#1 2019-07-03 17:22:33
kapqa
Kernel 5 / way better benchmark on geekbench
Hello ,
i have seen some benchmark for the new upcoming Ryzen 3000 CPU and it seems that with Kernel 5+ it is very fast.
On my Zen+ running kernel 4.1+ the single core is around 4.100 and multicore around 17-18.000
With Kernel 5.+ it is 4800+ and also Higher Multicore.
I am wondering if there is also an easy upgrade program for switching kernel for Debian/Devuan as on Ubuntu (UKUU application).
Also, are there any risks in installing (prematurely?) a newer kernel that is not yet used officially by the Distro?
#2 2019-07-04 10:05:38
kapqa
Re: Kernel 5 / way better benchmark on geekbench
here some first result for the few samples of this supposedly "200$ CPU"
http://browser.geekbench.com/v4/cpu/sea … sort=score
#3 2019-07-04 10:47:40
ToxicExMachina
It's called GRUB.
#4 2019-07-04 17:24:46
@OP: you can follow the Debian guide for building new kernel versions:
https://kernel-team.pages.debian.net/kernel-handbook/
The Liquorix kernel should be compatible with Devuan and they have v5.1 for jessie, stretch & buster:
https://liquorix.net/
And if you wait for a bit then the freeze will be over and v5 should make it into ceres & beowulf-backports.
