#1 2019-08-23 18:00:16
leegold
MX Repos for Devuan?
Is it possible to use MX Repos for Devuan? Does anyone do this with some success?
Thanks
#2 2019-08-23 23:40:12
Re: MX Repos for Devuan?
It's possible to selectively use some mx packages with devuan, but it would be a bad idea to add any other repos to your sources.
#3 2019-08-24 12:15:24
yeti
Try to rebuild the sources from the MX package on Devuan.
#4 2019-08-24 13:10:51
pcalvert
I use an MX repo for one package by using apt-pinning.
/etc/apt/preferences.d/mxrepo-pinning :
Package: adobe-flashplugin
Pin: origin "mxrepo.com"
Pin-Priority: 100
Package: *
Pin-Priority: 50
/etc/apt/sources.list.d/mx-17.list :
# MX Community Main and Test Repos
deb http://mxrepo.com/mx/repo/ stretch non-free main
#deb http://mxrepo.com/mx/testrepo/ stretch test
Download the repo keyring and install it:
wget http://mxrepo.com/mx/repo/pool/main/m/mx-archive-keyring/mx-archive-keyring_2018.2mx17_all.deb
sudo dpkg -i mx-archive-keyring_2018.2mx17_all.deb
Phil
Another one is called Luxxle.
#5 2019-08-25 09:40:11
@pcalvert, why pin the rest of the repository to 50?
A pin value of 100 makes the MX repositories behave like backports, which sounds ideal for the intended purpose.
Also, their Flash package downloads updated Flash versions without needing to be updated itself so using the .deb might be the best option.
#6 2019-08-25 16:15:30
pcalvert
Because aptitude was trying to pull other packages (e.g., intel-microcode) from that repo during upgrades, and pinning the rest of the repository to 50 stopped that behavior. Pinning it to 100 didn't work. I thought it would, but it didn't.
I'm not sure what you mean by that.
Phil
