#1 2019-12-07 20:01:51
w3
Eudev broke down after upgrade.
eudev broke down after the update and I can't access my desktop or have an internet connection.
The problem happened after enabling the proposed repository in my source.list and upgrading to eudev-3.2.2-16.
any solution in mind?
I thought about downloading the eudev-3.2.2-13 .deb package, saving it to a pendrive and installing it using dpkg, but I can't find a place to download the binary.
#2 2019-12-07 20:29:45
bgstack15
Re: Eudev broke down after upgrade.
I see 3.2.2-13 available under http://pkgmaster.devuan.org/devuan/pool/main/e/eudev/. Is that what you're looking for? Of course, make sure you grab a package that fits which suite you're using if applicable.
#3 2019-12-07 21:16:04
w3
thanks man. Problem solved
#4 2019-12-10 16:27:42
Geoff 42
I have also hit this problem with eudev after an upgrade.
Looking in /var/log/rc.log I can see :-
OpenRC 0.23 is starting up Linux 4.18.0-0.bpo.1-amd64 (x86_64)
* /proc is already mounted
* /run/openrc: creating directory
* /run/lock: correcting mode
* /run/lock: correcting owner
* Caching service dependencies ...
Service `eudev' needs non existent service `unmountroot'
[ ok ]
eudev                 | * ERROR: eudev needs service(s) unmountroot
keyboard-setup.sh     |[....] Setting up keyboard layout...cannot open file /tmp/tmpkbd.QWaL78
What I am seeing is that the keyboard and mouse appear dead but the screen is still live, with the time updating.
I can log in via ssh.
Geoff
#5 2019-12-10 16:31:25
Geoff 42
Looking in /var/log/dpkg.log I see :-
2019-12-10 10:32:15 upgrade eudev:amd64 3.2.2-13 3.2.2-16
Geoff
#6 2019-12-10 17:09:10
Geoff 42
I have tried reinstalling with the version 13 :-
apt install --reinstall  eudev=3.2.2-13 libeudev1=3.2.2-13 libeudev-dev=3.2.2-13
but is fails with
dpkg: error processing archive /var/cache/apt/archives/eudev_3.2.2-13_amd64.deb (--unpack):
subprocess new pre-installation script returned error exit status 1
insserv: warning: script 'savecache' missing LSB tags and overrides
dpkg: warning: downgrading libeudev1:amd64 from 3.2.2-16 to 3.2.2-13
Preparing to unpack .../libeudev1_3.2.2-13_amd64.deb ...
Unpacking libeudev1:amd64 (3.2.2-13) over (3.2.2-16) ...
Geoff
#7 2019-12-10 19:58:51
but is fails with <snip>
Geoff
Try adding --force-downgrade
#8 2019-12-10 20:08:42
Geoff 42
Thank you.
I have now tried unsuccessfully :-
apt install --reinstall  --force-downgrade eudev=3.2.2-13 libeudev1=3.2.2-13 libeudev-dev=3.2.2-13
E: Command line option --force-downgrade is not understood in combination with the other options
apt-get install --reinstall  --force-downgrade eudev=3.2.2-13 libeudev1=3.2.2-13 libeudev-dev=3.2.2-13
apt install --force-downgrade eudev=3.2.2-13 libeudev1=3.2.2-13 libeudev-dev=3.2.2-13
I expect I am overlooking something simple!
I have also managed to open a vnc window from my laptop and then run Synaptic, but that also gets the same problem unpacking eudev that I got with apt.
Geoff
#9 2019-12-10 20:41:13
Geoff 42
Ah, I think it is allow-downgrades.
This still produces the same problem with unpacking eudev.
Geoff
#10 2019-12-11 01:18:10
Oops! I gave you the option that goes with dpkg, not apt. Sorry about that.
You could try downloading the packages and installing with dpkg --force-downgrade -i <packages>.
Or maybe install an older package from /var/cache/apt/archives/
I'm not exactly sure what the problem is. If you're ambitious, you could unpack the deb, add a 'set -x' to the preinst script(s) and then repack. That might give useful information.
Not sure if this is relevant, but I recently had trouble upgrading  eudev to a lower package version (220:something from when ascii was in testing to 3.2.2-something). I had to comment out a couple lines in /var/lib/dpkg/info/libeudev1:amd64.list and .md5sums to nullify a dependency that was getting in the way.
These two:
/lib/x86_64-linux-gnu/libudev.so.1.6.3
#11 2019-12-11 14:15:15
Geoff 42
OK, I decided to come at this from a different angle and see if the eudev problem was a simple configuration problem.
rc.log was reporting :-
[ ok ]
I had a look in /etc/init.d/eudev and it started :-
#!/bin/sh -e
### BEGIN INIT INFO
# Provides:          eudev udev
# Required-Start:    mountkernfs
# Required-Stop:     unmountroot
# Default-Start:     S
# Default-Stop:      0 6
# Short-Description: Start udevd, populate /dev and load drivers.
### END INIT INFO
so it was asking for unmountroot, however, on my Beowulf laptop, it wants umountroot and there is indeed a service umountroot. I saved a copy of eudev in /root and then edited out the unwanted "n", so that eudev now starts :-
#!/bin/sh -e
### BEGIN INIT INFO
# Required-Stop:     umountroot
# Default-Start:     S
# Default-Stop:      0 6
### END INIT INFO
This now boots just fine and rc.log reports :-
OpenRC 0.23 is starting up Linux 4.19.0-0.bpo.4-amd64 (x86_64)
[ ok ]
eudev                 |[....] Starting hot-plug events dispatcher: udevd[ ok .
eudev                 |[....] Synthesizing the initial hotplug events...[ ok done.
eudev                 |[....] Waiting for /dev to be fully populated...keyboard-setup.sh     |[ ok done.
[ ok done.
Geoff
#12 2019-12-11 22:57:40
Thanks for finding that!
There's a new version in ascii-proposed with the fix. (3.2.2-17)  Please test and report.
#13 2019-12-12 09:33:25
Geoff 42
OK, but I can't afford to break my machine today, so it will probably have to wait until Friday.
Geoff
#14 2019-12-13 09:03:32
Geoff 42
Yes, a routine update has moved eudev and libeudev1 from 3.2.2-16 to 3.2.2-17 and I can reboot and still log in ;-)
rc.log reports :-
[ ok ]
[ ok done.
Thank you.
Geoff
