#1 2019-11-19 12:36:34
ReallyNigga
KDE doesn't shutdown or reboot!
Before install Devuan I was running Debian 10 in which KDE was working perfectly. After install Devuan, I can't shutdown or reboot the machine from the interface. When I click to turn off the computer, xorg are killed and then restart, with KDE session manager opening.
I had try what was suggested on web.
1) Purge and reinstall upower.
2) Purge and reinstall all xorg and KDE.
3) Purge and upgrade (ascii-updates) all xorg and KDE.
4) Upgrade the kernel.
5) Delete some log files of KDE.
6) Put user on adm group and give him permissions on /sbin/shutdown and /sbin/reboot.
I only can shutdown the system through root or the shutdown icon of session manager.
#2 2019-11-19 13:55:12
Re: KDE doesn't shutdown or reboot!
Post the output of the following command. That will show which policykit related packages are installed. Something you need might be missing.
dpkg -l | egrep "consolekit|elogind|policykit|polkit|libpam"
#3 2019-11-19 14:51:52
ReallyNigga
root@devuan:/home/notebook# dpkg -l | egrep "consolekit|elogind|policykit|polkit|libpam"
ii  consolekit                                    0.4.6-6                                    amd64        framework for defining and tracking users, sessions and seats
ii  elogind                                       234.4-2                                    amd64        user, seat and session management daemon
ii  libelogind0:amd64                             234.4-2                                    amd64        user, seat and session management library
ii  libpam-elogind:amd64                          234.4-2                                    amd64        elogind PAM module
ii  libpam-modules:amd64                          1.1.8-3.6                                  amd64        Pluggable Authentication Modules for PAM
ii  libpam-modules-bin                            1.1.8-3.6                                  amd64        Pluggable Authentication Modules for PAM - helper binaries
ii  libpam-runtime                                1.1.8-3.6                                  all          Runtime support for the PAM library
ii  libpam0g:amd64                                1.1.8-3.6                                  amd64        Pluggable Authentication Modules library
ii  libpolkit-agent-1-0:amd64                     0.105-25+devuan0~bpo2+1                    amd64        PolicyKit Authentication Agent API
ii  libpolkit-backend-1-0                         0.105-25+devuan0~bpo2+1                    all          PolicyKit Authorization API
ii  libpolkit-backend-consolekit-1-0:amd64        0.105-25+devuan0~bpo2+1                    amd64        PolicyKit backend API
ii  libpolkit-gobject-1-0                         0.105-25+devuan0~bpo2+1                    all          PolicyKit Authorization API
ii  libpolkit-gobject-consolekit-1-0:amd64        0.105-25+devuan0~bpo2+1                    amd64        PolicyKit Authorization API
ii  libpolkit-qt-1-1:amd64                        0.112.0-5                                  amd64        PolicyKit-qt-1 library
ii  libpolkit-qt5-1-1:amd64                       0.112.0-5                                  amd64        PolicyKit-qt5-1 library
ii  policykit-1                                   0.105-25+devuan0~bpo2+1                    amd64        framework for managing administrative policies and privileges
ii  polkit-kde-1                                  4:5.8.4-1                                  all          transitional dummy package
ii  polkit-kde-agent-1                            4:5.8.4-1                                  amd64        KDE dialogs for PolicyKit
#4 2019-11-19 19:33:38
I think you need to remove consolekit. I'm not sure if you'll have problems doing that. You'll need to replace
libpolkit-backend-consolekit-1-0 libpolkit-gobject-consolekit-1-0
with
libpolkit-backend-elogind-1-0 libpolkit-gobject-elogind-1-0
which may or may not happen automatically.
Yell if you need help with it. (And post some terminal output if there are conflicts that you or aptitude can't resolve.)
#5 2019-11-19 22:34:59
ReallyNigga
with
Oh, works! Thanks a lot. Can you say me if I had done some shit to this happens? Maybe I installed the wrong dependency or some shit like this? I don't want to repeat the error.
Edit: On a new install I had realized that elogind-dbgsym is also needed. Might it wasn't installed.
#6 2019-11-20 00:33:15
I can't say why it happened, but there's a good chance it wasn't anything that you did. Take a look at the section on Session management and policykit backends in the release notes. It's a rat's nest of dependencies.
http://files.devuan.org/devuan_ascii/Release_notes.txt
#7 2019-11-20 05:58:28
ReallyNigga
I'm afraid to bother you again, but I want to share my minimal KDE install with the community, so here is another question: would be wise to include consolekit*- on the list, forcing APT to not install consolekit?
#8 2019-11-20 11:46:40
What format for this system will you be offering? Live-iso, installer iso, disk image?
If you use live-sdk to make the iso, you can add consolekit to the purge_packages list. If you use refractasnapshot, you can remove consolekit before making the snapshot if it's installed. You should not add it to the excludes list - that wouldn't work right. If you're making a live iso that has the debian-installer, I probably can't help.
#9 2019-11-20 21:31:40
ReallyNigga
No man, it's just a tutorial, a list of packages to install. I didn't find none when decide to install KDE, so I want to share.
#10 2019-11-21 01:18:55
Then include instructions for replacing consolekit just how you did it, in case it's needed.
#11 2020-02-29 22:22:49
mclien
sorry to revive this old thread.
But why is this whole policy stuff? or at least, why is it used to regulate shutdown/reboot, which can be handled by sudoers just as fine?
(at least IF some of the lightwight loginmanager like slim will survive.Which sadly might be unlikely for slim)
#12 2020-03-01 09:46:14
The issues with consolekit are not only limited to reboot/shutdown, initially you also can't open memory sticks/external drives as a user.
Simply installing
apt install libpolkit-backend-elogind-1-0 libpolkit-gobject-elogind-1-0
did the trick for me. It removes consolekit or whatever and issues are gone.
I guess this is inherited from Debian. The ASCII2.0 installer brings consolekit, and if I am not mistaken this is fixed with ASCII2.1, and for sure with Beowulf, no matter if installed from netinstall (currently no more available) or upgraded from ASCII.
