#1 2019-04-14 12:14:29
Refracta 10 (beowulf) isos (No-X)
i386 and amd64
https://get.refracta.org/files/testing/
These are essentially the same as previous refracta-nox isos, except that I made them with live-sdk (and they're beowulf.) And libsystemd0 is gone - it's replaced with libelogind0.
You can install the iso with refractainstaller, or you can use it to do a debootstrap install of pure devuan.
#2 2019-04-15 00:51:10
Re: Refracta 10 (beowulf) isos (No-X)
The firmware packages in the user's home were the wrong set in the first isos (13 Apr). I've replaced the isos and they now have the right firmware packages. (2019 dates instead of 2016). The newer isos have "-live" in the file name.
