#1 2020-02-22 19:10:07
[Solved] Boot messages surpressed with new graphics card
Hardware: ASUS Prime X470 Pro, Ryzen 2700X CPU, 32 GByte RAM.
Original graphics card: Sapphire GPRO 2200 fanless
lspci: 0c:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM]
Replacment card: Sapphire Pulse Radeon RX 570 8G lite
lspci: 0c:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480] (rev ef)
Running on ASCII amd64 in uefi mode, Mate desktop 1.20 from backports on Lightdm, backports kernel 4.19.6, encrypted except /boot, kept up to date. Non-free firmware is installed.
The system was set up with ASCII in September 2018 originally. Some time last year the boot screen started to get grey when switching to graphics mode past some upgrade. This made it hard to read the bootup messages before the login screen by Lightdm. I lived with this situation for several months hoping for a fix by a later update.
In autumn I finally decided that I would go for a fix and bought the replacement card. After plugging that in the situation is different again.
Now the messages scroll down until "waiting for /dev to be fully populated / sp5100-tco sp5100-tco: Watchdog hardware is disabled", then nothing else is happening on the display until the Lightdm login prompt is displayed. Similar issue with shutting down: the exit screen remains until the PC powers off, no more messages scrolling.
When looking into the syslog, I see some error messages. The first complex is related to amd firmware (does that mean the correct firmware for the card is not included?), the second complex looks similar to a kernel panic, though the PC seems to be working fine.
What can I do to fix the issues?
Thanks, rolfie
Feb 22 10:59:38 rh050 kernel: [   15.611189] sp5100-tco sp5100-tco: Watchdog hardware is disabled
Feb 22 10:59:38 rh050 kernel: [   15.613046] input: PC Speaker as /devices/platform/pcspkr/input/input9
Feb 22 10:59:38 rh050 kernel: [   15.613312] EFI Variables Facility v0.08 2004-May-17
Feb 22 10:59:38 rh050 kernel: [   15.616899] ccp 0000:0d:00.2: enabling device (0000 -> 0002)
Feb 22 10:59:38 rh050 kernel: [   15.617215] efivars: duplicate variable: DeploymentModeNv-97e8965f-c761-4f48-b6e4-9ffa9cb2a2d6
Feb 22 10:59:38 rh050 kernel: [   15.619817] pstore: Using compression: deflate
Feb 22 10:59:38 rh050 kernel: [   15.619822] pstore: Registered efi as persistent store backend
Feb 22 10:59:38 rh050 kernel: [   15.624500] ccp 0000:0d:00.2: ccp enabled
Feb 22 10:59:38 rh050 kernel: [   15.624537] ccp 0000:0d:00.2: psp initialization failed
Feb 22 10:59:38 rh050 kernel: [   15.624538] ccp 0000:0d:00.2: enabled
Feb 22 10:59:38 rh050 kernel: [   15.665399] kvm: Nested Virtualization enabled
Feb 22 10:59:38 rh050 kernel: [   15.665406] kvm: Nested Paging enabled
Feb 22 10:59:38 rh050 kernel: [   15.665406] SVM: Virtual VMLOAD VMSAVE supported
Feb 22 10:59:38 rh050 kernel: [   15.665406] SVM: Virtual GIF supported
Feb 22 10:59:38 rh050 kernel: [   15.667220] MCE: In-kernel MCE decoding enabled.
Feb 22 10:59:38 rh050 kernel: [   15.669022] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   15.669023] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   15.669023]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   15.669023]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   15.673506] snd_hda_intel 0000:0c:00.1: Handle vga_switcheroo audio client
Feb 22 10:59:38 rh050 kernel: [   15.673507] snd_hda_intel 0000:0c:00.1: Force to non-snoop mode
Feb 22 10:59:38 rh050 kernel: [   15.673760] snd_hda_intel 0000:0e:00.3: enabling device (0000 -> 0002)
Feb 22 10:59:38 rh050 kernel: [   15.685450] asus_wmi: ASUS WMI generic driver loaded
Feb 22 10:59:38 rh050 kernel: [   15.686554] asus_wmi: Initialization: 0x0
Feb 22 10:59:38 rh050 kernel: [   15.686584] asus_wmi: BIOS WMI version: 0.9
Feb 22 10:59:38 rh050 kernel: [   15.686657] asus_wmi: SFUN value: 0x0
Feb 22 10:59:38 rh050 kernel: [   15.687007] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input10
Feb 22 10:59:38 rh050 kernel: [   15.687153] asus_wmi: Number of fans: 1
Feb 22 10:59:38 rh050 kernel: [   15.689229] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:0c:00.1/sound/card0/input11
Feb 22 10:59:38 rh050 kernel: [   15.689364] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:0c:00.1/sound/card0/input12
Feb 22 10:59:38 rh050 kernel: [   15.689451] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:0c:00.1/sound/card0/input13
Feb 22 10:59:38 rh050 kernel: [   15.689560] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:0c:00.1/sound/card0/input14
Feb 22 10:59:38 rh050 kernel: [   15.689682] input: HDA ATI HDMI HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:0c:00.1/sound/card0/input15
Feb 22 10:59:38 rh050 kernel: [   15.689743] input: HDA ATI HDMI HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.1/0000:0c:00.1/sound/card0/input16
Feb 22 10:59:38 rh050 kernel: [   15.693627] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
Feb 22 10:59:38 rh050 kernel: [   15.693629] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Feb 22 10:59:38 rh050 kernel: [   15.693631] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
Feb 22 10:59:38 rh050 kernel: [   15.693632] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
Feb 22 10:59:38 rh050 kernel: [   15.693633] snd_hda_codec_realtek hdaudioC1D0:    dig-out=0x1e/0x0
Feb 22 10:59:38 rh050 kernel: [   15.693634] snd_hda_codec_realtek hdaudioC1D0:    inputs:
Feb 22 10:59:38 rh050 kernel: [   15.693636] snd_hda_codec_realtek hdaudioC1D0:      Front Mic=0x19
Feb 22 10:59:38 rh050 kernel: [   15.693638] snd_hda_codec_realtek hdaudioC1D0:      Rear Mic=0x18
Feb 22 10:59:38 rh050 kernel: [   15.693639] snd_hda_codec_realtek hdaudioC1D0:      Line=0x1a
Feb 22 10:59:38 rh050 kernel: [   15.702636] usbcore: registered new interface driver usbserial_generic
Feb 22 10:59:38 rh050 kernel: [   15.702643] usbserial: USB Serial support registered for generic
Feb 22 10:59:38 rh050 kernel: [   15.705978] usbcore: registered new interface driver ftdi_sio
Feb 22 10:59:38 rh050 kernel: [   15.705984] usbserial: USB Serial support registered for FTDI USB Serial Device
Feb 22 10:59:38 rh050 kernel: [   15.706073] ftdi_sio 6-2:1.0: FTDI USB Serial Device converter detected
Feb 22 10:59:38 rh050 kernel: [   15.706095] usb 6-2: Detected FT232BM
Feb 22 10:59:38 rh050 kernel: [   15.707909] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:0e:00.3/sound/card1/input17
Feb 22 10:59:38 rh050 kernel: [   15.707961] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:0e:00.3/sound/card1/input18
Feb 22 10:59:38 rh050 kernel: [   15.708015] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:0e:00.3/sound/card1/input19
Feb 22 10:59:38 rh050 kernel: [   15.708076] input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:0e:00.3/sound/card1/input20
Feb 22 10:59:38 rh050 kernel: [   15.708120] input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:0e:00.3/sound/card1/input21
Feb 22 10:59:38 rh050 kernel: [   15.708155] input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:0e:00.3/sound/card1/input22
Feb 22 10:59:38 rh050 kernel: [   15.708196] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:0e:00.3/sound/card1/input23
Feb 22 10:59:38 rh050 kernel: [   15.708243] snd_hda_intel 0000:0e:00.3: device 1043:8733 is on the power_save blacklist, forcing power_save to 0
Feb 22 10:59:38 rh050 kernel: [   15.711129] usb 6-2: FTDI USB Serial Device converter now attached to ttyUSB0
Feb 22 10:59:38 rh050 kernel: [   15.725057] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Feb 22 10:59:38 rh050 kernel: [   15.748707] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   15.748708] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   15.748708]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   15.748708]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   15.788172] [drm] amdgpu kernel modesetting enabled.
Feb 22 10:59:38 rh050 kernel: [   15.801773] Parsing CRAT table with 1 nodes
Feb 22 10:59:38 rh050 kernel: [   15.801777] Ignoring ACPI CRAT on non-APU system
Feb 22 10:59:38 rh050 kernel: [   15.801779] Virtual CRAT table created for CPU
Feb 22 10:59:38 rh050 kernel: [   15.801779] Parsing CRAT table with 1 nodes
Feb 22 10:59:38 rh050 kernel: [   15.801780] Creating topology SYSFS entries
Feb 22 10:59:38 rh050 kernel: [   15.801788] Topology: Add CPU node
Feb 22 10:59:38 rh050 kernel: [   15.801788] Finished initializing topology
Feb 22 10:59:38 rh050 kernel: [   15.801849] kfd kfd: Initialized module
Feb 22 10:59:38 rh050 kernel: [   15.802010] checking generic (e0000000 300000) vs hw (e0000000 10000000)
Feb 22 10:59:38 rh050 kernel: [   15.802012] fb: switching to amdgpudrmfb from EFI VGA
Feb 22 10:59:38 rh050 kernel: [   15.802041] Console: switching to colour dummy device 80x25
Feb 22 10:59:38 rh050 kernel: [   15.802345] [drm] initializing kernel modesetting (POLARIS10 0x1002:0x67DF 0x174B:0x353E 0xEF).
Feb 22 10:59:38 rh050 kernel: [   15.802363] [drm] register mmio base: 0xFCE00000
Feb 22 10:59:38 rh050 kernel: [   15.802364] [drm] register mmio size: 262144
Feb 22 10:59:38 rh050 kernel: [   15.802374] [drm] add ip block number 0 <vi_common>
Feb 22 10:59:38 rh050 kernel: [   15.802375] [drm] add ip block number 1 <gmc_v8_0>
Feb 22 10:59:38 rh050 kernel: [   15.802376] [drm] add ip block number 2 <tonga_ih>
Feb 22 10:59:38 rh050 kernel: [   15.802376] [drm] add ip block number 3 <powerplay>
Feb 22 10:59:38 rh050 kernel: [   15.802377] [drm] add ip block number 4 <dm>
Feb 22 10:59:38 rh050 kernel: [   15.802378] [drm] add ip block number 5 <gfx_v8_0>
Feb 22 10:59:38 rh050 kernel: [   15.802379] [drm] add ip block number 6 <sdma_v3_0>
Feb 22 10:59:38 rh050 kernel: [   15.802380] [drm] add ip block number 7 <uvd_v6_0>
Feb 22 10:59:38 rh050 kernel: [   15.802381] [drm] add ip block number 8 <vce_v3_0>
Feb 22 10:59:38 rh050 kernel: [   15.802392] [drm] UVD is enabled in VM mode
Feb 22 10:59:38 rh050 kernel: [   15.802393] [drm] UVD ENC is enabled in VM mode
Feb 22 10:59:38 rh050 kernel: [   15.802394] [drm] VCE enabled in VM mode
Feb 22 10:59:38 rh050 kernel: [   15.802608] ATOM BIOS: 113-YE353HM-UPE
Feb 22 10:59:38 rh050 kernel: [   15.802639] [drm] vm size is 128 GB, 2 levels, block size is 10-bit, fragment size is 9-bit
Feb 22 10:59:38 rh050 kernel: [   15.803539] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_mc.bin
Feb 22 10:59:38 rh050 kernel: [   15.803549] amdgpu 0000:0c:00.0: VRAM: 8192M 0x000000F400000000 - 0x000000F5FFFFFFFF (8192M used)
Feb 22 10:59:38 rh050 kernel: [   15.803551] amdgpu 0000:0c:00.0: GART: 256M 0x0000000000000000 - 0x000000000FFFFFFF
Feb 22 10:59:38 rh050 kernel: [   15.803558] [drm] Detected VRAM RAM=8192M, BAR=256M
Feb 22 10:59:38 rh050 kernel: [   15.803559] [drm] RAM width 256bits GDDR5
Feb 22 10:59:38 rh050 kernel: [   15.803619] [TTM] Zone  kernel: Available graphics memory: 16458446 kiB
Feb 22 10:59:38 rh050 kernel: [   15.803620] [TTM] Zone   dma32: Available graphics memory: 2097152 kiB
Feb 22 10:59:38 rh050 kernel: [   15.803620] [TTM] Initializing pool allocator
Feb 22 10:59:38 rh050 kernel: [   15.803624] [TTM] Initializing DMA pool allocator
Feb 22 10:59:38 rh050 kernel: [   15.803660] [drm] amdgpu: 8192M of VRAM memory ready
Feb 22 10:59:38 rh050 kernel: [   15.803661] [drm] amdgpu: 8192M of GTT memory ready.
Feb 22 10:59:38 rh050 kernel: [   15.803670] [drm] GART: num cpu pages 65536, num gpu pages 65536
Feb 22 10:59:38 rh050 kernel: [   15.805362] [drm] PCIE GART of 256M enabled (table at 0x000000F400300000).
Feb 22 10:59:38 rh050 kernel: [   15.805461] amdgpu 0000:0c:00.0: firmware: failed to load amdgpu/polaris10_pfp_2.bin (-2)
Feb 22 10:59:38 rh050 kernel: [   15.805466] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
Feb 22 10:59:38 rh050 kernel: [   15.805470] amdgpu 0000:0c:00.0: Direct firmware load for amdgpu/polaris10_pfp_2.bin failed with error -2
Feb 22 10:59:38 rh050 kernel: [   15.805775] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_pfp.bin
Feb 22 10:59:38 rh050 kernel: [   15.805787] amdgpu 0000:0c:00.0: firmware: failed to load amdgpu/polaris10_me_2.bin (-2)
Feb 22 10:59:38 rh050 kernel: [   15.805792] amdgpu 0000:0c:00.0: Direct firmware load for amdgpu/polaris10_me_2.bin failed with error -2
Feb 22 10:59:38 rh050 kernel: [   15.805930] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_me.bin
Feb 22 10:59:38 rh050 kernel: [   15.805941] amdgpu 0000:0c:00.0: firmware: failed to load amdgpu/polaris10_ce_2.bin (-2)
Feb 22 10:59:38 rh050 kernel: [   15.805946] amdgpu 0000:0c:00.0: Direct firmware load for amdgpu/polaris10_ce_2.bin failed with error -2
Feb 22 10:59:38 rh050 kernel: [   15.806108] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_ce.bin
Feb 22 10:59:38 rh050 kernel: [   15.806265] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_rlc.bin
Feb 22 10:59:38 rh050 kernel: [   15.806279] amdgpu 0000:0c:00.0: firmware: failed to load amdgpu/polaris10_mec_2.bin (-2)
Feb 22 10:59:38 rh050 kernel: [   15.806284] amdgpu 0000:0c:00.0: Direct firmware load for amdgpu/polaris10_mec_2.bin failed with error -2
Feb 22 10:59:38 rh050 kernel: [   15.807829] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_mec.bin
Feb 22 10:59:38 rh050 kernel: [   15.807841] amdgpu 0000:0c:00.0: firmware: failed to load amdgpu/polaris10_mec2_2.bin (-2)
Feb 22 10:59:38 rh050 kernel: [   15.807846] amdgpu 0000:0c:00.0: Direct firmware load for amdgpu/polaris10_mec2_2.bin failed with error -2
Feb 22 10:59:38 rh050 kernel: [   15.808869] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_mec2.bin
Feb 22 10:59:38 rh050 kernel: [   15.809826] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_sdma.bin
Feb 22 10:59:38 rh050 kernel: [   15.809987] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_sdma1.bin
Feb 22 10:59:38 rh050 kernel: [   15.811331] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_uvd.bin
Feb 22 10:59:38 rh050 kernel: [   15.811333] [drm] Found UVD firmware Version: 1.79 Family ID: 16
Feb 22 10:59:38 rh050 kernel: [   15.811337] [drm] UVD ENC is disabled
Feb 22 10:59:38 rh050 kernel: [   15.812430] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_vce.bin
Feb 22 10:59:38 rh050 kernel: [   15.812434] [drm] Found VCE firmware Version: 52.4 Binary ID: 3
Feb 22 10:59:38 rh050 kernel: [   15.812675] amdgpu 0000:0c:00.0: firmware: failed to load amdgpu/polaris10_k_smc.bin (-2)
Feb 22 10:59:38 rh050 kernel: [   15.812679] amdgpu 0000:0c:00.0: Direct firmware load for amdgpu/polaris10_k_smc.bin failed with error -2
Feb 22 10:59:38 rh050 kernel: [   15.812729] [drm:amdgpu_cgs_get_firmware_info [amdgpu]] *ERROR* Failed to request firmware
Feb 22 10:59:38 rh050 kernel: [   16.283720] amdgpu: [powerplay] Failed to send Message.
Feb 22 10:59:38 rh050 kernel: [   16.761165] amdgpu: [powerplay] SMU Firmware start failed!
Feb 22 10:59:38 rh050 kernel: [   16.761165] amdgpu: [powerplay] Failed to load SMU ucode.
Feb 22 10:59:38 rh050 kernel: [   16.761166] amdgpu: [powerplay] smc start failed
Feb 22 10:59:38 rh050 kernel: [   16.761168] amdgpu: [powerplay] powerplay hw init failed
Feb 22 10:59:38 rh050 kernel: [   16.761204] [drm:amdgpu_device_init [amdgpu]] *ERROR* hw_init of IP block <powerplay> failed -22
Feb 22 10:59:38 rh050 kernel: [   16.761207] amdgpu 0000:0c:00.0: amdgpu_device_ip_init failed
Feb 22 10:59:38 rh050 kernel: [   16.761209] amdgpu 0000:0c:00.0: Fatal error during GPU init
Feb 22 10:59:38 rh050 kernel: [   16.761219] [drm] amdgpu: finishing device.
Feb 22 10:59:38 rh050 kernel: [   17.767534] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   17.767534]  last message was failed ret is 0
Feb 22 10:59:38 rh050 kernel: [   18.270243] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   18.270243]  failed to send message 261 ret is 0
Feb 22 10:59:38 rh050 kernel: [   19.275704] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   19.275704]  last message was failed ret is 0
Feb 22 10:59:38 rh050 kernel: [   19.778467] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   19.778467]  failed to send message 261 ret is 0
Feb 22 10:59:38 rh050 kernel: [   20.783863] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   20.783863]  last message was failed ret is 0
Feb 22 10:59:38 rh050 kernel: [   21.286594] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   21.286594]  failed to send message 261 ret is 0
Feb 22 10:59:38 rh050 kernel: [   22.292035] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   22.292035]  last message was failed ret is 0
Feb 22 10:59:38 rh050 kernel: [   22.794757] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   22.794757]  failed to send message 261 ret is 0
Feb 22 10:59:38 rh050 kernel: [   23.800230] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   23.800230]  last message was failed ret is 0
Feb 22 10:59:38 rh050 kernel: [   24.302904] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   24.302904]  failed to send message 261 ret is 0
Feb 22 10:59:38 rh050 kernel: [   25.308369] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   25.308369]  last message was failed ret is 0
Feb 22 10:59:38 rh050 kernel: [   25.811084] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   25.811084]  failed to send message 261 ret is 0
Feb 22 10:59:38 rh050 kernel: [   26.816541] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   26.816541]  last message was failed ret is 0
Feb 22 10:59:38 rh050 kernel: [   27.319268] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   27.319268]  failed to send message 261 ret is 0
Feb 22 10:59:38 rh050 kernel: [   28.324723] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   28.324723]  last message was failed ret is 0
Feb 22 10:59:38 rh050 kernel: [   28.827422] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   28.827422]  failed to send message 261 ret is 0
Feb 22 10:59:38 rh050 kernel: [   29.832877] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   29.832877]  last message was failed ret is 0
Feb 22 10:59:38 rh050 kernel: [   30.335578] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   30.335578]  failed to send message 261 ret is 0
Feb 22 10:59:38 rh050 kernel: [   31.341038] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   31.341038]  last message was failed ret is 0
Feb 22 10:59:38 rh050 kernel: [   31.843745] amdgpu: [powerplay]
Feb 22 10:59:38 rh050 kernel: [   31.843745]  failed to send message 261 ret is 0
Feb 22 10:59:38 rh050 kernel: [   31.844311] igb 0000:0a:00.0 eth0: igb: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
Feb 22 10:59:38 rh050 kernel: [   31.849818] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   31.849819] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   31.849819]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   31.849819]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   31.909251] ------------[ cut here ]------------
Feb 22 10:59:38 rh050 kernel: [   31.909252] Memory manager not clean during takedown.
Feb 22 10:59:38 rh050 kernel: [   31.909281] WARNING: CPU: 11 PID: 684 at /build/linux-3Qtbv4/linux-4.19.67/drivers/gpu/drm/drm_mm.c:950 drm_mm_takedown+0x20/0x30 [drm]
Feb 22 10:59:38 rh050 kernel: [   31.909281] Modules linked in: amd64_edac_mod(-) amdkfd amdgpu(+) ftdi_sio usbserial snd_hda_codec_realtek joydev snd_hda_codec_generic eeepc_wmi asus_wmi snd_hda_codec_hdmi sparse_keymap rfkill video wmi_bmof mxm_wmi evdev snd_hda_intel snd_hda_codec edac_mce_amd snd_hda_core kvm_amd snd_hwdep chash snd_pcm gpu_sched kvm ttm drm_kms_helper snd_timer irqbypass snd efi_pstore soundcore ccp k10temp drm efivars pcspkr sp5100_tco rng_core pcc_cpufreq wmi acpi_cpufreq button ext4 crc16 mbcache jbd2 crc32c_generic fscrypto ecb algif_skcipher af_alg dm_crypt dm_mod uas usb_storage sr_mod cdrom sg hid_generic usbhid hid sd_mod ohci_pci crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel pcbc ahci xhci_pci libahci xhci_hcd ehci_pci libata ohci_hcd ehci_hcd aesni_intel igb usbcore scsi_mod aes_x86_64
Feb 22 10:59:38 rh050 kernel: [   31.909308]  crypto_simd cryptd nvme glue_helper i2c_piix4 i2c_algo_bit nvme_core dca usb_common gpio_amdpt gpio_generic
Feb 22 10:59:38 rh050 kernel: [   31.909313] CPU: 11 PID: 684 Comm: udevd Not tainted 4.19.0-0.bpo.6-amd64 #1 Debian 4.19.67-2+deb10u2~bpo9+1
Feb 22 10:59:38 rh050 kernel: [   31.909314] Hardware name: System manufacturer System Product Name/PRIME X470-PRO, BIOS 5406 11/13/2019
Feb 22 10:59:38 rh050 kernel: [   31.909325] RIP: 0010:drm_mm_takedown+0x20/0x30 [drm]
Feb 22 10:59:38 rh050 kernel: [   31.909327] Code: fc 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 48 8b 47 38 48 83 c7 38 48 39 c7 75 02 f3 c3 48 c7 c7 70 a7 5f c0 e8 00 d0 cb fc <0f> 0b c3 0f 1f 00 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 41
Feb 22 10:59:38 rh050 kernel: [   31.909328] RSP: 0018:ffffa6e6c84fb9d8 EFLAGS: 00010282
Feb 22 10:59:38 rh050 kernel: [   31.909329] RAX: 0000000000000000 RBX: ffff9a9ef1e351e8 RCX: ffffffffbe24dea8
Feb 22 10:59:38 rh050 kernel: [   31.909330] RDX: 0000000000000001 RSI: 0000000000000086 RDI: 0000000000000247
Feb 22 10:59:38 rh050 kernel: [   31.909331] RBP: ffff9a9ef1e35100 R08: 0000000000000001 R09: 00000000000004e2
Feb 22 10:59:38 rh050 kernel: [   31.909331] R10: ffff9a9ef5994900 R11: 0000000000000000 R12: ffff9a9ef73a29a0
Feb 22 10:59:38 rh050 kernel: [   31.909332] R13: 0000000000000000 R14: 0000000000000170 R15: ffff9a9ef73a3080
Feb 22 10:59:38 rh050 kernel: [   31.909333] FS:  00007fe735655880(0000) GS:ffff9a9efe8c0000(0000) knlGS:0000000000000000
Feb 22 10:59:38 rh050 kernel: [   31.909334] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Feb 22 10:59:38 rh050 kernel: [   31.909335] CR2: 00007f2a85dacab4 CR3: 00000007f9616000 CR4: 00000000003406e0
Feb 22 10:59:38 rh050 kernel: [   31.909335] Call Trace:
Feb 22 10:59:38 rh050 kernel: [   31.909390]  amdgpu_vram_mgr_fini+0x27/0x50 [amdgpu]
Feb 22 10:59:38 rh050 kernel: [   31.909397]  ttm_bo_clean_mm+0xa7/0xf0 [ttm]
Feb 22 10:59:38 rh050 kernel: [   31.909447]  amdgpu_ttm_fini+0x72/0x110 [amdgpu]
Feb 22 10:59:38 rh050 kernel: [   31.909496]  amdgpu_bo_fini+0xe/0x30 [amdgpu]
Feb 22 10:59:38 rh050 kernel: [   31.909551]  gmc_v8_0_sw_fini+0x32/0x60 [amdgpu]
Feb 22 10:59:38 rh050 kernel: [   31.909598]  amdgpu_device_fini+0x431/0x550 [amdgpu]
Feb 22 10:59:38 rh050 kernel: [   31.909645]  amdgpu_driver_unload_kms+0x42/0x90 [amdgpu]
Feb 22 10:59:38 rh050 kernel: [   31.909692]  amdgpu_driver_load_kms+0x154/0x2d0 [amdgpu]
Feb 22 10:59:38 rh050 kernel: [   31.909703]  drm_dev_register+0x112/0x1a0 [drm]
Feb 22 10:59:38 rh050 kernel: [   31.909750]  amdgpu_pci_probe+0x1b5/0x280 [amdgpu]
Feb 22 10:59:38 rh050 kernel: [   31.909754]  local_pci_probe+0x44/0xa0
Feb 22 10:59:38 rh050 kernel: [   31.909757]  ? _cond_resched+0x16/0x40
Feb 22 10:59:38 rh050 kernel: [   31.909759]  pci_device_probe+0x105/0x1c0
Feb 22 10:59:38 rh050 kernel: [   31.909761]  really_probe+0x215/0x3f0
Feb 22 10:59:38 rh050 kernel: [   31.909763]  driver_probe_device+0x10b/0x130
Feb 22 10:59:38 rh050 kernel: [   31.909765]  __driver_attach+0x119/0x120
Feb 22 10:59:38 rh050 kernel: [   31.909766]  ? driver_probe_device+0x130/0x130
Feb 22 10:59:38 rh050 kernel: [   31.909768]  bus_for_each_dev+0x67/0xc0
Feb 22 10:59:38 rh050 kernel: [   31.909770]  ? klist_add_tail+0x3b/0x70
Feb 22 10:59:38 rh050 kernel: [   31.909771]  bus_add_driver+0x16a/0x260
Feb 22 10:59:38 rh050 kernel: [   31.909773]  driver_register+0x5b/0xe0
Feb 22 10:59:38 rh050 kernel: [   31.909774]  ? 0xffffffffc09ed000
Feb 22 10:59:38 rh050 kernel: [   31.909776]  do_one_initcall+0x4d/0x1c5
Feb 22 10:59:38 rh050 kernel: [   31.909778]  ? _cond_resched+0x16/0x40
Feb 22 10:59:38 rh050 kernel: [   31.909780]  ? kmem_cache_alloc_trace+0x16a/0x1d0
Feb 22 10:59:38 rh050 kernel: [   31.909783]  do_init_module+0x5b/0x21b
Feb 22 10:59:38 rh050 kernel: [   31.909785]  load_module+0x24de/0x2b20
Feb 22 10:59:38 rh050 kernel: [   31.909788]  ? __do_sys_finit_module+0xd7/0x110
Feb 22 10:59:38 rh050 kernel: [   31.909790]  __do_sys_finit_module+0xd7/0x110
Feb 22 10:59:38 rh050 kernel: [   31.909792]  do_syscall_64+0x55/0x120
Feb 22 10:59:38 rh050 kernel: [   31.909794]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
Feb 22 10:59:38 rh050 kernel: [   31.909795] RIP: 0033:0x7fe734b1b469
Feb 22 10:59:38 rh050 kernel: [   31.909797] Code: 00 f3 c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 40 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d ff 49 2b 00 f7 d8 64 89 01 48
Feb 22 10:59:38 rh050 kernel: [   31.909798] RSP: 002b:00007ffcdf856cf8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
Feb 22 10:59:38 rh050 kernel: [   31.909799] RAX: ffffffffffffffda RBX: 000056465676ff20 RCX: 00007fe734b1b469
Feb 22 10:59:38 rh050 kernel: [   31.909799] RDX: 0000000000000000 RSI: 00007fe734de7265 RDI: 000000000000000f
Feb 22 10:59:38 rh050 kernel: [   31.909800] RBP: 00007fe734de7265 R08: 0000000000000000 R09: 00007ffcdf857270
Feb 22 10:59:38 rh050 kernel: [   31.909801] R10: 000000000000000f R11: 0000000000000246 R12: 0000000000000000
Feb 22 10:59:38 rh050 kernel: [   31.909801] R13: 0000564656772090 R14: 0000000000020000 R15: 0000564655a76319
Feb 22 10:59:38 rh050 kernel: [   31.909803] ---[ end trace b98908ecc39fa167 ]---
Feb 22 10:59:38 rh050 kernel: [   31.909808] [TTM] Finalizing pool allocator
Feb 22 10:59:38 rh050 kernel: [   31.909812] [TTM] Finalizing DMA pool allocator
Feb 22 10:59:38 rh050 kernel: [   31.909840] [TTM] Zone  kernel: Used memory at exit: 22 kiB
Feb 22 10:59:38 rh050 kernel: [   31.909842] [TTM] Zone   dma32: Used memory at exit: 22 kiB
Feb 22 10:59:38 rh050 kernel: [   31.909844] [drm] amdgpu: ttm finalized
Feb 22 10:59:38 rh050 kernel: [   31.910039] amdgpu: probe of 0000:0c:00.0 failed with error -22
Feb 22 10:59:38 rh050 kernel: [   31.952908] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   31.952910] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   31.952910]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   31.952910]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   32.000861] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   32.000863] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   32.000863]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   32.000863]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   32.057072] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   32.057073] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   32.057073]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   32.057073]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   32.097084] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   32.097086] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   32.097086]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   32.097086]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   32.137102] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   32.137103] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   32.137103]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   32.137103]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   32.181398] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   32.181400] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   32.181400]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   32.181400]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   32.221396] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   32.221397] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   32.221397]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   32.221397]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   32.273256] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   32.273258] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   32.273258]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   32.273258]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   32.321052] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   32.321053] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   32.321053]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   32.321053]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   32.373105] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   32.373106] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   32.373106]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   32.373106]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   32.413134] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   32.413136] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   32.413136]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   32.413136]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   32.445207] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   32.445209] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   32.445209]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   32.445209]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   32.485111] EDAC amd64: Node 0: DRAM ECC disabled.
Feb 22 10:59:38 rh050 kernel: [   32.485112] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Feb 22 10:59:38 rh050 kernel: [   32.485112]  Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Feb 22 10:59:38 rh050 kernel: [   32.485112]  (Note that use of the override may cause unknown side effects.)
Feb 22 10:59:38 rh050 kernel: [   32.653619] EXT4-fs (dm-1): re-mounted. Opts: discard,errors=remount-ro
Feb 22 10:59:38 rh050 kernel: [   34.012335] igb 0000:0a:00.0: exceed max 2 second
Feb 22 10:59:38 rh050 kernel: [   34.012507] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Feb 22 10:59:38 rh050 kernel: [   44.136814] lp: driver loaded but no devices found
Feb 22 10:59:38 rh050 kernel: [   44.140919] ppdev: user-space parallel port driver
Feb 22 10:59:38 rh050 kernel: [   44.216544] Adding 31997948k swap on /dev/mapper/vgsys-2_swap.  Priority:-2 extents:1 across:31997948k SSFS
Feb 22 10:59:38 rh050 kernel: [   44.384616] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 22 10:59:38 rh050 kernel: [   44.411627] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Opts: discard
Feb 22 10:59:38 rh050 kernel: [   44.433402] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null)
Feb 22 10:59:38 rh050 kernel: [   44.469276] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
Feb 22 10:59:38 rh050 kernel: [   44.491782] fuse init (API version 7.27)
Feb 22 10:59:38 rh050 kernel: [   44.884523] audit: type=1400 audit(1582365577.327:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="virt-aa-helper" pid=2229 comm="apparmor_parser"
Feb 22 10:59:38 rh050 kernel: [   44.891532] audit: type=1400 audit(1582365577.331:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/libvirtd" pid=2240 comm="apparmor_parser"
Feb 22 10:59:38 rh050 kernel: [   44.891633] audit: type=1400 audit(1582365577.331:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/libvirtd//qemu_bridge_helper" pid=2240 comm="apparmor_parser"
Feb 22 10:59:38 rh050 kernel: [   44.901362] audit: type=1400 audit(1582365577.343:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=2228 comm="apparmor_parser"
Feb 22 10:59:38 rh050 kernel: [   44.905792] audit: type=1400 audit(1582365577.347:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ntpd" pid=2233 comm="apparmor_parser"
Feb 22 10:59:38 rh050 kernel: [   44.906789] RPC: Registered named UNIX socket transport module.
Feb 22 10:59:38 rh050 kernel: [   44.906790] RPC: Registered udp transport module.
Feb 22 10:59:38 rh050 kernel: [   44.906790] RPC: Registered tcp transport module.
Feb 22 10:59:38 rh050 kernel: [   44.906790] RPC: Registered tcp NFSv4.1 backchannel transport module.
Feb 22 10:59:38 rh050 kernel: [   44.915815] FS-Cache: Loaded
Feb 22 10:59:38 rh050 kernel: [   44.931224] FS-Cache: Netfs 'nfs' registered for caching
Feb 22 10:59:38 rh050 kernel: [   44.952692] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Feb 22 10:59:38 rh050 kernel: [   45.016082] audit: type=1400 audit(1582365577.459:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=2232 comm="apparmor_parser"
Feb 22 10:59:38 rh050 kernel: [   45.016281] audit: type=1400 audit(1582365577.459:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd" pid=2232 comm="apparmor_parser"
Feb 22 10:59:38 rh050 kernel: [   45.016326] audit: type=1400 audit(1582365577.459:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd//third_party" pid=2232 comm="apparmor_parser"
Feb 22 10:59:38 rh050 kernel: [   45.162551] audit: type=1400 audit(1582365577.603:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/telepathy/mission-control-5" pid=2230 comm="apparmor_parser"
Feb 22 10:59:38 rh050 kernel: [   45.162807] audit: type=1400 audit(1582365577.603:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/telepathy/telepathy-*" pid=2230 comm="apparmor_parser"
Feb 22 10:59:38 rh050 ntpd[2722]: ntpd 4.2.8p10@1.3728-o Sun Feb 25 21:22:55 UTC 2018 (1): Starting
Feb 22 10:59:38 rh050 ntpd[2722]: Command line: /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 108:113
Feb 22 10:59:38 rh050 ntpd[2790]: proto: precision = 0.050 usec (-24)
Feb 22 10:59:38 rh050 cron[2800]: (CRON) INFO (pidfile fd = 3)
Feb 22 10:59:38 rh050 cron[2865]: (CRON) STARTUP (fork ok)
Feb 22 10:59:38 rh050 ntpd[2790]: Listen and drop on 0 v6wildcard [::]:123
Feb 22 10:59:38 rh050 ntpd[2790]: Listen and drop on 1 v4wildcard 0.0.0.0:123
Feb 22 10:59:38 rh050 ntpd[2790]: Listen normally on 2 lo 127.0.0.1:123
Feb 22 10:59:38 rh050 ntpd[2790]: Listen normally on 3 eth0 10.6.6.50:123
Feb 22 10:59:38 rh050 ntpd[2790]: Listen normally on 4 lo [::1]:123
Feb 22 10:59:38 rh050 ntpd[2790]: Listen normally on 5 eth0 [fe80::4eed:fbff:fe79:1cdf%2]:123
Feb 22 10:59:38 rh050 ntpd[2790]: Listening on routing socket on fd #22 for interface updates
#2 2020-02-22 19:56:22
Re: [Solved] Boot messages surpressed with new graphics card
Just when finished posting this topic the idea crossed my mind that I should better check the version of firmware-amd-graphics installed.
Result is that that I had the original ASCII package dated 2016 on board, and not the one from backports as I thought. Update done, and now I see different messages.
Whats left looks like there is an residual error "Voltage value looks like a Leakage ID but it's not patched" thats also displayed as boot message. The kernel panic like section also is gone.
Any ideas how to get rid of this?
Thanks, rolfie
Feb 22 20:43:48 rh050 kernel: [   16.354304] [drm] PCIE GART of 256M enabled (table at 0x000000F400300000).
Feb 22 20:43:48 rh050 kernel: [   16.354649] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_pfp_2.bin
Feb 22 20:43:48 rh050 kernel: [   16.354809] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_me_2.bin
Feb 22 20:43:48 rh050 kernel: [   16.354940] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_ce_2.bin
Feb 22 20:43:48 rh050 kernel: [   16.354942] [drm] Chained IB support enabled!
Feb 22 20:43:48 rh050 kernel: [   16.355168] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_rlc.bin
Feb 22 20:43:48 rh050 kernel: [   16.355928] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_mec_2.bin
Feb 22 20:43:48 rh050 kernel: [   16.356678] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_mec2_2.bin
Feb 22 20:43:48 rh050 kernel: [   16.357625] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_sdma.bin
Feb 22 20:43:48 rh050 kernel: [   16.357730] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_sdma1.bin
Feb 22 20:43:48 rh050 kernel: [   16.358553] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_uvd.bin
Feb 22 20:43:48 rh050 kernel: [   16.358555] [drm] Found UVD firmware Version: 1.130 Family ID: 16
Feb 22 20:43:48 rh050 kernel: [   16.359655] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_vce.bin
Feb 22 20:43:48 rh050 kernel: [   16.359657] [drm] Found VCE firmware Version: 53.26 Binary ID: 3
Feb 22 20:43:48 rh050 kernel: [   16.360300] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/polaris10_k_smc.bin
Feb 22 20:43:48 rh050 kernel: [   16.406712] amdgpu: [powerplay] Voltage value looks like a Leakage ID but it's not patched
Feb 22 20:43:48 rh050 kernel: [   16.406716] amdgpu: [powerplay] Voltage value looks like a Leakage ID but it's not patched
Feb 22 20:43:48 rh050 kernel: [   16.406717] amdgpu: [powerplay] Voltage value looks like a Leakage ID but it's not patched
Feb 22 20:43:48 rh050 kernel: [   16.406719] amdgpu: [powerplay] Voltage value looks like a Leakage ID but it's not patched
Feb 22 20:43:48 rh050 kernel: [   16.406721] amdgpu: [powerplay] Voltage value looks like a Leakage ID but it's not patched
Feb 22 20:43:48 rh050 kernel: [   16.406722] amdgpu: [powerplay] Voltage value looks like a Leakage ID but it's not patched
Feb 22 20:43:48 rh050 kernel: [   16.406724] amdgpu: [powerplay] Voltage value looks like a Leakage ID but it's not patched
Feb 22 20:43:48 rh050 kernel: [   16.416856] amdgpu: [powerplay] Failed to retrieve minimum clocks.
Feb 22 20:43:48 rh050 kernel: [   16.416858] amdgpu: [powerplay] Error in phm_get_clock_info
#3 2020-02-22 20:09:43
You're going to need beowulf-backports to get a fixed kernel version: https://bbs.archlinux.org/viewtopic.php?id=239945
2nd generation Ryzen was always going to be a push for ASCII anyway so time to upgrade :-)
#4 2020-02-22 20:52:39
Thanks for your feedback. Well, the link you posted deals with an AC supply problem on a laptop, if I read it right. Different issue.
Using the Duck I could not find many threads about this Voltage value error. From the ones I found I could not take any benefit for me and this problem.
My Ryzen worked satisfactory for one and a half years on ASCII now. Its my workbench, and I do not see an urgent need to upgrade right now. And I have a complex setup that works for me, so I don't want to risk this and be offline. Maybe I install Beowulf in the free space I have on my SSD in parallel to ASCII. Need to have a closer look how to do this, never had this setup before.
#5 2020-02-22 21:30:09
I'm not so sure, the OP has the same error messages as you. Try an Arch live image and see if that shows the errors, they're on kernel 5.5.1 atm.
#6 2020-02-23 12:28:41
You are right, on a second look there are the same messages present, did not see them.
For the time being: problem solved.
#7 2020-02-24 19:30:26
Tried the current built 2020-02-01 on CD, that comes with kernel 5.4.15. Same messages displayed during boot.
I am not familiar with putting such an iso on a stick and then to update this. Will wait a few days for the next release.
