#1 2019-04-21 16:12:54
Luddit
[SOLVED] ntpd fuckup's
Ola companheiros / hello all
"everytime" i get this errormsg by update my time... i have no glue why?!
ntpd[2308]: receive: Unexpected origin timestamp 0xe06710a0.f3c43822 does not match aorg 0000000000.00000000 from server@194.117.9.130 xmt 0xe06710a1.90bd2a53
ntpd[2308]: receive: Unexpected origin timestamp 0xe06710a0.f3cf2112 does not match aorg 0000000000.00000000 from server@88.157.128.22 xmt 0xe06710a1.91b54dcc
ntpd[2308]: receive: Unexpected origin timestamp 0xe06710a0.f3d17dbe does not match aorg 0000000000.00000000 from server@194.117.9.136 xmt 0xe06710a1.91d6f889
ntpd[2308]: receive: Unexpected origin timestamp 0xe06710a0.f3bcf726 does not match aorg 0000000000.00000000 from server@193.30.120.245 xmt 0xe06710a1.98fdde67
what can i do to prevent (exclude bad servers?! ) or solv this problem
Thanks / obrigado
"If you think technology can solve your problems you don't understand technology and you don't understand your problems." Bruce Schneier
#2 2019-04-22 12:41:26
Ogis1975
Re: [SOLVED] ntpd fuckup's
Hello. Please check this.
#3 2019-04-22 16:14:39
Luddit
Thanks! this helps...
