#1 2020-01-22 13:18:23
EBoyWarrior
Shepherd Init Consideration
While looking at https://www.devuan.org/os/init-freedom/ , I noticed shepherd/Shepherd was in consideration. Currently, I am using artix linux with openrc -- at least it's not arch linux with systemd. However, I am trying to convert to devuan sometime in the future -- mostly because of the sysvinit scripts allowed with devuan. I have also been messing with guix in a QEMU VM, and trying to identify the init files, but it I am also having a hard time finding the init scripts. Basically, I would like to implement this in a tinkering method, but I am seriously curious about them. I also don't see guix on that page, but guix I think only works with shepherd.
Simple question : How would I go about transitioning sysvinit scripts to shepherd under devuan -- mostly because I am super curious and tinkery right now.
#2 2020-01-23 04:55:10
ToxicExMachina
Re: Shepherd Init Consideration
https://en.wikibooks.org/wiki/Scheme_Programming
http://www.shido.info/lisp/idx_scm_e.html
https://www.scheme.com/tspl4/
Good luck with GNU Shepherd and pro-SJW Guix.
#3 2020-01-24 16:33:36
Read the documentation: https://www.gnu.org/software/shepherd/m … l#Services
Probably a lost cause though because it seems to be tightly integrated with herd.
EDIT: removed wind-up, it's not worth it.
"Il semble que la perfection soit atteinte non quand il n'y a plus rien à ajouter, mais quand il n'y a plus rien à retrancher." — Antoine de Saint-Exupéry
