#1 2019-11-16 16:55:00
kapqa
amdgpu-pro + ascii on kernel 4.19 bpo ?
Hello ,
i just tried this guide here for installing the amdgpu-pro driver on devuan ascii.
https://wiki.debian.org/AMDGPUDriverOnS … all&rev=36
but it would not succeed.
i did install the kernel 4.19.0.0.bpo.5-amd64 + the linux-headers.
could it be that the author used another backported kernel in stretch or where could the error lie?
Thank you.
#2 2019-11-16 19:30:31
Re: amdgpu-pro + ascii on kernel 4.19 bpo ?
Don't follow that guide, I broke a Debian system trying that.
Why do you think you need the proprietary amdgpu drivers? The Phoronix benchmarks show consistently better performance from the open-source version for gaming and suchlike.
#3 2019-11-16 20:35:22
Got myself a R570 card on a Ryzen system with ASCII and backports kernel. Works fine with just the amgpu firmware.
There is a later kernel thatn bpo.5, try to upgrade.
#4 2019-11-18 11:08:59
ToxicExMachina
There is no wonder it doesn't work. AMDGPU-PRO support only Ubuntu 16.04 and RHEL 7.2/6.8
You have to use at least the same kernel as in Ubuntu 16.04. Or you can try to install userspace libraries manually... but I don't see and point to use AMDGPU-Pro. Mesa has great OpenGL support and AMDVLK can be installed separately. May be proprietary OpenCL implementation... But ROCm is already better for Polaris and newer GPUs.
#5 2019-11-18 14:26:57
kapqa
well, i just wanted to use AMD VCE for video encoding in HandBrake and it does require the AMDGPU-PRO driver.
i have seen that the opensource has good benchmark but some features seem only available with the amd drivers, hence my timid try to install them.
thanks rolfie, i tried also with bpo.6, it did not make a difference (for now). maybe i just it wrong.
#6 2019-11-19 07:38:11
ToxicExMachina
According to official info it's based on ffmpeg: https://github.com/HandBrake/HandBrake/ … S.markdown
You don't need AMDGPU-PRO driver. You can try vdpau or vaapi with amdgpu driver.
#7 2019-11-19 14:26:03
kapqa
I did use this guide here, and with Ubuntu 18.04 could get it to activate, however, it would also need some vulkan kit
https://handbrake.fr/docs/en/latest/tec … o-vce.html
according to AMD release notes for AMDGPU_Pro Driver (19.30)
To use the Vulkan driver in this stack, Vulkan SDK version v1.1.109.0 needs to be installed. The SDK can be downloaded from: https://vulkan.lunarg.com/sdk/home
#8 2019-11-20 04:50:08
ToxicExMachina
Vulkan and VCE are available via libre driver: https://www.x.org/wiki/RadeonFeature/#index1h2
You don't need AMDGPU-PRO for that.
#9 2019-11-21 20:40:34
kapqa
Hello thank you very much for your help; how can i check if i have those Vulkan and VCE enabled and libre driver installed?
The system is a Ascii with LXDE+KDE (sort of Hybrid atm).
