#1 2019-05-09 03:18:32
Giorgos
Problematic wake-up, after sleep (ASCII).
Hi!  smile
Sometimes, when (after sleep) my systems wakes up, it ends up on a black screen with a blinking cursor.
Nothing seems to work, and pressing at the keyboard ctrl-alt-F1 (or anything else), doesn't do something.
The only way to continue, is the hard reboot.
On ASCII x64 KDE.
Is there any way to find out, what's going wrong?
TIA!  cool
G.
#2 2019-05-09 16:32:44
Re: Problematic wake-up, after sleep (ASCII).
If you have more than 1 system try ping, ssh, etc from another system to see if the hung system responds.
Does pressing caps/num/shift lock turn on the light on the keyboard?
Do any of the lights on the motherboard or NIC show anything significant (if the light's usually on when it's working and off when it's sleeping what does it show when the systems hung?)
Chris
#3 2019-05-09 18:17:39
Giorgos
THANKS Chris!  wink
I'll try pinging and I'll observe the lights....at the next crash.
