#1 2019-09-22 17:43:02
jma_sp
Installing Devuan in Pendrive 3.x
Hello, i have installed Devuan in a pendrive 3.0 but it works extremely slow. Thereis some way to have it running more fast?.
A have tested it in several machines with identical result. Same installation but with external usb 3.1 case and ssd disk go ok, so its not a problem with the usb port that support 3.0.
Some advice please?
#2 2019-09-23 10:38:52
HevyDevy
Re: Installing Devuan in Pendrive 3.x
Try to use usb pendrive with usb 3.0
If using ext4 filesystem....
Disabling access time update,
/etc/fstab
/dev/sdb1    /    ext4    defaults,noatime    0    1
Increase commit interval
/etc/fstab
/dev/sdb1   /    ext4    defaults,noatime,commit=60    0    1
Disable journal (not recommended)
# tune2fs -O "^has_journal" /dev/sdb1
everyday is a beautiful day
eric the hobo
