#1 2019-10-28 17:01:47
e97
eth0 losing static ip
cat /etc/network/interfaces
auto lo
iface lo inet loopback
# The primary network interface
#allow-hotplug eth0
auto eth0
iface eth0 inet static
address 192.168.1.100
netmask 255.255.255.0
#network 192.168.1.0
gateway 192.168.1.1
allow-hotplug enx0042
#auto enx0042
iface enx0042 inet dhcp
after about 24 hours, eth0 switches to a dynamic ip
is this not the proper way to set a static ip on devuan beowulf ?
#2 2019-10-29 00:38:08
aut0exec
Re: eth0 losing static ip
Had this problem when network manager is installed on the system. NM likes to randomly start controlling the NIC. You're supposed to be able to issue:
nmcli device set <ethX> managed no
In practice it rarely stays consistent and in theory NM isn't supposed to be managing stuff in the interfaces file either. I usually resort to adding the following in
/etc/NetworkManager/NetworkManager.conf
[main]
plugins=ifupdown,keyfile
[ifupdown]
managed=false
[keyfile]
unmanaged-devices=interface-name:eth0
Then restart network-manager and networking. The output of nmcli should state that the interface is no "unmanaged".
root@Devuan:~# nmcli
eth1: unavailable
	"Broadcom Limited NetXtreme BCM5755 Gigabit Ethernet PCI Express"
	ethernet (tg3), DE:AD:BE:EF:00:01, hw, mtu 1500
eth0: unmanaged
	"Realtek RTL8169 PCI Gigabit Ethernet Controller (GA311)"
	ethernet (r8169), CA:FE:C0:FF:EE:01, hw, mtu 1500
lo: unmanaged
	loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
****EDIT*****
My preferred route is to just remove network manager all together with
apt purge network-manager
big_smile
#3 2019-10-29 13:19:50
e97
thanks @aut0exec ! I suspected it was another network control manager but couldn't figure out what it was. Its disabled and removed.
Reset dnsmasq as well because I probably misconfigured it resulting in a conflict with my router.
With those changes, everything seems good.
#4 2019-10-30 17:32:47
bbatten
FWIW, I find that wicd *does* leave uncommented /etc/network/interfaces entries alone. It has its own idiosyncracies, but that's not one of them.
#5 2019-11-06 00:56:54
aut0exec
No problem and glad all is well!
