#1 2019-04-24 11:27:44
rdav
wakeonlan and etherwake for WOL
Hi all
I can't seem to install either of these packages to use WOL to remotely wake a Devuan box from another Devuan box.
Both machines running a Ascii stable amd64
with repos in /etc/apt/sources.list:
deb http://deb.devuan.org/merged/ ascii main non-free contrib
deb http://deb.devuan.org/merged/ ascii-updates non-free main contrib
deb http://deb.devuan.org/merged/ ascii-backports non-free main contrib
deb http://deb.devuan.org/merged/ ascii-security main contrib non-free
Is there something I need to know to get these packages or is there another way to WOL remote machines with Devuan?
thanks in advance!
#2 2019-04-24 12:20:55
Re: wakeonlan and etherwake for WOL
How are you trying to install them, and what result or error messages are you getting?
apt update
apt install wakeonlan etherwake
#3 2019-04-26 08:25:00
rdav
hey fsmithred,
Thanks, Its all good now.
This box does unattended updates each day.
I left it for 2 days and now both packages installed
Dunno how that happened..
