#1 2019-07-23 20:26:58
macondo
Linux distros are getting there...
Today I was able to watch Netflix in Void linux smile
Desktop Celeron 4 GB RAM - Devuan Ceres -  Slackware 14.2  - Slackware Current - Grub - IceWM
#2 2019-07-31 08:04:00
SmokeyGrey
Re: Linux distros are getting there...
I'm curious. Did you have to manually enable DRM content, or does Void build Firefox/Chromium with that enabled by default?
If it's enabled by default, this means that your browser automatically downloaded and installed the closed source, proprietary Widevine DRM plugin onto your PC without asking.
The less likely scenario is that Netflix switched to an open source format for streaming.
#3 2019-08-08 18:20:33
macondo
No idea...
I installed chromium, updated all the repos, and then, installed 'chromium-widevine'
Logged into Netflix with my user/passwd and that was it, chrommium-widevine is in the repos.
I apologize for the delay, wasn't aware of your post.
#4 2019-08-16 06:27:09
SmokeyGrey
Excellent, that answered my question perfectly. Thanks.
