#1 2019-07-10 02:54:12
erdos
Brother laser printer installation on devuan
i have a brother hl-2270dw laser printer that i want to install the driver downloaded from manufacturer website.  the .deb package I downloaded is 32 bit package and i'm running into difficulty to install onto the 64-bit devuan.
erdos@t60:~/Downloads$ sudo dpkg -i hl2270dwlpr-2.1.0-1.i386.deb
[sudo] password for erdos:
dpkg: error processing archive hl2270dwlpr-2.1.0-1.i386.deb (--install):
 package architecture (i386) does not match system (amd64)
any suggestion how to resolve this?
#2 2019-07-10 08:23:07
ToxicExMachina
Re: Brother laser printer installation on devuan
#3 2019-07-10 08:43:42
Marjorie
I'm assuming you've already tried using CUPs with the available drivers provided there?
In my case I use the driver for a slightly different Brother model: I have a DCP 9015CDW and use the DCP 9010CDW dirver which works fine, including duplex.
A cursory search finds there's a discussion of drivers to use for your model here: http://openprinting.org/printer/Brother … -HL-2270DW.
#4 2019-07-12 03:41:16
erdos
ToxicExMachina wrote:
tried this, still having error:
root@t60:/home/erdos/Downloads# dpkg -i hl2270dwlpr-2.1.0-1.i386.deb
Selecting previously unselected package hl2270dwlpr:i386.
(Reading database ... 75692 files and directories currently installed.)
Preparing to unpack hl2270dwlpr-2.1.0-1.i386.deb ...
Unpacking hl2270dwlpr:i386 (2.1.0-1) ...
dpkg: dependency problems prevent configuration of hl2270dwlpr:i386:
 hl2270dwlpr:i386 depends on libc6 (>= 2.3.4-1).
dpkg: error processing package hl2270dwlpr:i386 (--install):
 hl2270dwlpr:i386
[1]+  Done                    synaptic
i installed mentioned missing libc6 for i386, still got the same error
#5 2019-07-12 03:44:02
erdos
the provided link is empty.
#6 2019-07-12 04:14:15
Dutch_Master
Forget openprinting.org, use the install commands from Brother.
Brother has a prerequisite explained here:
https://support.brother.com/g/b/faqend. … 100548_000
Pre-required Procedure (5)
Related distributions
Debian 64 bit version, Ubuntu 64 bit version
Related products/drivers
printer/PC-FAX drivers
Requirement
ia32-libs or lib32stdc++ is required to be installed.
This means you need to install one of the mentioned packages prior to installing the .deb for your printer.
Drivers can be found here;
https://support.brother.com/g/b/downloa … all&os=128
As I also have a Brother machine (MFC in my case) I d/l'ed the instructions years ago, as well as the drivers for my device, and in there I found to use the force option for dpkg:
dpkg  -i  --force-all <driver-name>.deb
HTH!
#7 2019-07-12 04:39:39
erdos
install i386 .deb didn't work for me on the 64-bit ascii.
I ended up downloading the 'Driver Install Tool' available on the Brother website for this printer (hl-2270DW) and followed the instruction to run the script, it automatically pulls in the needed package and installs  the printer.
Driver install Tool is available here:
