#1 2019-07-13 22:26:49
d0nzag
/etc/apt/apt.conf.d/05disable-suggests removed?
why?
It wouldnt hurt to add 06disable-recommends also as it has effect now, for examle - beowulf: apt install curl with or without it
#2 2019-07-13 22:47:51
Re: /etc/apt/apt.conf.d/05disable-suggests removed?
05disable-suggests was a useless file. Suggests are not installed automatically. Disabling Recommends should be left to the user. Functions will be missing without them. I sure don't want to have to figure out which packages are missing when people come here with problems.
I agree that a lot of unnecessary bloat will also be missing without them. I exclude Recommends for myself and in my Refracta releases. I'm pretty sure some (most?) of the other Devuan derivatives also exclude them.
#3 2019-07-14 03:09:57
stanz
Yeppers...it sure gave me..problems!  tongue
miyoisomix.i2p
