#1 2019-04-21 20:10:37
pota
Devuan and WireGuard / Mullvad VPN
I'm trying to configure WireGuard (with Mullvad) on Devuan by following this guide:
https://mullvad.net/it/guides/easy-wire … ultihop-wg
everything works.
the only problem is the following passage which obviously on devuan is not possible:
Q: How do I make WireGuard start automatically on boot?
A: systemctl enable wg-quick@mullvad-se4
how to do on devuan?
thank you!
#2 2019-04-21 20:42:57
Re: Devuan and WireGuard / Mullvad VPN
Here is the unit file:
https://git.zx2c4.com/WireGuard/plain/s … k@.service
The ExecStart line is the command that is executed by the unit file, replace %i with mullvad-se4 and incorporate it into a boot script for sysvinit.
SJW for hire, usual rates apply
#3 2019-04-22 08:18:50
pota
Thank you for your answer.
in which folder do I find the file unit to be edited?
excuse ignorance
#4 2019-04-22 08:53:32
The wgquick@.service unit file uses the .ini style ('cos the devs love Windows, presumably) and so cannot be used with sysvinit, you will need to convert it to a shell script instead.
Something like this executable file in /etc/init.d/wireguard might work:
#!/bin/sh -e
### BEGIN INIT INFO
# Provides:          wireguard
# Required-Start:    mountkernfs $local_fs
# Required-Stop:     $local_fs
# Default-Start:     S
# Default-Stop:      0 6
# Short-Description: WireGuard via wg-quick(8)
### END INIT INFO
. /lib/init/vars.sh
. /lib/lsb/init-functions
do_start() {
   /usr/bin/wg-quick up mullvad-se4
do_stop() {
   /usr/bin/wg-quick down mullvad-se4
case $1 in
(start|restart|reload|force-reload)
   do_invoke start
(stop)
   do_invoke stop
   echo >&2 "Usage: $0 {start|stop|restart|reload|force-reload}"
   exit 3
esac
Enable it with
# update-rc.d wireguard defaults
Disclaimer: I'm crap with sysvinit scripts so perhaps wait for somebody to point out my mistakes before trying this.
#5 2019-04-22 09:50:46
pota
#!/bin/sh -e
### BEGIN INIT INFO
# Default-Start:     S
# Default-Stop:      0 6
### END INIT INFO
. /lib/init/vars.sh
do_start() {
do_stop() {
case $1 in
   do_invoke start
(stop)
   do_invoke stop
   exit 3
esac
Enable it with
so. summarizing. I have to create a "blank file" in /etc/init.d/wireguard with the extension .ini named as I want. I paste into it the content of the text you provided me. I make it executable and active with the command
okay?
Sorry again and thanks
#6 2019-04-22 10:22:40
No "extension" is needed, that's a Windows thing. And .ini-style files are what systemd uses.
Also, please don't full quote for a straight reply, it reduces the readability of the thread.
#7 2019-04-22 11:27:20
pota
Okay. Sorry. So I'm giving this command:
nano /etc/init.d/wireguard
I insert the text you posted to me. and finally activate it with the command:
right?
#8 2019-04-22 11:30:34
Thinking about this a bit more: you may have to add networking to the Required-Start line to get the network up before the VPN is started but I'm not really sure.
I can't believe you full-quoted me again though (and even included the request to stop full-quoting in the quote). Ah well.
#9 2019-04-22 11:43:13
pota
insserv: script wireguard is not an executable regular file, skipped!
Releases me this error.
(I thought you were asking me not to mention long fragments of conversation. now I have not mentioned anything. excuse me.)
#10 2019-04-22 12:20:18
# chmod +x /etc/init.d/wireguard
#11 2019-04-22 12:38:18
pota
Thank you. done but not working. does not start automatically
#12 2019-04-22 14:19:14
In which case check the journal logs to find out what's going wrong and then fiddle with the service file to get it to work.
#13 2019-04-22 16:16:53
pota
I'm sorry, but I don't have the necessary skills.
I start it manually.
Is it possible to remove what we have done so far?
thanks. excuse the trouble
#14 2019-04-22 16:37:36
Me neither, that's why it didn't work big_smile
Of course: just run
# update-rc.d -f wireguard remove
# rm /etc/init.d/wireguard
pota wrote:
excuse the trouble
That's OK, it was no trouble at all.
Sorry I couldn't get it working for you.
#15 2019-04-23 09:00:19
pota
I solved it using OpenVPN instead of WireGuard ;-)
#16 2019-07-24 22:34:19
paulxx
For anyone else needing help, unless I'm missing something, just add
wg-quick up wg0
to   /etc/rc.local   before the "exit 0" line. That will run it on startup.
