#1 2020-01-28 03:20:47
Copper36
Mouse/touchpad settings in XFCE
I have a problem with mouse and touchpad settings: they both work, but both sensitivity and acceleration are locked. I can set any position on the bar, but nothing changes and the button "Restore to defaults" is greyed out. On the other hand, switching left/right-hand mouse works just fine. It looks like some settings can't be accessed using XFCE Settings GUI...
Would be grateful for any help.
Devuan ASCII 64bit.
Thank you.
#2 2020-02-02 21:13:20
Copper36
Re: Mouse/touchpad settings in XFCE
I have found a possible work-around for this issue, but not sure how it applies to Devuan.
Te link is here:
https://bugs.launchpad.net/ubuntu/+sour … ug/1758023
the very last post (#31), but I can't find the location of xorg conf files in my ASCII, looks like it's different from Debian 10.
Maybe post #10 is of some help, but:
  task-desktop task-xfce-desktop xserver-xorg-input-all
  xserver-xorg-input-libinput
and I am not sure if I want to do that.
Any suggestions?
Thank you.
#3 2020-02-03 15:13:05
No, you don't want to do that.
I installed xserver-xorg-input-synaptics and the 'Reset to defaults' button becomes active. Except it doesn't do anything, because I still can't change it to anything but the defaults.
I then removed xserver-xorg-input-libinput and installed xserver-xorg-input-evdev, rebooted, and it now works. I can change the speed of the touchpad. I still can't change the speed of the trackpoint.
(Thinkpad T420 has a Synaptics touchpad.)
#4 2020-02-06 03:02:41
Copper36
Thanks, fsmithred! At least the touchpad is now OK, though I'd prefer to configure my wireless mouse...
#5 2020-02-06 15:17:19
Create your own file at /etc/X11/xorg.conf.d/99-custom-evdev.conf — that location works for both Devuan ASCII and Debian buster.
#6 2020-02-08 18:35:59
Copper36
Thanks a lot, worked out perfectly!
