#1 2019-06-23 21:07:00
macondo
Does this reminds you of systemd?
I did a fresh install and got pulseaudio by default, I always use alsa.
bobo@foo:~$ sudo dpkg -P pulseaudio pulseaudio-utils
dpkg: dependency problems prevent removal of pulseaudio:
 osspd-pulseaudio depends on pulseaudio.
dpkg: error processing package pulseaudio (--purge):
 dependency problems - not removing
dpkg: dependency problems prevent removal of pulseaudio-utils:
 pulseaudio depends on pulseaudio-utils; however:
  Package pulseaudio-utils is to be removed.
dpkg: error processing package pulseaudio-utils (--purge):
 pulseaudio
 pulseaudio-utils
bobo@foo:~$ sudo dpkg -P pulseaudio osspd-pulseaudio pulseaudio-utils
dpkg: dependency problems prevent removal of osspd-pulseaudio:
 osspd depends on osspd-pulseaudio | osspd-backend; however:
  Package osspd-pulseaudio is to be removed.
  Package osspd-backend is not installed.
  Package osspd-pulseaudio which provides osspd-backend is to be removed.
dpkg: error processing package osspd-pulseaudio (--purge):
 osspd-pulseaudio
 pulseaudio
 pulseaudio-utils
#2 2019-06-23 21:56:05
nogeek
Re: Does this reminds you of systemd?
I always do a minimal installation and never get any package with "pulse" in the name.
Only libpulse0 is on my final-system, cause mpv and ffmpeg need it.
apt-cache rdepends *pulse*
let you see all packages wich are depending on packages with "pulse" in the name.
#3 2019-06-23 23:37:46
macondo
So do I, I use IceWM
I got 2 boxes, and installed Devuan on both, the 64 bit one with (XFS) and the 32 bit with (ext 4).
The 64 bit gave me Pulse audio by default, and the 32 bit, ALSA.
Now I can't get rid of pulseaudio. I DID NOT INSTALL PULSEAUDIO!!
#4 2019-06-24 01:36:43
pcalvert
Try using aptitude. It may give you some other options, some of which may allow you to get rid of pulseaudio and pulseaudio-utils.
Phil
Another one is called Luxxle.
#5 2019-06-24 02:57:47
macondo
Thank you guys. I finally did it.
Installed synaptic and uninstalled pulseaudio, pulseaudio-tools and pulseaudio-utils which in turn dragged a bunch of others. Went to the terminal and got my beloved alsamixer big_smile Happy camper! Sound is great.
#6 2019-06-24 03:13:24
czeekaj
  dpkg -r --force-depends pulse-audio
You could always force it but if you have dependencies. Aptitude will complain about unmet dependencies. So I don't recommend this
apt purge pulse-audio should remove most of it.
The cookie and a few folders will get left behind though. Just thought I'd mention it leaves a few files if you want to clean up a bit.
#7 2019-06-24 05:10:01
ToxicExMachina
Pshshshshsaudio and SystemD were made by the same person. Purge pulseaudio first (apt-get purge), then reinstall necessary packages and avoid pulseaudio in dependencies. Some of packages require pulseaudio libraries without pulseaudio itself. You can ignore that packages.
