#1 2019-11-06 19:53:28
Ozi
STAR: 2.1.1 Kirk, coming soon......
I'm currently refreshing all the 2.1.x images.
Star Kirk 2.1.1  (Dec 2019), images built with: live-sdk
    System updates
    Replaced loadlin with win32-loader
    Added tint2, sakura to fluxbox
    tint2 now inclues launchers (openbox, fluxbox)
    Added launchers to the tray (jwm)
    Updated netinst to also run live
I have a slow internet connect so this will take a few days. sad
Star Kirk 2.1.0  (Oct 2019), images built with: live-build
    System updates
    Usbpmount     Yad front-end to pmount for CD/DVD, USB and SD/MMC. Thanks fsr!
    Added alias ct to clear trash
    Added some cli apps to the Welcome script
    Updated instructions for the Netinst
    Issue: icedtea-8-plugin is not available
https://sourceforge.net/projects/linnix/files/
#2 2019-11-07 23:21:53
HevyDevy
Re: STAR: 2.1.1 Kirk, coming soon......
Hi Ozi
I tried out the openbox iso you put up, installed fine and working ok except for poweroff and shutdown.
Everytime i poweroff or shutdown -h now it goes into a reboot instead?
Is that by design or a bug? How would i remedy this?
#3 2019-11-08 00:29:58
HevyDevy
Nevermind i think i fixed it with the package "laptop-mode-tools". I powered off from command line "sudo poweroff" and it worked, yet to use star-exit to poweroff.
edit; star-exit now working too
#4 2019-11-09 20:58:56
paolo
Ozi wrote:
I'm currently refreshing all the 2.x.x images.
This is a great news, do you plan to add a new .iso with i3wm?
#5 2019-11-09 23:46:49
Ozi
Yes it's upload now.
#6 2019-11-09 23:51:56
Ozi
TBH I've never used poweroff, I mostly use a desktop, always use the the win + x yad dialog to shutdown. I do have ob running on a laptop and it works fine.
#7 2019-11-10 04:34:20
HevyDevy
I dont quite understand it myself, i found the solution on some ubuntu forum somewhere googling for a solution, maybe its the ascii kernel build as laptop-mode-tools package unlocks laptop mode in the kernel which i think i needed to powerdown/shutdown. Yours distro is the only one ive had this issue with, not saying its a problem as it was easily fixed. There must be some setting somewhere i needed turned on or off for my specific laptop maybe, anyhow laptop-mode-tools is a pretty neat package with some performance benefits to be had using it.
https://wiki.archlinux.org/index.php/Laptop_Mode_Tools
EDIT: come to think of it maybe it was during installation as i used the expert install and only chose the drivers needed for my system not include all drivers in the kernel, probably missed some that i needed perhaps.
#8 2019-11-10 18:12:24
paolo
Thanks
#9 2019-12-07 23:55:54
Ozi
I'm currently refreshing all the 2.1.x images. Built with live-sdk
#10 2019-12-15 20:18:17
Ozi
Uploading 2.1.1 images built with live-sdk now.
#11 2019-12-22 00:03:10
zephyr
Ozi wrote: Uploading 2.1.1 images built with live-sdk now.
Downloaded and have looked at most, great job!  Very impressed with the live-sdk changes and refresh, particularly i3! cool
Will be pushing up Crowz soon too, live-sdk coming along nicely! Thanks!  smile
cheers
zephyr
CROWZ / STAR
...easier to light a candle, but curse the dark instead
#12 2019-12-22 19:51:10
Ozi
Thanks zephyr! Appreciate the look-see!
Good luck the Crowz on live-sdk! smile
