#1 2019-05-16 11:39:27
boycottsystemd
ZombieLoad Attack (CVE-2018-12130), hyperthreading -how to disable it?
There is anoher intel vulnerability which uses hyperthreading.
I've booted ASCII kernel with noht parameter.
I've tried to disable hyperthreading:
sudo -i && echo 0 > /sys/devices/system/cpu/online
but
# cat /sys/devices/system/cpu/online
0-3
Any idea pls ?
$ uname -a
4.9.0-9-amd64 #1 SMP Debian 4.9.168-1+deb9u2 (2019-05-13) x86_64 GNU/Linux
#2 2019-05-16 13:56:55
siva
Re: ZombieLoad Attack (CVE-2018-12130), hyperthreading -how to disable it?
Similar vulnerabilities, especially from Intel, will keep coming.  2018 was the year of microcode exploits.  Until Intel releases a mass-recall to fix their hardware (they won't), just sit back and enjoy the show.
Any idea pls ?
It's good practice to find research whether or not the CVE has been resolved:
https://www.debian.org/security/2019/dsa-4444
#3 2019-05-16 15:21:13
The parameter you want is nosmt.
You also need the 2019-05-14 version of the intel-microcode package and the most recent kernel version (4.9.168-1+deb9u2, install the linux-image-amd64 metapackage to get this).
EDIT: you already have the kernel.
Use this to check vulnerabilities:
grep -R . /sys/devices/system/cpu/vulnerabilities
The zombieload vulnerability corresponds to MDS in the /sys checklist.
#4 2019-08-26 06:24:05
boycottsystemd
Thank you and apology for delay.
# grep -R . /sys/devices/system/cpu/vulnerabilities
/sys/devices/system/cpu/vulnerabilities/spectre_v2:Mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, RSB filling
/sys/devices/system/cpu/vulnerabilities/spec_store_bypass:Mitigation: Speculative Store Bypass disabled via prctl and seccomp
/sys/devices/system/cpu/vulnerabilities/mds:Mitigation: Clear CPU buffers; SMT disabled
/sys/devices/system/cpu/vulnerabilities/l1tf:Mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
/sys/devices/system/cpu/vulnerabilities/spectre_v1:Mitigation: usercopy/swapgs barriers and __user pointer sanitization
/sys/devices/system/cpu/vulnerabilities/meltdown:Mitigation: PTI
#5 2019-08-26 16:42:29
pcalvert
Here's mine:
/sys/devices/system/cpu/vulnerabilities/spectre_v2:Mitigation: Full generic retpoline, STIBP: disabled, RSB filling
/sys/devices/system/cpu/vulnerabilities/spec_store_bypass:Vulnerable
/sys/devices/system/cpu/vulnerabilities/mds:Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
/sys/devices/system/cpu/vulnerabilities/l1tf:Mitigation: PTE Inversion; VMX: EPT disabled
Doesn't look good. sad
Phil
Another one is called Luxxle.
#6 2019-08-27 18:12:58
boycottsystemd
pcalvert wrote:
Here's mine:
Phil
(... I suppose you are using latest firmware...)
#7 2019-08-28 16:59:07
pcalvert
That is correct.
Phil
