Pages: 1
HI,
I try to bind the windows+Z shorcut with the command lxqt-leave --shutdown but it doesn't work.
lxqt-leave --shutdown works as a regular user in a terminal
and my windows+S shortcut to lxqt-leave --suspend is working too.
Any help understanding what's wrong is welcome.
It works here (in ascii) but I can't say anything about beowulf (I haven't tested it). I use openbox. What WM do you use? Sometimes the WM may assign shortcuts to its actions and overrides this way the LXQT shortcuts. Try running the lxqt-globalkeysd daemon in foreground in a terminal window and check its output. Someting like this:
killall lxqt-globalkeysd
lxqt-globalkeysd --no-daemon --log-level=debugWhen you press a key combination that was successfully assigned by LXQT you should see an output like this:
[Debug] KeyPress 00000040 00000034 Meta+ZLast edited by omnio (2020-01-31 22:15:48)
Ok found out:
My keyboard is french, so the Z key is at the W place (and réciproquement).
lxqt-globalkeyshortcuts is telling me I mapped meta+Z when I hit the Z key, but the real mapping is to the qwerty Z key, I don't know why.
By the way, thanks for hinting me to the matter of the WM: I realized that it was XFWM I was running. And yes, it has shortcuts which interfere with the LXQT ones.
Pages: 1
