#1 2019-07-02 14:54:02
kapqa
[Solved] Installing printer Ecotank - cannot install "LSB"
Hello ,
i tried to install the printerpackage for Debian Stretch on a freshly Devuan Ascii.
There is a problem because it depends on LSB.
lsb : Depends: lsb-desktop (>= 4.1+devuan2) but it is not going to be installed
How could i overcome this?
thanks
#2 2019-07-02 15:04:41
kapqa
Re: [Solved] Installing printer Ecotank - cannot install "LSB"
this is my sources.list
deb http://it.deb.devuan.org/merged ascii main contrib non-free
deb-src http://it.deb.devuan.org/merged ascii main contrib non-free
deb http://it.deb.devuan.org/merged ascii-security main contrib non-free
deb-src http://it.deb.devuan.org/merged ascii-security main contrib non-free
deb http://it.deb.devuan.org/merged ascii-updates main contrib non-free
deb-src http://it.deb.devuan.org/merged ascii-updates main contrib non-free
#3 2019-07-02 16:15:57
kapqa
Hello ,
i would like to move this Thread into "Hardware & Software" section.
#4 2019-07-02 18:50:11
Either backport the printer package to Devuan ASCII or upgrade to beowulf.
Which package is this, exactly?
#5 2019-07-03 09:07:58
kapqa
i did upgrade to beowulf by changing "ascii" to "beowulf" and afterwards "sudo apt-get upgrade" & "sudo apt-get dist-upgrade". It installed a fair share of packages withouth error, but after reboot i was just greeted with grub console.
you can find the driver by inserting "ET-4750" in the search field
http://download.ebz.epson.net/dsc/searc … archModule
#6 2019-07-03 11:41:25
dxrobertson
See this thread, fsmithred post-
https://dev1galaxy.org/viewtopic.php?id=2676
grub-efi-amd64-signed package is a problem.
You 1st need to find out what partition /boot/grub is on (root partition).  Then you can manually boot from the grub prompt.  Something like this for my system, my root partition is sda3 (gpt3).  If you have a simple install, its probably sda2 (gpt2).
find root partition
grub> ls(hd0,gpt2)/
grub> ls(hd0,gpt3)/
manually boot grub:
grub> set prefix=(hd0,gpt3)/boot/grub
grub> set root=(hd0,gpt3)
grub> insmod normal
grub> normal
If you are able to boot into your system, then do this as per fsmithred:
apt purge grub-efi-amd64-signed
grub-install
update-grub
Then reboot and all should be well.
#7 2019-07-03 11:51:58
dxrobertson
LSB.  Not sure what package lsb-desktop is, I dont see it.
Devuan Beowulf/Debain has:
lsb-base/testing,now 10.2019051400 all [installed]
lsb-release/testing,now 10.2019051400 all [installed,automatic]
#8 2019-07-03 17:18:26
kapqa
Hello , i have purget the Devuan for now. But am going to reinstall. Will this problem /Beowulf grub-efi-amd64-signed
be solved within July hopefully?
On Ubuntu 18.04 the driver is recognized out-of-box withouth need to install any driver. So maybe there is a Kernel-Hardware-support for it that i have overlooked on Ascii.
#9 2019-08-17 22:29:14
kapqa
i would either need this package to install driver
epson-inkjet-printer-escpr
(installabe on debian)
or (lsb) > preferable > but it is not installable on devuan ascii, as it seems to conflict with (lsb-desktop)
and then i could install the proper printer driver from epson
#10 2019-08-17 23:34:58
The installable package is actually named printer-driver-escpr.
#11 2019-08-18 09:25:07
kapqa
Thank you, this package is already installed, and it seems the right one. The computer finds a compatible driver for "ET-4550" (previous model of ET-4750).
The printer is now installed.
Still i'd be happy if i could be able to install the "lsb" package, as this would allow me to install the official drivers (also the driver for Fax which seems missing; ).
#12 2019-08-18 22:01:58
It's not clear to me why you have a problem with installing lsb-desktop. It's a "standard" ascii package and version.
Try doing:
# apt-get update
# apt-get -f install
to ensure you have a workable apt state.
Thereafter a normal ad-hoc installation
# dpkg -i epson-inkjet-printer-escpr.deb
should work fine.
#13 2019-08-20 08:33:35
kapqa
I am running Devuan Ascii (just installed some day ago) and i noticed this error before
lsb-desktop : Depends: libpng12-0 but it is not installable
               Recommends: libqt3-mt (>= 3:3.3.6) but it is not installable
Until this is not solved, there seems no way to install the epson-driver package from the homepage.
#14 2019-08-20 08:36:45
kapqa
The name of the printer driver from Epson is epson-inkjet-printer-escpr2_1.1.1-1lsb3.2_amd64.deb
#15 2019-08-20 09:42:34
For that particular issue, you might want to temporarily put jessie/main back into the sources list, just to pick up the libpng12-0=1.2.50-2+deb8u3 package, and then restore the sources list again (and update egain).
I don't remember the exact details, but when libpng16 came about, libpng12 got left behind, with the result of needlessly but forcefully deprecating dependent packages. Whatever the case was, the "missing" libpng12 from jessie installs without issues on ascii (and both are merged directly from Debian).
#16 2019-08-20 14:27:19
kapqa
Thank you very much, that was really helpful.
Downloaded the libpng12 here
https://packages.debian.org/jessie/amd6 … 0/download
and now lsb package installs, problem solved.
#17 2020-10-04 19:12:30
kapqa
The problem however re-presents itself inDevuan Beowulf 3.0
and now LSB is not present or seems not installable.
i tried to add Ascii to sources, but this mixed things up, and seems not a way forward.
 lsb : Depends: lsb-core (>= 4.1+devuan2)
       Depends: lsb-graphics (>= 4.1+devuan2) but it is not going to be installed
       Depends: lsb-cxx (>= 4.1+devuan2) but it is not going to be installed
       Depends: lsb-printing (>= 4.1+devuan2) but it is not going to be installed
       Depends: lsb-languages (>= 4.1+devuan2) but it is not going to be installed
Any idea on how to install
LSB
on Devuan Beowulf for the official printer drivers from Epson, or is this package obsolete (hence also the official printer drivers, atleast as far a §Devuan is converned?)
#18 2020-10-18 20:31:37
PengouinPdt
Personnaly, I use my EcoTank 3700, with the driver printer-driver-escpr, but I'm on Ceres ;-)
#19 2020-10-19 20:04:32
kapqa
@yes, it is functioning, but i would like still to install driver package, for better options etc. also duplex is otherwise sometimes greyed out.
#20 2020-11-24 20:06:43
kapqa
Hello ,
i also use
because i am not able to install "lsb-package" at the moment, but it won't help with duplex-printing.
maybe i am doing something wrong here?
#21 2021-07-01 10:54:00
kapqa
hello , it would be nice to have LSB package available , for being able to install the proper Epson printer driver on Beowulf and later, similar to Ubuntu, where this is still possible.
(request).
#22 2021-07-01 11:10:05
kapqa
today i installed the printer on newly installed Devuan Beowulf, via the installed "printer-driver-espcr" (Model: Epson ET-4750)
and the printer would only print however a series of unrelated signs / letters / in a row;
i found a solution here on how to install the printer "manually" and now it functions, but this not simple as Linux should be.
https://forums.linuxmint.com/viewtopic. … 3&start=20
sudo lpadmin -p et4750 -v ipp://127.0.0.1:60000/ipp/print -E -m everywhere
#23 2021-07-04 08:35:56
Magnus
lsb-desktop hasn't been around since Debian Jessie.
https://packages.debian.org/jessie/lsb-desktop
#24 2021-07-09 08:24:01
kapqa
it is still installable on ubuntu, though, as in ubuntu 20.04 LTS (it is the current LTS version of Ubuntu, July 2020)
lsb is already the newest version (11.1.0ubuntu2).
