFIG_NET_FLOW_LIMIT=y
# Network testing
CONFIG_NET_PKTGEN=m
CONFIG_NET_DROP_MONITOR=m
CONFIG_HAMRADIO=y
# Packet Radio protocols
# CONFIG_AX25 is not set
CONFIG_CAN=m
CONFIG_CAN_RAW=m
CONFIG_CAN_BCM=m
CONFIG_CAN_GW=m
# CAN Device Drivers
# CONFIG_CAN_VCAN is not set
# CONFIG_CAN_VXCAN is not set
CONFIG_CAN_SLCAN=m
CONFIG_CAN_DEV=m
CONFIG_CAN_CALC_BITTIMING=y
# CONFIG_CAN_LEDS is not set
# CONFIG_CAN_FLEXCAN is not set
# CONFIG_CAN_GRCAN is not set
# CONFIG_CAN_TI_HECC is not set
# CONFIG_CAN_C_CAN is not set
# CONFIG_CAN_CC770 is not set
# CONFIG_CAN_IFI_CANFD is not set
# CONFIG_CAN_M_CAN is not set
# CONFIG_CAN_RCAR is not set
# CONFIG_CAN_RCAR_CANFD is not set
# CONFIG_CAN_SJA1000 is not set
# CONFIG_CAN_SOFTING is not set
# CAN SPI interfaces
# CONFIG_CAN_HI311X is not set
CONFIG_CAN_MCP251X=m
# CAN USB interfaces
CONFIG_CAN_EMS_USB=m
CONFIG_CAN_ESD_USB2=m
CONFIG_CAN_GS_USB=m
CONFIG_CAN_KVASER_USB=m
CONFIG_CAN_PEAK_USB=m
CONFIG_CAN_8DEV_USB=m
# CONFIG_CAN_MCBA_USB is not set
# CONFIG_CAN_DEBUG_DEVICES is not set
CONFIG_BT=m
CONFIG_BT_BREDR=y
CONFIG_BT_RFCOMM=m
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=m
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HIDP=m
CONFIG_BT_HS=y
CONFIG_BT_LE=y
CONFIG_BT_6LOWPAN=m
CONFIG_BT_LEDS=y
CONFIG_BT_DEBUGFS=y
# Bluetooth device drivers
CONFIG_BT_INTEL=m
CONFIG_BT_BCM=m
CONFIG_BT_RTL=m
CONFIG_BT_QCA=m
CONFIG_BT_HCIBTUSB=m
CONFIG_BT_HCIBTUSB_BCM=y
CONFIG_BT_HCIBTUSB_RTL=y
CONFIG_BT_HCIBTSDIO=m
CONFIG_BT_HCIUART=m
CONFIG_BT_HCIUART_H4=y
CONFIG_BT_HCIUART_BCSP=y
CONFIG_BT_HCIUART_ATH3K=y
CONFIG_BT_HCIUART_INTEL=y
CONFIG_BT_HCIUART_QCA=y
CONFIG_BT_HCIUART_AG6XX=y
CONFIG_BT_HCIUART_MRVL=y
CONFIG_BT_HCIBCM203X=m
CONFIG_BT_HCIBPA10X=m
CONFIG_BT_HCIBFUSB=m
CONFIG_BT_HCIVHCI=m
CONFIG_BT_MRVL=m
# CONFIG_BT_MRVL_SDIO is not set
CONFIG_BT_ATH3K=m
# CONFIG_AF_RXRPC is not set
# CONFIG_AF_KCM is not set
# CONFIG_STREAM_PARSER is not set
CONFIG_FIB_RULES=y
CONFIG_WIRELESS=y
CONFIG_WIRELESS_EXT=y
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
CONFIG_WEXT_SPY=y
CONFIG_WEXT_PRIV=y
CONFIG_CFG80211=m
# CONFIG_NL80211_TESTMODE is not set
# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
CONFIG_CFG80211_DEFAULT_PS=y
# CONFIG_CFG80211_DEBUGFS is not set
# CONFIG_CFG80211_INTERNAL_REGDB is not set
CONFIG_CFG80211_CRDA_SUPPORT=y
CONFIG_CFG80211_WEXT=y
CONFIG_LIB80211=m
# CONFIG_LIB80211_DEBUG is not set
CONFIG_MAC80211=m
CONFIG_MAC80211_HAS_RC=y
CONFIG_MAC80211_RC_MINSTREL=y
CONFIG_MAC80211_RC_MINSTREL_HT=y
# CONFIG_MAC80211_RC_MINSTREL_VHT is not set
CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
CONFIG_MAC80211_MESH=y
CONFIG_MAC80211_LEDS=y
CONFIG_MAC80211_DEBUGFS=y
# CONFIG_MAC80211_MESSAGE_TRACING is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
# CONFIG_WIMAX is not set
CONFIG_RFKILL=m
CONFIG_RFKILL_LEDS=y
CONFIG_RFKILL_INPUT=y
# CONFIG_RFKILL_GPIO is not set
# CONFIG_NET_9P is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
CONFIG_NFC=m
CONFIG_NFC_DIGITAL=m
# CONFIG_NFC_NCI is not set
CONFIG_NFC_HCI=m
# CONFIG_NFC_SHDLC is not set
# Near Field Communication (NFC) devices
# CONFIG_NFC_TRF7970A is not set
# CONFIG_NFC_SIM is not set
# CONFIG_NFC_PORT100 is not set
CONFIG_NFC_PN533=m
CONFIG_NFC_PN533_USB=m
# CONFIG_NFC_PN533_I2C is not set
# CONFIG_NFC_ST95HF is not set
# CONFIG_PSAMPLE is not set
CONFIG_NET_IFE=m
CONFIG_LWTUNNEL=y
CONFIG_LWTUNNEL_BPF=y
CONFIG_DST_CACHE=y
CONFIG_GRO_CELLS=y
CONFIG_NET_DEVLINK=m
CONFIG_MAY_USE_DEVLINK=m
CONFIG_HAVE_EBPF_JIT=y
# Device Drivers
CONFIG_ARM_AMBA=y
# Generic Driver Options
CONFIG_UEVENT_HELPER=y
CONFIG_UEVENT_HELPER_PATH=""
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
# CONFIG_PREVENT_FIRMWARE_BUILD is not set
CONFIG_FW_LOADER=y
CONFIG_FIRMWARE_IN_KERNEL=y
CONFIG_EXTRA_FIRMWARE="edid/480x320.bin edid/1920x1080_24hz.bin edid/1920x1080_23_976hz.bin edid/848x480.bin edid/1152x864_75hz.bin edid/1280x768.bin edid/1920x800.bin edid/1400x1050.bin edid/1792x1344.bin edid/1024x768.bin edid/1280x800.bin edid/1920x1080.bin edid/720x480.bin edid/800x600.bin edid/800x480.bin edid/480x800.bin edid/1280x1024.bin edid/1280x720.bin edid/1440x900.bin edid/1680x1050.bin edid/1360x768.bin edid/1366x768.bin edid/1600x1200.bin edid/1600x900.bin edid/1920x1200_30hz.bin edid/1920x1200_60hz.bin edid/1920x1080_50hz.bin edid/640x480.bin edid/720x576.bin edid/1024x600.bin edid/720x1280_61.bin edid/480x272.bin edid/1080x1920_55.bin"
CONFIG_EXTRA_FIRMWARE_DIR="firmware"
# CONFIG_FW_LOADER_USER_HELPER_FALLBACK is not set
CONFIG_WANT_DEV_COREDUMP=y
CONFIG_ALLOW_DEV_COREDUMP=y
CONFIG_DEV_COREDUMP=y
# CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
# CONFIG_SYS_HYPERVISOR is not set
# CONFIG_GENERIC_CPU_DEVICES is not set
CONFIG_GENERIC_CPU_AUTOPROBE=y
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=y
CONFIG_REGMAP_SPI=y
CONFIG_REGMAP_MMIO=y
CONFIG_REGMAP_IRQ=y
CONFIG_DMA_SHARED_BUFFER=y
# CONFIG_DMA_FENCE_TRACE is not set
CONFIG_DMA_CMA=y
# Default contiguous memory area size:
CONFIG_CMA_SIZE_MBYTES=128
CONFIG_CMA_SIZE_SEL_MBYTES=y
# CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
# CONFIG_CMA_SIZE_SEL_MIN is not set
# CONFIG_CMA_SIZE_SEL_MAX is not set
CONFIG_CMA_ALIGNMENT=8
CONFIG_GENERIC_ARCH_TOPOLOGY=y
# Bus devices
CONFIG_ARM_CCI=y
CONFIG_ARM_CCI400_COMMON=y
# CONFIG_ARM_CCI400_PMU is not set
CONFIG_ARM_CCI400_PORT_CTRL=y
# CONFIG_ARM_CCI5xx_PMU is not set
# CONFIG_ARM_CCN is not set
# CONFIG_BRCMSTB_GISB_ARB is not set
# CONFIG_SIMPLE_PM_BUS is not set
# CONFIG_VEXPRESS_CONFIG is not set
# CONFIG_CONNECTOR is not set
# CONFIG_MTD is not set
CONFIG_DTC=y
CONFIG_OF=y
# CONFIG_OF_UNITTEST is not set
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_NET=y
CONFIG_OF_MDIO=y
CONFIG_OF_RESERVED_MEM=y
# CONFIG_OF_OVERLAY is not set
CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
CONFIG_PARPORT=m
# CONFIG_PARPORT_PC is not set
# CONFIG_PARPORT_GSC is not set
# CONFIG_PARPORT_AX88796 is not set
# CONFIG_PARPORT_1284 is not set
CONFIG_BLK_DEV=y
CONFIG_BLK_DEV_NULL_BLK=m
CONFIG_ZRAM=m
CONFIG_ZRAM_WRITEBACK=y
# CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=m
CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
CONFIG_BLK_DEV_CRYPTOLOOP=m
CONFIG_BLK_DEV_DRBD=m
# CONFIG_DRBD_FAULT_INJECTION is not set
CONFIG_BLK_DEV_NBD=m
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=16384
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# CONFIG_BLK_DEV_RBD is not set
# CONFIG_NVME_FC is not set
# CONFIG_NVME_TARGET is not set
# Misc devices
# CONFIG_SENSORS_LIS3LV02D is not set
# CONFIG_AD525X_DPOT is not set
# CONFIG_DUMMY_IRQ is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_TI_DAC7512 is not set
# CONFIG_USB_SWITCH_FSA9480 is not set
# CONFIG_LATTICE_ECP3_CONFIG is not set
CONFIG_SRAM=y
CONFIG_SRAM_EXEC=y
# CONFIG_C2PORT is not set
# EEPROM support
# CONFIG_EEPROM_AT24 is not set
# CONFIG_EEPROM_AT25 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
CONFIG_EEPROM_93CX6=m
# CONFIG_EEPROM_93XX46 is not set
# CONFIG_EEPROM_IDT_89HPESX is not set
# Texas Instruments shared transport line discipline
# CONFIG_TI_ST is not set
# CONFIG_SENSORS_LIS3_SPI is not set
# CONFIG_SENSORS_LIS3_I2C is not set
# Altera FPGA firmware download module
# CONFIG_ALTERA_STAPL is not set
# Intel MIC Bus Driver
# SCIF Bus Driver
# VOP Bus Driver
# Intel MIC Host Driver
# Intel MIC Card Driver
# SCIF Driver
# Intel MIC Coprocessor State Management (COSM) Drivers
# VOP Driver
# CONFIG_ECHO is not set
# CONFIG_CXL_BASE is not set
# CONFIG_CXL_AFU_DRIVER_OPS is not set
# CONFIG_CXL_LIB is not set
# SCSI device support
CONFIG_SCSI_MOD=m
CONFIG_RAID_ATTRS=m
CONFIG_SCSI=m
CONFIG_SCSI_DMA=y
# CONFIG_SCSI_NETLINK is not set
# CONFIG_SCSI_MQ_DEFAULT is not set
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=m
CONFIG_CHR_DEV_ST=m
CONFIG_CHR_DEV_OSST=m
CONFIG_BLK_DEV_SR=m
CONFIG_BLK_DEV_SR_VENDOR=y
CONFIG_CHR_DEV_SG=m
CONFIG_CHR_DEV_SCH=m
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
CONFIG_SCSI_SCAN_ASYNC=y
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
CONFIG_SCSI_ISCSI_ATTRS=m
# CONFIG_SCSI_SAS_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
CONFIG_SCSI_LOWLEVEL=y
CONFIG_ISCSI_TCP=m
CONFIG_ISCSI_BOOT_SYSFS=m
# CONFIG_SCSI_UFSHCD is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_DH is not set
# CONFIG_SCSI_OSD_INITIATOR is not set
# CONFIG_ATA is not set
CONFIG_MD=y
CONFIG_BLK_DEV_MD=m
CONFIG_MD_LINEAR=m
CONFIG_MD_RAID0=m
CONFIG_MD_RAID1=m
CONFIG_MD_RAID10=m
CONFIG_MD_RAID456=m
CONFIG_MD_MULTIPATH=m
CONFIG_MD_FAULTY=m
CONFIG_BCACHE=m
# CONFIG_BCACHE_DEBUG is not set
# CONFIG_BCACHE_CLOSURES_DEBUG is not set
CONFIG_BLK_DEV_DM_BUILTIN=y
CONFIG_BLK_DEV_DM=y
CONFIG_DM_MQ_DEFAULT=y
# CONFIG_DM_DEBUG is not set
CONFIG_DM_BUFIO=m
CONFIG_DM_DEBUG_BLOCK_MANAGER_LOCKING=y
CONFIG_DM_DEBUG_BLOCK_STACK_TRACING=y
CONFIG_DM_BIO_PRISON=m
CONFIG_DM_PERSISTENT_DATA=m
CONFIG_DM_CRYPT=m
CONFIG_DM_SNAPSHOT=m
CONFIG_DM_THIN_PROVISIONING=m
CONFIG_DM_CACHE=m
CONFIG_DM_CACHE_SMQ=m
CONFIG_DM_ERA=m
CONFIG_DM_MIRROR=m
# CONFIG_DM_LOG_USERSPACE is not set
CONFIG_DM_RAID=m
CONFIG_DM_ZERO=m
CONFIG_DM_MULTIPATH=m
CONFIG_DM_MULTIPATH_QL=m
CONFIG_DM_MULTIPATH_ST=m
CONFIG_DM_DELAY=m
CONFIG_DM_UEVENT=y
CONFIG_DM_FLAKEY=m
CONFIG_DM_VERITY=m
CONFIG_DM_VERITY_FEC=y
CONFIG_DM_SWITCH=m
CONFIG_DM_LOG_WRITES=m
CONFIG_DM_INTEGRITY=m
CONFIG_DM_ZONED=m
CONFIG_TARGET_CORE=m
CONFIG_TCM_IBLOCK=m
CONFIG_TCM_FILEIO=m
CONFIG_TCM_PSCSI=m
CONFIG_TCM_USER2=m
CONFIG_LOOPBACK_TARGET=m
CONFIG_ISCSI_TARGET=m
CONFIG_NETDEVICES=y
CONFIG_MII=y
CONFIG_NET_CORE=y
CONFIG_BONDING=m
CONFIG_DUMMY=m
# CONFIG_EQUALIZER is not set
CONFIG_IFB=m
CONFIG_NET_TEAM=m
CONFIG_NET_TEAM_MODE_BROADCAST=m
CONFIG_NET_TEAM_MODE_ROUNDROBIN=m
CONFIG_NET_TEAM_MODE_RANDOM=m
CONFIG_NET_TEAM_MODE_ACTIVEBACKUP=m
CONFIG_NET_TEAM_MODE_LOADBALANCE=m
CONFIG_MACVLAN=m
CONFIG_MACVTAP=m
CONFIG_IPVLAN=m
# CONFIG_IPVTAP is not set
CONFIG_VXLAN=m
# CONFIG_GENEVE is not set
# CONFIG_GTP is not set
CONFIG_MACSEC=m
CONFIG_NETCONSOLE=m
CONFIG_NETCONSOLE_DYNAMIC=y
CONFIG_NETPOLL=y
CONFIG_NET_POLL_CONTROLLER=y
CONFIG_TUN=m
CONFIG_TAP=m
# CONFIG_TUN_VNET_CROSS_LE is not set
CONFIG_VETH=m
# CONFIG_NLMON is not set
# CONFIG_NET_VRF is not set
CONFIG_ATM_DRIVERS=y
CONFIG_ATM_DUMMY=m
CONFIG_ATM_TCP=m
# CAIF transport drivers
# Distributed Switch Architecture drivers
CONFIG_ETHERNET=y
CONFIG_NET_VENDOR_ALACRITECH=y
# CONFIG_ALTERA_TSE is not set
CONFIG_NET_VENDOR_AMAZON=y
CONFIG_NET_VENDOR_AQUANTIA=y
# CONFIG_NET_VENDOR_ARC is not set
# CONFIG_NET_VENDOR_AURORA is not set
# CONFIG_NET_CADENCE is not set
# CONFIG_NET_VENDOR_BROADCOM is not set
# CONFIG_NET_VENDOR_CIRRUS is not set
# CONFIG_DM9000 is not set
# CONFIG_DNET is not set
# CONFIG_NET_VENDOR_EZCHIP is not set
# CONFIG_NET_VENDOR_FARADAY is not set
# CONFIG_NET_VENDOR_HISILICON is not set
CONFIG_NET_VENDOR_HUAWEI=y
# CONFIG_NET_VENDOR_INTEL is not set
# CONFIG_NET_VENDOR_MARVELL is not set
CONFIG_NET_VENDOR_MELLANOX=y
# CONFIG_MLXSW_CORE is not set
# CONFIG_MLXFW is not set
# CONFIG_NET_VENDOR_MICREL is not set
# CONFIG_NET_VENDOR_MICROCHIP is not set
# CONFIG_NET_VENDOR_NATSEMI is not set
# CONFIG_NET_VENDOR_NETRONOME is not set
# CONFIG_ETHOC is not set
# CONFIG_NET_VENDOR_QUALCOMM is not set
# CONFIG_NET_VENDOR_RENESAS is not set
# CONFIG_NET_VENDOR_ROCKER is not set
# CONFIG_NET_VENDOR_SAMSUNG is not set
CONFIG_NET_VENDOR_SEEQ=y
CONFIG_NET_VENDOR_SOLARFLARE=y
CONFIG_NET_VENDOR_SMSC=y
# CONFIG_SMC91X is not set
# CONFIG_SMC911X is not set
CONFIG_SMSC911X=y
# CONFIG_SMSC911X_ARCH_HOOKS is not set
CONFIG_NET_VENDOR_STMICRO=y
# CONFIG_STMMAC_ETH is not set
CONFIG_NET_VENDOR_VIA=y
# CONFIG_VIA_RHINE is not set
# CONFIG_VIA_VELOCITY is not set
CONFIG_NET_VENDOR_WIZNET=y
# CONFIG_WIZNET_W5100 is not set
# CONFIG_WIZNET_W5300 is not set
CONFIG_NET_VENDOR_SYNOPSYS=y
# CONFIG_DWC_XLGMAC is not set
CONFIG_MDIO_DEVICE=y
CONFIG_MDIO_BUS=y
# CONFIG_MDIO_BCM_UNIMAC is not set
# CONFIG_MDIO_BITBANG is not set
# CONFIG_MDIO_BUS_MUX_GPIO is not set
# CONFIG_MDIO_BUS_MUX_MMIOREG is not set
# CONFIG_MDIO_HISI_FEMAC is not set
CONFIG_PHYLIB=y
CONFIG_SWPHY=y
# CONFIG_LED_TRIGGER_PHY is not set
# MII PHY device drivers
# CONFIG_AMD_PHY is not set
# CONFIG_AQUANTIA_PHY is not set
# CONFIG_AT803X_PHY is not set
# CONFIG_BCM7XXX_PHY is not set
# CONFIG_BCM87XX_PHY is not set
# CONFIG_BROADCOM_PHY is not set
# CONFIG_CICADA_PHY is not set
# CONFIG_CORTINA_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_DP83848_PHY is not set
# CONFIG_DP83867_PHY is not set
CONFIG_FIXED_PHY=y
# CONFIG_ICPLUS_PHY is not set
# CONFIG_INTEL_XWAY_PHY is not set
# CONFIG_LSI_ET1011C_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_MARVELL_PHY is not set
# CONFIG_MARVELL_10G_PHY is not set
# CONFIG_MICREL_PHY is not set
CONFIG_MICROCHIP_PHY=m
# CONFIG_MICROSEMI_PHY is not set
# CONFIG_NATIONAL_PHY is not set
# CONFIG_QSEMI_PHY is not set
# CONFIG_REALTEK_PHY is not set
# CONFIG_ROCKCHIP_PHY is not set
# CONFIG_SMSC_PHY is not set
# CONFIG_STE10XP is not set
# CONFIG_TERANETICS_PHY is not set
# CONFIG_VITESSE_PHY is not set
# CONFIG_XILINX_GMII2RGMII is not set
# CONFIG_MICREL_KS8995MA is not set
CONFIG_PLIP=m
CONFIG_PPP=m
CONFIG_PPP_BSDCOMP=m
CONFIG_PPP_DEFLATE=m
CONFIG_PPP_FILTER=y
CONFIG_PPP_MPPE=m
CONFIG_PPP_MULTILINK=y
CONFIG_PPPOATM=m
CONFIG_PPPOE=m
CONFIG_PPTP=m
CONFIG_PPPOL2TP=m
CONFIG_PPP_ASYNC=m
CONFIG_PPP_SYNC_TTY=m
# CONFIG_SLIP is not set
CONFIG_SLHC=m
CONFIG_USB_NET_DRIVERS=y
CONFIG_USB_CATC=m
CONFIG_USB_KAWETH=m
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
CONFIG_USB_RTL8152=y
CONFIG_USB_LAN78XX=m
CONFIG_USB_USBNET=y
CONFIG_USB_NET_AX8817X=m
CONFIG_USB_NET_AX88179_178A=m
CONFIG_USB_NET_CDCETHER=y
CONFIG_USB_NET_CDC_EEM=m
CONFIG_USB_NET_CDC_NCM=m
CONFIG_USB_NET_HUAWEI_CDC_NCM=m
CONFIG_USB_NET_CDC_MBIM=m
CONFIG_USB_NET_DM9601=m
CONFIG_USB_NET_SR9700=m
CONFIG_USB_NET_SR9800=m
CONFIG_USB_NET_SMSC75XX=m
CONFIG_USB_NET_SMSC95XX=m
CONFIG_USB_NET_GL620A=m
CONFIG_USB_NET_NET1080=m
CONFIG_USB_NET_PLUSB=m
CONFIG_USB_NET_MCS7830=m
CONFIG_USB_NET_RNDIS_HOST=m
CONFIG_USB_NET_CDC_SUBSET_ENABLE=y
CONFIG_USB_NET_CDC_SUBSET=y
CONFIG_USB_ALI_M5632=y
CONFIG_USB_AN2720=y
CONFIG_USB_BELKIN=y
CONFIG_USB_ARMLINUX=y
CONFIG_USB_EPSON2888=y
CONFIG_USB_KC2190=y
CONFIG_USB_NET_ZAURUS=m
CONFIG_USB_NET_CX82310_ETH=m
CONFIG_USB_NET_KALMIA=m
CONFIG_USB_NET_QMI_WWAN=m
CONFIG_USB_HSO=m
CONFIG_USB_NET_INT51X1=m
CONFIG_USB_IPHETH=m
CONFIG_USB_SIERRA_NET=m
CONFIG_USB_VL600=m
CONFIG_USB_NET_CH9200=m
CONFIG_WLAN=y
CONFIG_WLAN_VENDOR_ADMTEK=y
CONFIG_ATH_COMMON=m
CONFIG_WLAN_VENDOR_ATH=y
# CONFIG_ATH_DEBUG is not set
CONFIG_ATH9K_HW=m
CONFIG_ATH9K_COMMON=m
CONFIG_ATH9K_BTCOEX_SUPPORT=y
CONFIG_ATH9K=m
# CONFIG_ATH9K_AHB is not set
# CONFIG_ATH9K_DEBUGFS is not set
# CONFIG_ATH9K_DYNACK is not set
# CONFIG_ATH9K_WOW is not set
CONFIG_ATH9K_RFKILL=y
# CONFIG_ATH9K_CHANNEL_CONTEXT is not set
CONFIG_ATH9K_PCOEM=y
CONFIG_ATH9K_HTC=m
# CONFIG_ATH9K_HTC_DEBUGFS is not set
# CONFIG_ATH9K_HWRNG is not set
CONFIG_CARL9170=m
CONFIG_CARL9170_LEDS=y
# CONFIG_CARL9170_DEBUGFS is not set
CONFIG_CARL9170_WPC=y
CONFIG_CARL9170_HWRNG=y
# CONFIG_ATH6KL is not set
CONFIG_AR5523=m
CONFIG_ATH10K=m
# CONFIG_ATH10K_SDIO is not set
# CONFIG_ATH10K_USB is not set
# CONFIG_ATH10K_DEBUG is not set
# CONFIG_ATH10K_DEBUGFS is not set
# CONFIG_ATH10K_TRACING is not set
CONFIG_WCN36XX=m
# CONFIG_WCN36XX_DEBUGFS is not set
CONFIG_WLAN_VENDOR_ATMEL=y
CONFIG_AT76C50X_USB=m
CONFIG_WLAN_VENDOR_BROADCOM=y
# CONFIG_B43 is not set
# CONFIG_B43LEGACY is not set
CONFIG_BRCMUTIL=m
# CONFIG_BRCMSMAC is not set
CONFIG_BRCMFMAC=m
CONFIG_BRCMFMAC_PROTO_BCDC=y
# CONFIG_BRCMFMAC_SDIO is not set
CONFIG_BRCMFMAC_USB=y
# CONFIG_BRCM_TRACING is not set
# CONFIG_BRCMDBG is not set
CONFIG_WLAN_VENDOR_CISCO=y
CONFIG_WLAN_VENDOR_INTEL=y
CONFIG_WLAN_VENDOR_INTERSIL=y
# CONFIG_HOSTAP is not set
CONFIG_P54_COMMON=m
CONFIG_P54_USB=m
# CONFIG_P54_SPI is not set
CONFIG_P54_LEDS=y
CONFIG_WLAN_VENDOR_MARVELL=y
CONFIG_LIBERTAS=m
CONFIG_LIBERTAS_USB=m
# CONFIG_LIBERTAS_SDIO is not set
# CONFIG_LIBERTAS_SPI is not set
# CONFIG_LIBERTAS_DEBUG is not set
# CONFIG_LIBERTAS_MESH is not set
CONFIG_LIBERTAS_THINFIRM=m
# CONFIG_LIBERTAS_THINFIRM_DEBUG is not set
CONFIG_LIBERTAS_THINFIRM_USB=m
CONFIG_MWIFIEX=m
# CONFIG_MWIFIEX_SDIO is not set
CONFIG_MWIFIEX_USB=m
CONFIG_WLAN_VENDOR_MEDIATEK=y
CONFIG_MT7601U=m
CONFIG_WLAN_VENDOR_RALINK=y
CONFIG_RT2X00=m
CONFIG_RT2500USB=m
CONFIG_RT73USB=m
CONFIG_RT2800USB=m
CONFIG_RT2800USB_RT33XX=y
CONFIG_RT2800USB_RT35XX=y
CONFIG_RT2800USB_RT3573=y
CONFIG_RT2800USB_RT53XX=y
CONFIG_RT2800USB_RT55XX=y
CONFIG_RT2800USB_UNKNOWN=y
CONFIG_RT2800_LIB=m
CONFIG_RT2X00_LIB_USB=m
CONFIG_RT2X00_LIB=m
CONFIG_RT2X00_LIB_FIRMWARE=y
CONFIG_RT2X00_LIB_CRYPTO=y
CONFIG_RT2X00_LIB_LEDS=y
# CONFIG_RT2X00_LIB_DEBUGFS is not set
# CONFIG_RT2X00_DEBUG is not set
CONFIG_WLAN_VENDOR_REALTEK=y
CONFIG_RTL8187=m
CONFIG_RTL8187_LEDS=y
CONFIG_RTL_CARDS=m
CONFIG_RTL8192CU=m
CONFIG_RTLWIFI=m
CONFIG_RTLWIFI_USB=m
CONFIG_RTLWIFI_DEBUG=y
CONFIG_RTL8192C_COMMON=m
CONFIG_RTL8XXXU=m
CONFIG_RTL8XXXU_UNTESTED=y
CONFIG_WLAN_VENDOR_RSI=y
# CONFIG_RSI_91X is not set
CONFIG_WLAN_VENDOR_ST=y
# CONFIG_CW1200 is not set
CONFIG_WLAN_VENDOR_TI=y
# CONFIG_WL1251 is not set
# CONFIG_WL12XX is not set
# CONFIG_WL18XX is not set
# CONFIG_WLCORE is not set
CONFIG_WLAN_VENDOR_ZYDAS=y
CONFIG_USB_ZD1201=m
CONFIG_ZD1211RW=m
# CONFIG_ZD1211RW_DEBUG is not set
CONFIG_WLAN_VENDOR_QUANTENNA=y
CONFIG_RTL8812AU=m
CONFIG_RTL8188EU=m
# CONFIG_MAC80211_HWSIM is not set
CONFIG_USB_NET_RNDIS_WLAN=m
# Enable WiMAX (Networking options) to see the WiMAX drivers
CONFIG_WAN=y
CONFIG_HDLC=m
CONFIG_HDLC_RAW=m
CONFIG_HDLC_RAW_ETH=m
CONFIG_HDLC_CISCO=m
CONFIG_HDLC_FR=m
CONFIG_HDLC_PPP=m
# X.25/LAPB support is disabled
CONFIG_DLCI=m
CONFIG_DLCI_MAX=8
CONFIG_IEEE802154_DRIVERS=m
# CONFIG_IEEE802154_FAKELB is not set
# CONFIG_IEEE802154_AT86RF230 is not set
# CONFIG_IEEE802154_MRF24J40 is not set
# CONFIG_IEEE802154_CC2520 is not set
# CONFIG_IEEE802154_ATUSB is not set
# CONFIG_IEEE802154_ADF7242 is not set
# CONFIG_IEEE802154_CA8210 is not set
# CONFIG_ISDN is not set
# CONFIG_NVM is not set
# Input device support
CONFIG_INPUT=y
CONFIG_INPUT_LEDS=m
CONFIG_INPUT_FF_MEMLESS=m
CONFIG_INPUT_POLLDEV=m
# CONFIG_INPUT_SPARSEKMAP is not set
CONFIG_INPUT_MATRIXKMAP=y
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
CONFIG_INPUT_JOYDEV=y
CONFIG_INPUT_EVDEV=m
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADC is not set
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
CONFIG_KEYBOARD_ATKBD=m
# CONFIG_KEYBOARD_QT1070 is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_DLINK_DIR685 is not set
# CONFIG_KEYBOARD_LKKBD is not set
CONFIG_KEYBOARD_GPIO=m
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
# CONFIG_KEYBOARD_MATRIX is not set
# CONFIG_KEYBOARD_LM8323 is not set
# CONFIG_KEYBOARD_LM8333 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
CONFIG_KEYBOARD_SAMSUNG=y
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_OMAP4 is not set
# CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_CROS_EC is not set
# CONFIG_KEYBOARD_CAP11XX is not set
# CONFIG_KEYBOARD_BCM is not set
CONFIG_INPUT_MOUSE=y
# CONFIG_MOUSE_PS2 is not set
# CONFIG_MOUSE_SERIAL is not set
CONFIG_MOUSE_APPLETOUCH=m
CONFIG_MOUSE_BCM5974=m
CONFIG_MOUSE_CYAPA=m
CONFIG_MOUSE_ELAN_I2C=m
CONFIG_MOUSE_ELAN_I2C_I2C=y
CONFIG_MOUSE_ELAN_I2C_SMBUS=y
# CONFIG_MOUSE_VSXXXAA is not set
# CONFIG_MOUSE_GPIO is not set
CONFIG_MOUSE_SYNAPTICS_I2C=m
CONFIG_MOUSE_SYNAPTICS_USB=m
CONFIG_INPUT_JOYSTICK=y
CONFIG_JOYSTICK_ANALOG=m
CONFIG_JOYSTICK_A3D=m
CONFIG_JOYSTICK_ADI=m
CONFIG_JOYSTICK_COBRA=m
CONFIG_JOYSTICK_GF2K=m
CONFIG_JOYSTICK_GRIP=m
CONFIG_JOYSTICK_GRIP_MP=m
CONFIG_JOYSTICK_GUILLEMOT=m
CONFIG_JOYSTICK_INTERACT=m
CONFIG_JOYSTICK_SIDEWINDER=m
CONFIG_JOYSTICK_TMDC=m
CONFIG_JOYSTICK_IFORCE=m
CONFIG_JOYSTICK_IFORCE_USB=y
CONFIG_JOYSTICK_IFORCE_232=y
CONFIG_JOYSTICK_WARRIOR=m
CONFIG_JOYSTICK_MAGELLAN=m
CONFIG_JOYSTICK_SPACEORB=m
CONFIG_JOYSTICK_SPACEBALL=m
CONFIG_JOYSTICK_STINGER=m
CONFIG_JOYSTICK_TWIDJOY=m
CONFIG_JOYSTICK_ZHENHUA=m
CONFIG_JOYSTICK_DB9=m
CONFIG_JOYSTICK_GAMECON=m
CONFIG_JOYSTICK_TURBOGRAFX=m
CONFIG_JOYSTICK_AS5011=m
CONFIG_JOYSTICK_JOYDUMP=m
CONFIG_JOYSTICK_XPAD=m
CONFIG_JOYSTICK_XPAD_FF=y
CONFIG_JOYSTICK_XPAD_LEDS=y
CONFIG_JOYSTICK_WALKERA0701=m
CONFIG_JOYSTICK_PSXPAD_SPI=m
CONFIG_JOYSTICK_PSXPAD_SPI_FF=y
CONFIG_INPUT_TABLET=y
CONFIG_TABLET_USB_ACECAD=m
CONFIG_TABLET_USB_AIPTEK=m
CONFIG_TABLET_USB_GTCO=m
CONFIG_TABLET_USB_HANWANG=m
CONFIG_TABLET_USB_KBTAB=m
# CONFIG_TABLET_USB_PEGASUS is not set
# CONFIG_TABLET_SERIAL_WACOM4 is not set
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_PROPERTIES=y
CONFIG_TOUCHSCREEN_ADS7846=m
# CONFIG_TOUCHSCREEN_AD7877 is not set
# CONFIG_TOUCHSCREEN_AD7879 is not set
# CONFIG_TOUCHSCREEN_AR1021_I2C is not set
CONFIG_TOUCHSCREEN_ATMEL_MXT=y
# CONFIG_TOUCHSCREEN_ATMEL_MXT_T37 is not set
# CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
# CONFIG_TOUCHSCREEN_BU21013 is not set
# CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
# CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
# CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
# CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
# CONFIG_TOUCHSCREEN_DYNAPRO is not set
# CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
CONFIG_TOUCHSCREEN_EETI=m
CONFIG_TOUCHSCREEN_EGALAX=m
# CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
# CONFIG_TOUCHSCREEN_FUJITSU is not set
CONFIG_TOUCHSCREEN_GOODIX=m
# CONFIG_TOUCHSCREEN_ILI210X is not set
# CONFIG_TOUCHSCREEN_GUNZE is not set
CONFIG_TOUCHSCREEN_EKTF2127=m
CONFIG_TOUCHSCREEN_ELAN=m
# CONFIG_TOUCHSCREEN_ELO is not set
# CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
CONFIG_TOUCHSCREEN_WACOM_I2C=m
# CONFIG_TOUCHSCREEN_MAX11801 is not set
# CONFIG_TOUCHSCREEN_MCS5000 is not set
CONFIG_TOUCHSCREEN_MMS114=m
# CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
# CONFIG_TOUCHSCREEN_MTOUCH is not set
# CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
# CONFIG_TOUCHSCREEN_INEXIO is not set
# CONFIG_TOUCHSCREEN_MK712 is not set
# CONFIG_TOUCHSCREEN_PENMOUNT is not set
CONFIG_TOUCHSCREEN_EDT_FT5X06=m
# CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
# CONFIG_TOUCHSCREEN_TOUCHWIN is not set
CONFIG_TOUCHSCREEN_PIXCIR=m
CONFIG_TOUCHSCREEN_WDT87XX_I2C=m
CONFIG_TOUCHSCREEN_USB_COMPOSITE=m
CONFIG_TOUCHSCREEN_USB_EGALAX=y
CONFIG_TOUCHSCREEN_USB_PANJIT=y
CONFIG_TOUCHSCREEN_USB_3M=y
CONFIG_TOUCHSCREEN_USB_ITM=y
CONFIG_TOUCHSCREEN_USB_ETURBO=y
CONFIG_TOUCHSCREEN_USB_GUNZE=y
CONFIG_TOUCHSCREEN_USB_DMC_TSC10=y
CONFIG_TOUCHSCREEN_USB_IRTOUCH=y
CONFIG_TOUCHSCREEN_USB_IDEALTEK=y
CONFIG_TOUCHSCREEN_USB_GENERAL_TOUCH=y
CONFIG_TOUCHSCREEN_USB_GOTOP=y
CONFIG_TOUCHSCREEN_USB_JASTEC=y
CONFIG_TOUCHSCREEN_USB_ELO=y
CONFIG_TOUCHSCREEN_USB_E2I=y
CONFIG_TOUCHSCREEN_USB_ZYTRONIC=y
CONFIG_TOUCHSCREEN_USB_ETT_TC45USB=y
CONFIG_TOUCHSCREEN_USB_NEXIO=y
CONFIG_TOUCHSCREEN_USB_EASYTOUCH=y
# CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
# CONFIG_TOUCHSCREEN_TSC_SERIO is not set
# CONFIG_TOUCHSCREEN_TSC2004 is not set
# CONFIG_TOUCHSCREEN_TSC2005 is not set
# CONFIG_TOUCHSCREEN_TSC2007 is not set
CONFIG_TOUCHSCREEN_RM_TS=m
CONFIG_TOUCHSCREEN_SILEAD=m
CONFIG_TOUCHSCREEN_SIS_I2C=m
# CONFIG_TOUCHSCREEN_ST1232 is not set
# CONFIG_TOUCHSCREEN_STMFTS is not set
# CONFIG_TOUCHSCREEN_SUR40 is not set
CONFIG_TOUCHSCREEN_SURFACE3_SPI=m
# CONFIG_TOUCHSCREEN_SX8654 is not set
# CONFIG_TOUCHSCREEN_TPS6507X is not set
# CONFIG_TOUCHSCREEN_ZET6223 is not set
# CONFIG_TOUCHSCREEN_ZFORCE is not set
# CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set
CONFIG_TOUCHSCREEN_SX865X=m
CONFIG_TOUCHSCREEN_DWAV_USB_MT=m
CONFIG_INPUT_MISC=y
CONFIG_INPUT_AD714X=m
CONFIG_INPUT_AD714X_I2C=m
CONFIG_INPUT_AD714X_SPI=m
CONFIG_INPUT_ATMEL_CAPTOUCH=m
CONFIG_INPUT_BMA150=m
CONFIG_INPUT_E3X0_BUTTON=m
CONFIG_INPUT_MMA8450=m
CONFIG_INPUT_GP2A=m
CONFIG_INPUT_GPIO_BEEPER=m
CONFIG_INPUT_GPIO_TILT_POLLED=m
CONFIG_INPUT_GPIO_DECODER=m
CONFIG_INPUT_ATI_REMOTE2=m
CONFIG_INPUT_KEYSPAN_REMOTE=m
CONFIG_INPUT_KXTJ9=m
CONFIG_INPUT_KXTJ9_POLLED_MODE=y
CONFIG_INPUT_POWERMATE=m
CONFIG_INPUT_YEALINK=m
CONFIG_INPUT_CM109=m
CONFIG_INPUT_REGULATOR_HAPTIC=m
CONFIG_INPUT_UINPUT=m
CONFIG_INPUT_PCF8574=m
CONFIG_INPUT_PWM_BEEPER=m
CONFIG_INPUT_PWM_VIBRA=m
CONFIG_INPUT_GPIO_ROTARY_ENCODER=m
CONFIG_INPUT_ADXL34X=m
CONFIG_INPUT_ADXL34X_I2C=m
CONFIG_INPUT_ADXL34X_SPI=m
CONFIG_INPUT_IMS_PCU=m
CONFIG_INPUT_CMA3000=m
CONFIG_INPUT_CMA3000_I2C=m
CONFIG_INPUT_SOC_BUTTON_ARRAY=m
CONFIG_INPUT_DRV260X_HAPTICS=m
CONFIG_INPUT_DRV2665_HAPTICS=m
CONFIG_INPUT_DRV2667_HAPTICS=m
CONFIG_RMI4_CORE=m
# CONFIG_RMI4_I2C is not set
# CONFIG_RMI4_SPI is not set
# CONFIG_RMI4_SMB is not set
CONFIG_RMI4_F03=y
CONFIG_RMI4_F03_SERIO=m
CONFIG_RMI4_2D_SENSOR=y
CONFIG_RMI4_F11=y
CONFIG_RMI4_F12=y
CONFIG_RMI4_F30=y
# CONFIG_RMI4_F34 is not set
# CONFIG_RMI4_F54 is not set
# CONFIG_RMI4_F55 is not set
# Hardware I/O ports
CONFIG_SERIO=m
CONFIG_SERIO_SERPORT=m
# CONFIG_SERIO_PARKBD is not set
# CONFIG_SERIO_AMBAKMI is not set
CONFIG_SERIO_LIBPS2=m
CONFIG_SERIO_RAW=m
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_SERIO_ARC_PS2 is not set
# CONFIG_SERIO_APBPS2 is not set
# CONFIG_SERIO_GPIO_PS2 is not set
# CONFIG_USERIO is not set
CONFIG_GAMEPORT=m
CONFIG_GAMEPORT_NS558=m
CONFIG_GAMEPORT_L4=m
# Character devices
CONFIG_TTY=y
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_VT_CONSOLE_SLEEP=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# CONFIG_TRACE_SINK is not set
CONFIG_LDISC_AUTOLOAD=y
CONFIG_DEVMEM=y
CONFIG_DEVKMEM=y
# Serial drivers
CONFIG_SERIAL_EARLYCON=y
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
# CONFIG_SERIAL_8250_FINTEK is not set
# CONFIG_SERIAL_8250_CONSOLE is not set
CONFIG_SERIAL_8250_DMA=y
CONFIG_SERIAL_8250_NR_UARTS=4
CONFIG_SERIAL_8250_RUNTIME_UARTS=4
# CONFIG_SERIAL_8250_EXTENDED is not set
# CONFIG_SERIAL_8250_ASPEED_VUART is not set
# CONFIG_SERIAL_8250_DW is not set
# CONFIG_SERIAL_8250_EM is not set
# CONFIG_SERIAL_8250_RT288X is not set
CONFIG_SERIAL_OF_PLATFORM=y
# Non-8250 serial port support
# CONFIG_SERIAL_AMBA_PL010 is not set
# CONFIG_SERIAL_AMBA_PL011 is not set
# CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
CONFIG_SERIAL_SAMSUNG=y
CONFIG_SERIAL_SAMSUNG_UARTS_4=y
CONFIG_SERIAL_SAMSUNG_UARTS=4
CONFIG_SERIAL_SAMSUNG_CONSOLE=y
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX310X is not set
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_SCCNXP is not set
# CONFIG_SERIAL_SC16IS7XX is not set
# CONFIG_SERIAL_BCM63XX is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_IFX6X60 is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_FSL_LPUART is not set
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_ST_ASC is not set
# CONFIG_SERIAL_DEV_BUS is not set
# CONFIG_PRINTER is not set
# CONFIG_PPDEV is not set
# CONFIG_HVC_DCC is not set
# CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=y
# CONFIG_HW_RANDOM_TIMERIOMEM is not set
CONFIG_HW_RANDOM_TPM=y
# CONFIG_RAW_DRIVER is not set
CONFIG_TCG_TPM=y
# CONFIG_TCG_TIS is not set
# CONFIG_TCG_TIS_SPI is not set
# CONFIG_TCG_TIS_I2C_ATMEL is not set
CONFIG_TCG_TIS_I2C_INFINEON=y
# CONFIG_TCG_TIS_I2C_NUVOTON is not set
# CONFIG_TCG_VTPM_PROXY is not set
# CONFIG_TCG_TIS_ST33ZP24_I2C is not set
# CONFIG_TCG_TIS_ST33ZP24_SPI is not set
# CONFIG_XILLYBUS is not set
CONFIG_EXYNOS_GPIOMEM=m
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_MUX=y
# Multiplexer I2C Chip support
CONFIG_I2C_ARB_GPIO_CHALLENGE=y
# CONFIG_I2C_MUX_GPIO is not set
# CONFIG_I2C_MUX_GPMUX is not set
# CONFIG_I2C_MUX_LTC4306 is not set
# CONFIG_I2C_MUX_PCA9541 is not set
# CONFIG_I2C_MUX_PCA954x is not set
# CONFIG_I2C_MUX_PINCTRL is not set
# CONFIG_I2C_MUX_REG is not set
# CONFIG_I2C_DEMUX_PINCTRL is not set
# CONFIG_I2C_MUX_MLXCPLD is not set
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_ALGOBIT=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_CBUS_GPIO is not set
# CONFIG_I2C_DESIGNWARE_PLATFORM is not set
# CONFIG_I2C_EMEV2 is not set
CONFIG_I2C_EXYNOS5=y
CONFIG_I2C_GPIO=y
CONFIG_I2C_GPIO_CUSTOM=m
# CONFIG_I2C_NOMADIK is not set
# CONFIG_I2C_OCORES is not set
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_PXA_PCI is not set
# CONFIG_I2C_RK3X is not set
CONFIG_HAVE_S3C2410_I2C=y
CONFIG_I2C_S3C2410=y
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_DIOLAN_U2C is not set
# CONFIG_I2C_PARPORT is not set
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_ROBOTFUZZ_OSIF is not set
# CONFIG_I2C_TAOS_EVM is not set
# CONFIG_I2C_TINY_USB is not set
# Other I2C/SMBus bus drivers
CONFIG_I2C_CROS_EC_TUNNEL=y
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_SLAVE is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
# CONFIG_SPI_AXI_SPI_ENGINE is not set
CONFIG_SPI_BITBANG=y
# CONFIG_SPI_BUTTERFLY is not set
# CONFIG_SPI_CADENCE is not set
# CONFIG_SPI_DESIGNWARE is not set
CONFIG_SPI_GPIO=y
# CONFIG_SPI_LM70_LLP is not set
# CONFIG_SPI_FSL_SPI is not set
# CONFIG_SPI_OC_TINY is not set
# CONFIG_SPI_PL022 is not set
# CONFIG_SPI_PXA2XX_PCI is not set
# CONFIG_SPI_ROCKCHIP is not set
CONFIG_SPI_S3C64XX=m
# CONFIG_SPI_SC18IS602 is not set
# CONFIG_SPI_XCOMM is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_ZYNQMP_GQSPI is not set
# SPI Protocol Masters
CONFIG_SPI_SPIDEV=m
# CONFIG_SPI_LOOPBACK_TEST is not set
# CONFIG_SPI_TLE62X0 is not set
# CONFIG_SPI_SLAVE is not set
# CONFIG_SPMI is not set
# CONFIG_HSI is not set
CONFIG_PPS=y
CONFIG_PPS_DEBUG=y
# PPS clients support
CONFIG_PPS_CLIENT_KTIMER=m
CONFIG_PPS_CLIENT_LDISC=m
CONFIG_PPS_CLIENT_PARPORT=m
CONFIG_PPS_CLIENT_GPIO=m
# PPS generators support
# PTP clock support
# CONFIG_PTP_1588_CLOCK is not set
CONFIG_PINCTRL=y
# Pin controllers
CONFIG_PINMUX=y
CONFIG_PINCONF=y
# CONFIG_PINCTRL_AMD is not set
# CONFIG_PINCTRL_MCP23S08 is not set
# CONFIG_PINCTRL_SINGLE is not set
# CONFIG_PINCTRL_SX150X is not set
CONFIG_PINCTRL_SAMSUNG=y
CONFIG_PINCTRL_EXYNOS=y
CONFIG_PINCTRL_EXYNOS_ARM=y
CONFIG_PINCTRL_EXYNOS5440=y
CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
CONFIG_GPIOLIB=y
CONFIG_OF_GPIO=y
CONFIG_GPIOLIB_IRQCHIP=y
CONFIG_GPIO_SYSFS=y
# Memory mapped GPIO drivers
# CONFIG_GPIO_74XX_MMIO is not set
# CONFIG_GPIO_ALTERA is not set
# CONFIG_GPIO_DWAPB is not set
# CONFIG_GPIO_FTGPIO010 is not set
# CONFIG_GPIO_GENERIC_PLATFORM is not set
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_MOCKUP is not set
# CONFIG_GPIO_MPC8XXX is not set
# CONFIG_GPIO_PL061 is not set
# CONFIG_GPIO_SYSCON is not set
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_ZEVIO is not set
# I2C GPIO expanders
# CONFIG_GPIO_ADP5588 is not set
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_GPIO_PCF857X is not set
# CONFIG_GPIO_SX150X is not set
# CONFIG_GPIO_TPIC2810 is not set
# MFD GPIO expanders
# CONFIG_HTC_EGPIO is not set
# CONFIG_GPIO_WM8994 is not set
# SPI GPIO expanders
# CONFIG_GPIO_74X164 is not set
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_PISOSR is not set
# CONFIG_GPIO_XRA1403 is not set
# USB GPIO expanders
CONFIG_W1=m
# 1-wire Bus Masters
CONFIG_W1_MASTER_DS2490=m
CONFIG_W1_MASTER_DS2482=m
CONFIG_W1_MASTER_DS1WM=m
CONFIG_W1_MASTER_GPIO=m
# 1-wire Slaves
CONFIG_W1_SLAVE_THERM=m
CONFIG_W1_SLAVE_SMEM=m
# CONFIG_W1_SLAVE_DS2405 is not set
CONFIG_W1_SLAVE_DS2408=m
# CONFIG_W1_SLAVE_DS2408_READBACK is not set
CONFIG_W1_SLAVE_DS2413=m
CONFIG_W1_SLAVE_DS2406=m
CONFIG_W1_SLAVE_DS2423=m
# CONFIG_W1_SLAVE_DS2805 is not set
CONFIG_W1_SLAVE_DS2431=m
CONFIG_W1_SLAVE_DS2433=m
CONFIG_W1_SLAVE_DS2433_CRC=y
# CONFIG_W1_SLAVE_DS2438 is not set
CONFIG_W1_SLAVE_DS2760=m
CONFIG_W1_SLAVE_DS2780=m
CONFIG_W1_SLAVE_DS2781=m
CONFIG_W1_SLAVE_DS28E04=m
# CONFIG_POWER_AVS is not set
CONFIG_POWER_RESET=y
# CONFIG_POWER_RESET_BRCMKONA is not set
# CONFIG_POWER_RESET_BRCMSTB is not set
CONFIG_POWER_RESET_GPIO=y
CONFIG_POWER_RESET_GPIO_RESTART=y
# CONFIG_POWER_RESET_LTC2952 is not set
# CONFIG_POWER_RESET_RESTART is not set
# CONFIG_POWER_RESET_VERSATILE is not set
CONFIG_POWER_RESET_SYSCON=y
CONFIG_POWER_RESET_SYSCON_POWEROFF=y
# CONFIG_SYSCON_REBOOT_MODE is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
# CONFIG_PDA_POWER is not set
# CONFIG_GENERIC_ADC_BATTERY is not set
# CONFIG_TEST_POWER is not set
# CONFIG_BATTERY_DS2760 is not set
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_LEGO_EV3 is not set
CONFIG_BATTERY_SBS=y
# CONFIG_CHARGER_SBS is not set
# CONFIG_BATTERY_BQ27XXX is not set
CONFIG_BATTERY_MAX17040=y
CONFIG_BATTERY_MAX17042=y
# CONFIG_BATTERY_MAX1721X is not set
# CONFIG_CHARGER_MAX8903 is not set
# CONFIG_CHARGER_LP8727 is not set
# CONFIG_CHARGER_GPIO is not set
# CONFIG_CHARGER_MANAGER is not set
# CONFIG_CHARGER_LTC3651 is not set
# CONFIG_CHARGER_DETECTOR_MAX14656 is not set
# CONFIG_CHARGER_BQ2415X is not set
# CONFIG_CHARGER_BQ24190 is not set
# CONFIG_CHARGER_BQ24257 is not set
# CONFIG_CHARGER_BQ24735 is not set
# CONFIG_CHARGER_BQ25890 is not set
# CONFIG_CHARGER_SMB347 is not set
# CONFIG_BATTERY_GAUGE_LTC2941 is not set
# CONFIG_CHARGER_RT9455 is not set
CONFIG_HWMON=y
# CONFIG_HWMON_VID is not set
# CONFIG_HWMON_DEBUG_CHIP is not set
# Native drivers
# CONFIG_SENSORS_AD7314 is not set
# CONFIG_SENSORS_AD7414 is not set
# CONFIG_SENSORS_AD7418 is not set
# CONFIG_SENSORS_ADM1021 is not set
# CONFIG_SENSORS_ADM1025 is not set
# CONFIG_SENSORS_ADM1026 is not set
# CONFIG_SENSORS_ADM1029 is not set
# CONFIG_SENSORS_ADM1031 is not set
# CONFIG_SENSORS_ADM9240 is not set
# CONFIG_SENSORS_ADT7310 is not set
# CONFIG_SENSORS_ADT7410 is not set
# CONFIG_SENSORS_ADT7411 is not set
# CONFIG_SENSORS_ADT7462 is not set
# CONFIG_SENSORS_ADT7470 is not set
# CONFIG_SENSORS_ADT7475 is not set
# CONFIG_SENSORS_ASC7621 is not set
# CONFIG_SENSORS_ASPEED is not set
# CONFIG_SENSORS_ATXP1 is not set
# CONFIG_SENSORS_DS620 is not set
# CONFIG_SENSORS_DS1621 is not set
# CONFIG_SENSORS_F71805F is not set
# CONFIG_SENSORS_F71882FG is not set
# CONFIG_SENSORS_F75375S is not set
# CONFIG_SENSORS_FTSTEUTATES is not set
# CONFIG_SENSORS_GL518SM is not set
# CONFIG_SENSORS_GL520SM is not set
# CONFIG_SENSORS_G760A is not set
# CONFIG_SENSORS_G762 is not set
# CONFIG_SENSORS_GPIO_FAN is not set
# CONFIG_SENSORS_HIH6130 is not set
# CONFIG_SENSORS_IIO_HWMON is not set
# CONFIG_SENSORS_IT87 is not set
# CONFIG_SENSORS_JC42 is not set
# CONFIG_SENSORS_POWR1220 is not set
# CONFIG_SENSORS_LINEAGE is not set
# CONFIG_SENSORS_LTC2945 is not set
# CONFIG_SENSORS_LTC2990 is not set
# CONFIG_SENSORS_LTC4151 is not set
# CONFIG_SENSORS_LTC4215 is not set
# CONFIG_SENSORS_LTC4222 is not set
# CONFIG_SENSORS_LTC4245 is not set
# CONFIG_SENSORS_LTC4260 is not set
# CONFIG_SENSORS_LTC4261 is not set
# CONFIG_SENSORS_MAX1111 is not set
# CONFIG_SENSORS_MAX16065 is not set
# CONFIG_SENSORS_MAX1619 is not set
# CONFIG_SENSORS_MAX1668 is not set
# CONFIG_SENSORS_MAX197 is not set
# CONFIG_SENSORS_MAX31722 is not set
# CONFIG_SENSORS_MAX6639 is not set
# CONFIG_SENSORS_MAX6642 is not set
# CONFIG_SENSORS_MAX6650 is not set
# CONFIG_SENSORS_MAX6697 is not set
# CONFIG_SENSORS_MAX31790 is not set
# CONFIG_SENSORS_MCP3021 is not set
# CONFIG_SENSORS_TC654 is not set
# CONFIG_SENSORS_ADCXX is not set
# CONFIG_SENSORS_LM63 is not set
# CONFIG_SENSORS_LM70 is not set
# CONFIG_SENSORS_LM73 is not set
# CONFIG_SENSORS_LM75 is not set
# CONFIG_SENSORS_LM77 is not set
# CONFIG_SENSORS_LM78 is not set
# CONFIG_SENSORS_LM80 is not set
# CONFIG_SENSORS_LM83 is not set
# CONFIG_SENSORS_LM85 is not set
# CONFIG_SENSORS_LM87 is not set
CONFIG_SENSORS_LM90=y
# CONFIG_SENSORS_LM92 is not set
# CONFIG_SENSORS_LM93 is not set
# CONFIG_SENSORS_LM95234 is not set
# CONFIG_SENSORS_LM95241 is not set
# CONFIG_SENSORS_LM95245 is not set
# CONFIG_SENSORS_PC87360 is not set
# CONFIG_SENSORS_PC87427 is not set
CONFIG_SENSORS_NTC_THERMISTOR=y
# CONFIG_SENSORS_NCT6683 is not set
# CONFIG_SENSORS_NCT6775 is not set
# CONFIG_SENSORS_NCT7802 is not set
# CONFIG_SENSORS_NCT7904 is not set
# CONFIG_SENSORS_PCF8591 is not set
# CONFIG_PMBUS is not set
CONFIG_SENSORS_PWM_FAN=y
# CONFIG_SENSORS_SHT15 is not set
# CONFIG_SENSORS_SHT21 is not set
# CONFIG_SENSORS_SHT3x is not set
# CONFIG_SENSORS_SHTC1 is not set
# CONFIG_SENSORS_DME1737 is not set
# CONFIG_SENSORS_EMC1403 is not set
# CONFIG_SENSORS_EMC2103 is not set
# CONFIG_SENSORS_EMC6W201 is not set
# CONFIG_SENSORS_SMSC47M1 is not set
# CONFIG_SENSORS_SMSC47M192 is not set
# CONFIG_SENSORS_SMSC47B397 is not set
# CONFIG_SENSORS_SCH56XX_COMMON is not set
# CONFIG_SENSORS_SCH5627 is not set
# CONFIG_SENSORS_SCH5636 is not set
# CONFIG_SENSORS_STTS751 is not set
# CONFIG_SENSORS_SMM665 is not set
# CONFIG_SENSORS_ADC128D818 is not set
# CONFIG_SENSORS_ADS1015 is not set
# CONFIG_SENSORS_ADS7828 is not set
# CONFIG_SENSORS_ADS7871 is not set
# CONFIG_SENSORS_AMC6821 is not set
# CONFIG_SENSORS_INA209 is not set
# CONFIG_SENSORS_INA2XX is not set
# CONFIG_SENSORS_INA3221 is not set
# CONFIG_SENSORS_TC74 is not set
# CONFIG_SENSORS_THMC50 is not set
# CONFIG_SENSORS_TMP102 is not set
# CONFIG_SENSORS_TMP103 is not set
# CONFIG_SENSORS_TMP108 is not set
# CONFIG_SENSORS_TMP401 is not set
# CONFIG_SENSORS_TMP421 is not set
# CONFIG_SENSORS_VT1211 is not set
# CONFIG_SENSORS_W83781D is not set
# CONFIG_SENSORS_W83791D is not set
# CONFIG_SENSORS_W83792D is not set
# CONFIG_SENSORS_W83793 is not set
# CONFIG_SENSORS_W83795 is not set
# CONFIG_SENSORS_W83L785TS is not set
# CONFIG_SENSORS_W83L786NG is not set
# CONFIG_SENSORS_W83627HF is not set
# CONFIG_SENSORS_W83627EHF is not set
CONFIG_THERMAL=y
CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
CONFIG_THERMAL_HWMON=y
CONFIG_THERMAL_OF=y
CONFIG_THERMAL_WRITABLE_TRIPS=y
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
# CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
# CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
# CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set
# CONFIG_THERMAL_GOV_FAIR_SHARE is not set
CONFIG_THERMAL_GOV_STEP_WISE=y
# CONFIG_THERMAL_GOV_BANG_BANG is not set
# CONFIG_THERMAL_GOV_USER_SPACE is not set
# CONFIG_THERMAL_GOV_POWER_ALLOCATOR is not set
CONFIG_CPU_THERMAL=y
# CONFIG_CLOCK_THERMAL is not set
# CONFIG_DEVFREQ_THERMAL is not set
CONFIG_THERMAL_EMULATION=y
# CONFIG_QORIQ_THERMAL is not set
# ACPI INT340X thermal drivers
# Texas Instruments thermal drivers
# CONFIG_TI_SOC_THERMAL is not set
# Samsung thermal drivers
CONFIG_EXYNOS_THERMAL=y
# CONFIG_GENERIC_ADC_THERMAL is not set
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
# CONFIG_WATCHDOG_SYSFS is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
# CONFIG_GPIO_WATCHDOG is not set
# CONFIG_XILINX_WATCHDOG is not set
# CONFIG_ZIIRAVE_WATCHDOG is not set
# CONFIG_ARM_SP805_WATCHDOG is not set
# CONFIG_CADENCE_WATCHDOG is not set
CONFIG_HAVE_S3C2410_WATCHDOG=y
CONFIG_S3C2410_WATCHDOG=y
# CONFIG_DW_WATCHDOG is not set
# CONFIG_MAX63XX_WATCHDOG is not set
# CONFIG_MEN_A21_WDT is not set
# USB-based Watchdog Cards
# CONFIG_USBPCWATCHDOG is not set
# Watchdog Pretimeout Governors
# CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set
CONFIG_SSB_POSSIBLE=y
# Sonics Silicon Backplane
# CONFIG_SSB is not set
CONFIG_BCMA_POSSIBLE=y
# CONFIG_BCMA is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
# CONFIG_MFD_ACT8945A is not set
# CONFIG_MFD_AS3711 is not set
# CONFIG_MFD_AS3722 is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_AAT2870_CORE is not set
# CONFIG_MFD_ATMEL_FLEXCOM is not set
# CONFIG_MFD_ATMEL_HLCDC is not set
# CONFIG_MFD_BCM590XX is not set
# CONFIG_MFD_BD9571MWV is not set
# CONFIG_MFD_AXP20X_I2C is not set
CONFIG_MFD_CROS_EC=y
CONFIG_MFD_CROS_EC_I2C=y
CONFIG_MFD_CROS_EC_SPI=y
# CONFIG_MFD_ASIC3 is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_DA9052_SPI is not set
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_DA9055 is not set
# CONFIG_MFD_DA9062 is not set
# CONFIG_MFD_DA9063 is not set
# CONFIG_MFD_DA9150 is not set
# CONFIG_MFD_DLN2 is not set
# CONFIG_MFD_EXYNOS_LPASS is not set
# CONFIG_MFD_MC13XXX_SPI is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_MFD_HI6421_PMIC is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_MFD_KEMPLD is not set
# CONFIG_MFD_88PM800 is not set
# CONFIG_MFD_88PM805 is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_MAX14577 is not set
# CONFIG_MFD_MAX77620 is not set
# CONFIG_MFD_MAX77686 is not set
# CONFIG_MFD_MAX77693 is not set
# CONFIG_MFD_MAX77843 is not set
# CONFIG_MFD_MAX8907 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_MT6397 is not set
# CONFIG_MFD_MENF21BMC is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_CPCAP is not set
# CONFIG_MFD_VIPERBOARD is not set
# CONFIG_MFD_RETU is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_PM8XXX is not set
# CONFIG_MFD_RT5033 is not set
# CONFIG_MFD_RTSX_USB is not set
# CONFIG_MFD_RC5T583 is not set
# CONFIG_MFD_RK808 is not set
# CONFIG_MFD_RN5T618 is not set
CONFIG_MFD_SEC_CORE=y
# CONFIG_MFD_SI476X_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_SKY81452 is not set
# CONFIG_MFD_SMSC is not set
# CONFIG_ABX500_CORE is not set
# CONFIG_MFD_STMPE is not set
CONFIG_MFD_SYSCON=y
# CONFIG_MFD_TI_AM335X_TSCADC is not set
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
# CONFIG_MFD_TI_LMU is not set
# CONFIG_MFD_PALMAS is not set
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_MFD_TPS65086 is not set
# CONFIG_MFD_TPS65090 is not set
# CONFIG_MFD_TPS65217 is not set
# CONFIG_MFD_TI_LP873X is not set
# CONFIG_MFD_TI_LP87565 is not set
# CONFIG_MFD_TPS65218 is not set
# CONFIG_MFD_TPS6586X is not set
# CONFIG_MFD_TPS65910 is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS65912_SPI is not set
# CONFIG_MFD_TPS80031 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_TWL6040_CORE is not set
# CONFIG_MFD_WL1273_CORE is not set
# CONFIG_MFD_LM3533 is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_TMIO is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_MFD_ARIZONA_I2C is not set
# CONFIG_MFD_ARIZONA_SPI is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
CONFIG_MFD_WM8994=m
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_FIXED_VOLTAGE=y
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_ACT8865 is not set
# CONFIG_REGULATOR_AD5398 is not set
# CONFIG_REGULATOR_ANATOP is not set
# CONFIG_REGULATOR_DA9210 is not set
# CONFIG_REGULATOR_DA9211 is not set
# CONFIG_REGULATOR_FAN53555 is not set
CONFIG_REGULATOR_GPIO=y
# CONFIG_REGULATOR_ISL9305 is not set
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_LP872X is not set
# CONFIG_REGULATOR_LP8755 is not set
# CONFIG_REGULATOR_LTC3589 is not set
# CONFIG_REGULATOR_LTC3676 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8952 is not set
# CONFIG_REGULATOR_MAX8973 is not set
# CONFIG_REGULATOR_MT6311 is not set
# CONFIG_REGULATOR_PFUZE100 is not set
# CONFIG_REGULATOR_PV88060 is not set
# CONFIG_REGULATOR_PV88080 is not set
# CONFIG_REGULATOR_PV88090 is not set
# CONFIG_REGULATOR_PWM is not set
CONFIG_REGULATOR_S2MPA01=y
CONFIG_REGULATOR_S2MPS11=y
CONFIG_REGULATOR_S5M8767=y
# CONFIG_REGULATOR_TPS51632 is not set
# CONFIG_REGULATOR_TPS62360 is not set
# CONFIG_REGULATOR_TPS65023 is not set
# CONFIG_REGULATOR_TPS6507X is not set
# CONFIG_REGULATOR_TPS65132 is not set
# CONFIG_REGULATOR_TPS6524X is not set
# CONFIG_REGULATOR_VCTRL is not set
# CONFIG_REGULATOR_WM8994 is not set
CONFIG_CEC_CORE=y
CONFIG_CEC_NOTIFIER=y
CONFIG_RC_CORE=y
CONFIG_RC_MAP=y
CONFIG_RC_DECODERS=y
CONFIG_LIRC=m
CONFIG_IR_LIRC_CODEC=m
CONFIG_IR_NEC_DECODER=m
CONFIG_IR_RC5_DECODER=m
CONFIG_IR_RC6_DECODER=m
CONFIG_IR_JVC_DECODER=m
CONFIG_IR_SONY_DECODER=m
CONFIG_IR_SANYO_DECODER=m
CONFIG_IR_SHARP_DECODER=m
CONFIG_IR_MCE_KBD_DECODER=m
CONFIG_IR_XMP_DECODER=m
CONFIG_RC_DEVICES=y
CONFIG_RC_ATI_REMOTE=m
CONFIG_IR_HIX5HD2=m
CONFIG_IR_IMON=m
CONFIG_IR_MCEUSB=m
CONFIG_IR_REDRAT3=m
# CONFIG_IR_SPI is not set
CONFIG_IR_STREAMZAP=m
CONFIG_IR_IGORPLUGUSB=m
CONFIG_IR_IGUANA=m
CONFIG_IR_TTUSBIR=m
# CONFIG_RC_LOOPBACK is not set
CONFIG_IR_GPIO_CIR=y
CONFIG_IR_GPIOPLUG_CIR=m
# CONFIG_IR_GPIO_TX is not set
# CONFIG_IR_PWM_TX is not set
# CONFIG_IR_SERIAL is not set
# CONFIG_IR_SIR is not set
CONFIG_MEDIA_SUPPORT=y
# Multimedia core support
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_MEDIA_ANALOG_TV_SUPPORT=y
CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
CONFIG_MEDIA_RADIO_SUPPORT=y
CONFIG_MEDIA_SDR_SUPPORT=y
CONFIG_MEDIA_CEC_SUPPORT=y
# CONFIG_MEDIA_CEC_RC is not set
CONFIG_MEDIA_CONTROLLER=y
CONFIG_MEDIA_CONTROLLER_DVB=y
CONFIG_VIDEO_DEV=y
CONFIG_VIDEO_V4L2_SUBDEV_API=y
CONFIG_VIDEO_V4L2=y
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
CONFIG_VIDEO_TUNER=m
CONFIG_V4L2_MEM2MEM_DEV=y
# CONFIG_V4L2_FLASH_LED_CLASS is not set
CONFIG_V4L2_FWNODE=m
CONFIG_VIDEOBUF_GEN=m
CONFIG_VIDEOBUF_VMALLOC=m
CONFIG_VIDEOBUF_DVB=m
CONFIG_VIDEOBUF2_CORE=y
CONFIG_VIDEOBUF2_MEMOPS=y
CONFIG_VIDEOBUF2_DMA_CONTIG=y
CONFIG_VIDEOBUF2_VMALLOC=m
CONFIG_DVB_CORE=y
CONFIG_DVB_NET=y
CONFIG_TTPCI_EEPROM=m
CONFIG_DVB_MAX_ADAPTERS=8
# CONFIG_DVB_DYNAMIC_MINORS is not set
# CONFIG_DVB_DEMUX_SECTION_LOSS_LOG is not set
# Media drivers
CONFIG_MEDIA_USB_SUPPORT=y
# Webcam devices
CONFIG_USB_VIDEO_CLASS=m
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
CONFIG_USB_GSPCA=m
CONFIG_USB_M5602=m
CONFIG_USB_STV06XX=m
CONFIG_USB_GL860=m
CONFIG_USB_GSPCA_BENQ=m
CONFIG_USB_GSPCA_CONEX=m
CONFIG_USB_GSPCA_CPIA1=m
CONFIG_USB_GSPCA_DTCS033=m
CONFIG_USB_GSPCA_ETOMS=m
CONFIG_USB_GSPCA_FINEPIX=m
CONFIG_USB_GSPCA_JEILINJ=m
CONFIG_USB_GSPCA_JL2005BCD=m
CONFIG_USB_GSPCA_KINECT=m
CONFIG_USB_GSPCA_KONICA=m
CONFIG_USB_GSPCA_MARS=m
CONFIG_USB_GSPCA_MR97310A=m
CONFIG_USB_GSPCA_NW80X=m
CONFIG_USB_GSPCA_OV519=m
CONFIG_USB_GSPCA_OV534=m
CONFIG_USB_GSPCA_OV534_9=m
CONFIG_USB_GSPCA_PAC207=m
CONFIG_USB_GSPCA_PAC7302=m
CONFIG_USB_GSPCA_PAC7311=m
CONFIG_USB_GSPCA_SE401=m
CONFIG_USB_GSPCA_SN9C2028=m
CONFIG_USB_GSPCA_SN9C20X=m
CONFIG_USB_GSPCA_SONIXB=m
CONFIG_USB_GSPCA_SONIXJ=m
CONFIG_USB_GSPCA_SPCA500=m
CONFIG_USB_GSPCA_SPCA501=m
CONFIG_USB_GSPCA_SPCA505=m
CONFIG_USB_GSPCA_SPCA506=m
CONFIG_USB_GSPCA_SPCA508=m
CONFIG_USB_GSPCA_SPCA561=m
CONFIG_USB_GSPCA_SPCA1528=m
CONFIG_USB_GSPCA_SQ905=m
CONFIG_USB_GSPCA_SQ905C=m
CONFIG_USB_GSPCA_SQ930X=m
CONFIG_USB_GSPCA_STK014=m
CONFIG_USB_GSPCA_STK1135=m
CONFIG_USB_GSPCA_STV0680=m
CONFIG_USB_GSPCA_SUNPLUS=m
CONFIG_USB_GSPCA_T613=m
CONFIG_USB_GSPCA_TOPRO=m
CONFIG_USB_GSPCA_TOUPTEK=m
CONFIG_USB_GSPCA_TV8532=m
CONFIG_USB_GSPCA_VC032X=m
CONFIG_USB_GSPCA_VICAM=m
CONFIG_USB_GSPCA_XIRLINK_CIT=m
CONFIG_USB_GSPCA_ZC3XX=m
CONFIG_USB_PWC=m
# CONFIG_USB_PWC_DEBUG is not set
CONFIG_USB_PWC_INPUT_EVDEV=y
CONFIG_VIDEO_CPIA2=m
CONFIG_USB_ZR364XX=m
CONFIG_USB_STKWEBCAM=m
CONFIG_USB_S2255=m
CONFIG_VIDEO_USBTV=m
# Analog TV USB devices
CONFIG_VIDEO_PVRUSB2=m
CONFIG_VIDEO_PVRUSB2_SYSFS=y
CONFIG_VIDEO_PVRUSB2_DVB=y
# CONFIG_VIDEO_PVRUSB2_DEBUGIFC is not set
CONFIG_VIDEO_HDPVR=m
CONFIG_VIDEO_USBVISION=m
CONFIG_VIDEO_STK1160_COMMON=m
CONFIG_VIDEO_STK1160=m
CONFIG_VIDEO_GO7007=m
CONFIG_VIDEO_GO7007_USB=m
CONFIG_VIDEO_GO7007_LOADER=m
CONFIG_VIDEO_GO7007_USB_S2250_BOARD=m
# Analog/digital TV USB devices
CONFIG_VIDEO_AU0828=m
CONFIG_VIDEO_AU0828_V4L2=y
CONFIG_VIDEO_AU0828_RC=y
CONFIG_VIDEO_CX231XX=m
CONFIG_VIDEO_CX231XX_RC=y
CONFIG_VIDEO_CX231XX_ALSA=m
CONFIG_VIDEO_CX231XX_DVB=m
CONFIG_VIDEO_TM6000=m
CONFIG_VIDEO_TM6000_ALSA=m
CONFIG_VIDEO_TM6000_DVB=m
# Digital TV USB devices
CONFIG_DVB_USB=m
# CONFIG_DVB_USB_DEBUG is not set
CONFIG_DVB_USB_DIB3000MC=m
CONFIG_DVB_USB_A800=m
CONFIG_DVB_USB_DIBUSB_MB=m
CONFIG_DVB_USB_DIBUSB_MB_FAULTY=y
CONFIG_DVB_USB_DIBUSB_MC=m
CONFIG_DVB_USB_DIB0700=m
CONFIG_DVB_USB_UMT_010=m
CONFIG_DVB_USB_CXUSB=m
CONFIG_DVB_USB_M920X=m
CONFIG_DVB_USB_DIGITV=m
CONFIG_DVB_USB_VP7045=m
CONFIG_DVB_USB_VP702X=m
CONFIG_DVB_USB_GP8PSK=m
CONFIG_DVB_USB_NOVA_T_USB2=m
CONFIG_DVB_USB_TTUSB2=m
CONFIG_DVB_USB_DTT200U=m
CONFIG_DVB_USB_OPERA1=m
CONFIG_DVB_USB_AF9005=m
CONFIG_DVB_USB_AF9005_REMOTE=m
CONFIG_DVB_USB_PCTV452E=m
CONFIG_DVB_USB_DW2102=m
CONFIG_DVB_USB_CINERGY_T2=m
CONFIG_DVB_USB_DTV5100=m
CONFIG_DVB_USB_FRIIO=m
CONFIG_DVB_USB_AZ6027=m
CONFIG_DVB_USB_TECHNISAT_USB2=m
CONFIG_DVB_USB_V2=m
CONFIG_DVB_USB_AF9015=m
CONFIG_DVB_USB_AF9035=m
CONFIG_DVB_USB_ANYSEE=m
CONFIG_DVB_USB_AU6610=m
CONFIG_DVB_USB_AZ6007=m
CONFIG_DVB_USB_CE6230=m
CONFIG_DVB_USB_EC168=m
CONFIG_DVB_USB_GL861=m
CONFIG_DVB_USB_LME2510=m
CONFIG_DVB_USB_MXL111SF=m
CONFIG_DVB_USB_RTL28XXU=m
CONFIG_DVB_USB_DVBSKY=m
# CONFIG_DVB_USB_ZD1301 is not set
CONFIG_SMS_USB_DRV=m
CONFIG_DVB_B2C2_FLEXCOP_USB=m
# CONFIG_DVB_B2C2_FLEXCOP_USB_DEBUG is not set
CONFIG_DVB_AS102=m
# Webcam, TV (analog/digital) USB devices
CONFIG_VIDEO_EM28XX=m
CONFIG_VIDEO_EM28XX_V4L2=m
CONFIG_VIDEO_EM28XX_ALSA=m
CONFIG_VIDEO_EM28XX_DVB=m
CONFIG_VIDEO_EM28XX_RC=m
# Software defined radio USB devices
CONFIG_USB_AIRSPY=m
CONFIG_USB_HACKRF=m
CONFIG_USB_MSI2500=m
# USB HDMI CEC adapters
# CONFIG_USB_PULSE8_CEC is not set
# CONFIG_USB_RAINSHADOW_CEC is not set
CONFIG_V4L_PLATFORM_DRIVERS=y
# CONFIG_VIDEO_MUX is not set
# CONFIG_SOC_CAMERA is not set
CONFIG_VIDEO_SAMSUNG_EXYNOS4_IS=m
CONFIG_VIDEO_EXYNOS4_IS_COMMON=m
CONFIG_VIDEO_S5P_FIMC=m
CONFIG_VIDEO_S5P_MIPI_CSIS=m
CONFIG_VIDEO_EXYNOS_FIMC_LITE=m
CONFIG_VIDEO_EXYNOS4_FIMC_IS=m
CONFIG_VIDEO_EXYNOS4_ISP_DMA_CAPTURE=y
# CONFIG_VIDEO_XILINX is not set
CONFIG_V4L_MEM2MEM_DRIVERS=y
# CONFIG_VIDEO_MEM2MEM_DEINTERLACE is not set
# CONFIG_VIDEO_SAMSUNG_S5P_G2D is not set
CONFIG_VIDEO_SAMSUNG_S5P_JPEG=y
CONFIG_VIDEO_SAMSUNG_S5P_MFC=y
CONFIG_VIDEO_SAMSUNG_EXYNOS_GSC=y
# CONFIG_VIDEO_SH_VEU is not set
CONFIG_V4L_TEST_DRIVERS=y
# CONFIG_VIDEO_VIMC is not set
CONFIG_VIDEO_VIVID=m
# CONFIG_VIDEO_VIVID_CEC is not set
CONFIG_VIDEO_VIVID_MAX_DEVS=64
# CONFIG_VIDEO_VIM2M is not set
CONFIG_DVB_PLATFORM_DRIVERS=y
# CONFIG_DVB_C8SECTPFE is not set
CONFIG_CEC_PLATFORM_DRIVERS=y
CONFIG_VIDEO_SAMSUNG_S5P_CEC=y
# CONFIG_SDR_PLATFORM_DRIVERS is not set
# Supported MMC/SDIO adapters
# CONFIG_SMS_SDIO_DRV is not set
CONFIG_RADIO_ADAPTERS=y
# CONFIG_RADIO_SI470X is not set
# CONFIG_RADIO_SI4713 is not set
# CONFIG_USB_MR800 is not set
# CONFIG_USB_DSBR is not set
# CONFIG_RADIO_SHARK is not set
# CONFIG_RADIO_SHARK2 is not set
# CONFIG_USB_KEENE is not set
# CONFIG_USB_RAREMONO is not set
# CONFIG_USB_MA901 is not set
# CONFIG_RADIO_TEA5764 is not set
# CONFIG_RADIO_SAA7706H is not set
# CONFIG_RADIO_TEF6862 is not set
# CONFIG_RADIO_WL1273 is not set
# Texas Instruments WL128x FM driver (ST based)
CONFIG_MEDIA_COMMON_OPTIONS=y
# common driver options
CONFIG_VIDEO_CX2341X=m
CONFIG_VIDEO_TVEEPROM=m
CONFIG_CYPRESS_FIRMWARE=m
CONFIG_DVB_B2C2_FLEXCOP=m
CONFIG_SMS_SIANO_MDTV=m
CONFIG_SMS_SIANO_RC=y
CONFIG_VIDEO_V4L2_TPG=m
# Media ancillary drivers (tuners, sensors, i2c, spi, frontends)
CONFIG_MEDIA_SUBDRV_AUTOSELECT=y
CONFIG_MEDIA_ATTACH=y
CONFIG_VIDEO_IR_I2C=y
# Audio decoders, processors and mixers
CONFIG_VIDEO_MSP3400=m
CONFIG_VIDEO_CS53L32A=m
CONFIG_VIDEO_UDA1342=m
CONFIG_VIDEO_WM8775=m
CONFIG_VIDEO_SONY_BTF_MPX=m
# RDS decoders
# Video decoders
CONFIG_VIDEO_SAA711X=m
CONFIG_VIDEO_TVP5150=m
CONFIG_VIDEO_TW2804=m
CONFIG_VIDEO_TW9903=m
CONFIG_VIDEO_TW9906=m
# Video and audio decoders
CONFIG_VIDEO_CX25840=m
# Video encoders
# Camera sensor devices
CONFIG_VIDEO_OV2640=m
CONFIG_VIDEO_OV7640=m
CONFIG_VIDEO_MT9V011=m
# Flash devices
# Video improvement chips
# Audio/Video compression chips
# SDR tuner chips
# Miscellaneous helper chips
# Sensors used on soc_camera driver
CONFIG_MEDIA_TUNER=y
CONFIG_MEDIA_TUNER_SIMPLE=y
CONFIG_MEDIA_TUNER_TDA8290=y
CONFIG_MEDIA_TUNER_TDA827X=y
CONFIG_MEDIA_TUNER_TDA18271=y
CONFIG_MEDIA_TUNER_TDA9887=y
CONFIG_MEDIA_TUNER_TEA5761=y
CONFIG_MEDIA_TUNER_TEA5767=y
CONFIG_MEDIA_TUNER_MSI001=m
CONFIG_MEDIA_TUNER_MT20XX=y
CONFIG_MEDIA_TUNER_MT2060=m
CONFIG_MEDIA_TUNER_MT2063=m
CONFIG_MEDIA_TUNER_MT2266=m
CONFIG_MEDIA_TUNER_QT1010=m
CONFIG_MEDIA_TUNER_XC2028=y
CONFIG_MEDIA_TUNER_XC5000=y
CONFIG_MEDIA_TUNER_XC4000=y
CONFIG_MEDIA_TUNER_MXL5005S=m
CONFIG_MEDIA_TUNER_MXL5007T=m
CONFIG_MEDIA_TUNER_MC44S803=y
CONFIG_MEDIA_TUNER_MAX2165=m
CONFIG_MEDIA_TUNER_TDA18218=m
CONFIG_MEDIA_TUNER_FC0011=m
CONFIG_MEDIA_TUNER_FC0012=m
CONFIG_MEDIA_TUNER_FC0013=m
CONFIG_MEDIA_TUNER_TDA18212=m
CONFIG_MEDIA_TUNER_E4000=m
CONFIG_MEDIA_TUNER_FC2580=m
CONFIG_MEDIA_TUNER_TUA9001=m
CONFIG_MEDIA_TUNER_SI2157=m
CONFIG_MEDIA_TUNER_IT913X=m
CONFIG_MEDIA_TUNER_R820T=m
CONFIG_MEDIA_TUNER_QM1D1C0042=m
# Multistandard (satellite) frontends
CONFIG_DVB_STB0899=m
CONFIG_DVB_STB6100=m
CONFIG_DVB_STV090x=m
CONFIG_DVB_STV6110x=m
CONFIG_DVB_M88DS3103=m
# Multistandard (cable + terrestrial) frontends
CONFIG_DVB_DRXK=m
CONFIG_DVB_TDA18271C2DD=m
CONFIG_DVB_SI2165=m
CONFIG_DVB_MN88472=m
CONFIG_DVB_MN88473=m
# DVB-S (satellite) frontends
CONFIG_DVB_CX24123=m
CONFIG_DVB_MT312=m
CONFIG_DVB_ZL10039=m
CONFIG_DVB_S5H1420=m
CONFIG_DVB_STV0288=m
CONFIG_DVB_STB6000=m
CONFIG_DVB_STV0299=m
CONFIG_DVB_STV6110=m
CONFIG_DVB_STV0900=m
CONFIG_DVB_TDA10086=m
CONFIG_DVB_TUNER_ITD1000=m
CONFIG_DVB_TUNER_CX24113=m
CONFIG_DVB_TDA826X=m
CONFIG_DVB_CX24116=m
CONFIG_DVB_CX24120=m
CONFIG_DVB_SI21XX=m
CONFIG_DVB_TS2020=m
CONFIG_DVB_DS3000=m
CONFIG_DVB_TDA10071=m
# DVB-T (terrestrial) frontends
CONFIG_DVB_CX22702=m
CONFIG_DVB_DRXD=m
CONFIG_DVB_TDA1004X=m
CONFIG_DVB_NXT6000=m
CONFIG_DVB_MT352=m
CONFIG_DVB_ZL10353=m
CONFIG_DVB_DIB3000MB=m
CONFIG_DVB_DIB3000MC=m
CONFIG_DVB_DIB7000M=m
CONFIG_DVB_DIB7000P=m
CONFIG_DVB_TDA10048=m
CONFIG_DVB_AF9013=m
CONFIG_DVB_EC100=m
CONFIG_DVB_CXD2820R=m
CONFIG_DVB_RTL2830=m
CONFIG_DVB_RTL2832=m
CONFIG_DVB_RTL2832_SDR=m
CONFIG_DVB_SI2168=m
CONFIG_DVB_AS102_FE=m
CONFIG_DVB_GP8PSK_FE=m
# DVB-C (cable) frontends
CONFIG_DVB_TDA10023=m
CONFIG_DVB_STV0297=m
# ATSC (North American/Korean Terrestrial/Cable DTV) frontends
CONFIG_DVB_NXT200X=m
CONFIG_DVB_BCM3510=m
CONFIG_DVB_LGDT330X=m
CONFIG_DVB_LGDT3305=m
CONFIG_DVB_LGDT3306A=m
CONFIG_DVB_LG2160=m
CONFIG_DVB_S5H1409=m
CONFIG_DVB_AU8522=m
CONFIG_DVB_AU8522_DTV=m
CONFIG_DVB_AU8522_V4L=m
CONFIG_DVB_S5H1411=m
# ISDB-T (terrestrial) frontends
CONFIG_DVB_S921=m
CONFIG_DVB_DIB8000=m
CONFIG_DVB_MB86A20S=m
# ISDB-S (satellite) & ISDB-T (terrestrial) frontends
CONFIG_DVB_TC90522=m
# Digital terrestrial only tuners/PLL
CONFIG_DVB_PLL=m
CONFIG_DVB_TUNER_DIB0070=m
CONFIG_DVB_TUNER_DIB0090=m
# SEC control devices for DVB-S
CONFIG_DVB_DRX39XYJ=m
CONFIG_DVB_LNBP21=m
CONFIG_DVB_LNBP22=m
CONFIG_DVB_ISL6421=m
CONFIG_DVB_ISL6423=m
CONFIG_DVB_A8293=m
CONFIG_DVB_SP2=m
CONFIG_DVB_LGS8GXX=m
CONFIG_DVB_ATBM8830=m
CONFIG_DVB_IX2505V=m
CONFIG_DVB_M88RS2000=m
CONFIG_DVB_AF9033=m
# Tools to develop new frontends
# CONFIG_DVB_DUMMY_FE is not set
# Graphics support
# CONFIG_IMX_IPUV3_CORE is not set
CONFIG_DRM=y
CONFIG_DRM_MIPI_DSI=y
# CONFIG_DRM_DP_AUX_CHARDEV is not set
# CONFIG_DRM_DEBUG_MM is not set
CONFIG_DRM_KMS_HELPER=y
CONFIG_DRM_KMS_FB_HELPER=y
CONFIG_DRM_FBDEV_EMULATION=y
CONFIG_DRM_FBDEV_OVERALLOC=100
CONFIG_DRM_LOAD_EDID_FIRMWARE=y
# I2C encoder or helper chips
# CONFIG_DRM_I2C_CH7006 is not set
# CONFIG_DRM_I2C_SIL164 is not set
# CONFIG_DRM_I2C_NXP_TDA998X is not set
# CONFIG_DRM_HDLCD is not set
# CONFIG_DRM_MALI_DISPLAY is not set
# ACP (Audio CoProcessor) Configuration
# CONFIG_DRM_VGEM is not set
CONFIG_DRM_EXYNOS=y
CONFIG_DRM_EXYNOS_IOMMU=y
# CRTCs
# CONFIG_DRM_EXYNOS_FIMD is not set
# CONFIG_DRM_EXYNOS5433_DECON is not set
# CONFIG_DRM_EXYNOS7_DECON is not set
CONFIG_DRM_EXYNOS_MIXER=y
# CONFIG_DRM_EXYNOS_VIDI is not set
# Encoders and Bridges
CONFIG_DRM_EXYNOS_HDMI=y
# Sub-drivers
CONFIG_DRM_EXYNOS_G2D=y
CONFIG_DRM_EXYNOS_IPP=y
CONFIG_DRM_EXYNOS_FIMC=y
CONFIG_DRM_EXYNOS_ROTATOR=y
# CONFIG_DRM_UDL is not set
# CONFIG_DRM_ARMADA is not set
# CONFIG_DRM_RCAR_DW_HDMI is not set
# CONFIG_DRM_OMAP is not set
# CONFIG_DRM_TILCDC is not set
# CONFIG_DRM_FSL_DCU is not set
# CONFIG_DRM_STM is not set
CONFIG_DRM_PANEL=y
# Display Panels
# CONFIG_DRM_PANEL_LVDS is not set
CONFIG_DRM_PANEL_SIMPLE=y
# CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set
# CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set
CONFIG_DRM_PANEL_SAMSUNG_LD9040=y
# CONFIG_DRM_PANEL_LG_LG4573 is not set
# CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set
CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0=y
# CONFIG_DRM_PANEL_SHARP_LQ101R1SX01 is not set
# CONFIG_DRM_PANEL_SHARP_LS043T1LE01 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
CONFIG_DRM_BRIDGE=y
CONFIG_DRM_PANEL_BRIDGE=y
# Display Interface Bridges
# CONFIG_DRM_ANALOGIX_ANX78XX is not set
# CONFIG_DRM_DUMB_VGA_DAC is not set
# CONFIG_DRM_LVDS_ENCODER is not set
# CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
CONFIG_DRM_NXP_PTN3460=y
CONFIG_DRM_PARADE_PS8622=y
# CONFIG_DRM_SIL_SII8620 is not set
# CONFIG_DRM_SII902X is not set
# CONFIG_DRM_TOSHIBA_TC358767 is not set
# CONFIG_DRM_TI_TFP410 is not set
# CONFIG_DRM_I2C_ADV7511 is not set
# CONFIG_DRM_STI is not set
# CONFIG_DRM_ARCPGU is not set
# CONFIG_DRM_MXSFB is not set
# CONFIG_DRM_TINYDRM is not set
# CONFIG_DRM_PL111 is not set
# CONFIG_DRM_LEGACY is not set
# CONFIG_DRM_LIB_RANDOM is not set
# ARM GPU Configuration
CONFIG_MALI_MIDGARD=y
CONFIG_MALI_GATOR_SUPPORT=y
# CONFIG_MALI_MIDGARD_ENABLE_TRACE is not set
CONFIG_MALI_DEVFREQ=y
CONFIG_MALI_DMA_FENCE=y
CONFIG_MALI_PLATFORM_NAME="devicetree"
CONFIG_MALI_EXPERT=y
# CONFIG_MALI_CORESTACK is not set
# CONFIG_MALI_PRFCNT_SET_SECONDARY is not set
# CONFIG_MALI_DEBUG is not set
# CONFIG_MALI_FENCE_DEBUG is not set
# CONFIG_MALI_NO_MALI is not set
# CONFIG_MALI_TRACE_TIMELINE is not set
# CONFIG_MALI_SYSTEM_TRACE is not set
# CONFIG_MALI_2MB_ALLOC is not set
# CONFIG_MALI_PWRSOFT_765 is not set
CONFIG_MALI_KUTF=m
# Frame buffer Devices
CONFIG_FB=y
CONFIG_FIRMWARE_EDID=y
CONFIG_FB_CMDLINE=y
CONFIG_FB_NOTIFY=y
# CONFIG_FB_DDC is not set
# CONFIG_FB_BOOT_VESA_SUPPORT is not set
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
# CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set
CONFIG_FB_SYS_FILLRECT=y
CONFIG_FB_SYS_COPYAREA=y
CONFIG_FB_SYS_IMAGEBLIT=y
# CONFIG_FB_PROVIDE_GET_FB_UNMAPPED_AREA is not set
# CONFIG_FB_FOREIGN_ENDIAN is not set
CONFIG_FB_SYS_FOPS=y
CONFIG_FB_DEFERRED_IO=y
# CONFIG_FB_SVGALIB is not set
# CONFIG_FB_MACMODES is not set
CONFIG_FB_BACKLIGHT=y
CONFIG_FB_MODE_HELPERS=y
# CONFIG_FB_TILEBLITTING is not set
# Frame buffer hardware drivers
# CONFIG_FB_ARMCLCD is not set
# CONFIG_FB_OPENCORES is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_S3C is not set
# CONFIG_FB_SMSCUFX is not set
# CONFIG_FB_UDL is not set
# CONFIG_FB_IBM_GXT4500 is not set
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
# CONFIG_FB_BROADSHEET is not set
# CONFIG_FB_AUO_K190X is not set
# CONFIG_FB_SIMPLE is not set
# CONFIG_FB_SSD1307 is not set
CONFIG_BACKLIGHT_LCD_SUPPORT=y
CONFIG_LCD_CLASS_DEVICE=m
# CONFIG_LCD_L4F00242T03 is not set
# CONFIG_LCD_LMS283GF05 is not set
# CONFIG_LCD_LTV350QV is not set
# CONFIG_LCD_ILI922X is not set
# CONFIG_LCD_ILI9320 is not set
# CONFIG_LCD_TDO24M is not set
# CONFIG_LCD_VGG2432A4 is not set
CONFIG_LCD_PLATFORM=m
# CONFIG_LCD_S6E63M0 is not set
# CONFIG_LCD_LD9040 is not set
# CONFIG_LCD_AMS369FG06 is not set
# CONFIG_LCD_LMS501KF03 is not set
# CONFIG_LCD_HX8357 is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=y
CONFIG_BACKLIGHT_GENERIC=y
CONFIG_BACKLIGHT_PWM=y
# CONFIG_BACKLIGHT_PM8941_WLED is not set
# CONFIG_BACKLIGHT_ADP8860 is not set
# CONFIG_BACKLIGHT_ADP8870 is not set
# CONFIG_BACKLIGHT_LM3630A is not set
# CONFIG_BACKLIGHT_LM3639 is not set
# CONFIG_BACKLIGHT_LP855X is not set
# CONFIG_BACKLIGHT_GPIO is not set
# CONFIG_BACKLIGHT_LV5207LP is not set
# CONFIG_BACKLIGHT_BD6107 is not set
# CONFIG_BACKLIGHT_ARCXCNN is not set
# CONFIG_VGASTATE is not set
CONFIG_VIDEOMODE_HELPERS=y
CONFIG_HDMI=y
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
CONFIG_LOGO=y
CONFIG_LOGO_LINUX_MONO=y
CONFIG_LOGO_LINUX_VGA16=y
CONFIG_LOGO_LINUX_CLUT224=y
CONFIG_SOUND=y
CONFIG_SOUND_OSS_CORE=y
CONFIG_SOUND_OSS_CORE_PRECLAIM=y
CONFIG_SND=y
CONFIG_SND_TIMER=y
CONFIG_SND_PCM=y
CONFIG_SND_PCM_ELD=y
CONFIG_SND_PCM_IEC958=y
CONFIG_SND_DMAENGINE_PCM=y
CONFIG_SND_HWDEP=m
CONFIG_SND_SEQ_DEVICE=m
CONFIG_SND_RAWMIDI=m
CONFIG_SND_JACK=y
CONFIG_SND_JACK_INPUT_DEV=y
CONFIG_SND_OSSEMUL=y
CONFIG_SND_MIXER_OSS=m
CONFIG_SND_PCM_OSS=m
CONFIG_SND_PCM_OSS_PLUGINS=y
CONFIG_SND_PCM_TIMER=y
CONFIG_SND_HRTIMER=y
CONFIG_SND_DYNAMIC_MINORS=y
CONFIG_SND_MAX_CARDS=32
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_PROC_FS=y
CONFIG_SND_VERBOSE_PROCFS=y
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
CONFIG_SND_VMASTER=y
CONFIG_SND_SEQUENCER=m
CONFIG_SND_SEQ_DUMMY=m
CONFIG_SND_SEQUENCER_OSS=m
CONFIG_SND_SEQ_HRTIMER_DEFAULT=y
CONFIG_SND_SEQ_MIDI_EVENT=m
CONFIG_SND_SEQ_MIDI=m
CONFIG_SND_SEQ_VIRMIDI=m
# CONFIG_SND_OPL3_LIB_SEQ is not set
# CONFIG_SND_OPL4_LIB_SEQ is not set
CONFIG_SND_DRIVERS=y
# CONFIG_SND_DUMMY is not set
CONFIG_SND_ALOOP=m
CONFIG_SND_VIRMIDI=m
# CONFIG_SND_MTPAV is not set
# CONFIG_SND_MTS64 is not set
# CONFIG_SND_SERIAL_U16550 is not set
# CONFIG_SND_MPU401 is not set
# CONFIG_SND_PORTMAN2X4 is not set
# HD-Audio
CONFIG_SND_HDA_PREALLOC_SIZE=64
CONFIG_SND_ARM=y
# CONFIG_SND_ARMAACI is not set
CONFIG_SND_SPI=y
CONFIG_SND_USB=y
CONFIG_SND_USB_AUDIO=m
CONFIG_SND_USB_UA101=m
CONFIG_SND_USB_CAIAQ=m
CONFIG_SND_USB_CAIAQ_INPUT=y
CONFIG_SND_USB_6FIRE=m
CONFIG_SND_USB_HIFACE=m
CONFIG_SND_BCD2000=m
CONFIG_SND_USB_LINE6=m
CONFIG_SND_USB_POD=m
CONFIG_SND_USB_PODHD=m
CONFIG_SND_USB_TONEPORT=m
CONFIG_SND_USB_VARIAX=m
CONFIG_SND_SOC=y
CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
# CONFIG_SND_SOC_AMD_ACP is not set
# CONFIG_SND_ATMEL_SOC is not set
# CONFIG_SND_DESIGNWARE_I2S is not set
# SoC Audio for Freescale CPUs
# Common SoC Audio options for Freescale CPUs:
# CONFIG_SND_SOC_FSL_ASRC is not set
# CONFIG_SND_SOC_FSL_SAI is not set
# CONFIG_SND_SOC_FSL_SSI is not set
# CONFIG_SND_SOC_FSL_SPDIF is not set
# CONFIG_SND_SOC_FSL_ESAI is not set
# CONFIG_SND_SOC_IMX_AUDMUX is not set
# CONFIG_SND_I2S_HI6210_I2S is not set
# CONFIG_SND_SOC_IMG is not set
CONFIG_SND_SOC_SAMSUNG=y
CONFIG_SND_SAMSUNG_PCM=y
CONFIG_SND_SAMSUNG_SPDIF=m
CONFIG_SND_SAMSUNG_I2S=y
CONFIG_SND_SOC_SAMSUNG_SMDK_WM8994=m
CONFIG_SND_SOC_SAMSUNG_SMDK_SPDIF=m
CONFIG_SND_SOC_SMDK_WM8994_PCM=m
CONFIG_SND_SOC_SNOW=m
CONFIG_SND_SOC_ODROID=y
CONFIG_SND_SOC_ARNDALE_RT5631_ALC5631=m
# STMicroelectronics STM32 SOC audio support
# CONFIG_SND_SOC_XTFPGA_I2S is not set
# CONFIG_ZX_TDM is not set
CONFIG_SND_SOC_I2C_AND_SPI=y
# CODEC drivers
CONFIG_SND_SOC_WM_HUBS=m
# CONFIG_SND_SOC_AC97_CODEC is not set
# CONFIG_SND_SOC_ADAU1701 is not set
# CONFIG_SND_SOC_ADAU1761_I2C is not set
# CONFIG_SND_SOC_ADAU1761_SPI is not set
# CONFIG_SND_SOC_ADAU7002 is not set
# CONFIG_SND_SOC_AK4104 is not set
# CONFIG_SND_SOC_AK4554 is not set
# CONFIG_SND_SOC_AK4613 is not set
# CONFIG_SND_SOC_AK4642 is not set
# CONFIG_SND_SOC_AK5386 is not set
# CONFIG_SND_SOC_ALC5623 is not set
# CONFIG_SND_SOC_BT_SCO is not set
# CONFIG_SND_SOC_CS35L32 is not set
# CONFIG_SND_SOC_CS35L33 is not set
# CONFIG_SND_SOC_CS35L34 is not set
# CONFIG_SND_SOC_CS35L35 is not set
# CONFIG_SND_SOC_CS42L42 is not set
# CONFIG_SND_SOC_CS42L51_I2C is not set
# CONFIG_SND_SOC_CS42L52 is not set
# CONFIG_SND_SOC_CS42L56 is not set
# CONFIG_SND_SOC_CS42L73 is not set
# CONFIG_SND_SOC_CS4265 is not set
# CONFIG_SND_SOC_CS4270 is not set
# CONFIG_SND_SOC_CS4271_I2C is not set
# CONFIG_SND_SOC_CS4271_SPI is not set
# CONFIG_SND_SOC_CS42XX8_I2C is not set
# CONFIG_SND_SOC_CS43130 is not set
# CONFIG_SND_SOC_CS4349 is not set
# CONFIG_SND_SOC_CS53L30 is not set
# CONFIG_SND_SOC_DIO2125 is not set
CONFIG_SND_SOC_HDMI_CODEC=y
# CONFIG_SND_SOC_ES7134 is not set
# CONFIG_SND_SOC_ES8316 is not set
# CONFIG_SND_SOC_ES8328_I2C is not set
# CONFIG_SND_SOC_ES8328_SPI is not set
# CONFIG_SND_SOC_GTM601 is not set
# CONFIG_SND_SOC_INNO_RK3036 is not set
CONFIG_SND_SOC_MAX98090=y
CONFIG_SND_SOC_MAX98095=m
# CONFIG_SND_SOC_MAX98504 is not set
# CONFIG_SND_SOC_MAX98927 is not set
# CONFIG_SND_SOC_MAX9860 is not set
# CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
# CONFIG_SND_SOC_PCM1681 is not set
# CONFIG_SND_SOC_PCM179X_I2C is not set
# CONFIG_SND_SOC_PCM179X_SPI is not set
# CONFIG_SND_SOC_PCM3168A_I2C is not set
# CONFIG_SND_SOC_PCM3168A_SPI is not set
# CONFIG_SND_SOC_PCM512x_I2C is not set
# CONFIG_SND_SOC_PCM512x_SPI is not set
# CONFIG_SND_SOC_RT5616 is not set
CONFIG_SND_SOC_RT5631=m
# CONFIG_SND_SOC_RT5677_SPI is not set
# CONFIG_SND_SOC_SGTL5000 is not set
# CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set
CONFIG_SND_SOC_SPDIF=y
# CONFIG_SND_SOC_SSM2602_SPI is not set
# CONFIG_SND_SOC_SSM2602_I2C is not set
# CONFIG_SND_SOC_SSM4567 is not set
# CONFIG_SND_SOC_STA32X is not set
# CONFIG_SND_SOC_STA350 is not set
# CONFIG_SND_SOC_STI_SAS is not set
# CONFIG_SND_SOC_TAS2552 is not set
# CONFIG_SND_SOC_TAS5086 is not set
# CONFIG_SND_SOC_TAS571X is not set
# CONFIG_SND_SOC_TAS5720 is not set
# CONFIG_SND_SOC_TFA9879 is not set
# CONFIG_SND_SOC_TLV320AIC23_I2C is not set
# CONFIG_SND_SOC_TLV320AIC23_SPI is not set
# CONFIG_SND_SOC_TLV320AIC31XX is not set
# CONFIG_SND_SOC_TLV320AIC3X is not set
# CONFIG_SND_SOC_TS3A227E is not set
# CONFIG_SND_SOC_WM8510 is not set
# CONFIG_SND_SOC_WM8523 is not set
# CONFIG_SND_SOC_WM8524 is not set
# CONFIG_SND_SOC_WM8580 is not set
# CONFIG_SND_SOC_WM8711 is not set
# CONFIG_SND_SOC_WM8728 is not set
# CONFIG_SND_SOC_WM8731 is not set
# CONFIG_SND_SOC_WM8737 is not set
# CONFIG_SND_SOC_WM8741 is not set
# CONFIG_SND_SOC_WM8750 is not set
# CONFIG_SND_SOC_WM8753 is not set
# CONFIG_SND_SOC_WM8770 is not set
# CONFIG_SND_SOC_WM8776 is not set
# CONFIG_SND_SOC_WM8804_I2C is not set
# CONFIG_SND_SOC_WM8804_SPI is not set
# CONFIG_SND_SOC_WM8903 is not set
# CONFIG_SND_SOC_WM8960 is not set
# CONFIG_SND_SOC_WM8962 is not set
# CONFIG_SND_SOC_WM8974 is not set
# CONFIG_SND_SOC_WM8978 is not set
# CONFIG_SND_SOC_WM8985 is not set
CONFIG_SND_SOC_WM8994=m
# CONFIG_SND_SOC_ZX_AUD96P22 is not set
# CONFIG_SND_SOC_NAU8540 is not set
# CONFIG_SND_SOC_NAU8810 is not set
# CONFIG_SND_SOC_NAU8824 is not set
# CONFIG_SND_SOC_TPA6130A2 is not set
CONFIG_SND_SIMPLE_CARD_UTILS=y
CONFIG_SND_SIMPLE_CARD=y
# CONFIG_SND_SIMPLE_SCU_CARD is not set
# CONFIG_SND_AUDIO_GRAPH_CARD is not set
# CONFIG_SND_AUDIO_GRAPH_SCU_CARD is not set
# HID support
CONFIG_HID=y
CONFIG_HID_BATTERY_STRENGTH=y
CONFIG_HIDRAW=y
CONFIG_UHID=y
CONFIG_HID_GENERIC=y
# Special HID drivers
CONFIG_HID_A4TECH=m
CONFIG_HID_ACCUTOUCH=m
CONFIG_HID_ACRUX=m
CONFIG_HID_ACRUX_FF=y
CONFIG_HID_APPLE=m
CONFIG_HID_APPLEIR=m
CONFIG_HID_ASUS=m
CONFIG_HID_AUREAL=m
CONFIG_HID_BELKIN=m
CONFIG_HID_BETOP_FF=m
CONFIG_HID_CHERRY=m
CONFIG_HID_CHICONY=m
CONFIG_HID_CORSAIR=m
CONFIG_HID_PRODIKEYS=m
CONFIG_HID_CMEDIA=m
CONFIG_HID_CP2112=m
CONFIG_HID_CYPRESS=m
CONFIG_HID_DRAGONRISE=m
CONFIG_DRAGONRISE_FF=y
CONFIG_HID_EMS_FF=m
CONFIG_HID_ELECOM=m
CONFIG_HID_ELO=m
CONFIG_HID_EZKEY=m
CONFIG_HID_GEMBIRD=m
CONFIG_HID_GFRM=m
CONFIG_HID_HOLTEK=m
CONFIG_HOLTEK_FF=y
CONFIG_HID_GT683R=m
CONFIG_HID_KEYTOUCH=m
CONFIG_HID_KYE=m
CONFIG_HID_UCLOGIC=m
CONFIG_HID_WALTOP=m
CONFIG_HID_GYRATION=m
CONFIG_HID_ICADE=m
CONFIG_HID_ITE=m
CONFIG_HID_TWINHAN=m
CONFIG_HID_KENSINGTON=m
CONFIG_HID_LCPOWER=m
CONFIG_HID_LED=m
CONFIG_HID_LENOVO=m
CONFIG_HID_LOGITECH=m
CONFIG_HID_LOGITECH_DJ=m
CONFIG_HID_LOGITECH_HIDPP=m
CONFIG_LOGITECH_FF=y
CONFIG_LOGIRUMBLEPAD2_FF=y
CONFIG_LOGIG940_FF=y
CONFIG_LOGIWHEELS_FF=y
CONFIG_HID_MAGICMOUSE=m
CONFIG_HID_MAYFLASH=m
CONFIG_HID_MICROSOFT=m
CONFIG_HID_MONTEREY=m
CONFIG_HID_MULTITOUCH=m
CONFIG_HID_NTI=m
CONFIG_HID_NTRIG=m
CONFIG_HID_ORTEK=m
CONFIG_HID_PANTHERLORD=m
CONFIG_PANTHERLORD_FF=y
CONFIG_HID_PENMOUNT=m
CONFIG_HID_PETALYNX=m
CONFIG_HID_PICOLCD=m
CONFIG_HID_PICOLCD_FB=y
CONFIG_HID_PICOLCD_BACKLIGHT=y
CONFIG_HID_PICOLCD_LCD=y
CONFIG_HID_PICOLCD_LEDS=y
CONFIG_HID_PICOLCD_CIR=y
CONFIG_HID_PLANTRONICS=m
CONFIG_HID_PRIMAX=m
CONFIG_HID_RETRODE=m
CONFIG_HID_ROCCAT=m
CONFIG_HID_SAITEK=m
CONFIG_HID_SAMSUNG=m
CONFIG_HID_SONY=m
CONFIG_SONY_FF=y
CONFIG_HID_SPEEDLINK=m
CONFIG_HID_STEELSERIES=m
CONFIG_HID_SUNPLUS=m
CONFIG_HID_RMI=m
CONFIG_HID_GREENASIA=m
CONFIG_GREENASIA_FF=y
CONFIG_HID_SMARTJOYPLUS=m
CONFIG_SMARTJOYPLUS_FF=y
CONFIG_HID_TIVO=m
CONFIG_HID_TOPSEED=m
CONFIG_HID_THINGM=m
CONFIG_HID_THRUSTMASTER=m
CONFIG_THRUSTMASTER_FF=y
CONFIG_HID_UDRAW_PS3=m
CONFIG_HID_WACOM=m
CONFIG_HID_WIIMOTE=m
CONFIG_HID_XINMO=m
CONFIG_HID_ZEROPLUS=m
CONFIG_ZEROPLUS_FF=y
CONFIG_HID_ZYDACRON=m
CONFIG_HID_SENSOR_HUB=m
CONFIG_HID_SENSOR_CUSTOM_SENSOR=m
CONFIG_HID_ALPS=m
# USB HID support
CONFIG_USB_HID=m
CONFIG_HID_PID=y
CONFIG_USB_HIDDEV=y
# I2C HID support
CONFIG_I2C_HID=m
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
# Miscellaneous USB options
CONFIG_USB_DEFAULT_PERSIST=y
# CONFIG_USB_DYNAMIC_MINORS is not set
CONFIG_USB_OTG=y
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
# CONFIG_USB_OTG_FSM is not set
# CONFIG_USB_LEDS_TRIGGER_USBPORT is not set
# CONFIG_USB_MON is not set
# CONFIG_USB_WUSB_CBAF is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
CONFIG_USB_XHCI_HCD=y
CONFIG_USB_XHCI_PLATFORM=y
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_ROOT_HUB_TT is not set
CONFIG_USB_EHCI_TT_NEWSCHED=y
CONFIG_USB_EHCI_EXYNOS=y
# CONFIG_USB_EHCI_HCD_PLATFORM is not set
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_ISP1362_HCD is not set
# CONFIG_USB_FOTG210_HCD is not set
# CONFIG_USB_MAX3421_HCD is not set
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_EXYNOS=y
# CONFIG_USB_OHCI_HCD_PLATFORM is not set
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_HCD_TEST_MODE is not set
# USB Device Class drivers
CONFIG_USB_ACM=m
CONFIG_USB_PRINTER=m
CONFIG_USB_WDM=m
CONFIG_USB_TMC=m
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=m
# CONFIG_USB_STORAGE_DEBUG is not set
CONFIG_USB_STORAGE_REALTEK=m
CONFIG_REALTEK_AUTOPM=y
CONFIG_USB_STORAGE_DATAFAB=m
CONFIG_USB_STORAGE_FREECOM=m
CONFIG_USB_STORAGE_ISD200=m
CONFIG_USB_STORAGE_USBAT=m
CONFIG_USB_STORAGE_SDDR09=m
CONFIG_USB_STORAGE_SDDR55=m
CONFIG_USB_STORAGE_JUMPSHOT=m
CONFIG_USB_STORAGE_ALAUDA=m
CONFIG_USB_STORAGE_ONETOUCH=m
CONFIG_USB_STORAGE_KARMA=m
CONFIG_USB_STORAGE_CYPRESS_ATACB=m
CONFIG_USB_STORAGE_ENE_UB6250=m
CONFIG_USB_UAS=m
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
CONFIG_USBIP_CORE=m
CONFIG_USBIP_VHCI_HCD=m
CONFIG_USBIP_VHCI_HC_PORTS=8
CONFIG_USBIP_VHCI_NR_HCS=1
CONFIG_USBIP_HOST=m
CONFIG_USBIP_VUDC=m
# CONFIG_USBIP_DEBUG is not set
# CONFIG_USB_MUSB_HDRC is not set
CONFIG_USB_DWC3=y
# CONFIG_USB_DWC3_HOST is not set
# CONFIG_USB_DWC3_GADGET is not set
CONFIG_USB_DWC3_DUAL_ROLE=y
# Platform Glue Driver Support
CONFIG_USB_DWC3_EXYNOS=y
CONFIG_USB_DWC3_OF_SIMPLE=y
CONFIG_USB_DWC2=y
# CONFIG_USB_DWC2_HOST is not set
# Gadget/Dual-role mode requires USB Gadget support to be enabled
# CONFIG_USB_DWC2_PERIPHERAL is not set
CONFIG_USB_DWC2_DUAL_ROLE=y
# CONFIG_USB_DWC2_DEBUG is not set
# CONFIG_USB_DWC2_TRACK_MISSED_SOFS is not set
# CONFIG_USB_CHIPIDEA is not set
# CONFIG_USB_ISP1760 is not set
# USB port drivers
# CONFIG_USB_USS720 is not set
CONFIG_USB_SERIAL=m
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_SIMPLE=m
CONFIG_USB_SERIAL_AIRCABLE=m
CONFIG_USB_SERIAL_ARK3116=m
CONFIG_USB_SERIAL_BELKIN=m
CONFIG_USB_SERIAL_CH341=m
CONFIG_USB_SERIAL_WHITEHEAT=m
CONFIG_USB_SERIAL_DIGI_ACCELEPORT=m
CONFIG_USB_SERIAL_CP210X=m
CONFIG_USB_SERIAL_CYPRESS_M8=m
CONFIG_USB_SERIAL_EMPEG=m
CONFIG_USB_SERIAL_FTDI_SIO=m
CONFIG_USB_SERIAL_VISOR=m
CONFIG_USB_SERIAL_IPAQ=m
CONFIG_USB_SERIAL_IR=m
CONFIG_USB_SERIAL_EDGEPORT=m
CONFIG_USB_SERIAL_EDGEPORT_TI=m
CONFIG_USB_SERIAL_F81232=m
# CONFIG_USB_SERIAL_F8153X is not set
CONFIG_USB_SERIAL_GARMIN=m
CONFIG_USB_SERIAL_IPW=m
CONFIG_USB_SERIAL_IUU=m
CONFIG_USB_SERIAL_KEYSPAN_PDA=m
CONFIG_USB_SERIAL_KEYSPAN=m
CONFIG_USB_SERIAL_KEYSPAN_MPR=y
CONFIG_USB_SERIAL_KEYSPAN_USA28=y
CONFIG_USB_SERIAL_KEYSPAN_USA28X=y
CONFIG_USB_SERIAL_KEYSPAN_USA28XA=y
CONFIG_USB_SERIAL_KEYSPAN_USA28XB=y
CONFIG_USB_SERIAL_KEYSPAN_USA19=y
CONFIG_USB_SERIAL_KEYSPAN_USA18X=y
CONFIG_USB_SERIAL_KEYSPAN_USA19W=y
CONFIG_USB_SERIAL_KEYSPAN_USA19QW=y
CONFIG_USB_SERIAL_KEYSPAN_USA19QI=y
CONFIG_USB_SERIAL_KEYSPAN_USA49W=y
CONFIG_USB_SERIAL_KEYSPAN_USA49WLC=y
CONFIG_USB_SERIAL_KLSI=m
CONFIG_USB_SERIAL_KOBIL_SCT=m
CONFIG_USB_SERIAL_MCT_U232=m
CONFIG_USB_SERIAL_METRO=m
CONFIG_USB_SERIAL_MOS7720=m
# CONFIG_USB_SERIAL_MOS7715_PARPORT is not set
CONFIG_USB_SERIAL_MOS7840=m
CONFIG_USB_SERIAL_MXUPORT=m
CONFIG_USB_SERIAL_NAVMAN=m
CONFIG_USB_SERIAL_PL2303=m
CONFIG_USB_SERIAL_OTI6858=m
CONFIG_USB_SERIAL_QCAUX=m
CONFIG_USB_SERIAL_QUALCOMM=m
CONFIG_USB_SERIAL_SPCP8X5=m
CONFIG_USB_SERIAL_SAFE=m
CONFIG_USB_SERIAL_SAFE_PADDED=y
CONFIG_USB_SERIAL_SIERRAWIRELESS=m
CONFIG_USB_SERIAL_SYMBOL=m
CONFIG_USB_SERIAL_TI=m
CONFIG_USB_SERIAL_CYBERJACK=m
CONFIG_USB_SERIAL_XIRCOM=m
CONFIG_USB_SERIAL_WWAN=m
CONFIG_USB_SERIAL_OPTION=m
CONFIG_USB_SERIAL_OMNINET=m
CONFIG_USB_SERIAL_OPTICON=m
CONFIG_USB_SERIAL_XSENS_MT=m
CONFIG_USB_SERIAL_WISHBONE=m
CONFIG_USB_SERIAL_SSU100=m
CONFIG_USB_SERIAL_QT2=m
# CONFIG_USB_SERIAL_UPD78F0730 is not set
# CONFIG_USB_SERIAL_DEBUG is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
# CONFIG_USB_TEST is not set
# CONFIG_USB_EHSET_TEST_FIXTURE is not set
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_YUREX is not set
CONFIG_USB_EZUSB_FX2=m
# CONFIG_USB_HUB_USB251XB is not set
CONFIG_USB_HSIC_USB3503=y
# CONFIG_USB_HSIC_USB4604 is not set
# CONFIG_USB_LINK_LAYER_TEST is not set
# CONFIG_USB_CHAOSKEY is not set
# CONFIG_USB_ATM is not set
# USB Physical Layer drivers
# CONFIG_USB_PHY is not set
# CONFIG_NOP_USB_XCEIV is not set
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ISP1301 is not set
# CONFIG_USB_ULPI is not set
CONFIG_USB_GADGET=y
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
# CONFIG_U_SERIAL_CONSOLE is not set
# USB Peripheral Controller
# CONFIG_USB_FUSB300 is not set
# CONFIG_USB_FOTG210_UDC is not set
# CONFIG_USB_GR_UDC is not set
# CONFIG_USB_R8A66597 is not set
# CONFIG_USB_PXA27X is not set
# CONFIG_USB_MV_UDC is not set
# CONFIG_USB_MV_U3D is not set
# CONFIG_USB_SNP_UDC_PLAT is not set
# CONFIG_USB_M66592 is not set
# CONFIG_USB_BDC_UDC is not set
# CONFIG_USB_NET2272 is not set
# CONFIG_USB_GADGET_XILINX is not set
# CONFIG_USB_DUMMY_HCD is not set
CONFIG_USB_LIBCOMPOSITE=m
CONFIG_USB_F_ACM=m
CONFIG_USB_U_SERIAL=m
CONFIG_USB_U_ETHER=m
CONFIG_USB_F_SERIAL=m
CONFIG_USB_F_OBEX=m
CONFIG_USB_F_ECM=m
CONFIG_USB_F_SUBSET=m
CONFIG_USB_F_RNDIS=m
CONFIG_USB_F_MASS_STORAGE=m
# CONFIG_USB_CONFIGFS is not set
# CONFIG_USB_ZERO is not set
# CONFIG_USB_AUDIO is not set
CONFIG_USB_ETH=m
CONFIG_USB_ETH_RNDIS=y
# CONFIG_USB_ETH_EEM is not set
# CONFIG_USB_G_NCM is not set
# CONFIG_USB_GADGETFS is not set
# CONFIG_USB_FUNCTIONFS is not set
CONFIG_USB_MASS_STORAGE=m
# CONFIG_USB_GADGET_TARGET is not set
CONFIG_USB_G_SERIAL=m
# CONFIG_USB_MIDI_GADGET is not set
# CONFIG_USB_G_PRINTER is not set
# CONFIG_USB_CDC_COMPOSITE is not set
# CONFIG_USB_G_ACM_MS is not set
# CONFIG_USB_G_MULTI is not set
# CONFIG_USB_G_HID is not set
# CONFIG_USB_G_DBGP is not set
# CONFIG_USB_G_WEBCAM is not set
# USB Power Delivery and Type-C drivers
# CONFIG_TYPEC_UCSI is not set
# CONFIG_USB_LED_TRIG is not set
# CONFIG_USB_ULPI_BUS is not set
# CONFIG_UWB is not set
CONFIG_MMC=y
CONFIG_PWRSEQ_EMMC=y
# CONFIG_PWRSEQ_SD8787 is not set
CONFIG_PWRSEQ_SIMPLE=y
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=16
# CONFIG_SDIO_UART is not set
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
# CONFIG_MMC_DEBUG is not set
# CONFIG_MMC_ARMMMCI is not set
CONFIG_MMC_SDHCI=y
# CONFIG_MMC_SDHCI_PLTFM is not set
CONFIG_MMC_SDHCI_S3C=y
CONFIG_MMC_SDHCI_S3C_DMA=y
# CONFIG_MMC_SPI is not set
CONFIG_MMC_DW=y
CONFIG_MMC_DW_PLTFM=y
CONFIG_MMC_DW_EXYNOS=y
# CONFIG_MMC_DW_K3 is not set
# CONFIG_MMC_VUB300 is not set
# CONFIG_MMC_USHC is not set
# CONFIG_MMC_USDHI6ROL0 is not set
# CONFIG_MMC_MTK is not set
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
CONFIG_LEDS_CLASS_FLASH=y
# CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set
# LED drivers
# CONFIG_LEDS_AAT1290 is not set
# CONFIG_LEDS_AS3645A is not set
# CONFIG_LEDS_BCM6328 is not set
# CONFIG_LEDS_BCM6358 is not set
# CONFIG_LEDS_LM3530 is not set
# CONFIG_LEDS_LM3642 is not set
# CONFIG_LEDS_PCA9532 is not set
CONFIG_LEDS_GPIO=y
# CONFIG_LEDS_LP3944 is not set
# CONFIG_LEDS_LP3952 is not set
# CONFIG_LEDS_LP5521 is not set
# CONFIG_LEDS_LP5523 is not set
# CONFIG_LEDS_LP5562 is not set
# CONFIG_LEDS_LP8501 is not set
# CONFIG_LEDS_LP8860 is not set
# CONFIG_LEDS_PCA955X is not set
# CONFIG_LEDS_PCA963X is not set
# CONFIG_LEDS_DAC124S085 is not set
CONFIG_LEDS_PWM=y
# CONFIG_LEDS_REGULATOR is not set
# CONFIG_LEDS_BD2802 is not set
# CONFIG_LEDS_LT3593 is not set
# CONFIG_LEDS_TCA6507 is not set
# CONFIG_LEDS_TLC591XX is not set
# CONFIG_LEDS_LM355x is not set
# CONFIG_LEDS_KTD2692 is not set
# CONFIG_LEDS_IS31FL319X is not set
# CONFIG_LEDS_IS31FL32XX is not set
# LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
# CONFIG_LEDS_BLINKM is not set
# CONFIG_LEDS_SYSCON is not set
# CONFIG_LEDS_USER is not set
# LED Triggers
CONFIG_LEDS_TRIGGERS=y
CONFIG_LEDS_TRIGGER_TIMER=y
CONFIG_LEDS_TRIGGER_ONESHOT=y
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
# CONFIG_LEDS_TRIGGER_BACKLIGHT is not set
CONFIG_LEDS_TRIGGER_CPU=y
CONFIG_LEDS_TRIGGER_GPIO=y
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
# iptables trigger is under Netfilter config (LED target)
CONFIG_LEDS_TRIGGER_TRANSIENT=y
# CONFIG_LEDS_TRIGGER_CAMERA is not set
# CONFIG_LEDS_TRIGGER_PANIC is not set
# CONFIG_ACCESSIBILITY is not set
CONFIG_EDAC_ATOMIC_SCRUB=y
CONFIG_EDAC_SUPPORT=y
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
CONFIG_RTC_SYSTOHC=y
CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
# CONFIG_RTC_DEBUG is not set
CONFIG_RTC_NVMEM=y
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
# CONFIG_RTC_DRV_ABB5ZES3 is not set
# CONFIG_RTC_DRV_ABX80X is not set
# CONFIG_RTC_DRV_DS1307 is not set
# CONFIG_RTC_DRV_DS1374 is not set
# CONFIG_RTC_DRV_DS1672 is not set
# CONFIG_RTC_DRV_HYM8563 is not set
# CONFIG_RTC_DRV_MAX6900 is not set
# CONFIG_RTC_DRV_RS5C372 is not set
# CONFIG_RTC_DRV_ISL1208 is not set
# CONFIG_RTC_DRV_ISL12022 is not set
# CONFIG_RTC_DRV_X1205 is not set
# CONFIG_RTC_DRV_PCF8523 is not set
# CONFIG_RTC_DRV_PCF85063 is not set
# CONFIG_RTC_DRV_PCF8563 is not set
# CONFIG_RTC_DRV_PCF8583 is not set
# CONFIG_RTC_DRV_M41T80 is not set
# CONFIG_RTC_DRV_BQ32K is not set
# CONFIG_RTC_DRV_S35390A is not set
# CONFIG_RTC_DRV_FM3130 is not set
# CONFIG_RTC_DRV_RX8010 is not set
# CONFIG_RTC_DRV_RX8581 is not set
# CONFIG_RTC_DRV_RX8025 is not set
# CONFIG_RTC_DRV_EM3027 is not set
# CONFIG_RTC_DRV_RV8803 is not set
CONFIG_RTC_DRV_S5M=y
# SPI RTC drivers
# CONFIG_RTC_DRV_M41T93 is not set
# CONFIG_RTC_DRV_M41T94 is not set
# CONFIG_RTC_DRV_DS1302 is not set
# CONFIG_RTC_DRV_DS1305 is not set
# CONFIG_RTC_DRV_DS1343 is not set
# CONFIG_RTC_DRV_DS1347 is not set
# CONFIG_RTC_DRV_DS1390 is not set
# CONFIG_RTC_DRV_MAX6916 is not set
# CONFIG_RTC_DRV_R9701 is not set
# CONFIG_RTC_DRV_RX4581 is not set
# CONFIG_RTC_DRV_RX6110 is not set
# CONFIG_RTC_DRV_RS5C348 is not set
# CONFIG_RTC_DRV_MAX6902 is not set
# CONFIG_RTC_DRV_PCF2123 is not set
# CONFIG_RTC_DRV_MCP795 is not set
CONFIG_RTC_I2C_AND_SPI=y
# SPI and I2C RTC drivers
# CONFIG_RTC_DRV_DS3232 is not set
# CONFIG_RTC_DRV_PCF2127 is not set
# CONFIG_RTC_DRV_RV3029C2 is not set
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1685_FAMILY is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_DS2404 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# CONFIG_RTC_DRV_ZYNQMP is not set
# on-CPU RTC drivers
CONFIG_HAVE_S3C_RTC=y
CONFIG_RTC_DRV_S3C=y
# CONFIG_RTC_DRV_PL030 is not set
# CONFIG_RTC_DRV_PL031 is not set
# CONFIG_RTC_DRV_FTRTC010 is not set
# CONFIG_RTC_DRV_SNVS is not set
# CONFIG_RTC_DRV_R7301 is not set
# HID Sensor RTC drivers
# CONFIG_RTC_DRV_HID_SENSOR_TIME is not set
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
# DMA Devices
CONFIG_DMA_ENGINE=y
CONFIG_DMA_OF=y
# CONFIG_ALTERA_MSGDMA is not set
# CONFIG_AMBA_PL08X is not set
# CONFIG_FSL_EDMA is not set
# CONFIG_INTEL_IDMA64 is not set
# CONFIG_NBPFAXI_DMA is not set
CONFIG_PL330_DMA=y
# CONFIG_QCOM_HIDMA_MGMT is not set
# CONFIG_QCOM_HIDMA is not set
# CONFIG_DW_DMAC is not set
# DMA Clients
# CONFIG_ASYNC_TX_DMA is not set
# CONFIG_DMATEST is not set
# DMABUF options
CONFIG_SYNC_FILE=y
# CONFIG_SW_SYNC is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_PANEL is not set
CONFIG_UIO=m
CONFIG_UIO_PDRV_GENIRQ=m
CONFIG_UIO_DMEM_GENIRQ=m
# CONFIG_UIO_PRUSS is not set
# CONFIG_VFIO is not set
# CONFIG_VIRT_DRIVERS is not set
# Virtio drivers
# CONFIG_VIRTIO_MMIO is not set
# Microsoft Hyper-V guest support
# CONFIG_HYPERV_TSCPAGE is not set
CONFIG_STAGING=y
CONFIG_IRDA=m
# IrDA protocols
CONFIG_IRLAN=m
# CONFIG_IRNET is not set
CONFIG_IRCOMM=m
CONFIG_IRDA_ULTRA=y
# IrDA options
CONFIG_IRDA_CACHE_LAST_LSAP=y
CONFIG_IRDA_FAST_RR=y
# CONFIG_IRDA_DEBUG is not set
# Infrared-port device drivers
# SIR device drivers
CONFIG_IRTTY_SIR=m
# Dongle support
CONFIG_DONGLE=y
CONFIG_ESI_DONGLE=m
CONFIG_ACTISYS_DONGLE=m
CONFIG_TEKRAM_DONGLE=m
CONFIG_TOIM3232_DONGLE=m
CONFIG_LITELINK_DONGLE=m
CONFIG_MA600_DONGLE=m
CONFIG_GIRBIL_DONGLE=m
CONFIG_MCP2120_DONGLE=m
CONFIG_OLD_BELKIN_DONGLE=m
CONFIG_ACT200L_DONGLE=m
CONFIG_KINGSUN_DONGLE=m
CONFIG_KSDAZZLE_DONGLE=m
CONFIG_KS959_DONGLE=m
# FIR device drivers
CONFIG_USB_IRDA=m
CONFIG_SIGMATEL_FIR=m
CONFIG_MCS_FIR=m
CONFIG_PRISM2_USB=m
# CONFIG_COMEDI is not set
# CONFIG_RTLLIB is not set
# CONFIG_RTL8723BS is not set
CONFIG_R8712U=m
CONFIG_R8188EU=m
CONFIG_88EU_AP_MODE=y
# CONFIG_VT6656 is not set
# IIO staging drivers
# Accelerometers
# CONFIG_ADIS16201 is not set
# CONFIG_ADIS16203 is not set
# CONFIG_ADIS16209 is not set
# CONFIG_ADIS16240 is not set
# Analog to digital converters
# CONFIG_AD7606 is not set
# CONFIG_AD7780 is not set
# CONFIG_AD7816 is not set
# CONFIG_AD7192 is not set
# CONFIG_AD7280 is not set
# Analog digital bi-direction converters
# CONFIG_ADT7316 is not set
# Capacitance to digital converters
# CONFIG_AD7150 is not set
# CONFIG_AD7152 is not set
# CONFIG_AD7746 is not set
# Direct Digital Synthesis
# CONFIG_AD9832 is not set
# CONFIG_AD9834 is not set
# Digital gyroscope sensors
# CONFIG_ADIS16060 is not set
# Network Analyzer, Impedance Converters
# CONFIG_AD5933 is not set
# Light sensors
# CONFIG_TSL2x7x is not set
# Active energy metering IC
# CONFIG_ADE7753 is not set
# CONFIG_ADE7754 is not set
# CONFIG_ADE7758 is not set
# CONFIG_ADE7759 is not set
# CONFIG_ADE7854 is not set
# Resolver to digital converters
# CONFIG_AD2S90 is not set
# CONFIG_AD2S1200 is not set
# CONFIG_AD2S1210 is not set
# Triggers - standalone
# Speakup console speech
# CONFIG_SPEAKUP is not set
CONFIG_STAGING_MEDIA=y
# CONFIG_I2C_BCM2048 is not set
CONFIG_LIRC_STAGING=y
# CONFIG_LIRC_ZILOG is not set
CONFIG_LIRC_ODROID=m
# Android
# CONFIG_STAGING_BOARD is not set
# CONFIG_LTE_GDM724X is not set
# CONFIG_LNET is not set
# CONFIG_GS_FPGABOOT is not set
# CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set
CONFIG_FB_TFT=m
CONFIG_FB_TFT_AGM1264K_FL=m
CONFIG_FB_TFT_BD663474=m
CONFIG_FB_TFT_HX8340BN=m
CONFIG_FB_TFT_HX8347D=m
CONFIG_FB_TFT_HX8353D=m
CONFIG_FB_TFT_HX8357D=m
CONFIG_FB_TFT_ILI9163=m
CONFIG_FB_TFT_ILI9320=m
CONFIG_FB_TFT_ILI9325=m
CONFIG_FB_TFT_ILI9340=m
CONFIG_FB_TFT_ILI9341=m
CONFIG_FB_TFT_ILI9481=m
CONFIG_FB_TFT_ILI9486=m
CONFIG_FB_TFT_PCD8544=m
CONFIG_FB_TFT_RA8875=m
CONFIG_FB_TFT_S6D02A1=m
CONFIG_FB_TFT_S6D1121=m
# CONFIG_FB_TFT_SH1106 is not set
CONFIG_FB_TFT_SSD1289=m
CONFIG_FB_TFT_SSD1305=m
CONFIG_FB_TFT_SSD1306=m
CONFIG_FB_TFT_SSD1325=m
CONFIG_FB_TFT_SSD1331=m
CONFIG_FB_TFT_SSD1351=m
CONFIG_FB_TFT_ST7735R=m
CONFIG_FB_TFT_ST7789V=m
CONFIG_FB_TFT_TINYLCD=m
CONFIG_FB_TFT_TLS8204=m
CONFIG_FB_TFT_UC1611=m
CONFIG_FB_TFT_UC1701=m
CONFIG_FB_TFT_UPD161704=m
CONFIG_FB_TFT_WATTEROTT=m
CONFIG_FB_FLEX=m
CONFIG_FB_TFT_FBTFT_DEVICE=m
# CONFIG_WILC1000_SDIO is not set
# CONFIG_WILC1000_SPI is not set
# CONFIG_MOST is not set
# CONFIG_KS7010 is not set
# CONFIG_GREYBUS is not set
# CONFIG_CRYPTO_DEV_CCREE is not set
# CONFIG_TYPEC_TCPM is not set
# CONFIG_PI433 is not set
# CONFIG_GOLDFISH is not set
CONFIG_CHROME_PLATFORMS=y
# CONFIG_CROS_EC_CHARDEV is not set
CONFIG_CROS_EC_PROTO=y
CONFIG_CLKDEV_LOOKUP=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
# Common Clock Framework
# CONFIG_CLK_HSDK is not set
# CONFIG_COMMON_CLK_SI5351 is not set
# CONFIG_COMMON_CLK_SI514 is not set
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
# CONFIG_COMMON_CLK_CS2000_CP is not set
CONFIG_COMMON_CLK_S2MPS11=y
# CONFIG_CLK_QORIQ is not set
# CONFIG_COMMON_CLK_NXP is not set
# CONFIG_COMMON_CLK_PWM is not set
# CONFIG_COMMON_CLK_PXA is not set
# CONFIG_COMMON_CLK_PIC32 is not set
# CONFIG_COMMON_CLK_VC5 is not set
CONFIG_COMMON_CLK_SAMSUNG=y
CONFIG_EXYNOS_AUDSS_CLK_CON=y
# CONFIG_HWSPINLOCK is not set
# Clock Source drivers
CONFIG_TIMER_OF=y
CONFIG_TIMER_PROBE=y
CONFIG_ARM_ARCH_TIMER=y
CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
# CONFIG_ARM_TIMER_SP804 is not set
# CONFIG_ATMEL_PIT is not set
CONFIG_CLKSRC_EXYNOS_MCT=y
CONFIG_CLKSRC_SAMSUNG_PWM=y
# CONFIG_SH_TIMER_CMT is not set
# CONFIG_SH_TIMER_MTU2 is not set
# CONFIG_SH_TIMER_TMU is not set
# CONFIG_EM_TIMER_STI is not set
# CONFIG_MAILBOX is not set
CONFIG_IOMMU_API=y
CONFIG_IOMMU_SUPPORT=y
# Generic IOMMU Pagetable Support
# CONFIG_IOMMU_IO_PGTABLE_LPAE is not set
# CONFIG_IOMMU_IO_PGTABLE_ARMV7S is not set
CONFIG_OF_IOMMU=y
CONFIG_EXYNOS_IOMMU=y
# CONFIG_EXYNOS_IOMMU_DEBUG is not set
# CONFIG_ARM_SMMU is not set
# Remoteproc drivers
# CONFIG_REMOTEPROC is not set
# Rpmsg drivers
# SOC (System On Chip) specific Drivers
# Amlogic SoC drivers
# Broadcom SoC drivers
# CONFIG_SOC_BRCMSTB is not set
# i.MX SoC drivers
# Qualcomm SoC drivers
CONFIG_SOC_SAMSUNG=y
CONFIG_EXYNOS_PMU=y
CONFIG_EXYNOS_PMU_ARM_DRIVERS=y
CONFIG_EXYNOS_PM_DOMAINS=y
# CONFIG_SUNXI_SRAM is not set
# CONFIG_SOC_TI is not set
CONFIG_PM_DEVFREQ=y
# DEVFREQ Governors
CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=y
CONFIG_DEVFREQ_GOV_PERFORMANCE=y
CONFIG_DEVFREQ_GOV_POWERSAVE=y
CONFIG_DEVFREQ_GOV_USERSPACE=y
CONFIG_DEVFREQ_GOV_PASSIVE=y
# DEVFREQ Drivers
CONFIG_ARM_EXYNOS_BUS_DEVFREQ=y
CONFIG_PM_DEVFREQ_EVENT=y
CONFIG_DEVFREQ_EVENT_EXYNOS_NOCP=y
CONFIG_DEVFREQ_EVENT_EXYNOS_PPMU=y
CONFIG_EXTCON=y
# Extcon Device Drivers
# CONFIG_EXTCON_ADC_JACK is not set
# CONFIG_EXTCON_GPIO is not set
# CONFIG_EXTCON_MAX3355 is not set
# CONFIG_EXTCON_RT8973A is not set
# CONFIG_EXTCON_SM5502 is not set
CONFIG_EXTCON_USB_GPIO=m
# CONFIG_EXTCON_USBC_CROS_EC is not set
CONFIG_MEMORY=y
# CONFIG_ARM_PL172_MPMC is not set
CONFIG_SAMSUNG_MC=y
CONFIG_EXYNOS_SROM=y
CONFIG_IIO=y
CONFIG_IIO_BUFFER=y
# CONFIG_IIO_BUFFER_CB is not set
CONFIG_IIO_KFIFO_BUF=y
CONFIG_IIO_TRIGGERED_BUFFER=y
# CONFIG_IIO_CONFIGFS is not set
CONFIG_IIO_TRIGGER=y
CONFIG_IIO_CONSUMERS_PER_TRIGGER=2
# CONFIG_IIO_SW_DEVICE is not set
# CONFIG_IIO_SW_TRIGGER is not set
# Accelerometers
# CONFIG_BMA180 is not set
# CONFIG_BMA220 is not set
# CONFIG_BMC150_ACCEL is not set
# CONFIG_DA280 is not set
# CONFIG_DA311 is not set
# CONFIG_DMARD06 is not set
# CONFIG_DMARD09 is not set
# CONFIG_DMARD10 is not set
# CONFIG_HID_SENSOR_ACCEL_3D is not set
# CONFIG_IIO_ST_ACCEL_3AXIS is not set
# CONFIG_KXSD9 is not set
# CONFIG_KXCJK1013 is not set
# CONFIG_MC3230 is not set
# CONFIG_MMA7455_I2C is not set
# CONFIG_MMA7455_SPI is not set
# CONFIG_MMA7660 is not set
# CONFIG_MMA8452 is not set
# CONFIG_MMA9551 is not set
# CONFIG_MMA9553 is not set
# CONFIG_MXC4005 is not set
# CONFIG_MXC6255 is not set
# CONFIG_SCA3000 is not set
# CONFIG_STK8312 is not set
# CONFIG_STK8BA50 is not set
# CONFIG_AD7266 is not set
# CONFIG_AD7291 is not set
# CONFIG_AD7298 is not set
# CONFIG_AD7476 is not set
# CONFIG_AD7766 is not set
# CONFIG_AD7791 is not set
# CONFIG_AD7793 is not set
# CONFIG_AD7887 is not set
# CONFIG_AD7923 is not set
# CONFIG_AD799X is not set
# CONFIG_CC10001_ADC is not set
# CONFIG_ENVELOPE_DETECTOR is not set
CONFIG_EXYNOS_ADC=y
# CONFIG_HI8435 is not set
# CONFIG_HX711 is not set
# CONFIG_INA2XX_ADC is not set
# CONFIG_LTC2471 is not set
# CONFIG_LTC2485 is not set
# CONFIG_LTC2497 is not set
# CONFIG_MAX1027 is not set
# CONFIG_MAX11100 is not set
# CONFIG_MAX1118 is not set
# CONFIG_MAX1363 is not set
# CONFIG_MAX9611 is not set
# CONFIG_MCP320X is not set
# CONFIG_MCP3422 is not set
# CONFIG_NAU7802 is not set
# CONFIG_TI_ADC081C is not set
# CONFIG_TI_ADC0832 is not set
# CONFIG_TI_ADC084S021 is not set
# CONFIG_TI_ADC12138 is not set
# CONFIG_TI_ADC108S102 is not set
# CONFIG_TI_ADC128S052 is not set
# CONFIG_TI_ADC161S626 is not set
# CONFIG_TI_ADS1015 is not set
# CONFIG_TI_ADS7950 is not set
# CONFIG_TI_ADS8688 is not set
# CONFIG_TI_TLC4541 is not set
# CONFIG_VF610_ADC is not set
# Amplifiers
# CONFIG_AD8366 is not set
# Chemical Sensors
# CONFIG_ATLAS_PH_SENSOR is not set
# CONFIG_CCS811 is not set
# CONFIG_IAQCORE is not set
# CONFIG_VZ89X is not set
# CONFIG_IIO_CROS_EC_SENSORS_CORE is not set
# Hid Sensor IIO Common
# CONFIG_HID_SENSOR_IIO_COMMON is not set
# SSP Sensor Common
# CONFIG_IIO_SSP_SENSORHUB is not set
# Counters
# Digital to analog converters
# CONFIG_AD5064 is not set
# CONFIG_AD5360 is not set
# CONFIG_AD5380 is not set
# CONFIG_AD5421 is not set
# CONFIG_AD5446 is not set
# CONFIG_AD5449 is not set
# CONFIG_AD5592R is not set
# CONFIG_AD5593R is not set
# CONFIG_AD5504 is not set
# CONFIG_AD5624R_SPI is not set
# CONFIG_LTC2632 is not set
# CONFIG_AD5686 is not set
# CONFIG_AD5755 is not set
# CONFIG_AD5761 is not set
# CONFIG_AD5764 is not set
# CONFIG_AD5791 is not set
# CONFIG_AD7303 is not set
# CONFIG_AD8801 is not set
# CONFIG_DPOT_DAC is not set
# CONFIG_M62332 is not set
# CONFIG_MAX517 is not set
# CONFIG_MAX5821 is not set
# CONFIG_MCP4725 is not set
# CONFIG_MCP4922 is not set
# CONFIG_VF610_DAC is not set
# IIO dummy driver
# Frequency Synthesizers DDS/PLL
# Clock Generator/Distribution
# CONFIG_AD9523 is not set
# Phase-Locked Loop (PLL) frequency synthesizers
# CONFIG_ADF4350 is not set
# CONFIG_ADIS16080 is not set
# CONFIG_ADIS16130 is not set
# CONFIG_ADIS16136 is not set
# CONFIG_ADIS16260 is not set
# CONFIG_ADXRS450 is not set
# CONFIG_BMG160 is not set
# CONFIG_HID_SENSOR_GYRO_3D is not set
# CONFIG_MPU3050_I2C is not set
# CONFIG_IIO_ST_GYRO_3AXIS is not set
# CONFIG_ITG3200 is not set
# Health Sensors
# Heart Rate Monitors
# CONFIG_AFE4403 is not set
# CONFIG_AFE4404 is not set
# CONFIG_MAX30100 is not set
# CONFIG_MAX30102 is not set
# Humidity sensors
# CONFIG_AM2315 is not set
# CONFIG_DHT11 is not set
# CONFIG_HDC100X is not set
# CONFIG_HID_SENSOR_HUMIDITY is not set
# CONFIG_HTS221 is not set
# CONFIG_HTU21 is not set
# CONFIG_SI7005 is not set
# CONFIG_SI7020 is not set
# Inertial measurement units
# CONFIG_ADIS16400 is not set
# CONFIG_ADIS16480 is not set
# CONFIG_BMI160_I2C is not set
# CONFIG_BMI160_SPI is not set
# CONFIG_KMX61 is not set
# CONFIG_INV_MPU6050_I2C is not set
# CONFIG_INV_MPU6050_SPI is not set
# CONFIG_IIO_ST_LSM6DSX is not set
# Light sensors
# CONFIG_ADJD_S311 is not set
# CONFIG_AL3320A is not set
# CONFIG_APDS9300 is not set
# CONFIG_APDS9960 is not set
# CONFIG_BH1750 is not set
# CONFIG_BH1780 is not set
# CONFIG_CM32181 is not set
# CONFIG_CM3232 is not set
# CONFIG_CM3323 is not set
# CONFIG_CM3605 is not set
CONFIG_CM36651=y
# CONFIG_GP2AP020A00F is not set
# CONFIG_SENSORS_ISL29018 is not set
# CONFIG_SENSORS_ISL29028 is not set
# CONFIG_ISL29125 is not set
# CONFIG_HID_SENSOR_ALS is not set
# CONFIG_HID_SENSOR_PROX is not set
# CONFIG_JSA1212 is not set
# CONFIG_RPR0521 is not set
# CONFIG_LTR501 is not set
# CONFIG_MAX44000 is not set
# CONFIG_OPT3001 is not set
# CONFIG_PA12203001 is not set
# CONFIG_SI1145 is not set
# CONFIG_STK3310 is not set
# CONFIG_TCS3414 is not set
# CONFIG_TCS3472 is not set
# CONFIG_SENSORS_TSL2563 is not set
# CONFIG_TSL2583 is not set
# CONFIG_TSL4531 is not set
# CONFIG_US5182D is not set
# CONFIG_VCNL4000 is not set
# CONFIG_VEML6070 is not set
# CONFIG_VL6180 is not set
# Magnetometer sensors
# CONFIG_AK8974 is not set
CONFIG_AK8975=y
# CONFIG_AK09911 is not set
# CONFIG_BMC150_MAGN_I2C is not set
# CONFIG_BMC150_MAGN_SPI is not set
# CONFIG_MAG3110 is not set
# CONFIG_HID_SENSOR_MAGNETOMETER_3D is not set
# CONFIG_MMC35240 is not set
# CONFIG_IIO_ST_MAGN_3AXIS is not set
# CONFIG_SENSORS_HMC5843_I2C is not set
# CONFIG_SENSORS_HMC5843_SPI is not set
# Multiplexers
# CONFIG_IIO_MUX is not set
# Inclinometer sensors
# CONFIG_HID_SENSOR_INCLINOMETER_3D is not set
# CONFIG_HID_SENSOR_DEVICE_ROTATION is not set
# CONFIG_IIO_INTERRUPT_TRIGGER is not set
# CONFIG_IIO_SYSFS_TRIGGER is not set
# Digital potentiometers
# CONFIG_DS1803 is not set
# CONFIG_MAX5481 is not set
# CONFIG_MAX5487 is not set
# CONFIG_MCP4131 is not set
# CONFIG_MCP4531 is not set
# CONFIG_TPL0102 is not set
# Digital potentiostats
# CONFIG_LMP91000 is not set
# Pressure sensors
# CONFIG_ABP060MG is not set
# CONFIG_BMP280 is not set
# CONFIG_HID_SENSOR_PRESS is not set
# CONFIG_HP03 is not set
# CONFIG_MPL115_I2C is not set
# CONFIG_MPL115_SPI is not set
# CONFIG_MPL3115 is not set
# CONFIG_MS5611 is not set
# CONFIG_MS5637 is not set
# CONFIG_IIO_ST_PRESS is not set
# CONFIG_T5403 is not set
# CONFIG_HP206C is not set
# CONFIG_ZPA2326 is not set
# Lightning sensors
# CONFIG_AS3935 is not set
# Proximity and distance sensors
# CONFIG_LIDAR_LITE_V2 is not set
# CONFIG_SRF04 is not set
# CONFIG_SX9500 is not set
# CONFIG_SRF08 is not set
# Temperature sensors
# CONFIG_MAXIM_THERMOCOUPLE is not set
# CONFIG_HID_SENSOR_TEMP is not set
# CONFIG_MLX90614 is not set
# CONFIG_TMP006 is not set
# CONFIG_TMP007 is not set
# CONFIG_TSYS01 is not set
# CONFIG_TSYS02D is not set
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
# CONFIG_PWM_CROS_EC is not set
# CONFIG_PWM_FSL_FTM is not set
# CONFIG_PWM_PCA9685 is not set
CONFIG_PWM_SAMSUNG=y
CONFIG_IRQCHIP=y
CONFIG_ARM_GIC=y
CONFIG_ARM_GIC_MAX_NR=1
CONFIG_GIC_NON_BANKED=y
# CONFIG_IPACK_BUS is not set
# CONFIG_RESET_CONTROLLER is not set
# CONFIG_FMC is not set
# PHY Subsystem
CONFIG_GENERIC_PHY=y
# CONFIG_BCM_KONA_USB2_PHY is not set
# CONFIG_PHY_PXA_28NM_HSIC is not set
# CONFIG_PHY_PXA_28NM_USB2 is not set
# CONFIG_PHY_CPCAP_USB is not set
CONFIG_PHY_EXYNOS_DP_VIDEO=y
CONFIG_PHY_EXYNOS_MIPI_VIDEO=y
# CONFIG_PHY_EXYNOS_PCIE is not set
CONFIG_PHY_SAMSUNG_USB2=y
CONFIG_PHY_EXYNOS4210_USB2=y
CONFIG_PHY_EXYNOS4X12_USB2=y
CONFIG_PHY_EXYNOS5250_USB2=y
CONFIG_PHY_EXYNOS5_USBDRD=y
CONFIG_PHY_EXYNOS5250_SATA=y
# CONFIG_POWERCAP is not set
# CONFIG_MCB is not set
# Performance monitor support
CONFIG_ARM_PMU=y
# CONFIG_RAS is not set
# Android
# CONFIG_ANDROID is not set
CONFIG_DAX=y
CONFIG_NVMEM=y
# CONFIG_STM is not set
# CONFIG_INTEL_TH is not set
# CONFIG_FPGA is not set
# FSI support
# CONFIG_FSI is not set
# CONFIG_TEE is not set
# ODROID Specific Hardware
CONFIG_ODROID_EXYNOS5_SP=m
# Gator module for ARM streamline
CONFIG_GATOR=m
# CONFIG_GATOR_DO_NOT_ONLINE_CORES_AT_STARTUP is not set
CONFIG_GATOR_WITH_MALI_SUPPORT=y
# CONFIG_GATOR_MALI_4XXMP is not set
CONFIG_GATOR_MALI_MIDGARD=y
CONFIG_GATOR_MALI_MIDGARD_PATH="drivers/gpu/arm/midgard"
# Firmware Drivers
# CONFIG_FIRMWARE_MEMMAP is not set
CONFIG_HAVE_ARM_SMCCC=y
# CONFIG_GOOGLE_FIRMWARE is not set
# Tegra firmware driver
# File systems
CONFIG_DCACHE_WORD_ACCESS=y
CONFIG_FS_IOMAP=y
CONFIG_EXT2_FS=y
# CONFIG_EXT2_FS_XATTR is not set
CONFIG_EXT3_FS=y
CONFIG_EXT3_FS_POSIX_ACL=y
CONFIG_EXT3_FS_SECURITY=y
CONFIG_EXT4_FS=y
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_EXT4_FS_SECURITY=y
CONFIG_EXT4_ENCRYPTION=y
CONFIG_EXT4_FS_ENCRYPTION=y
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=y
CONFIG_REISERFS_FS=m
# CONFIG_REISERFS_CHECK is not set
CONFIG_REISERFS_PROC_INFO=y
CONFIG_REISERFS_FS_XATTR=y
CONFIG_REISERFS_FS_POSIX_ACL=y
CONFIG_REISERFS_FS_SECURITY=y
# CONFIG_JFS_FS is not set
CONFIG_XFS_FS=m
CONFIG_XFS_QUOTA=y
CONFIG_XFS_POSIX_ACL=y
CONFIG_XFS_RT=y
# CONFIG_XFS_WARN is not set
# CONFIG_XFS_DEBUG is not set
# CONFIG_GFS2_FS is not set
CONFIG_OCFS2_FS=m
CONFIG_OCFS2_FS_O2CB=m
CONFIG_OCFS2_FS_STATS=y
CONFIG_OCFS2_DEBUG_MASKLOG=y
# CONFIG_OCFS2_DEBUG_FS is not set
CONFIG_BTRFS_FS=m
CONFIG_BTRFS_FS_POSIX_ACL=y
# CONFIG_BTRFS_FS_CHECK_INTEGRITY is not set
# CONFIG_BTRFS_FS_RUN_SANITY_TESTS is not set
# CONFIG_BTRFS_DEBUG is not set
# CONFIG_BTRFS_ASSERT is not set
# CONFIG_NILFS2_FS is not set
CONFIG_F2FS_FS=m
CONFIG_F2FS_STAT_FS=y
CONFIG_F2FS_FS_XATTR=y
CONFIG_F2FS_FS_POSIX_ACL=y
CONFIG_F2FS_FS_SECURITY=y
CONFIG_F2FS_CHECK_FS=y
CONFIG_F2FS_FS_ENCRYPTION=y
# CONFIG_F2FS_FAULT_INJECTION is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
CONFIG_EXPORTFS_BLOCK_OPS=y
CONFIG_FILE_LOCKING=y
CONFIG_MANDATORY_FILE_LOCKING=y
CONFIG_FS_ENCRYPTION=y
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_FANOTIFY is not set
CONFIG_QUOTA=y
CONFIG_QUOTA_NETLINK_INTERFACE=y
# CONFIG_PRINT_QUOTA_WARNING is not set
# CONFIG_QUOTA_DEBUG is not set
CONFIG_QUOTA_TREE=m
CONFIG_QFMT_V1=m
CONFIG_QFMT_V2=m
CONFIG_QUOTACTL=y
CONFIG_AUTOFS4_FS=y
CONFIG_FUSE_FS=m
# CONFIG_CUSE is not set
CONFIG_OVERLAY_FS=m
# CONFIG_OVERLAY_FS_REDIRECT_DIR is not set
# CONFIG_OVERLAY_FS_INDEX is not set
# Caches
CONFIG_FSCACHE=m
# CONFIG_FSCACHE_STATS is not set
# CONFIG_FSCACHE_HISTOGRAM is not set
# CONFIG_FSCACHE_DEBUG is not set
# CONFIG_FSCACHE_OBJECT_LIST is not set
# CONFIG_CACHEFILES is not set
# CD-ROM/DVD Filesystems
CONFIG_ISO9660_FS=m
CONFIG_JOLIET=y
CONFIG_ZISOFS=y
CONFIG_UDF_FS=m
CONFIG_UDF_NLS=y
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
CONFIG_FAT_DEFAULT_UTF8=y
CONFIG_NTFS_FS=m
# CONFIG_NTFS_DEBUG is not set
CONFIG_NTFS_RW=y
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
# CONFIG_PROC_CHILDREN is not set
CONFIG_KERNFS=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_TMPFS_XATTR=y
# CONFIG_HUGETLB_PAGE is not set
CONFIG_CONFIGFS_FS=y
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ORANGEFS_FS is not set
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_ECRYPT_FS is not set
CONFIG_HFS_FS=m
CONFIG_HFSPLUS_FS=m
CONFIG_HFSPLUS_FS_POSIX_ACL=y
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
CONFIG_CRAMFS=y
CONFIG_SQUASHFS=y
CONFIG_SQUASHFS_FILE_CACHE=y
# CONFIG_SQUASHFS_FILE_DIRECT is not set
CONFIG_SQUASHFS_DECOMP_SINGLE=y
# CONFIG_SQUASHFS_DECOMP_MULTI is not set
# CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set
CONFIG_SQUASHFS_XATTR=y
CONFIG_SQUASHFS_ZLIB=y
CONFIG_SQUASHFS_LZ4=y
CONFIG_SQUASHFS_LZO=y
CONFIG_SQUASHFS_XZ=y
CONFIG_SQUASHFS_ZSTD=y
CONFIG_SQUASHFS_4K_DEVBLK_SIZE=y
# CONFIG_SQUASHFS_EMBEDDED is not set
CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
# CONFIG_VXFS_FS is not set
CONFIG_MINIX_FS=m
# CONFIG_OMFS_FS is not set
CONFIG_HPFS_FS=m
# CONFIG_QNX4FS_FS is not set
# CONFIG_QNX6FS_FS is not set
CONFIG_ROMFS_FS=y
CONFIG_ROMFS_BACKED_BY_BLOCK=y
CONFIG_ROMFS_ON_BLOCK=y
# CONFIG_PSTORE is not set
# CONFIG_SYSV_FS is not set
CONFIG_UFS_FS=m
CONFIG_UFS_FS_WRITE=y
# CONFIG_UFS_DEBUG is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V2=y
CONFIG_NFS_V3=y
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=y
CONFIG_NFS_SWAP=y
CONFIG_NFS_V4_1=y
CONFIG_NFS_V4_2=y
CONFIG_PNFS_FILE_LAYOUT=y
CONFIG_PNFS_BLOCK=y
CONFIG_PNFS_FLEXFILE_LAYOUT=m
CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org"
CONFIG_NFS_V4_1_MIGRATION=y
CONFIG_ROOT_NFS=y
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
CONFIG_NFSD=m
CONFIG_NFSD_V2_ACL=y
CONFIG_NFSD_V3=y
CONFIG_NFSD_V3_ACL=y
CONFIG_NFSD_V4=y
CONFIG_NFSD_PNFS=y
CONFIG_NFSD_BLOCKLAYOUT=y
CONFIG_NFSD_SCSILAYOUT=y
CONFIG_NFSD_FLEXFILELAYOUT=y
CONFIG_GRACE_PERIOD=y
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_NFS_ACL_SUPPORT=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
CONFIG_SUNRPC_GSS=y
CONFIG_SUNRPC_BACKCHANNEL=y
CONFIG_SUNRPC_SWAP=y
CONFIG_RPCSEC_GSS_KRB5=m
# CONFIG_SUNRPC_DEBUG is not set
# CONFIG_CEPH_FS is not set
CONFIG_CIFS=m
# CONFIG_CIFS_STATS is not set
CONFIG_CIFS_ALLOW_INSECURE_LEGACY=y
CONFIG_CIFS_WEAK_PW_HASH=y
CONFIG_CIFS_UPCALL=y
CONFIG_CIFS_XATTR=y
CONFIG_CIFS_POSIX=y
CONFIG_CIFS_ACL=y
# CONFIG_CIFS_DEBUG is not set
CONFIG_CIFS_DFS_UPCALL=y
CONFIG_CIFS_SMB311=y
CONFIG_CIFS_FSCACHE=y
# CONFIG_NCP_FS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_CODEPAGE_737=m
CONFIG_NLS_CODEPAGE_775=m
CONFIG_NLS_CODEPAGE_850=m
CONFIG_NLS_CODEPAGE_852=m
CONFIG_NLS_CODEPAGE_855=m
CONFIG_NLS_CODEPAGE_857=m
CONFIG_NLS_CODEPAGE_860=m
CONFIG_NLS_CODEPAGE_861=m
CONFIG_NLS_CODEPAGE_862=m
CONFIG_NLS_CODEPAGE_863=m
CONFIG_NLS_CODEPAGE_864=m
CONFIG_NLS_CODEPAGE_865=m
CONFIG_NLS_CODEPAGE_866=m
CONFIG_NLS_CODEPAGE_869=m
CONFIG_NLS_CODEPAGE_936=m
CONFIG_NLS_CODEPAGE_950=m
CONFIG_NLS_CODEPAGE_932=m
CONFIG_NLS_CODEPAGE_949=m
CONFIG_NLS_CODEPAGE_874=m
CONFIG_NLS_ISO8859_8=m
CONFIG_NLS_CODEPAGE_1250=m
CONFIG_NLS_CODEPAGE_1251=m
CONFIG_NLS_ASCII=y
CONFIG_NLS_ISO8859_1=y
CONFIG_NLS_ISO8859_2=m
CONFIG_NLS_ISO8859_3=m
CONFIG_NLS_ISO8859_4=m
CONFIG_NLS_ISO8859_5=m
CONFIG_NLS_ISO8859_6=m
CONFIG_NLS_ISO8859_7=m
CONFIG_NLS_ISO8859_9=m
CONFIG_NLS_ISO8859_13=m
CONFIG_NLS_ISO8859_14=m
CONFIG_NLS_ISO8859_15=m
CONFIG_NLS_KOI8_R=m
CONFIG_NLS_KOI8_U=m
CONFIG_NLS_MAC_ROMAN=m
CONFIG_NLS_MAC_CELTIC=m
CONFIG_NLS_MAC_CENTEURO=m
CONFIG_NLS_MAC_CROATIAN=m
CONFIG_NLS_MAC_CYRILLIC=m
CONFIG_NLS_MAC_GAELIC=m
CONFIG_NLS_MAC_GREEK=m
CONFIG_NLS_MAC_ICELAND=m
CONFIG_NLS_MAC_INUIT=m
CONFIG_NLS_MAC_ROMANIAN=m
CONFIG_NLS_MAC_TURKISH=m
CONFIG_NLS_UTF8=m
# CONFIG_DLM is not set
# Kernel hacking
# printk and dmesg options
CONFIG_PRINTK_TIME=y
CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
CONFIG_DYNAMIC_DEBUG=y
# Compile-time checks and compiler options
CONFIG_ENABLE_WARN_DEPRECATED=y
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_UNUSED_SYMBOLS is not set
CONFIG_DEBUG_FS=y
# CONFIG_HEADERS_CHECK is not set
# CONFIG_DEBUG_SECTION_MISMATCH is not set
CONFIG_SECTION_MISMATCH_WARN_ONLY=y
CONFIG_MAGIC_SYSRQ=y
CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1
CONFIG_MAGIC_SYSRQ_SERIAL=y
# CONFIG_DEBUG_KERNEL is not set
# Memory Debugging
# CONFIG_PAGE_EXTENSION is not set
# CONFIG_PAGE_POISONING is not set
# CONFIG_DEBUG_RODATA_TEST is not set
# CONFIG_SLUB_DEBUG_ON is not set
# CONFIG_SLUB_STATS is not set
CONFIG_HAVE_DEBUG_KMEMLEAK=y
CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
CONFIG_DEBUG_MEMORY_INIT=y
# Debug Lockups and Hangs
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
CONFIG_SCHED_INFO=y
# CONFIG_DEBUG_TIMEKEEPING is not set
# Lock Debugging (spinlocks, mutexes, etc...)
# CONFIG_WW_MUTEX_SELFTEST is not set
CONFIG_STACKTRACE=y
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
CONFIG_DEBUG_BUGVERBOSE=y
# RCU Debugging
# CONFIG_PROVE_RCU is not set
# CONFIG_TORTURE_TEST is not set
CONFIG_RCU_CPU_STALL_TIMEOUT=21
CONFIG_NOP_TRACER=y
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_TRACE_CLOCK=y
CONFIG_RING_BUFFER=y
CONFIG_EVENT_TRACING=y
CONFIG_CONTEXT_SWITCH_TRACER=y
CONFIG_TRACING=y
CONFIG_TRACING_SUPPORT=y
CONFIG_FTRACE=y
# CONFIG_FUNCTION_TRACER is not set
# CONFIG_IRQSOFF_TRACER is not set
# CONFIG_PREEMPT_TRACER is not set
# CONFIG_SCHED_TRACER is not set
# CONFIG_HWLAT_TRACER is not set
CONFIG_ENABLE_DEFAULT_TRACERS=y
# CONFIG_FTRACE_SYSCALLS is not set
# CONFIG_TRACER_SNAPSHOT is not set
CONFIG_BRANCH_PROFILE_NONE=y
# CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
# CONFIG_PROFILE_ALL_BRANCHES is not set
# CONFIG_STACK_TRACER is not set
# CONFIG_BLK_DEV_IO_TRACE is not set
CONFIG_UPROBE_EVENTS=y
CONFIG_BPF_EVENTS=y
CONFIG_PROBE_EVENTS=y
# CONFIG_TRACEPOINT_BENCHMARK is not set
# CONFIG_RING_BUFFER_BENCHMARK is not set
# CONFIG_RING_BUFFER_STARTUP_TEST is not set
# CONFIG_TRACE_EVAL_MAP_FILE is not set
CONFIG_TRACING_EVENTS_GPIO=y
# CONFIG_DMA_API_DEBUG is not set
# Runtime Testing
# CONFIG_LKDTM is not set
# CONFIG_TEST_LIST_SORT is not set
# CONFIG_TEST_SORT is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_ASYNC_RAID6_TEST is not set
# CONFIG_TEST_HEXDUMP is not set
# CONFIG_TEST_STRING_HELPERS is not set
# CONFIG_TEST_KSTRTOX is not set
# CONFIG_TEST_PRINTF is not set
# CONFIG_TEST_BITMAP is not set
# CONFIG_TEST_UUID is not set
# CONFIG_TEST_RHASHTABLE is not set
# CONFIG_TEST_HASH is not set
# CONFIG_TEST_LKM is not set
# CONFIG_TEST_USER_COPY is not set
# CONFIG_TEST_BPF is not set
# CONFIG_TEST_FIRMWARE is not set
# CONFIG_TEST_SYSCTL is not set
# CONFIG_TEST_UDELAY is not set
# CONFIG_TEST_STATIC_KEYS is not set
# CONFIG_TEST_KMOD is not set
# CONFIG_MEMTEST is not set
# CONFIG_BUG_ON_DATA_CORRUPTION is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_ARCH_WANTS_UBSAN_NO_NULL is not set
# CONFIG_UBSAN is not set
CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y
# CONFIG_STRICT_DEVMEM is not set
CONFIG_ARM_UNWIND=y
# CONFIG_DEBUG_USER is not set
CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
# CONFIG_DEBUG_UART_8250 is not set
CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
# CONFIG_PID_IN_CONTEXTIDR is not set
# CONFIG_CORESIGHT is not set
# Security options
CONFIG_KEYS=y
# CONFIG_PERSISTENT_KEYRINGS is not set
# CONFIG_BIG_KEYS is not set
# CONFIG_TRUSTED_KEYS is not set
CONFIG_ENCRYPTED_KEYS=y
# CONFIG_KEY_DH_OPERATIONS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
CONFIG_SECURITYFS=y
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
# CONFIG_HARDENED_USERCOPY is not set
# CONFIG_STATIC_USERMODEHELPER is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_DEFAULT_SECURITY=""
CONFIG_XOR_BLOCKS=m
CONFIG_ASYNC_CORE=m
CONFIG_ASYNC_MEMCPY=m
CONFIG_ASYNC_XOR=m
CONFIG_ASYNC_PQ=m
CONFIG_ASYNC_RAID6_RECOV=m
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_RNG_DEFAULT=y
CONFIG_CRYPTO_AKCIPHER2=y
CONFIG_CRYPTO_AKCIPHER=y
CONFIG_CRYPTO_KPP2=y
CONFIG_CRYPTO_KPP=m
CONFIG_CRYPTO_ACOMP2=y
CONFIG_CRYPTO_RSA=m
CONFIG_CRYPTO_DH=m
CONFIG_CRYPTO_ECDH=m
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
CONFIG_CRYPTO_USER=m
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
CONFIG_CRYPTO_GF128MUL=y
CONFIG_CRYPTO_NULL=y
CONFIG_CRYPTO_NULL2=y
CONFIG_CRYPTO_PCRYPT=m
CONFIG_CRYPTO_WORKQUEUE=y
CONFIG_CRYPTO_CRYPTD=m
CONFIG_CRYPTO_MCRYPTD=m
CONFIG_CRYPTO_AUTHENC=m
CONFIG_CRYPTO_TEST=m
CONFIG_CRYPTO_SIMD=m
# Authenticated Encryption with Associated Data
CONFIG_CRYPTO_CCM=m
CONFIG_CRYPTO_GCM=m
CONFIG_CRYPTO_CHACHA20POLY1305=m
CONFIG_CRYPTO_SEQIV=y
CONFIG_CRYPTO_ECHAINIV=m
# Block modes
CONFIG_CRYPTO_CBC=y
CONFIG_CRYPTO_CTR=y
CONFIG_CRYPTO_CTS=y
CONFIG_CRYPTO_ECB=y
CONFIG_CRYPTO_LRW=m
CONFIG_CRYPTO_PCBC=m
CONFIG_CRYPTO_XTS=y
CONFIG_CRYPTO_KEYWRAP=m
# Hash modes
CONFIG_CRYPTO_CMAC=m
CONFIG_CRYPTO_HMAC=y
CONFIG_CRYPTO_XCBC=m
CONFIG_CRYPTO_VMAC=m
# Digest
CONFIG_CRYPTO_CRC32C=y
CONFIG_CRYPTO_CRC32=m
CONFIG_CRYPTO_CRCT10DIF=y
CONFIG_CRYPTO_GHASH=m
CONFIG_CRYPTO_POLY1305=m
CONFIG_CRYPTO_MD4=m
CONFIG_CRYPTO_MD5=y
CONFIG_CRYPTO_MICHAEL_MIC=m
CONFIG_CRYPTO_RMD128=m
CONFIG_CRYPTO_RMD160=m
CONFIG_CRYPTO_RMD256=m
CONFIG_CRYPTO_RMD320=m
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=y
CONFIG_CRYPTO_SHA512=m
CONFIG_CRYPTO_SHA3=m
CONFIG_CRYPTO_TGR192=m
CONFIG_CRYPTO_WP512=m
# Ciphers
CONFIG_CRYPTO_AES=y
CONFIG_CRYPTO_AES_TI=m
CONFIG_CRYPTO_ANUBIS=m
CONFIG_CRYPTO_ARC4=y
CONFIG_CRYPTO_BLOWFISH=m
CONFIG_CRYPTO_BLOWFISH_COMMON=m
CONFIG_CRYPTO_CAMELLIA=m
CONFIG_CRYPTO_CAST_COMMON=m
CONFIG_CRYPTO_CAST5=m
CONFIG_CRYPTO_CAST6=m
CONFIG_CRYPTO_DES=m
CONFIG_CRYPTO_FCRYPT=m
CONFIG_CRYPTO_KHAZAD=m
CONFIG_CRYPTO_SALSA20=m
CONFIG_CRYPTO_CHACHA20=m
CONFIG_CRYPTO_SEED=m
CONFIG_CRYPTO_SERPENT=m
CONFIG_CRYPTO_TEA=m
CONFIG_CRYPTO_TWOFISH=m
CONFIG_CRYPTO_TWOFISH_COMMON=m
# Compression
CONFIG_CRYPTO_DEFLATE=m
CONFIG_CRYPTO_LZO=m
CONFIG_CRYPTO_842=m
CONFIG_CRYPTO_LZ4=m
CONFIG_CRYPTO_LZ4HC=m
CONFIG_CRYPTO_ZSTD=m
# Random Number Generation
CONFIG_CRYPTO_ANSI_CPRNG=m
CONFIG_CRYPTO_DRBG_MENU=y
CONFIG_CRYPTO_DRBG_HMAC=y
# CONFIG_CRYPTO_DRBG_HASH is not set
# CONFIG_CRYPTO_DRBG_CTR is not set
CONFIG_CRYPTO_DRBG=y
CONFIG_CRYPTO_JITTERENTROPY=y
CONFIG_CRYPTO_USER_API=m
CONFIG_CRYPTO_USER_API_HASH=m
CONFIG_CRYPTO_USER_API_SKCIPHER=m
CONFIG_CRYPTO_USER_API_RNG=m
CONFIG_CRYPTO_USER_API_AEAD=m
CONFIG_CRYPTO_HASH_INFO=y
CONFIG_CRYPTO_HW=y
# CONFIG_CRYPTO_DEV_FSL_CAAM_CRYPTO_API_DESC is not set
# CONFIG_CRYPTO_DEV_EXYNOS_RNG is not set
CONFIG_CRYPTO_DEV_S5P=y
CONFIG_CRYPTO_DEV_EXYNOS_HASH=y
CONFIG_ASYMMETRIC_KEY_TYPE=y
CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
CONFIG_X509_CERTIFICATE_PARSER=y
CONFIG_PKCS7_MESSAGE_PARSER=y
# Certificates for signature checking
CONFIG_SYSTEM_TRUSTED_KEYRING=y
CONFIG_SYSTEM_TRUSTED_KEYS=""
# CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set
# CONFIG_SECONDARY_TRUSTED_KEYRING is not set
# CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
CONFIG_ARM_CRYPTO=y
CONFIG_CRYPTO_SHA1_ARM=m
CONFIG_CRYPTO_SHA1_ARM_NEON=m
CONFIG_CRYPTO_SHA1_ARM_CE=m
CONFIG_CRYPTO_SHA2_ARM_CE=m
CONFIG_CRYPTO_SHA256_ARM=m
CONFIG_CRYPTO_SHA512_ARM=m
CONFIG_CRYPTO_AES_ARM=m
CONFIG_CRYPTO_AES_ARM_BS=m
CONFIG_CRYPTO_AES_ARM_CE=m
CONFIG_CRYPTO_GHASH_ARM_CE=m
CONFIG_CRYPTO_CRCT10DIF_ARM_CE=m
CONFIG_CRYPTO_CRC32_ARM_CE=m
CONFIG_CRYPTO_CHACHA20_NEON=m
CONFIG_BINARY_PRINTF=y
# Library routines
CONFIG_RAID6_PQ=m
CONFIG_BITREVERSE=y
CONFIG_HAVE_ARCH_BITREVERSE=y
CONFIG_RATIONAL=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
CONFIG_GENERIC_PCI_IOMAP=y
CONFIG_GENERIC_IO=y
CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
CONFIG_CRC_CCITT=y
CONFIG_CRC16=y
CONFIG_CRC_T10DIF=y
CONFIG_CRC_ITU_T=y
CONFIG_CRC32=y
# CONFIG_CRC32_SELFTEST is not set
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
# CONFIG_CRC4 is not set
# CONFIG_CRC7 is not set
CONFIG_LIBCRC32C=m
# CONFIG_CRC8 is not set
CONFIG_XXHASH=y
CONFIG_AUDIT_GENERIC=y
# CONFIG_AUDIT_ARCH_COMPAT_GENERIC is not set
# CONFIG_RANDOM32_SELFTEST is not set
CONFIG_842_COMPRESS=m
CONFIG_842_DECOMPRESS=m
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=m
CONFIG_LZO_COMPRESS=m
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_COMPRESS=m
CONFIG_LZ4HC_COMPRESS=m
CONFIG_LZ4_DECOMPRESS=y
CONFIG_ZSTD_COMPRESS=m
CONFIG_ZSTD_DECOMPRESS=y
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_DECOMPRESS_LZ4=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_REED_SOLOMON=m
CONFIG_REED_SOLOMON_DEC8=y
CONFIG_TEXTSEARCH=y
CONFIG_TEXTSEARCH_KMP=m
CONFIG_TEXTSEARCH_BM=m
CONFIG_TEXTSEARCH_FSM=m
CONFIG_ASSOCIATIVE_ARRAY=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_DMA=y
CONFIG_SGL_ALLOC=y
# CONFIG_DMA_NOOP_OPS is not set
# CONFIG_DMA_VIRT_OPS is not set
CONFIG_CPU_RMAP=y
CONFIG_DQL=y
CONFIG_GLOB=y
# CONFIG_GLOB_SELFTEST is not set
CONFIG_NLATTR=y
CONFIG_LRU_CACHE=m
CONFIG_CLZ_TAB=y
# CONFIG_CORDIC is not set
# CONFIG_DDR is not set
# CONFIG_IRQ_POLL is not set
CONFIG_MPILIB=y
CONFIG_LIBFDT=y
CONFIG_OID_REGISTRY=y
CONFIG_FONT_SUPPORT=y
CONFIG_FONTS=y
# CONFIG_FONT_8x8 is not set
CONFIG_FONT_8x16=y
# CONFIG_FONT_6x11 is not set
CONFIG_FONT_7x14=y
# CONFIG_FONT_PEARL_8x8 is not set
# CONFIG_FONT_ACORN_8x8 is not set
# CONFIG_FONT_MINI_4x6 is not set
# CONFIG_FONT_6x10 is not set
# CONFIG_FONT_10x18 is not set
# CONFIG_FONT_SUN8x16 is not set
# CONFIG_FONT_SUN12x22 is not set
# CONFIG_SG_SPLIT is not set
CONFIG_SG_POOL=y
CONFIG_ARCH_HAS_SG_CHAIN=y
CONFIG_SBITMAP=y
# CONFIG_STRING_SELFTEST is not set
# CONFIG_VIRTUALIZATION is not set
#7 2020-02-27 23:20:12
Illegalum
Re: Devuan on Odroid HC1
cpuinfo
processor	: 0
model name	: ARMv7 Processor rev 3 (v7l)
BogoMIPS	: 90.00
Features	: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xc07
CPU revision	: 3
processor	: 1
BogoMIPS	: 90.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xc07
CPU revision	: 3
processor	: 2
BogoMIPS	: 90.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xc07
CPU revision	: 3
processor	: 3
BogoMIPS	: 90.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xc07
CPU revision	: 3
processor	: 4
BogoMIPS	: 120.00
CPU architecture: 7
CPU variant	: 0x2
CPU part	: 0xc0f
CPU revision	: 3
processor	: 5
BogoMIPS	: 120.00
CPU architecture: 7
CPU variant	: 0x2
CPU part	: 0xc0f
CPU revision	: 3
processor	: 6
BogoMIPS	: 120.00
CPU architecture: 7
CPU variant	: 0x2
CPU part	: 0xc0f
CPU revision	: 3
processor	: 7
BogoMIPS	: 120.00
CPU architecture: 7
CPU variant	: 0x2
CPU part	: 0xc0f
CPU revision	: 3
Hardware	: ODROID-XU3
Revision	: 0100
Serial		: 0000000000000000
#8 2020-02-27 23:27:03
Illegalum
The current debian -> devuan converted version is running everything  so copying data there is not a problem. the commands were also not a problem , just as you said a  lot of data so wasn't sure how readable it would be after pasting , actually the code box keeps it nice and clear.
Lum
#9 2020-02-28 19:39:09
tuxd3v
hello, yes it was nice smile
Can you do this as root ?
find /boot -type f -exec ls -l {} \;
to see how boot loader is configured
I already compiled a kernel smile
regards,
tux
Best Regards,
tux
#10 2020-02-29 06:48:56
Illegalum
sure i can ,
:~# find /boot -type f -exec ls -l {} \;
-rwxr-xr-x 1 root root 5699608 Feb 25 14:34 /boot/zImage
-rwxr-xr-x 1 root root 9958 Feb 25 14:31 /boot/boot.ini
-rwxr-xr-x 1 root root 150790 Mar 22  2018 /boot/config-4.14.28+
-rwxr-xr-x 1 root root 151263 Jan 20 11:01 /boot/config-4.14.165+
-rwxr-xr-x 1 root root 56387 Jan 20 11:05 /boot/exynos5422-odroidhc1.dtb
-rwxr-xr-x 1 root root 5572827 Feb 25 14:34 /boot/uInitrd-4.14.165+
-rwxr-xr-x 1 root root 5661776 Mar 22  2018 /boot/vmlinuz-4.14.28+
-rwxr-xr-x 1 root root 5711842 Feb 25 14:34 /boot/uInitrd-4.14.28+
-rwxr-xr-x 1 root root 2684702 Mar 22  2018 /boot/System.map-4.14.28+
-rwxr-xr-x 1 root root 5711778 Mar 24  2018 /boot/initrd.img-4.14.28+
-rwxr-xr-x 1 root root 62462 Jan 20 11:05 /boot/exynos5422-odroidxu3-lite.dtb
-rwxr-xr-x 1 root root 63517 Jan 20 11:05 /boot/exynos5422-odroidxu3.dtb
-rwxr-xr-x 1 root root 63628 Jan 20 11:05 /boot/exynos5422-odroidxu4-kvm.dtb
-rwxr-xr-x 1 root root 63484 Jan 20 11:05 /boot/exynos5422-odroidxu4.dtb
-rwxr-xr-x 1 root root 5699608 Jan 20 11:01 /boot/vmlinuz-4.14.165+
-rwxr-xr-x 1 root root 2703487 Jan 20 11:01 /boot/System.map-4.14.165+
-rwxr-xr-x 1 root root 9806 Mar 24  2018 /boot/boot.ini.orig
-rwxr-xr-x 1 root root 12 Feb 25 15:10 /boot/System Volume Information/WPSettings.dat
-rwxr-xr-x 1 root root 76 Feb 25 15:10 /boot/System Volume Information/IndexerVolumeGuid
-rwxr-xr-x 1 root root 5572767 Feb 25 14:34 /boot/initrd.img-4.14.165+
Lum
#11 2020-02-29 17:36:05
tuxd3v
Hello Illegalum,
Seems that '/boot/boot.ini' is were uboot is configured..
I don't know its contents, it sould be were dtb/kernel files are loaded..
Best Regards,
tux
#12 2020-02-29 19:27:51
Illegalum
Hope it's more useful to you then to me wink
cat boot.ini
ODROIDXU-UBOOT-CONFIG
# U-Boot Parameters
setenv initrd_high "0xffffffff"
setenv fdt_high "0xffffffff"
# Mac address configuration
setenv macaddr "00:1e:06:61:7a:87
# Basic Ubuntu Setup. Don't touch unless you know what you are doing.
setenv bootrootfs "console=tty1 console=ttySAC2,115200n8 root=UUID=e139ce78-9841-40fe-8823-96a304a09859 rootwait ro fsck.repair=yes net.ifnames=0"
# --- Screen Configuration for HDMI --- #
# Uncomment only ONE line! Leave all commented for automatic selection.
# Uncomment only the setenv line!
# ODROID-VU forced resolution
# setenv videoconfig "video=HDMI-A-1:1280x800@60"
# ODROID-VU forced EDID
# setenv videoconfig "drm_kms_helper.edid_firmware=edid/1280x800.bin"
# 1920x1080 (1080P) with monitor provided EDID information. (1080p-edid)
# setenv videoconfig "video=HDMI-A-1:1920x1080@60"
# 1920x1080 (1080P) without monitor data using generic information (1080p-noedid)
# setenv videoconfig "drm_kms_helper.edid_firmware=edid/1920x1080.bin"
# 1920x1080 50hz (1080P) with monitor provided EDID information. (1080p 50hz-edid)
# setenv videoconfig "video=HDMI-A-1:1920x1080@50"
# 1920x1080 50hz (1080P) without monitor data using generic information (1080p 50hz-noedid)
# setenv videoconfig "drm_kms_helper.edid_firmware=edid/1920x1080_50hz.bin"
# 1440x900 with monitor provided EDID information.
# setenv videoconfig "video=HDMI-A-1:1440x900@60"
# 1440x900 without monitor data using generic information
# setenv videoconfig "drm_kms_helper.edid_firmware=edid/1440x900.bin"
# 1280x1024 without monitor data using generic information
# setenv videoconfig "drm_kms_helper.edid_firmware=edid/1280x1024.bin"
# 1280x720 (720P) with monitor provided EDID information. (720p-edid)
# setenv videoconfig "video=HDMI-A-1:1280x720@60"
# 1280x720 (720P) without monitor data using generic information (720p-noedid)
# setenv videoconfig "drm_kms_helper.edid_firmware=edid/1280x720.bin"
# 1024x768 without monitor data using generic information
# setenv videoconfig "drm_kms_helper.edid_firmware=edid/1024x768.bin"
# 1024x600 without monitor data using generic information (ODROID VU7+)
# setenv videoconfig "drm_kms_helper.edid_firmware=edid/1024x600.bin"
# 800x600 without monitor data using generic information
# setenv videoconfig "drm_kms_helper.edid_firmware=edid/800x600.bin"
# 800x480 without monitor data using generic information (ODROID 7")
# setenv videoconfig "drm_kms_helper.edid_firmware=edid/800x480.bin"
# 720x576 without monitor data using generic information
# setenv videoconfig "drm_kms_helper.edid_firmware=edid/720x576.bin"
# 720x480 without monitor data using generic information
# setenv videoconfig "drm_kms_helper.edid_firmware=edid/720x480.bin"
# 640x480 without monitor data using generic information
# setenv videoconfig "drm_kms_helper.edid_firmware=edid/640x480.bin"
# --- HDMI / DVI Mode Selection ---
# - HDMI Mode
setenv vout "hdmi"
# - DVI Mode (disables sound over HDMI as per DVI compat)
# setenv vout "dvi"
# --- HDMI CEC Configuration ---
setenv cecenable "false" # false or true
# set to true to enable HDMI CEC
# --- CPU Governor Setup ---
# Uncomment only one line. New governor is set after 90secs after boot.
# - Performance (Keep all the CPU's at Maximum frequency)
setenv governor "performance"
# - Ondemand
# setenv governor "ondemand"
# - Interactive (Pretty much just like ondemand with more possible customization via sysfs.)
# setenv governor "interactive"
# - Conservative (Like ondemand, but do the frequency transitions more slowly, great for battery powered applications)
# setenv governor "conservative"
# - Powersave (Keeps the CPU's to the lowest possible temps)
# setenv governor "powersave"
# Enable/Disable ODROID-VU7 Touchsreen
setenv disable_vu7 "true" # false
# DRAM Frequency
# Sets the LPDDR3 memory frequency
# Supported values: 933 825 728 633 (MHZ)
setenv ddr_freq 825
# HDMI-PHY Parameter Control
# HDMI Hot Plug detection
# Forces the HDMI subsystem to ignore the check if the cable is connected or
# not.
# false : disable the detection and force it as connected.
# true : let cable, board and monitor decide the connection status.
# default: true
setenv HPD "true"
#  TMDS data amplitude control.
#  1LSB corresponds to 20 mVdiff amplitude level.
#  tx_amp_lvl : 0 = 760 mVdiff(Min), 31 = 1380 mVdiff(Max)
#  Hardkernel default hdmi_tx_amp_lvl = 31(1380 mVdiff);
setenv hdmi_tx_amp_lvl  "31"
#  TMDS data amplitude fine control for each channel.
#  tx_lvl : 0 = 0 mVdiff(Min), 3 = 60 mVdiff(Max)
#      hdmi_tx_lvl_ch0 = 3, hdmi_tx_lvl_ch1 = 3, hdmi_tx_lvl_ch2 = 3,
setenv hdmi_tx_lvl_ch0      "3"
setenv hdmi_tx_lvl_ch1      "3"
setenv hdmi_tx_lvl_ch2      "3"
#  TMDS data pre-emphasis level control.
#  1LSB corresponds to -0.45dB emphasis level except for 1
#  tx_emp_lvl : 0 = 0 db(Min), 1 = -0.25 db, 2 = 0.7 db, 15 = -7.45 db(Max)
#  Hardkernel default hdmi_tx_emp_lvl = 6 (-2.50 db);
setenv hdmi_tx_emp_lvl      "6"
#  TMDS clock amplitude control.
#  clk_amp_lvl : 0 = 790 mVdiff(Min), 31 = 1410 mVdiff(Max)
#  Hardkernel default hdmi_clk_amp_lvl = 31 (1410 mVdiff)
setenv hdmi_clk_amp_lvl     "31"
#  TMDS data source termination resistor control.
#  tx_res :
#      0 = Source Termination OFF(Min), 1 = 200 ohm, 2 = 300 ohm, 3 = 120 ohm(Max)
#  Hardkernrel default hdmi_tx_res = 0 (Source Termination OFF)
setenv hdmi_tx_res      "0"
setenv hdmi_phy_control "hdmi_tx_amp_lvl=${hdmi_tx_amp_lvl} hdmi_tx_lvl_ch0=${hdmi_tx_lvl_ch0} hdmi_tx_lvl_ch1=${hdmi_tx_lvl_ch1} hdmi_tx_lvl_ch2=${hdmi_tx_lvl_ch2} hdmi_tx_emp_lvl=${hdmi_tx_emp_lvl} hdmi_clk_amp_lvl=${hdmi_clk_amp_lvl} hdmi_tx_res=${hdmi_tx_res} HPD=${HPD} vout=${vout}"
# Load kernel, initrd and dtb in that sequence
fatload mmc 0:1 0x40008000 zImage
fatload mmc 0:1 0x42000000 uInitrd
if test "${board_name}" = "xu4"; then fatload mmc 0:1 0x44000000 exynos5422-odroidxu4.dtb; setenv fdtloaded "true"; fi
if test "${board_name}" = "xu3"; then fatload mmc 0:1 0x44000000 exynos5422-odroidxu3.dtb; setenv fdtloaded "true"; fi
if test "${board_name}" = "xu3l"; then fatload mmc 0:1 0x44000000 exynos5422-odroidxu3-lite.dtb; setenv fdtloaded "true"; fi
#failsafe
if test "x${board_name}" = "x"; then fatload mmc 0:1 0x44000000 exynos5422-odroidxu4.dtb; fi
# set FDT address
fdt addr 0x44000000
if test "${cecenable}" = "false"; then fdt rm /cec@101B0000; fi
if test "${disable_vu7}" = "false"; then setenv hid_quirks "usbhid.quirks=0x0eef:0x0005:0x0004"; fi
# set DDR frequency
dmc ${ddr_freq}
# final boot args
setenv bootargs "${bootrootfs} ${videoconfig} smsc95xx.macaddr=${macaddr} governor=${governor} ${hdmi_phy_control} ${hid_quirks}"
# drm.debug=0xff"
# Boot the board
bootz 0x40008000 0x42000000 0x44000000
root@Odroid-HC1-1:/boot#
Lum
#13 2020-03-01 00:56:52
tuxd3v
Hello Illegalum,
thanks,
I took a loot at boot.ini, and adapted it for a mainline kernel 5.5.7, and to Odroid hc1 dtb.
I created a share with the kernel and the boot.ini new files..
This share here, contains the deb packages to try a mainline kernel, and also the new boot.ini file..
Backup first your boot.ini file:
cp boot.ini boot.ini.backup
Then copy to the sdcard, the contents of the shared folder:
linux-headers-5.5.7_5.5.7-1_armhf.deb,
linux-image-5.5.7_5.5.7-1_armhf.deb,
linux-libc-dev_5.5.7-1_armhf.deb
Copy also 'boot.ini.new' to /boot,
then boot the board, install the new kernel:
dpkg -i *.deb
change 'boot.ini.new' to 'boot.ini':
mv /boot/boot.ini.new /boot/boot.ini
then restart and check if that kernel, works well in your board, if it doesn't:
dpkg -l |grep -E "linux-.*(image|headers|libc-dev)"
See the 5.5.7 installed packages and remove them:
apt-get remove --purge linux-headers-5.5.7 linux-image-5.5.7 linux-libc-dev
get back your 'boot.ini' file:
mv /boot/boot.ini.backup /boot/boot.ini
And restart..
It would be nice to get some feedback from you, since you own one of this boards smile
Best Regards,
Best Regards,
tux
#14 2020-03-01 11:41:59
Illegalum
we've got ourselfs a kernel panic ... smile
U-Boot 2017.05-15377-gedb23d4 (Aug 24 2017 - 07:09:51 -0300) for ODROID-XU4
CPU:   Exynos5422 @ 800 MHz
Model: Odroid XU4 based on EXYNOS5422
Board: Odroid XU4 based on EXYNOS5422
Type:  xu4
DRAM:  2 GiB
MMC:   EXYNOS DWMMC: 0, EXYNOS DWMMC: 1
MMC Device 0 ( SD ): 59.5 GiB
Card did not respond to voltage select!
mmc_init: -95, time 12
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Press quickly 'Enter' twice to stop autoboot:  0
reading boot.ini
10396 bytes read in 9 ms (1.1 MiB/s)
cfgload: applying boot.ini...
cfgload: setenv initrd_high "0xffffffff"
cfgload: setenv fdt_high "0xffffffff"
cfgload: setenv macaddr "00:1e:06:61:7a:87
cfgload: setenv bootrootfs "console=tty1 console=ttySAC2,115200n8 root=/dev/mmcblk0p2 rootwait ro fsck.repair=yes biosdevname=0 net.ifnames=0"
cfgload: setenv vout "hdmi"
cfgload: setenv cecenable "false" # false or true
cfgload: setenv governor "ondemand"
cfgload: setenv disable_vu7 "true" # false
cfgload: setenv ddr_freq 825
cfgload: setenv HPD "true"
cfgload: setenv hdmi_tx_amp_lvl  "31"
cfgload: setenv hdmi_tx_lvl_ch0      "3"
cfgload: setenv hdmi_tx_lvl_ch1      "3"
cfgload: setenv hdmi_tx_lvl_ch2      "3"
cfgload: setenv hdmi_tx_emp_lvl      "6"
cfgload: setenv hdmi_clk_amp_lvl     "31"
cfgload: setenv hdmi_tx_res      "0"
cfgload: setenv hdmi_phy_control "hdmi_tx_amp_lvl=${hdmi_tx_amp_lvl} hdmi_tx_lvl_ch0=${hdmi_tx_lvl_ch0} hdmi_tx_lvl_ch1=${hdmi_tx_lvl_ch1} hdmi_tx_lvl_ch2=${hdmi_tx_lvl_ch2} hdmi_tx_emp_lvl=${hdmi_tx_emp_lvl} hdmi_clk_amp_lvl=${hdmi_clk_amp_lvl} hdmi_tx_res=${hdmi_tx_res} HPD=${HPD} vout=${vout}"
cfgload: fatload mmc 0:1 0x40008000 vmlinuz-5.5.7
reading vmlinuz-5.5.7
6474360 bytes read in 369 ms (16.7 MiB/s)
cfgload: if test "${board_name}" = "hc1"; then load mmc 0:2 0x44000000 usr/lib/linux-image-5.5.7/exynos5422-odroidhc1.dtb; setenv fdtloaded "true"; fi
cfgload: if test "${board_name}" = "xu4"; then load mmc 0:2 0x44000000 usr/lib/linux-image-5.5.7/exynos5422-odroidhc1.dtb; setenv fdtloaded "true"; fi
58630 bytes read in 100 ms (572.3 KiB/s)
cfgload: fdt addr 0x44000000
cfgload: if test "${cecenable}" = "false"; then fdt rm /cec@101B0000; fi
libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND
cfgload: if test "${disable_vu7}" = "false"; then setenv hid_quirks "usbhid.quirks=0x0eef:0x0005:0x0004"; fi
cfgload: dmc ${ddr_freq}
cfgload: setenv bootargs "${bootrootfs} ${videoconfig} smsc95xx.macaddr=${macaddr} governor=${governor} ${hdmi_phy_control} ${hid_quirks}"
cfgload: bootz 0x40008000 - 0x44000000
Kernel image @ 0x40008000 [ 0x000000 - 0x62ca78 ]
## Flattened Device Tree blob at 44000000
   Booting using the fdt blob at 0x44000000
   Using Device Tree in place at 44000000, end 44011505
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x100
[    0.000000] Linux version 5.5.7 (tuxd3v@desktop0) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #1 SMP PREEMPT Fri Feb 28 22:14:58 WET 2020
[    0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Hardkernel Odroid HC1
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 128 MiB at 0xb6800000
[    0.000000] Samsung CPU ID: 0xe5422001
[    0.000000] Running under secure firmware.
[    0.000000] percpu: Embedded 20 pages/cpu s52364 r8192 d21364 u81920
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516928
[    0.000000] Kernel command line: console=tty1 console=ttySAC2,115200n8 root=/dev/mmcblk0p2 rootwait ro fsck.repair=yes biosdevname=0 net.ifnames=0  smsc95xx.macaddr=00:1e:06:61:7a:87  governor=ondemand hdmi_tx_amp_lvl=31 hdmi_tx_lvl_ch0=3 hdmi_tx_lvl_ch1=3 hdmi_tx_lvl_ch2=3 hdmi_tx_emp_lvl=6 hdmi_clk_amp_lvl=31 hdmi_tx_res=0 HPD=true vout=hdmi  s5p_mfc.mem=16M
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1909164K/2074624K available (9216K kernel code, 789K rwdata, 2728K rodata, 1024K init, 324K bss, 34388K reserved, 131072K cma-reserved, 1157120K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x330/0x4f8 with crng_init=0
[    0.000000] Switching to timer-based delay loop, resolution 41ns
[    0.000000] clocksource: mct-frc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000007] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000032] genirq: irq_chip COMBINER did not update eff. affinity mask of irq 49
[    0.001506] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.001525] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.001545] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001558] Ignoring duplicate/late registration of read_current_timer delay
[    0.001939] Console: colour dummy device 80x30
[    0.002589] printk: console [tty1] enabled
[    0.002643] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002683] pid_max: default: 32768 minimum: 301
[    0.002909] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002955] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.004174] CPU: Testing write buffer coherency: ok
[    0.004762] CPU0: thread -1, cpu 0, socket 1, mpidr 80000100
[    0.028051] Setting up static identity map for 0x40100000 - 0x40100060
[    0.028412] ARM CCI driver probed
[    0.028658] Exynos MCPM support installed
[    0.035986] rcu: Hierarchical SRCU implementation.
[    0.046137] soc soc0: Exynos: CPU[EXYNOS5800] PRO_ID[0xe5422001] REV[0x1] Detected
[    0.051987] smp: Bringing up secondary CPUs ...
[    0.084374] CPU1: thread -1, cpu 1, socket 1, mpidr 80000101
[    0.116331] CPU2: thread -1, cpu 2, socket 1, mpidr 80000102
[    0.148331] CPU3: thread -1, cpu 3, socket 1, mpidr 80000103
[    0.180373] CPU4: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.180384] CPU4: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[    0.212343] CPU5: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.212351] CPU5: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[    0.244351] CPU6: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.244359] CPU6: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[    0.276349] CPU7: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.276358] CPU7: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[    0.276584] smp: Brought up 1 node, 8 CPUs
[    0.276633] SMP: Total of 8 processors activated (384.00 BogoMIPS).
[    0.276656] CPU: All CPU(s) started in HYP mode.
[    0.276674] CPU: Virtualization extensions available.
[    0.277883] devtmpfs: initialized
[    0.297405] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 3
[    0.298040] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.298098] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.305267] pinctrl core: initialized pinctrl subsystem
[    0.307876] thermal_sys: Registered thermal governor 'step_wise'
[    0.310476] NET: Registered protocol family 16
[    0.313169] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.314874] audit: initializing netlink subsys (disabled)
[    0.315174] audit: type=2000 audit(0.312:1): state=initialized audit_enabled=0 res=1
[    0.316431] cpuidle: using governor menu
[    0.317205] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.317255] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.378315] EXYNOS5420 PMU initialized
[    0.404351] random: fast init done
[    0.493397] iommu: Default domain type: Translated
[    0.494008] usbcore: registered new interface driver usbfs
[    0.494094] usbcore: registered new interface driver hub
[    0.494271] usbcore: registered new device driver usb
[    0.495059] mc: Linux media interface: v0.10
[    0.495120] videodev: Linux video capture interface: v2.00
[    0.495276] pps_core: LinuxPPS API ver. 1 registered
[    0.495300] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.495901] Advanced Linux Sound Architecture Driver Initialized.
[    0.497507] clocksource: Switched to clocksource mct-frc
[    1.383107] VFS: Disk quotas dquot_6.6.0
[    1.383193] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.396147] NET: Registered protocol family 2
[    1.396864] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.396918] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.397012] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.397179] TCP: Hash tables configured (established 8192 bind 8192)
[    1.397299] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.397354] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.397650] NET: Registered protocol family 1
[    1.398381] RPC: Registered named UNIX socket transport module.
[    1.398403] RPC: Registered udp transport module.
[    1.398421] RPC: Registered tcp transport module.
[    1.398439] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.400412] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.401227] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    1.405031] Initialise system trusted keyrings
[    1.405291] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    1.414329] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.415261] NFS: Registering the id_resolver key type
[    1.415296] Key type id_resolver registered
[    1.415315] Key type id_legacy registered
[    1.415343] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.415397] romfs: ROMFS MTD (C) 2007 Red Hat, Inc.
[    1.446336] Key type asymmetric registered
[    1.446358] Asymmetric key parser 'x509' registered
[    1.446432] bounce: pool size: 64 pages
[    1.446504] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.446780] io scheduler mq-deadline registered
[    1.446801] io scheduler kyber registered
[    1.446959] io scheduler bfq registered
[    1.449789] samsung-usb2-phy 12130000.phy: 12130000.phy supply vbus not found, using dummy regulator
[    1.450863] exynos5_usb3drd_phy 12100000.phy: 12100000.phy supply vbus not found, using dummy regulator
[    1.450967] exynos5_usb3drd_phy 12100000.phy: 12100000.phy supply vbus-boost not found, using dummy regulator
[    1.451371] exynos5_usb3drd_phy 12500000.phy: 12500000.phy supply vbus not found, using dummy regulator
[    1.451483] exynos5_usb3drd_phy 12500000.phy: 12500000.phy supply vbus-boost not found, using dummy regulator
[    1.459383] dma-pl330 121a0000.pdma: Loaded driver for PL330 DMAC-241330
[    1.459413] dma-pl330 121a0000.pdma:         DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[    1.462102] dma-pl330 121b0000.pdma: Loaded driver for PL330 DMAC-241330
[    1.462129] dma-pl330 121b0000.pdma:         DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[    1.463006] dma-pl330 10800000.mdma: Loaded driver for PL330 DMAC-241330
[    1.463033] dma-pl330 10800000.mdma:         DBUFF-64x8bytes Num_Chans-8 Num_Peri-1 Num_Events-32
[    1.538312] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.540566] samsung-uart 12c00000.serial: IRQ index 1 not found
[    1.540655] 12c00000.serial: ttySAC0 at MMIO 0x12c00000 (irq = 62, base_baud = 0) is a S3C6400/10
[    1.541088] samsung-uart 12c10000.serial: IRQ index 1 not found
[    1.541157] 12c10000.serial: ttySAC1 at MMIO 0x12c10000 (irq = 63, base_baud = 0) is a S3C6400/10
[    1.541625] samsung-uart 12c20000.serial: IRQ index 1 not found
[    1.541686] 12c20000.serial: ttySAC2 at MMIO 0x12c20000 (irq = 64, base_baud = 0) is a S3C6400/10
[    2.423006] printk: console [ttySAC2] enabled
[    2.427974] samsung-uart 12c30000.serial: IRQ index 1 not found
[    2.433338] 12c30000.serial: ttySAC3 at MMIO 0x12c30000 (irq = 65, base_baud = 0) is a S3C6400/10
[    2.443887] exynos-trng 10830600.rng: Exynos True Random Number Generator.
[    2.451023] exynos-drm-g2d 10850000.g2d: Adding to iommu group 0
[    2.457034] exynos-rotator 11c00000.rotator: Adding to iommu group 1
[    2.464545] 8<--- cut here ---
[    2.466168] Unable to handle kernel NULL pointer dereference at virtual address 00000160
[    2.474226] pgd = (ptrval)
[    2.476872] [00000160] *pgd=00000000
[    2.480464] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[    2.485715] Modules linked in:
[    2.488746] CPU: 4 PID: 1 Comm: swapper/0 Not tainted 5.5.7 #1
[    2.494552] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[    2.500627] PC is at dma_alloc_attrs+0x8/0x114
[    2.505042] LR is at g2d_bind+0x44/0x17c
[    2.508936] pc : [<c0197f1c>]    lr : [<c061339c>]    psr: 60000013
[    2.515177] sp : ee8f5c8c  ip : 00000004  fp : c0bd5e80
[    2.520375] r10: c0ead438  r9 : ee24cc00  r8 : eebc5010
[    2.525575] r7 : ed8bb2c0  r6 : 00000000  r5 : ee24cc00  r4 : ee00fa40
[    2.532075] r3 : 00000cc0  r2 : ee00fa8c  r1 : 00010000  r0 : 00000000
[    2.538576] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
[    2.545681] Control: 10c5387d  Table: 4000406a  DAC: 00000051
[    2.551398] Process swapper/0 (pid: 1, stack limit = 0x(ptrval))
[    2.557379] Stack: (0xee8f5c8c to 0xee8f6000)
[    2.561712] 5c80:                            ee00fa40 ee24cc00 eebc5010 ed8bb2c0 eebc5010
[    2.569865] 5ca0: ee24cc00 c061339c 00000004 c0ead438 ed8b6f40 00000000 00000000 ed8b6900
[    2.578010] 5cc0: 00000002 c061b104 ee24cc00 c05fc058 00000000 c0bd5e68 ffffffff 00000000
[    2.586155] 5ce0: ee24cc00 ed8bb2c0 ee24c810 00000002 c0e6d4d8 ed8b95c0 c0ead438 c060bca0
[    2.594301] 5d00: ed8b6e80 ed8b6f18 00000030 ed8b6f40 00000002 c061b460 ee0d3810 c048b158
[    2.602446] 5d20: ee7ba920 c0e6d4bc c0bd5ed4 00000000 c0e6d4bc ed8b6f40 c0e6d4bc ee24c810
[    2.610591] 5d40: c0a7df98 c060baa4 ee8f5d88 c0a7e010 ee0d3810 c061b95c c0a8d894 54e67e95
[    2.618737] 5d60: c060baa4 00000000 c0a7e010 c0e6cf30 ee24c810 c060be50 ee0d3810 ed8b8a50
[    2.626882] 5d80: ed8b7738 c0e04f48 ed8b95c0 54e67e95 00000000 ee24c810 00000000 c0e6cf44
[    2.635028] 5da0: 00000000 c0ead708 c0e6cf44 00000000 00000000 c0624920 c0f09e30 ee24c810
[    2.643173] 5dc0: c0f09e34 c06224b4 60000013 ee24c810 ee24c914 ee24c810 c0e6cf44 c0e6cf44
[    2.651319] 5de0: c0e04f48 c0a7e010 c0bd37e4 c0d67854 c0d94164 c0622858 00000000 00000000
[    2.659464] 5e00: 00001276 ee24c810 00000000 c0e6cf44 c0e04f48 c0a7e010 c0bd37e4 c0d67854
[    2.667609] 5e20: c0d94164 c0622c0c 00000000 c0e6cf44 ee24c810 c0622ce0 00000000 c0e6cf44
[    2.675755] 5e40: c0622c14 c062049c c0bd37e4 ee8a3a58 ed8b0bb4 54e67e95 c0e6d9b0 c0e6cf44
[    2.683901] 5e60: ed8b9500 c0e6d9b0 00000000 c06215c4 c0bd37e4 c0a7e010 c0e04f48 c0e6cf44
[    2.692046] 5e80: c0a7e010 c0e04f48 c0a7dfa0 c06238b4 00000000 c0a7e010 c0e04f48 c060bfec
[    2.700191] 5ea0: c0bcf2f8 000000e2 00000000 00000000 00000000 c0bd37e4 ffffffff 00000000
[    2.708337] 5ec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.716483] 5ee0: c0d38824 54e67e95 00000000 c0e04f48 c0ea6240 ffffe000 c060bf20 00000000
[    2.724629] 5f00: c0d0058c c0103000 00000000 c0d0058c c0eaae88 00000000 00000006 c0bf1b98
[    2.732774] 5f20: c0c23e0c 00000000 00000000 c0e04f48 c0b88720 c0b800fc 000004b8 efffc13a
[    2.740919] 5f40: efffc146 54e67e95 00000000 c0ec5580 c0ec5580 54e67e95 c0ec5580 c0ec5580
[    2.749065] 5f60: 00000007 c0d67834 000000fc c0d01104 00000006 00000006 00000000 c0d0058c
[    2.757210] 5f80: c09dd880 00000000 c09dd880 00000000 00000000 00000000 00000000 00000000
[    2.765355] 5fa0: 00000000 c09dd888 00000000 c01010e8 00000000 00000000 00000000 00000000
[    2.773501] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.781646] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[    2.789800] [<c0197f1c>] (dma_alloc_attrs) from [<00000000>] (0x0)
[    2.795943] Code: e3a01000 e12fff1e e92d43f0 e1a06000 (e5965160)
[    2.802102] ---[ end trace a2a570575652f180 ]---
[    2.806632] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    2.814254] CPU1: stopping
[    2.816929] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G      D           5.5.7 #1
[    2.824107] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[    2.830196] [<c0111e7c>] (unwind_backtrace) from [<c010d9b8>] (show_stack+0x10/0x14)
[    2.837902] [<c010d9b8>] (show_stack) from [<c09c5614>] (dump_stack+0x94/0xa8)
[    2.845089] [<c09c5614>] (dump_stack) from [<c0110a34>] (handle_IPI+0x400/0x414)
[    2.852454] [<c0110a34>] (handle_IPI) from [<c0531b04>] (gic_handle_irq+0x98/0x9c)
[    2.859993] [<c0531b04>] (gic_handle_irq) from [<c0101a8c>] (__irq_svc+0x6c/0xa8)
[    2.867436] Exception stack(0xee925f58 to 0xee925fa0)
[    2.872456] 5f40:                                                       00000000 00001004
[    2.880614] 5f60: 00000001 c011d0c0 ffffe000 c0e04f68 c0e04fa8 00000002 00000000 c0e04f48
[    2.888760] 5f80: c0da02a8 00000000 c0e04f78 ee925fa8 c010a0fc c010a100 60000013 ffffffff
[    2.896914] [<c0101a8c>] (__irq_svc) from [<c010a100>] (arch_cpu_idle+0x4c/0x50)
[    2.904273] [<c010a100>] (arch_cpu_idle) from [<c0159b54>] (do_idle+0x1bc/0x2ac)
[    2.911636] [<c0159b54>] (do_idle) from [<c0159f38>] (cpu_startup_entry+0x18/0x20)
[    2.919174] [<c0159f38>] (cpu_startup_entry) from [<4010268c>] (0x4010268c)
[    2.926098] CPU5: stopping
[    2.928786] CPU: 5 PID: 0 Comm: swapper/5 Tainted: G      D           5.5.7 #1
[    2.935976] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[    2.942053] [<c0111e7c>] (unwind_backtrace) from [<c010d9b8>] (show_stack+0x10/0x14)
[    2.949767] [<c010d9b8>] (show_stack) from [<c09c5614>] (dump_stack+0x94/0xa8)
[    2.956957] [<c09c5614>] (dump_stack) from [<c0110a34>] (handle_IPI+0x400/0x414)
[    2.964321] [<c0110a34>] (handle_IPI) from [<c0531b04>] (gic_handle_irq+0x98/0x9c)
[    2.971859] [<c0531b04>] (gic_handle_irq) from [<c0101a8c>] (__irq_svc+0x6c/0xa8)
[    2.979304] Exception stack(0xee92df58 to 0xee92dfa0)
[    2.984328] df40:                                                       00000000 00000b58
[    2.992482] df60: 00000005 c011d0c0 ffffe000 c0e04f68 c0e04fa8 00000020 00000000 c0e04f48
[    3.000627] df80: c0da02a8 00000000 c0e04f78 ee92dfa8 c010a0fc c010a100 60000013 ffffffff
[    3.008778] [<c0101a8c>] (__irq_svc) from [<c010a100>] (arch_cpu_idle+0x4c/0x50)
[    3.016139] [<c010a100>] (arch_cpu_idle) from [<c0159b54>] (do_idle+0x1bc/0x2ac)
[    3.023503] [<c0159b54>] (do_idle) from [<c0159f38>] (cpu_startup_entry+0x18/0x20)
[    3.031041] [<c0159f38>] (cpu_startup_entry) from [<4010268c>] (0x4010268c)
[    3.037971] CPU3: stopping
[    3.040667] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G      D           5.5.7 #1
[    3.047847] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[    3.053920] [<c0111e7c>] (unwind_backtrace) from [<c010d9b8>] (show_stack+0x10/0x14)
[    3.061637] [<c010d9b8>] (show_stack) from [<c09c5614>] (dump_stack+0x94/0xa8)
[    3.068827] [<c09c5614>] (dump_stack) from [<c0110a34>] (handle_IPI+0x400/0x414)
[    3.076192] [<c0110a34>] (handle_IPI) from [<c0531b04>] (gic_handle_irq+0x98/0x9c)
[    3.083730] [<c0531b04>] (gic_handle_irq) from [<c0101a8c>] (__irq_svc+0x6c/0xa8)
[    3.091176] Exception stack(0xee929f58 to 0xee929fa0)
[    3.096196] 9f40:                                                       00000000 00000690
[    3.104354] 9f60: 00000003 c011d0c0 ffffe000 c0e04f68 c0e04fa8 00000008 00000000 c0e04f48
[    3.112500] 9f80: c0da02a8 00000000 c0e04f78 ee929fa8 c010a0fc c010a100 60000013 ffffffff
[    3.120649] [<c0101a8c>] (__irq_svc) from [<c010a100>] (arch_cpu_idle+0x4c/0x50)
[    3.128012] [<c010a100>] (arch_cpu_idle) from [<c0159b54>] (do_idle+0x1bc/0x2ac)
[    3.135375] [<c0159b54>] (do_idle) from [<c0159f38>] (cpu_startup_entry+0x18/0x20)
[    3.142913] [<c0159f38>] (cpu_startup_entry) from [<4010268c>] (0x4010268c)
[    3.149839] CPU2: stopping
[    3.152522] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G      D           5.5.7 #1
[    3.159717] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[    3.165790] [<c0111e7c>] (unwind_backtrace) from [<c010d9b8>] (show_stack+0x10/0x14)
[    3.173507] [<c010d9b8>] (show_stack) from [<c09c5614>] (dump_stack+0x94/0xa8)
[    3.180698] [<c09c5614>] (dump_stack) from [<c0110a34>] (handle_IPI+0x400/0x414)
[    3.188062] [<c0110a34>] (handle_IPI) from [<c0531b04>] (gic_handle_irq+0x98/0x9c)
[    3.195601] [<c0531b04>] (gic_handle_irq) from [<c0101a8c>] (__irq_svc+0x6c/0xa8)
[    3.203047] Exception stack(0xee927f58 to 0xee927fa0)
[    3.208067] 7f40:                                                       00000000 0000073c
[    3.216225] 7f60: 00000002 c011d0c0 ffffe000 c0e04f68 c0e04fa8 00000004 00000000 c0e04f48
[    3.224371] 7f80: c0da02a8 00000000 c0e04f78 ee927fa8 c010a0fc c010a100 60000013 ffffffff
[    3.232519] [<c0101a8c>] (__irq_svc) from [<c010a100>] (arch_cpu_idle+0x4c/0x50)
[    3.239882] [<c010a100>] (arch_cpu_idle) from [<c0159b54>] (do_idle+0x1bc/0x2ac)
[    3.247246] [<c0159b54>] (do_idle) from [<c0159f38>] (cpu_startup_entry+0x18/0x20)
[    3.254784] [<c0159f38>] (cpu_startup_entry) from [<4010268c>] (0x4010268c)
[    3.261709] CPU6: stopping
[    3.264396] CPU: 6 PID: 0 Comm: swapper/6 Tainted: G      D           5.5.7 #1
[    3.271588] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[    3.277661] [<c0111e7c>] (unwind_backtrace) from [<c010d9b8>] (show_stack+0x10/0x14)
[    3.285374] [<c010d9b8>] (show_stack) from [<c09c5614>] (dump_stack+0x94/0xa8)
[    3.292567] [<c09c5614>] (dump_stack) from [<c0110a34>] (handle_IPI+0x400/0x414)
[    3.299931] [<c0110a34>] (handle_IPI) from [<c0531b04>] (gic_handle_irq+0x98/0x9c)
[    3.307469] [<c0531b04>] (gic_handle_irq) from [<c0101a8c>] (__irq_svc+0x6c/0xa8)
[    3.314916] Exception stack(0xee92ff58 to 0xee92ffa0)
[    3.319939] ff40:                                                       00000000 00000318
[    3.328092] ff60: 00000006 c011d0c0 ffffe000 c0e04f68 c0e04fa8 00000040 00000000 c0e04f48
[    3.336239] ff80: c0da02a8 00000000 c0e04f78 ee92ffa8 c010a0fc c010a100 60000013 ffffffff
[    3.344388] [<c0101a8c>] (__irq_svc) from [<c010a100>] (arch_cpu_idle+0x4c/0x50)
[    3.351751] [<c010a100>] (arch_cpu_idle) from [<c0159b54>] (do_idle+0x1bc/0x2ac)
[    3.359114] [<c0159b54>] (do_idle) from [<c0159f38>] (cpu_startup_entry+0x18/0x20)
[    3.366651] [<c0159f38>] (cpu_startup_entry) from [<4010268c>] (0x4010268c)
[    3.373583] CPU0: stopping
[    3.376279] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D           5.5.7 #1
[    3.383459] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[    3.389531] [<c0111e7c>] (unwind_backtrace) from [<c010d9b8>] (show_stack+0x10/0x14)
[    3.397248] [<c010d9b8>] (show_stack) from [<c09c5614>] (dump_stack+0x94/0xa8)
[    3.404439] [<c09c5614>] (dump_stack) from [<c0110a34>] (handle_IPI+0x400/0x414)
[    3.411804] [<c0110a34>] (handle_IPI) from [<c0531b04>] (gic_handle_irq+0x98/0x9c)
[    3.419342] [<c0531b04>] (gic_handle_irq) from [<c0101a8c>] (__irq_svc+0x6c/0xa8)
[    3.426788] Exception stack(0xc0e01f10 to 0xc0e01f58)
[    3.431809] 1f00:                                     00000000 0000114c 00000000 c011d0c0
[    3.439966] 1f20: ffffe000 c0e04f68 c0e04fa8 00000001 00000000 c0e04f48 c0da02a8 00000000
[    3.448110] 1f40: c0e05024 c0e01f60 c010a0fc c010a100 60000113 ffffffff
[    3.454695] [<c0101a8c>] (__irq_svc) from [<c010a100>] (arch_cpu_idle+0x4c/0x50)
[    3.462063] [<c010a100>] (arch_cpu_idle) from [<c0159b54>] (do_idle+0x1bc/0x2ac)
[    3.469427] [<c0159b54>] (do_idle) from [<c0159f38>] (cpu_startup_entry+0x18/0x20)
[    3.476968] [<c0159f38>] (cpu_startup_entry) from [<c0d00f0c>] (start_kernel+0x4c8/0x4f8)
[    3.485113] [<c0d00f0c>] (start_kernel) from [<00000000>] (0x0)
[    3.490994] CPU7: stopping
[    3.493683] CPU: 7 PID: 0 Comm: swapper/7 Tainted: G      D           5.5.7 #1
[    3.500875] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[    3.506949] [<c0111e7c>] (unwind_backtrace) from [<c010d9b8>] (show_stack+0x10/0x14)
[    3.514662] [<c010d9b8>] (show_stack) from [<c09c5614>] (dump_stack+0x94/0xa8)
[    3.521854] [<c09c5614>] (dump_stack) from [<c0110a34>] (handle_IPI+0x400/0x414)
[    3.529219] [<c0110a34>] (handle_IPI) from [<c0531b04>] (gic_handle_irq+0x98/0x9c)
[    3.536757] [<c0531b04>] (gic_handle_irq) from [<c0101a8c>] (__irq_svc+0x6c/0xa8)
[    3.544203] Exception stack(0xee931f58 to 0xee931fa0)
[    3.549226] 1f40:                                                       00000000 0000097c
[    3.557379] 1f60: 00000007 c011d0c0 ffffe000 c0e04f68 c0e04fa8 00000080 00000000 c0e04f48
[    3.565524] 1f80: c0da02a8 00000000 00000000 ee931fa8 c010a0fc c010a100 60000013 ffffffff
[    3.573673] [<c0101a8c>] (__irq_svc) from [<c010a100>] (arch_cpu_idle+0x4c/0x50)
[    3.581037] [<c010a100>] (arch_cpu_idle) from [<c0159b54>] (do_idle+0x1bc/0x2ac)
[    3.588401] [<c0159b54>] (do_idle) from [<c0159f38>] (cpu_startup_entry+0x18/0x20)
[    3.595939] [<c0159f38>] (cpu_startup_entry) from [<4010268c>] (0x4010268c)
[    3.602894] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
Lum
#15 2020-03-01 22:49:42
tuxd3v
Lum
Indeed,
When I compiled that kernel I received a warning about a possibility of a pointer not been initialized, maybe its related to that..
I compiled it using the linaro crosscompiling toolchains 7.5, since the ARM ones only have as host amd64(I am on devuan i386..).
at same time it could also be something uboot config related( addresses or else.. )..
I created a basic 'boot.scr' file , its in the share, if you want to try a last time..
You only need to copy it to /boot,
rename '/boot/boot.ini'  to something like '/boot/boot.ini.backup',
and restart..
ofcourse this with the new kernel.. if you get again a kernel panic, get previous( original situation.. )..
In that case,
maybe the uboot version you have doesn't support yet the Odroid HC1.. for the few things I read about that board, still there are diferences between them, that's why you can boot XU4 and not HC1 with devuan image..
Best Regards,
tux
#16 2020-03-02 18:43:47
Illegalum
Hi tux,
Had some interesting times to get it booting with the old kernel again after i got the kernel panic , going to order another sd card so i have one install spare for killing smile so give me a few day to come back to you with this.
Kind regards,
Lum
#17 2020-03-04 23:23:38
wfk
Hi all,
The other week I tried to boot the Odroid XU4 image and found it, indeed, not booting.
I'ld be happy to help out with any testing, kernel building, or whatever.  I have a couple of "scratch" Odroid HC1 and HC2 machines here that I have been using to compile my own kernel and uboot for use with a devuan install that I created using debootstrap.  That worked quite well, although I found you have to be careful about which Odroid kernel source commit you use, as some are decidedly unstable.  I don't know what the "official" way is to build a Devuan arm embedded SD card image.
Regards,
wfk
#18 2020-03-06 01:30:09
tuxd3v
Hi Illegalum,
Ok, no problem, no rush smile
Hi wfk,
For the work Illegalum have done, he experienced problems with the network card, I believe?!( using the devuan image for xu4.. )
I found there are indeed a dts in mainline for hc1..
I compiled 5.5.7 kernel, and I were checking it with Illegalum..
My Kernel gave a kernel panic( I also saw a compiler warning about a pointer not been initialized first.. in compilation process)..
But it could also be that my toolchain is the one to blame..
I am with Linaro 7.5 unfortunately, since ARM only provides amd64 cross toolchains...
So I am locked on 7.5 cross toolchains..
What kernel are you using?
Best Regards,
tux
Best Regards,
tux
#19 2020-03-06 12:50:10
wfk
I'm compiling native on the HC1.
I'm using the kernel source provided by Odroid on their site, which contains various Samsung cpu related patches.  It looks like Ubuntu is using that same source, as the kernel they deliver with their image is a similar version.
This is what comes with the standard Ubuntu SD card image:
Linux version 4.14.5-92 (root@1604_builder_armhf) (gcc version 5.4.1 20160904 (Ubuntu/Linaro 5.4.1-2ubuntu1~16.04)) #1 SMP PREEMPT Mon Dec 11 15:48:15 UTC 2017
What's running on my compile box is currently:
Linux version 4.14.141+ (root@eiger) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1)) #1 SMP PREEMPT Fri Oct 4 19:34:42 UTC 2019
The current Odroid version is newer than that.  They recently merged a 4.14 update.
I have seen no indications that they intend to go to 5.x any time soon.
wfk
#20 2020-03-09 20:49:05
Illegalum
Sorry took some time , but finally some update.
Unfortunately moving the boot.ini  to boot.ini.sav and then copy the boot.scr in /boot results in a message that boot.ini is not found. putting the boot.ini back results again in the same kernel panic.
Have some spare sd cards now so hope i can do some quicker tests
I actually found that from the debian source image witch I converted to devuan ascii it has some sources directed to a deb source oph.mdrjr.net_meveric_dists_all_xu3 and it pull a specific kernel from there  linux-image-4.14-armhf-odroid-xu4
Lum
#21 2020-03-09 20:51:09
Illegalum
Hi WFK as You say you have and the HC1 board and the HC2
are the boards the same and does the HC2 report as a HC1 or does it report as a HC2 ?
because for me the main difference looks to be the housing for the 3.5 inch disk
Lum
#22 2020-03-10 03:28:23
tuxd3v
thanks Illegalum,wfk,
At beguining I tought it would be nice to go with mainline, but there are problems with it..
I will create a image with 4.4.165 from hardkernel, with Illegalum, defconfig above, and devuan userspace smile
EDIT: In fact hardkernel does have a 'odroid-5.4.y' branch, but I don't know how good it is..
Best Regards,
tux
#23 2020-03-10 20:47:34
Illegalum
I understand it can take long time to compile , but in general if it gives a better result we can try to compile it on the odroid itself, just might need some help with the steps smile
Lum
#24 2020-03-10 22:23:57
tuxd3v
Hello  Illegalum,wfk,
I created 3 instalable packages with a '4.14.165' kernel from hardkernel repo..
to install it you can follow bellow intructions,
It would be nice to know if it boots, and if ethernet is working correctly,
The idea is creating a image for hc1, with zram as swap using lz4 algo on it smile
but we need first a stable kernel..
in the share folder bellow is also a 'log' file, with the compilation log process..
if this works nicelly, I will tune the kernel for big.LITTLE on hc1 cpu smile
tuxd3v wrote:
Hello Illegalum,
thanks,
dpkg -i *.deb
And restart..
Best Regards,
Best Regards,
tux
#25 2020-03-12 00:59:14
tuxd3v
Lum
The steps don't change its the same as above smile
you just don't need a crosscompiler , you would use a native one..
so were you have ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf-, delete this from the commands smile
Regards,
tux
Best Regards,
tux
