I installed beowulf on an RPi 4. It works fine in tty, but I only have a black screen with xorg. I tried with .xinitrc and mate+lightdm. Both gave the same result : black screen.
.xinitrc
exec xterm & sleep 10Xorg0.log
X.Org X Server 1.20.4
Build Operating System: Linux 4.9.0-8-arm64 armv8l Debian
Current Operating System: Linux RPi-4 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l
Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M cma=256M video=HDMI-A-1:1920x1080M@50,margin_left=0,margin_right=0,margin_top=0,margin_bottom=0 smsc95xx.macaddr=DC:A6:32:0D:02:34 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 root=/dev/sda3 rw rootwait console=ttyAMA0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 kgdboc=ttyAMA0,115200 elevator=noop raid=noautodetect noswap
Build Date: 05 March 2019 08:11:12PM
xorg-server 2:1.20.4-1 (https://www.debian.org/support)
Current version of pixman: 0.36.0
Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/home/aviolleau/.local/share/xorg/Xorg.0.log", Time: Thu Jan 1 01:01:04 1970
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(==) No Layout section. Using the first Screen section.
(==) No screen section available. Using defaults.
(**) |-->Screen "Default Screen Section" (0)
(**) | |-->Monitor "<default monitor>"
(==) No monitor specified for screen "Default Screen Section".
(==) Automatically adding devices
(==) Automatically enabling devices
(==) Automatically adding GPU devices
(==) Max clients allowed: 256, resource mask: 0x1fffff
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) The server relies on udev to provide the list of input devices.
(II) Loader magic: 0x663f98
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 24.0
X.Org XInput driver : 24.1
X.Org Server Extension : 10.0
(++) using VT number 1
(II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
(II) xfree86: Adding drm device (/dev/dri/card1)
(II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 11 paused 0
(II) xfree86: Adding drm device (/dev/dri/card0)
(II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
(II) no primary bus or device found
falling back to /sys/devices/platform/soc/soc:gpu/drm/card1
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
compiled for 1.20.4, module version = 1.0.0
ABI class: X.Org Server Extension, version 10.0
(==) Matched modesetting as autoconfigured driver 0
(==) Matched fbdev as autoconfigured driver 1
(==) Assigned the driver to the xf86ConfigLayout
(II) LoadModule: "modesetting"
(II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
(II) Module modesetting: vendor="X.Org Foundation"
compiled for 1.20.4, module version = 1.20.4
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 24.0
(II) LoadModule: "fbdev"
(II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) Module fbdev: vendor="X.Org Foundation"
compiled for 1.20.0, module version = 0.5.0
(II) modesetting: Driver for Modesetting Kernel Drivers: kms
(II) FBDEV: driver for framebuffer: fbdev
(II) modeset(0): using drv /dev/dri/card1
(WW) Falling back to old probe method for fbdev
(II) Loading sub module "fbdevhw"
(II) LoadModule: "fbdevhw"
(II) Loading /usr/lib/xorg/modules/libfbdevhw.so
(II) Module fbdevhw: vendor="X.Org Foundation"
compiled for 1.20.4, module version = 0.0.2
(WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
(II) modeset(0): Creating default Display subsection in Screen section
(==) modeset(0): Depth 24, (==) framebuffer bpp 32
(==) modeset(0): RGB weight 888
(==) modeset(0): Default visual is TrueColor
(II) Loading sub module "glamoregl"
(II) LoadModule: "glamoregl"
(II) Loading /usr/lib/xorg/modules/libglamoregl.so
(II) Module glamoregl: vendor="X.Org Foundation"
compiled for 1.20.4, module version = 1.0.1
ABI class: X.Org ANSI C Emulation, version 0.4
(II) modeset(0): glamor X acceleration enabled on VC4 V3D 2.1
(II) modeset(0): glamor initialized
(II) modeset(0): Output HDMI-1 has no monitor section
(II) modeset(0): EDID for output HDMI-1
(II) modeset(0): Manufacturer: SNY Model: 4b03 Serial#: 16843009
(II) modeset(0): Year: 2014 Week: 1
(II) modeset(0): EDID Version: 1.3
(II) modeset(0): Digital Display Input
: horiz.: 89 vert.: 50
(II) modeset(0): Gamma: 2.20
(II) modeset(0): No DPMS capabilities specified
(II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
(II) modeset(0): First detailed timing is preferred mode
(II) modeset(0): redX: 0.625 redY: 0.340 greenX: 0.280 greenY: 0.595
(II) modeset(0): blueX: 0.155 blueY: 0.070 whiteX: 0.283 whiteY: 0.298
(II) modeset(0): Supported established timings:
(II) modeset(0): 640x480@60Hz
(II) modeset(0): 800x600@60Hz
(II) modeset(0): 1024x768@60Hz
(II) modeset(0): Manufacturer's mask: 0
(II) modeset(0): Supported standard timings:
(II) modeset(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) modeset(0): #1: hsize: 1600 vsize 900 refresh: 60 vid: 49321
(II) modeset(0): #2: hsize: 1152 vsize 864 refresh: 75 vid: 20337
(II) modeset(0): #3: hsize: 1680 vsize 1050 refresh: 60 vid: 179
(II) modeset(0): Supported detailed timing:
(II) modeset(0): clock: 148.5 MHz Image Size: 886 x 498 mm
(II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
(II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
(II) modeset(0): clock: 74.2 MHz Image Size: 886 x 498 mm
(II) modeset(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
(II) modeset(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
(II) modeset(0): Monitor name: SONY TV
(II) modeset(0): Ranges: V min: 48 V max: 62 Hz, H min: 14 H max: 70 kHz, PixClock max 155 MHz
(II) modeset(0): h_active: 1920 h_sync: 2448 h_sync_end 2492 h_blank_end 2640 h_border: 0
(II) modeset(0): h_active: 1280 h_sync: 1720 h_sync_end 1760 h_blank_end 1980 h_border: 0
(II) modeset(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
(II) modeset(0): Number of EDID sections to follow: 1
(II) modeset(0): EDID (in hex):
(II) modeset(0): 00ffffffffffff004dd9034b01010101
(II) modeset(0): 01180103805932780a0dc9a057479827
(II) modeset(0): 12484c2108008180a9c0714fb3000101
(II) modeset(0): 010101010101023a801871382d40582c
(II) modeset(0): 450076f23100001e011d007251d01e20
(II) modeset(0): 6e28550076f23100001e000000fc0053
(II) modeset(0): 4f4e592054560a2020202020000000fd
(II) modeset(0): 00303e0e460f000a2020202020200110
(II) modeset(0): 02032ff0531f101405130420223c3e12
(II) modeset(0): 1603071115020601260d070715075083
(II) modeset(0): 0f000068030c001000b82d0fe200fb02
(II) modeset(0): 3a80d072382d40102c458076f2310000
(II) modeset(0): 1e011d00bc52d01e20b828554076f231
(II) modeset(0): 00001e011d8018711c1620582c250076
(II) modeset(0): f23100009e011d80d0721c1620102c25
(II) modeset(0): 8076f23100009e000000000000000012
(--) modeset(0): HDMI max TMDS frequency 225000KHz
(II) modeset(0): Printing probed modes for output HDMI-1
(II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
(II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
(II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
(II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
(II) modeset(0): Modeline "1920x1080"x30.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
(II) modeset(0): Modeline "1920x1080"x24.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
(II) modeset(0): Modeline "1920x1080"x30.0 74.18 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
(II) modeset(0): Modeline "1920x1080"x24.0 74.18 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
(II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
(II) modeset(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
(II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
(II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
(II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
(II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
(II) modeset(0): Modeline "1280x720"x30.0 74.25 1280 3040 3080 3300 720 725 730 750 +hsync +vsync (22.5 kHz e)
(II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
(II) modeset(0): Modeline "1280x720"x30.0 74.18 1280 3040 3080 3300 720 725 730 750 +hsync +vsync (22.5 kHz e)
(II) modeset(0): Modeline "1280x720"x24.0 59.40 1280 3040 3080 3300 720 725 730 750 +hsync +vsync (18.0 kHz e)
(II) modeset(0): Modeline "1280x720"x24.0 59.34 1280 3040 3080 3300 720 725 730 750 +hsync +vsync (18.0 kHz e)
(II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
(II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
(II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
(II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
(II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
(II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
(II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
(II) modeset(0): Output HDMI-1 connected
(II) modeset(0): Using exact sizes for initial modes
(II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0
(==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
(==) modeset(0): DPI set to (96, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
(II) UnloadModule: "fbdev"
(II) Unloading fbdev
(II) UnloadSubModule: "fbdevhw"
(II) Unloading fbdevhw
(==) modeset(0): Backing store enabled
(==) modeset(0): Silken mouse enabled
(II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
(==) modeset(0): DPMS enabled
Setup complete
DRI driver: vc4
VDPAU driver: vc4
(II) Initializing extension Generic Event Extension
(II) Initializing extension SHAPE
(II) Initializing extension MIT-SHM
(II) Initializing extension XInputExtension
(II) Initializing extension XTEST
(II) Initializing extension BIG-REQUESTS
(II) Initializing extension SYNC
(II) Initializing extension XKEYBOARD
(II) Initializing extension XC-MISC
(II) Initializing extension SECURITY
(II) Initializing extension XFIXES
(II) Initializing extension RENDER
(II) Initializing extension RANDR
(II) Initializing extension COMPOSITE
(II) Initializing extension DAMAGE
(II) Initializing extension MIT-SCREEN-SAVER
(II) Initializing extension DOUBLE-BUFFER
(II) Initializing extension RECORD
(II) Initializing extension DPMS
(II) Initializing extension Present
(II) Initializing extension DRI3
(II) Initializing extension X-Resource
(II) Initializing extension XVideo
(II) Initializing extension XVideo-MotionCompensation
(II) Initializing extension SELinux
(II) SELinux: Disabled on system
(II) Initializing extension GLX
(II) AIGLX: Loaded and initialized vc4
(II) GLX: Initialized DRI2 GL provider for screen 0
(II) Initializing extension XFree86-VidModeExtension
(II) Initializing extension XFree86-DGA
(II) Initializing extension XFree86-DRI
(II) Initializing extension DRI2
(II) modeset(0): Damage tracking initialized
(II) modeset(0): Setting screen physical size to 508 x 285
(II) config/udev: Adding input device mini keyboard (/dev/input/event0)
(**) mini keyboard: Applying InputClass "libinput keyboard catchall"
(II) LoadModule: "libinput"
(II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
(II) Module libinput: vendor="X.Org Foundation"
compiled for 1.20.4, module version = 0.28.2
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 24.1
(II) Using input driver 'libinput' for ' mini keyboard'
(II) systemd-logind: got fd for /dev/input/event0 13:64 fd 25 paused 0
(**) mini keyboard: always reports core events
(**) Option "Device" "/dev/input/event0"
(**) Option "_source" "server/udev"
(II) event0 - mini keyboard: is tagged by udev as: Keyboard
(II) event0 - mini keyboard: device is a keyboard
(II) event0 - mini keyboard: device removed
(**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:1997:2433.0001/input/input0/event0"
(II) XINPUT: Adding extended input device " mini keyboard" (type: KEYBOARD, id 6)
(**) Option "xkb_model" "pc105"
(**) Option "xkb_layout" "fr"
(**) Option "xkb_variant" "oss_latin9"
(II) config/udev: Adding input device mini keyboard Mouse (/dev/input/event1)
(**) mini keyboard Mouse: Applying InputClass "libinput pointer catchall"
(II) Using input driver 'libinput' for ' mini keyboard Mouse'
(II) systemd-logind: got fd for /dev/input/event1 13:65 fd 28 paused 0
(**) mini keyboard Mouse: always reports core events
(**) Option "Device" "/dev/input/event1"
(II) event1 - mini keyboard Mouse: is tagged by udev as: Mouse
(II) event1 - mini keyboard Mouse: device is a pointer
(II) event1 - mini keyboard Mouse: device removed
(**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0002/input/input1/event1"
(II) XINPUT: Adding extended input device " mini keyboard Mouse" (type: MOUSE, id 7)
(**) Option "AccelerationScheme" "none"
(**) mini keyboard Mouse: (accel) selected scheme none/0
(**) mini keyboard Mouse: (accel) acceleration factor: 2.000
(**) mini keyboard Mouse: (accel) acceleration threshold: 4
(II) config/udev: Adding input device mini keyboard Mouse (/dev/input/mouse0)
(II) No input driver specified, ignoring this device.
(II) This device may have been added with another device file.
(II) config/udev: Adding input device mini keyboard System Control (/dev/input/event2)
(**) mini keyboard System Control: Applying InputClass "libinput keyboard catchall"
(II) Using input driver 'libinput' for ' mini keyboard System Control'
(II) systemd-logind: got fd for /dev/input/event2 13:66 fd 29 paused 0
(**) mini keyboard System Control: always reports core events
(**) Option "Device" "/dev/input/event2"
(II) event2 - mini keyboard System Control: is tagged by udev as: Keyboard
(II) event2 - mini keyboard System Control: device is a keyboard
(II) event2 - mini keyboard System Control: device removed
(**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0002/input/input2/event2"
(II) XINPUT: Adding extended input device " mini keyboard System Control" (type: KEYBOARD, id 8)
(II) config/udev: Adding input device mini keyboard Consumer Control (/dev/input/event3)
(**) mini keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
(II) Using input driver 'libinput' for ' mini keyboard Consumer Control'
(II) systemd-logind: got fd for /dev/input/event3 13:67 fd 30 paused 0
(**) mini keyboard Consumer Control: always reports core events
(**) Option "Device" "/dev/input/event3"
(II) event3 - mini keyboard Consumer Control: is tagged by udev as: Keyboard
(II) event3 - mini keyboard Consumer Control: device is a keyboard
(II) event3 - mini keyboard Consumer Control: device removed
(II) libinput: mini keyboard Consumer Control: needs a virtual subdevice
(**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0002/input/input3/event3"
(II) XINPUT: Adding extended input device " mini keyboard Consumer Control" (type: MOUSE, id 9)
(**) mini keyboard Consumer Control: (accel) selected scheme none/0
(**) mini keyboard Consumer Control: (accel) acceleration factor: 2.000
(**) mini keyboard Consumer Control: (accel) acceleration threshold: 4
(II) systemd-logind: returning pre-existing fd for /dev/input/event3 13:67
(**) Option "_source" "_driver/libinput"
(II) libinput: mini keyboard Consumer Control: is a virtual subdevice
(II) XINPUT: Adding extended input device " mini keyboard Consumer Control" (type: KEYBOARD, id 10)
(II) modeset(0): Disabling kernel dirty updates, not required.
(**) Option "fd" "25"
(**) Option "fd" "28"
(**) Option "fd" "29"
(**) Option "fd" "30"
(II) UnloadModule: "libinput"
(II) systemd-logind: not releasing fd for 13:67, still in use
(II) systemd-logind: releasing fd for 13:67
(II) systemd-logind: releasing fd for 13:66
(II) systemd-logind: releasing fd for 13:65
(II) systemd-logind: releasing fd for 13:64
(II) Server terminated successfully (0). Closing log file.This configuration works in archlinuxarm (systemd) on the same RPi4. Raspbian desktop also works.
This configuration works for beowulf on x86-64.
What did I forget?
Thanks
ubik post gave me the solution.
You have to install :
libgl1-mesa-dri_19.2.0~rc1-1~bpo10+1~rpt3_armhf.deb
libglapi-mesa_19.2.0~rc1-1~bpo10+1~rpt3_armhf.deb
libglx-mesa0_19.2.0~rc1-1~bpo10+1~rpt3_armhf.deb
from http://archive.raspberrypi.org/debian/pool/main/m/mesa
and
libllvm8_8.0.1-3~bpo10+1_armhf.deb
llvm-8_8.0.1-3~bpo10+1_armhf.deb
llvm-8-runtime_8.0.1-3~bpo10+1_armhf.deb
from http://ftp.nl.debian.org/debian/pool/ma … olchain-8/
