Pages: 1
Hi!
I was playing XMahJongg these days and I have a couple of questions.
Not important ones though, I'm asking just out of curiosity:
1) Launching XMahJongg (from console) with the geometry argument (in order to fit the screen), like this "xmahjongg -g 1360X768", produces the error message "xmahjongg: warning: bad geometry specification".
Not any visible side-effects though. The game runs properly.
Why this error message? Running xrandr returns this mode as the active one: "1360x768_60.00 60.00".
2) Looking at it's source code, one can see (giving "./configure -h") a possible arguments for configure: "--with-x use the X Window System".
Any idea, what it does???
Is anyone familiar with these X related things?
TIA!!!
Because you used a capital X in the geometry specification, try it again with a lower case x instead.
Fabricando fit faber
Ooops!!! Indeed!
THANKS Head_on_a_Stick!!!
Pages: 1
